I’ve got a fancy German manual gun with a locking head that I like but that’s the problem, can’t get it in there. Ordered those 45s, hope that works.
Also I found a local trailer suspension shop that’s been here for decades so should be good. I’ll order the Alcans before too long and do it locally. Probably going with four unless they manage to convince me otherwise 😅
Still feeling it out and need to find the time to read the other half of this thread
Sierra EV AT4 2026 (max range 500 mile pack)
4 hours ago, DanielBoondock said:
 Fair point, retract the 1750s from what I said, except perhaps for people who lightly use their trailer
It was a reasonable starting point but charging now comes with risk aversion to change probably. Maybe they’ll do it sometime as an update. 2027 looks like they’ll be adding a DC-DC converter, it’s already labeled in on the electrical panel. I don’t need it but useful for ICE TVs
3k miles and I’m hearing the suspension squeak now, doing my first grease. What a pain, getting a right angle grease gun fitting
I use the 90° Lock n lube grease gun with that attachment.  It makes those awkward fittings much easier to lube.
The power grease gun sits nearby on the ground, has a long hose with the lock-n-lube on end. Just attach, hit the power button for a few seconds. Used a manual gun for 40 years, always fighting it!
The #1 Ollie Tool I purchased was the Lock-N-Lube lock on grease gun fixture.  It is amazing and certainly helps.   I had a new ole style grease gun and just added the below to it.  Love it.  With it I did not need to go right angle.  I liked the 45 degree ones better.  Especially with the below.
When I need to replace my grease gun, I'll pay the bucks for the Lock-N-Lube version for sure
JPR
Per the above posts, even that group is seeing failures.  Time for OTT to wake up to the reality that the owners want a change to a stronger spring.
For JD's sake I'll not go further on that!  LOL
Edited by Geronimo John
On 4/29/2026 at 1:17 PM, jd1923 said:
Dan is new here
Been a member for four or five years 🙂 took me that long to make my choice. Oliver was the first choice but then Bigfoot seduced me with that cool BIG FOOT front storage. Got a tour, meh, and noticed the seams and conventional RV hardware everywhere, so came back into the fold. Pretty brave, or stupid too as it was sight unseen, they’re rare out on the West Coast
Many of us know that feeling.  We purchased ours from Hawaii having never seen one in person.  But what we, as you, did was to really study the tone and helpfulness of the members here on this forum and the "SOB's" (Some Other Brands) as well.  At the time, and still to this day, I think that the owners sell more trailers than OTT does themselves.  No other brand came close in this regard.  After our purchase I had an opportunity to go to the factory tour and instantly fell in love with our decision.
As a technical we all know that machines need maintenance and TLC.  Also that some times tweeks to the foundational design of a machine is necessary.  WIth OTT, we have seen a few upgrades, a few changes, and very few OOPS.  And the number of OOPs is very small.
However over times things change.   The two biggest changes I have observed in the past ten years from an owner's perspective likely are the percentage of owners taking their OTT's boondocking further into the wild and running heavier than earlier years.  The impacts are higher "G" forces and typically +/- 6,000 pound weights on the suspension 100% of the time. Both of these changes are not OTT fault.
There is clear evidence of premature spring failures from OTT owners having road side spring failures, and dozens more finding that their springs flatening out way too early in what should be a normal spring's useful life.  So a design change is needed. I believe from history that OTT would not ignore such failures without concern and would be monitoring our experiences.
I also would wager one of Art's famous home brews that they are looking at an upgrade standard spring to the 2400 # Dexter four-leaf springs and an option for a "Boondocker's Heavy Duty" suspension package featuring the Alcon type of 5 leaf.  Those options both make good common sense.
Good news is that OTT takes a lot of care and time, as they should, before making such changes.  In that regard it would smart to keep track of the owners who have changed their springs and to monitor them in the normal duty and heavy duty class.  In doing so to get specific data as to the pros and cons of their spring choice for their use.  If I was running their quality control team that is exactly what I would be doing.  One needs data to to make data driven decisions.
Question from the peanut gallery
did anyone see the need to adjust your tow vehicle ball height higher after adding the Alcan springs and new shocks ?
did the upgrade change your ball hitch weight ? lighter ?
just trying to anticipate
Robert E
2022 LE II , LIthium Pro, 2018 F150 XLT 4WD 2.7 EcoBoost , 355 gears, tow package,36 gallon fuel, factory brake controller, transmission cooler
Actually the owners didn’t sell it for me, Escape and Bigfoot owners are equally passionate. In the end what did it was a tallying of positives and negatives. For me, I figured that whatever undiscovered problems the Oliver will have will be less than the known negatives of the others. I was worried about the bed length in particular. Fortunately nothing came to pass, and I found more positives IRL. Having said that, couldn’t they have made the bathroom just a little bit bigger? 🙂
Anyhow OT the greasing went just fine with a right angle fitting (not right angle zircs). Question: a couple of the outrigger ones - the ones on spring ends, would not take grease at all. Clogged? I’m going to try again after I move it, figuring that the position it’s in is preventing ingress
Sure they could - BUT - then you would not have a closet (or, at least a smaller closet).🛁
I didn’t have to make any adjustments.   Ball height was/is the same.
5 hours ago, Tideline77 said:
did anyone see the need to adjust your tow vehicle ball height higher after adding the Alcan springs and new shocks ?did the upgrade change your ball hitch weight ? lighter ?
I did not actually measure. Height change may be up, <1” or negligible.
Tongue weight should not change since distances, the 3-point geometry of the trailer has not changed. Porpoising will be minimized, so that weight up and down on the hitch will be more even.
Edited by jd1923
I mean make it a little longer. The glass body is what, only 18’ on a 24’ 6” body? I don’t understand the exceptionally long tongue except stability, but then why not move the wheels back a bit instead? I don’t know the details but would love to, but just another 6” or foot of interior length would go a long way. Weights a consideration but going to 8k isn’t that bad I think
Anyhow the only history I know is they hired some guys from a nearby house boat catamaran company initially. That’s where they probably got the marine hidden gasket idea, and the fitting out with electrical and such. I wonder how the chassis was designed?
From another thread about the X23 2027 model, the offroad version includes (drumroll)
Quote
Bulldog HD shocks & Alcan leaf springs, off-road suspension
Four or five leaf? Five I'll guess. Good for Alcan this is a regular business for them. Well that's good enough for me, I'll order my set before too long.
I went through most of the thread but don't recall a link or specs for the bulldogs, can anybody provide a link?
https://www.4statetrucks.com/search/?search_query=19-050000007
This is what I bought and had Alcan install with 5 spring kit based on other's recommendations. Glad I did shocks too as Alcan said the original shocks were shot.
 Hull#1047 "Saunter"
Solar Pro 390 aH Lithionics
2022 Ram 1500 5.7L Hemi
Got a quote from Alcan, here's some answers to questions I had
Quote
We recommend buying the shocks yourself as we cannot get a better price. Most
Oliver owners go with the 5 leaf spring. The 4 leaf spring will work just fine if
you are not carrying a lot of extra weight. The new model of Oliver trailer is
using our 4 leaf spring pack. The 4 leaf pack is the same price as the 5 leaf pack.
So Oliver is being cautious and going 4 leaf
I just got some Bulldog Shocks From O’reilly,s  (just need two).  There were going to be about $78 with tax and shipping,because they had to special order them..  I asked for my veterans discount, no good on spec.orders…He said let me try this..  Got the price down to $58 out the door…  the shocks were $31 each normally..I was pleasantly surprised.and the parts come in 2 days instead of a week.. Now that is customer satisfaction!!
spacer.png2022 Elite I  # 1179  |  2024 Tundra SR5 4x4 Crewmax. 5.5 ft. Bed. 3.31gears 10 spd.trans
Oliver is adamant about maintaining their 7000 pound GVWR. The 4 leaf spring pack is now the weakest link and achieves their goal.
  • 4 weeks later...
Just had our Alcan Springs installed today, along with Bulldog Shocks on our 2022PXL_20260529_135930702.thumb.jpg.ee435f22fa4b907cbfc1f3a7194cc367.jpgPXL_20260529_135930702.thumb.jpg.ee435f22fa4b907cbfc1f3a7194cc367.jpg. The Dexter Springs had started to flatten anywhere from 1/2" to 3/4".
I had a spare Dexter 4-Leaf spring that the arch measured at 3-3/4".
Edited by John Dorrer
Try unloading the fitting and likely you will get it to take grease.
Sorry for speed reading this 36 page thread if you already tried this.
No worries, thanks yeah I did get clued into that trick. Worked great, the suspension quieted right down. Still a little creaky, suspecting the leaves are rubbing or maybe there’s a bit of grease missing somewhere. I noticed on the Alcan page they smartly put poly rub pads on the end of the leaves to avoid this.
Well we’ll be in the neighborhood this summertime (roughly) so I set up an appointment to get fitted at Alcan. Full hog five leaf, who am I to argue with them? And I was thinking about when camping we’re going over weight anyhow with all the tanks and people in it. Plus I generally agree with having some extra margin and IIRC Alcan believes 20% is the right amount so OK.
For the Alcan spring Oliver group
would you do anything different  if you had a second chance to make this upgrade ?
or would you suggest any other improvements ?
Robert E
would you do anything different  if you had a second chance to make this upgrade?
Wow, all day long and no replies here on our 36-page Alcan thread! 🤣
Robert, you have a newer hull, so I assume you have D52 axles. Those with D35 axles should upgrade at the same time (my build thread below). You want to install everything NEW; D52 axles, Alcan 5-pack leaf springs, a new EZ Flex kit and new shocks.
I had installed new shocks the year before, so after they tested good, I reinstalled them. I wish somebody would come up with a HD replacement shock (I've looked)! The Bulldog shocks are likely better than the OEM Monroe 555001 shocks, but they are both light duty shocks designed for 1750 LB springs. I wonder if the Oliver would tow any different without these shocks, given the HD Alcan springs. I'd like new HD shocks with similar min/max length specs but heavier, larger diameter shaft, piston and casing.
Do differently? I would purchase the full Dexter EZ-Flex kit with HD shackles and wet bolts. I purchased the wet bolts from Alcan and new EZ-Flex center links only. I do love Alcan Springs, but their shackles and wet bolts are not splined so do slip, so not as good as the Dexter wet-bolts that come with the EZ Flex kit. Another route would be to look at a MORryde substitute for the entire EZ Flex kit. That's all I see, more info here =>
I have D52s rated 3500, the guy at Alcan claimed these were somewhat different than D52s rated 5200 - the brakes when I questioned him. Not sure I believe it.
