Teaney Hull 292 Posted October 15, 2025 Posted October 15, 2025 On 9/12/2025 at 12:55 PM, jd1923 said: We moved back to our AZ home seven years ago after living for 12 years back and forth between two homes, where my tools were spread between the two and my truck. On Craig's I found large stand-up Snap-on toolbox and was lucky to find a huge, well made workbench setup that Adam and I disassembled to move and rebuilt it to fit a custom L-shaped layout around 2 stalls of our 3-car garage, the center stall being my workspace. I also found a used Tuff Shed for storage, so my garage would be solely an auto workshop, not junked up with storage items. I installed other standing toolboxes and cabinets, enough room for a major 45-year collection of hand tools and spare parts. Then I emptied every hand-carry toolbox into the larger stationery toolboxes. During a winter cold-spell I spent days sorting our every box and package I hade with nuts & bolts, auto parts, electrical and plumbing parts. , etc. I bought a case of blue plastic single-gang electrical boxes (cheap effective storage bins) to hold all the small screws, nuts & bolts, nails, crimp parts..., drawers full of them in mounted file cabinets. For years now to the present, I know where every tool and most spare parts are located. I return all tools to where they belong daily, unless I'm in the middle of a job I will continue the very next day. Spending considerable time in organizing your tools is well worth it. I get repairs done now in half the time, not having to hunt for parts and tools! In getting ready to work, climbing under truck or trailer, I think a hard 5-10 minutes and collect part & tools needed in flat plastic trays that I lay on the ground where I'm working. The other thing I bring, since I/we will always forget something is my phone. With Chris' office just inside our home from the garage entrance, she's nearby and often happy to help. 😂 She'll come out to hand me a tool or two, knowing its easier for her to do so vs. what it takes me to get off a hard garage floor, and then climb down again. I do mean the word 'climb' as the downs and ups are not as easy as they used to be! 🤣 We all prefer to work preventive maintenance at home vs. getting stuck on the road. I have enough extras that I've assembled a small dedicated toolbox and a plastic parts box for the Oliver. They sit in the bottom of my large truck toolbox along with a 3/4" breaker bar, cheater bar and other long items. Proud to be keeping our truck and trailer in good maintenance so that these tools just sit ready, and have not been yet needed, 124 overnights in two years with our Oliver! Hope to never need them, but I have what we need to change tires, bearings, leaf springs or do a truck repair, like replacing an alternator or water pump on the road. Now that we've upgraded to Alcan Leaf Springs, I just removed the spare set of 1750 LB springs from the TV. The Alcans are not going to fail in my lifetime, though I do have tools with to replace wet bolts/bushings or most anything else! John, would love to know what parts you keep in that tool box. I’m on a 4 week run in our trailer and odds are, I’ll wish I had something that is needed. Gary and Anita Teaney and Ranger 2017 Oliver Elite II Hull 292 2018 Nissan Armada Tampa, FL
Geronimo John Posted Sunday at 03:15 AM Posted Sunday at 03:15 AM On 9/19/2025 at 3:45 PM, Mike and Carol said: We were at ALCAN this morning. They do good work! When getting the D52's does Alcan run the brake line in or along the outside of the axle? Do they use "high dollar" water proof connections? Do they check what wire gauge was used before connecting to the new 12" brakes? GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderators Mike and Carol Posted Sunday at 12:29 PM Moderators Posted Sunday at 12:29 PM 9 hours ago, Geronimo John said: When getting the D52's does Alcan run the brake line in or along the outside of the axle? Do they use "high dollar" water proof connections? Do they check what wire gauge was used before connecting to the new 12" brakes? GJ My understanding is that the axles come prewired with the brakes. Like the smaller axles I assume that the brake wires are run inside. During my torque sessions underneath the trailer with the new springs I didn’t see any wires run along the outside. Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
2008RN Posted Sunday at 03:26 PM Posted Sunday at 03:26 PM (edited) 12 hours ago, Geronimo John said: Do they check what wire gauge was used before connecting to the new 12" brakes? I was trying to find specs on the brakes. What I found is the it didn't matter if it was 12" or 10" brakes. Dexter shows 12 gauge to run 2 or 4 brakes from the tongue of the trailer. I do not think the dexter wires coming out of each of 10" brakes are 12 gauge the look more like 14 or 16 gauge. Other places such as trailer shows 14 gauge to each brake. One 12 gauge from the tongue could easily be split into 4 separate 14 gauge wires. I just do not know how and where Oliver did this. If there are problems I would say it was Oliver design problems and not Alcan upgrade. Edited Sunday at 03:27 PM by 2008RN 1 Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648
John Dorrer Posted Sunday at 08:07 PM Posted Sunday at 08:07 PM 4 hours ago, 2008RN said: I was trying to find specs on the brakes. What I found is the it didn't matter if it was 12" or 10" brakes. Dexter shows 12 gauge to run 2 or 4 brakes from the tongue of the trailer. I do not think the dexter wires coming out of each of 10" brakes are 12 gauge the look more like 14 or 16 gauge. Other places such as trailer shows 14 gauge to each brake. One 12 gauge from the tongue could easily be split into 4 separate 14 gauge wires. I just do not know how and where Oliver did this. If there are problems I would say it was Oliver design problems and not Alcan upgrade. Dexter pre-wires the brake wires inside the axel. Oliver only connects their wiring to the Dexter wiring. 4 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Geronimo John Posted Sunday at 10:05 PM Posted Sunday at 10:05 PM Thanks guys. I sort of suspected as much. But was wishing the other way. GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Geronimo John Posted Monday at 03:09 AM Posted Monday at 03:09 AM (edited) On 3/8/2026 at 5:26 AM, 2008RN said: I was trying to find specs on the brakes. I recall they are: D35 Axles have 10 X 2.5" shoes. D52 Axles have 12" X 2" shoe. Both magnets sets pull a nominal 3 amps each drum = 12 amps for LE2. Wiring per above is the same (Run thru the axle) GJ Edited 19 hours ago by Geronimo John 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderators mossemi Posted Monday at 08:14 PM Moderators Posted Monday at 08:14 PM 23 hours ago, John Dorrer said: Dexter pre-wires the brake wires inside the axel. Oliver only connects their wiring to the Dexter wiring. When I replaced my factory D35 axles with D52's last year, the brake wiring was an option. Based on other OTTO experience’s repairing the brake wiring inside the axles, I chose pigtails for each hub and used hose clamps to attach PVC conduit to the axle and ran the wiring through the conduit. Was that the right thing to do? Time will tell! Mossey 6 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Geronimo John Posted 19 hours ago Posted 19 hours ago On 3/9/2026 at 10:14 AM, mossemi said: When I replaced my factory D35 axles with D52's last year Was it done at Alcan or DIY? I'm thinking of bringing to Alcan a pre-cut section of 1/2" CPV, and some zipties and a tube of clear silicone to seal it up. And a clear sketch of where "on the back of the front axle" is. 🙂 For previous Alcaners, were they amenable to such an arrangement if they knew about it ahead? Any better ideas would be appreciated. Thanks GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
jd1923 Posted 4 hours ago Posted 4 hours ago 15 hours ago, Geronimo John said: Any better ideas would be appreciated. Just wire it as designed. I'm surprised to see issues with the OEM wiring internal to the axles. How many have rewired due to actual failure of the wiring vs. worry. When I removed our 10-year-old D35 axles there was nothing wrong with the internal brake wiring. I have a old dual axle flat bed trailer that we used for hauling dirt bikes and our SxS. I restored it 8 years ago, all 100% new wiring and I added brakes on one axle since it did not have brakes. I ran the wire across inside the axle as designed. Anything exterior, especially something "wire-tied" can be easily torn of from road debris! If my brand new D52 axles ever get shorted brake wiring, which is an extremely low likelihood, I will run new wire right down the axle where it belongs. Just my opinion. 😎 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators Mike and Carol Posted 1 hour ago Moderators Posted 1 hour ago (edited) 2 hours ago, jd1923 said: Just wire it as designed. I'm surprised to see issues with the OEM wiring internal to the axles. How many have rewired due to actual failure of the wiring vs. worry. I rewired my D35 due to intermittent brake disconnects. I know of one other owner who did the same (and first told me of the solution). When I pulled the wires there were several spots where the insulation was gone. There was about 3 or 4 feet of excess wire and my theory is that it was bunched up causing it to rub inside the axle. Once a new wire was zip tied to the outside of the axle my intermittent disconnect disappeared. It’s obviously not a common problem and I wouldn’t change anything or rerun the wires if there were no issues. I’ve now got the D52 axles and they are wired however the factory wired them. Mike Edited 1 hour ago by Mike and Carol 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
