15 minutes ago, DanielBoondock said:
I have D52s rated 3500, the guy at Alcan claimed these were somewhat different than D52s rated 5200 - the brakes when I questioned him. Not sure I believe it.
Not, something miscommunicated! Your D52 axles are labeled 3500 only due to the OEM installation of 1750 LB springs. They are the same D52 axles. With an Alcan upgrade you’ll have a 10K LB suspension, but 3500 axle labels and 7,000 GVWR legally per the DOT sticker on the body.
Awesome, now 37 pages in a dead heat with “Where’s Ollie!” 🤣
He seemed unsure about it when I pushed on the point. I think he was thinking about the difference between a true D35 and D52. It would be very unusual for Dexter to gimp the brakes specially I think as it would complicate inventory. Easier/cheaper to take a stock D52, ship it with the stock 1750’s and just print a new label.
OK so with this new 2026 axels I’ve got, I’m having them just upgrade the springs, and I’m bringing Bulldogs with me to replace the stock shocks. They mentioned D rings, those will get replaced it sounds like, but the EZ flex and the rest of it will get reused as-is
Sierra EV AT4 2026 (max range 530 mile pack)
On 6/3/2026 at 6:21 PM, jd1923 said:
Wow, all day long and no replies here on our 36-page Alcan thread! 🤣
Robert, you have a newer hull, so I assume you have D52 axles. Those with D35 axles should upgrade at the same time (my build thread below). You want to install everything NEW; D52 axles, Alcan 5-pack leaf springs, a new EZ Flex kit and new shocks.
I had installed new shocks the year before, so after they tested good, I reinstalled them. I wish somebody would come up with a HD replacement shock (I've looked)! The Bulldog shocks are likely better than the OEM Monroe 555001 shocks, but they are both light duty shocks designed for 1750 LB springs. I wonder if the Oliver would tow any different without these shocks, given the HD Alcan springs. I'd like new HD shocks with similar min/max length specs but heavier, larger diameter shaft, piston and casing.
Do differently? I would purchase the full Dexter EZ-Flex kit with HD shackles and wet bolts. I purchased the wet bolts from Alcan and new EZ-Flex center links only. I do love Alcan Springs, but their shackles and wet bolts are not splined so do slip, so not as good as the Dexter wet-bolts that come with the EZ Flex kit. Another route would be to look at a MORryde substitute for the entire EZ Flex kit. That's all I see, more info here =>
Thank you for this detailed information
we are roaming around Colorado and I was thinking about contacting Alcan to check on appointment availability for the upgrade.
Maybe we will just pick up the springs and haul them home to complete the job after we gather all the other parts , shocks, EZ Flex, Shackle U Bolts and wet bolts
Thanks a million
Robert E
2022 LE II , LIthium Pro, 2018 F150 XLT 4WD 2.7 EcoBoost , 355 gears, tow package,36 gallon fuel, factory brake controller, transmission cooler
Thanks a million
You're welcome, Robert. That's great that you are in Colorado! You should definitely visit Alcan like I did on our trip, purchase parts at a minimum, get the Alcan Leaf Springs and get their U-bolts also to mount the springs.
Your Oliver is a 2022, mine a 2016 needed everything. I'm assuming you have the HD EZ Flex kit installed from new. For example, if you have towed 50K miles in 4 years, your EZ Flex equalizers are likely shot. There is a section in my post about the equalizers. They wear cock-eyed inherent to their design. If your mileage in 4 years is much lower say 20K miles, they may be OK to be reused.
Shocks don't matter much. If you had Alcan work the spring install, you could ask them to test the shocks. If bad they could replace them if available, or just reinstall them as-is and you could DIY new shocks at anytime, a simple task.
Many on this forum and elsewhere are adamant about the wet-bolts installed in a certain 3 or 9 o'clock position. I'm not sure that matters, I worry less about some things. Since the Alcan wet-bolts were not splined, I just mounted ours in random positions. When I grease, I usually get one Zerk per side that will not take grease (yes wheels and load OFF). I just loosen that bolt, give it a 1/4 turn, apply grease and retorque.
To date, only one Oliver owner had issue with the Alcan shackles, where they got buggered with use. The same owner went with an extremely light torque setting, hence the damage. No other complaints from what, 200 Oliver owners with Alcan Springs!
If you believe in the 3-9 positioning get a HD splined set instead. I also thought afterwards, I could have bought the full HD EZ Flex set saving money. If needed when there, purchasing Alcan wet-bolts would be fine. One thing I can tell you is they will reuse everything good and are not the kind of outfit to upsell their customers.
Another thing I would have done differently? If Alcan had in stock the axles I needed, in hindsight, I would have had them do the whole job when I was there. They charged others a very reasonable $600 for labor, and got the job done in a half day. I enjoy DIY on my vehicles, always pay for parts only, dislike paying for contract labor! But to install axles and springs was a long hard job for one old guy at home (my son helped when asked), pacing myself I spent a few days!
They certainly would have fit me in vs. allowing me to drive off that day! They measured our Oliver and spent so much time with me. Our Oliver is one of the few with the 50" axles, while Alcan had a whole pallet of 50.50" axles for their Oliver customers. My axles had to be custom ordered, so having them do the work while we were in CO was not in the cards.
You have a lot to consider. I suggest you keep the installation option open. Call them and talk to Lew or Tim. Let us know how it turns out for you!
Edited by jd1923
On the Bulldog shocks Alcan didn’t want to order them (I got the feeling like they’re just about the leaf springs and didn’t want to be bothered), so I did so from advice on this thread from 4trucks. Note they don’t carry them in stock but have to come from a warehouse which adds delay, it was maybe a month all told to get them.
Alcan is a Dexter authorized reseller which is mainstream in the trailer business. It's a lot of work to become a reseller, just to sell a few parts. They might have accounts with mainstream shock companies, Monroe, KYB, Bilstein, and whatever the 4x4 Jeep guys use in Colorado!
Why install new shocks on your Oliver? You only have a few months and maybe 2K miles on the Monroes. I purchased new Monroe 555001 shocks in 2023 when I first serviced my suspension. They were bad, 3 of 4 shock were blown. I would have tried Bulldogs, but we had not heard of them back then. I replaced axles and leaf springs two years later and all 4 Monroe shocks tested good, so I remounted them. IMO, they're not mission critical anyway.
Edited by jd1923
4k and soon to be 6k. But why? Why not? They’re redoing the suspension so it’s certainly the right time for it. Plus those Bulldogs look so much more coooooooollllllll 🙂
The bigger thing is I largely went with Oliver because I just don’t want to deal with problems. I’m a retiring engineer dammit, I don’t need to keep fixing bad designs and issues! 😅I could get some more milage out of this suspension but if I believe that it is undersized then there’s no reason to wait …
FWIW here’s what Google thinks about the two, but granted we (or at least I) don’t know what if any differences there are with Bulldogs HD and these light duty trailer shocks
Quote
Bulldog shocks (typically Bulldog HD) are engineered as an ultra-premium, heavy-duty upgrade over standard aftermarket replacements like Monroe. They are designed to withstand the extreme demands of commercial trucking fleets and heavy-duty vehicles, outperforming standard options in durability, internal sealing, and structural integrity. [1, 2]
Key advantages of Bulldog shocks over standard Monroe models include:
Superior Durability: Backed by an impressive 2-year, 200,000 to 250,000-mile warranty, whereas standard light-duty Monroes may fade or require replacement sooner in heavy-duty applications. [1, 2, 3]
Enhanced Sealing: Bulldog utilizes a double-lip Viton OE-style seal that drastically reduces oil misting and internal leaks compared to standard seals. [1, 2]
Rugged Construction: They feature 40% thicker inner cylinder walls, hardened polished chrome piston rods, and cold-forged steel eye-rings with 360-degree robotic welds to eliminate cracking and splitting.[1, 2]
Proprietary Bushings: Built with a specialized rubber formulation using less filler, preventing premature cracking and failure seen in standard aftermarket options. [1, 2]
Advanced Oil & Nitrogen: The internal oil can withstand extreme temperature ranges (-$30°F to well over 200°F), and the shocks are nitrogen-charged to completely eliminate performance fade. [1]
Bulldog focuses explicitly on addressing the common points of failure that commercial operators experience with general-purpose shocks
Edited by DanielBoondock
It's true. The Dexter axles supplied to Oliver are D52's that are derated to 3500 pounds because they are supplied with the same ole 4 leaf spring pack as always. I.E. the ones that fail. I believe you are correct that the axle itself is the same in both. Did your D52 axles come with 12-inch brake drums?
Yeah, reason enough. They certainly do look better, and the Google search assistant sure found all the good marketing copy.
I'd like to know how shocks are rated technically. If I had one of each brand new, I'd push them on a scale and see the force in LBS it takes to compress the shock! Not sure that is a valid test but could see relative difference.
What I found on our hull, same Monroe shocks before and after the Alcan Springs upgrade is the hull used to waddle like a duck and would porpoise (without the WDH) on the 1750 springs. Switch to Alcan 2750 LB leaf springs, same Monroe shocks, and there is barely any movement in any direction. I'd bet I can take the shocks off and it wouldn't matter, because the leaf springs have much less movement. I also believe the top-heavy E2 sways so much with the 1750s, t causes the shock failures (and spring failures for that matter).
I have a 7K dual-axle flatbed trailer at home. It was designed with no shocks. I load a SxS and dirt bikes on it. It doesn't move around at all since it has a low center of gravity. It has 1750s but loaded weight is only about +/- 4K LBS.
These came off our Oliver after we got it in 2023, yeah UGLY! 🤣 They used to be yellow years ago. At least they were MADE IN U.S.A. I'll order Bulldogs when the Monroes fail, unless there's something better when needed.
Agree, not sure how much I believe the hype. Shocks have a simple job, have been around forever, hard to believe it can be improved that much. Anyhow at $40 each its a cheap upgrade
Quote
Good to hear. I get a little (non problematic) side waddle. It’s the porpoising thats annoying, if that goes away I’ll be happy.
Dunno, what do you think?
The waddling will occur with the 1750s every time you hit uneven pavement, like driving up the apron to a service station or taking a bridge seam or RR tracks on an angle.
I've heard all 2026 have D52s and if the label states such it should be so. To be sure, you cannot tell from the front picture, since OTT used a 6-stud bolt pattern on all (5-stud is standard for 3500 axles). You must get under the trailer, look at the back of the brake backing plate. If you see on the back 5 studs in a pentagon shape, they're 5200 LB axles. The 3500s with 10" brakes have 4 mounting studs in a square pattern.
Another way to find brake size is measuring the drum diameter and brake shoe height. Last time I had the drums off for bearing grease repack, seal replacement and brake inspection, measured Ollie's Dexter 5200lb axle brake drum:
Edit: There is also a tag attached on the axle from Dexter (serial number also engraved on axle) that can give additional information about your axle, information on one of my axles emailed from Dexter:
Edited by rideandfly
Bill 2015 LE2 2024 F-350 6.8L
Right
The question is whether these have gimped 3500 brakes, maybe the conversation is getting a little mixed. Just realized I misinterpreted what scuba was saying, I thought he meant that a 12” drum means a different brake than the standard D52, but on re-reading I think he means that’s just a D52. Those drums look like they’re 12”, and from the label we know 26’s have D52’s derated to 3500.
Long story short I think these are stock 52’s with the on paper derating due to the springs. Speak up if I’m missing something
Sounds like you have it right.
You can get additional information from Dexter on your axle assembly by contacting Dexter customer service with the axle serial number, to get a build sheet emailed from them.
Here's a video about the tag you posted:
OK. Yeah the Alcan guy on the phone asked if I also wanted to install new axels? “Uh, no, why?” I explained that they were D52’s with the spring derate, to which he replied that the brakes were (maybe?) different. Like I say he didn’t seem confident of that and I wasn’t really buying it, I think from our discussion we can conclude that we believe it’s just a stock D52.
Dexter builds axles according to customer (Oliver) specifications, contact Dexter customer service during normal business hours with your axle serial number they can email a Build Sheet for your axle. When you're talking to them they can tell you if you have 12" brakes along with any other questions, I'm guessing you have 12" brakes.
I’ll call (probably), but still won’t change the axels. I’m at 0% gain on the freeways now and only go up to an exciting 0.5% when in traffic. Don’t use the brakes much basically
Reset 2.0 (Hull 1364 ‘23) has new Alcan springs! Even though I got mixed up on the drop off time and was late, the team at Alcan did a great job.
Had an incredible breakfast at the Dream Cafe per several suggestions in this thread, then Rebecca and I went up through the Colorado National Monument with Reset 2.0 safely in the hands the Alcan team. Can’t imagine going over that Rim Road with the Ollie 😀
Adding to my list of “designations I never wanted to achieve,” they told me my springs were among the worst they had seen. Bushings completely shot and in terrible shape. That’s the joy of purchasing a used Ollie. At least we have solid records from the day we purchased forward.
Now doing the enforced rest breaks under the trailer, a.k.a tightening the shackles and u-bolts.
Kevin and Rebecca Dunn | Duncanville, TX
Current: 2023 Oliver Elite II - Hull #1364 "Reset 2.0" (Second Owner)
Tow Vehicle: 2023 Ford F-150 XLT 3.5L EcoBoost /w 3.55 axle and Max Tow Package "SIlver"
Original: 2022 Oliver Elite I - Hull #1030 "Reset" (Sold)
Original Tow Vehicle: 2022 Subaru Ascent "Blue Moose"
It's good that you got that taken care of. New or used the factory springs on these trailers are a significant worry. We have a 2023 trailer and one of our springs snapped on our last trip.
That’s only three years old! Any idea why they got so bad, previous owner didn’t grease?
Would be pure speculation. When we sold our previous LE I, the new owner got spreadsheets and the handwritten logbook that's like an airplane's log. We didn't receive anything like that, just some vague contradictory statements about how little the trailer had traveled and the distant places that they had visited.
Based on several other items (shocks, refrigerator, plumbing) I have my opinions and speculations. I have tried to go through (with the help of the smart people on this forum) each system and bring it up to better than specs. Bulldog shocks, new refregerator, etc. I also try to give back with designs for installing the GasStop units on an LE I and will eventually get around to posting my refrigerator fan design that has a temp sensor to run the exhaust fans when needed.
The reason we purchased an Oliver is the community, the bunch of experienced travelers and engineers that will see a panic message on a Saturday afternoon and start throwing out helpful and thougtful troubleshooting tips. Besides the incredible engineering and reliability of our trailers, it's the community that sets our Oliver apart from the Grand Design sitting across from us and the Apex next door.
Wow - this response got off topic. Road brain, or possibly the wide open spaces of Wyoming out the window.
  • Love 3
I recently had the pleasure of working with Alcan Spring in Grand Junction CO for a set of new 5-leaf springs for my Oliver. Alcan is fantastic to work with. My mechanic's name was Tucker, and he was kind enough to take time before and after the install to be sure I understood what is needed in terms of torquing all the various nuts -- there are quite a few to be done, at 50 miles, 100 miles and then at 500 miles post-installation. The torquing isn't difficult, though doing the nuts on the springs is much easier with two people. Note that the requirements vary from the fixed end of the springs to the flex ends, so pay attention. About a week after my install, I spoke to Lew on the phone and he noted that yet another Oliver had just pulled through for new springs. Someone there said that they have installed new springs on at least 250 Olivers. Imagine that!
While I was there, Alcan also installed a new set of Dexter Brakes for my Oliver. Thanks to @jd1923 for looking at my brakes and also to @ScubaRx for encouraging me to follow through with a Warranty Claim (I had 25,000 miles so I was within the 5 year, 100,000 mile warranty window.)  Dexter was dynamite with their turn-around on the Warranty and shipping the brakes to Alcan, where I was already scheduled for new springs.  I truly appreciate both of these businesses -- Dexter and Alcan Spring -- for their efficiency and excellent service.
my Oliver has camped here
ALAZARCOFLGAIDILIAKSKYLAMSMOMTNENMNCNDOH
Congrats on the new running gear. Best money we ever spent on labor was having Alcan professionally do the work on our Oliver. Good for you. The torquing is the easy part.
Safe Travels!
