  1. Today
  2. Great job! I think this set-up is way better than the Beech Lane with that goofy control box. The original switches are hard to source because the indicating LED is on the top side of the switch. Most of them have the LED on the bottom side of the switch and I bought several before finding the right one. The specifications just don't say! For future reference, LighthouseLEDS sells them for $2.99, SKU# SPST12VROCKERSWITCHBLUE, and they ship fast!
  3. Yesterday
  4. 5k buys a lot of battery power and portable solar. An awning has to be brought in in windy conditions. Pretty prevalent in many parts of the west. I'd skip it. We use the original awning a lot. Sometimes only a foot or two over the door. Never been tempted to get a second awning, though. Congratulations on your upcoming adventures!
  5. I am NOT disappointed to see the dealer network go. But a separate issue is finding good service centers outside Hohenwald. I managed to find one in my Wisconsin area where i feel comfortable taking my Oliver. The key to this success is the willingness of Oliver tech support to work with them when necessary. OTT has been very good about this. After all, most of the components are not "Oliver" and appear in other trailers. At one time I suggested creating a directory of Oliver-friendly service centers across the US, but the logistics of doing so and the relatively small footprint of Olivers didnt make it practical.
  6. A little sad to see this, as I thought the intent was to have qualified service beyond Hohenwald . But, I get it. Oliver is a distinct elite niche product.
  7. We use a compressor and small nozzle at the end to blow out the track drains. Also have used pipe cleaners and wire in the past. The window design is pretty much window industry standard. My home windows also have weepholes. If drains/weephole are clear, you have other issues. Definitely eyebrows/gutters help, but is there another issue?
  8. Geoff, Thanks for all the ground worked you did in testing and designing your fan system and such a great writeup. It really made this job a lot easier. I copied the bottom side of the installation pretty much what you had. The only change I made was the order of wires on the terminal Block. I started with the 12V+ on the bottom and then the 12V- on the top of the block, and did the flow up the terminal block just like your electric diagram: 12V+ ->Main switch -> Thermal Switch -> Fans -> 12V-. On the top side I had about 3.5 inches of opening clearance from the bottom of the opening to the fiberglass support for the microwave shelf. I did find a fan that was 92mm (3 5/8") with IP68 waterproof rating. I used a 1/2 aluminum angle stock and screwed downward into the middle of the outer shell and shimmed the aluminum angle up about 7/32" so the #8 Bolts heads would clear the plastic and I would have A little more contact of the fans against the upper section in the back. The top of the fans are not screwed in. They are setting against the upper fiber glass shelf with about 3-5 pounds of pressure. Nice tight fit. Sorry the picture is upside down I can't figure out get it correct. I tried rotating the original but that didn't help. Things I really like about this setup. 1. The terminal block Allows for quick diagnostic with a voltmeter. 2. Nothing is hardwired, All components have connectors so the thermal switch and fans are easily replaceable when there is a failure. 3. The thermal switch is very easily adjustable for height and location. 4. The wiring looks clean. I did a test on it yesterday. It was around 86 degrees outside. Took about 30 minutes for the thermal switch to kick on. Temp was between 120-125 degrees coming out of of the hottest side of the fans . I don't know why but I couldn't find a source for the original switches on the inside control panel without going through Oliver. I wanted to put in a dimmer for the outside porch lights and I was pressed for time to order an original switch from Oliver and to wait 2-4 weeks to get a part from them. So I bought a dimmer for the porch lights and received it in 2 days and moved the original porch light switch to the Street side awning position to use for the fans. Lastly, thanks for the info on removing the microwave, I never would have known about the jack screw. The inside of the microwave cabinet was slightly different. There was a step up in the back sort of like a backstop for the microwave the went clear across the back of the cabinet. So I removed 5 screws holding the bottom panel and backstop, This allowed full access to the back. After feeding the wires and loom through to the back of the fridge area, I resealed the hole with spray foam behind the microwave, and re-taped the Fridge area with aluminum duct tape around the loom and touched up some areas where the original tape was having some problems. It was a good thing I had to remove the microwave. The microwave was coated with fiberglass dust and there were piles of fiber glass dust in the cabinet. Now at least the back of the microwave and the cabinet is clean. I do not know what the air flow is inside and around the microwave, but I would hate to think that fiberglass dust got into the food/drinks.
  9. I see the added piece behind the dinette tabletop, but where get you get the deeper pantry shelf - as well as the matching pattern for the dinette?
  10. I guess I’ll look closer next time. (I go in that area so seldom because it’s a PITA to wedge up the mattress topper, cushions, access cover just to reconfigure the valves to winterize/boondock/nornal.) I wonder if the “engineers” that put valves, breakers, and fuse holders in places that require moving bedding and cushions might have come up with better ideas if they had taken a prototype out first for a few months - changing configurations and the like.
  11. John and I don’t think the wire pulled from the axle looks like the culprit (though only the wire from front axle was pulled, the other is still in there, cut free)… only the small section near the hole with missing grommet was nicked. However, there were no warning messages yesterday. Today will be a longer tow, and I will keep the forum updated.
  12. Time will tell! John and I don’t think the wire pulled from the axle looks like the culprit (though only the wire from front axle was pulled, the other is still in there, cut free)… only the small section near the hole with missing grommet was nicked. However, there were no warning messages yesterday. Today will be a longer tow, and I will keep the forum updated.
  13. Hopefully her brake issue is fixed for good!
  14. Ours too, but we're hoping to go camping for a few days next week! 😎 We just had a guest Ollie here, for a few great days! 😂 But now she's gone. You might know who. Woke up yesterday, looked out our living room window and I got scared! Thought for a moment we still had a Dometic P2, oh NO! 🤣
  15. Last week
  16. I'm jealous! Really beautiful area.
  17. Thanks, appreciate the info and context!
  18. I just noticed that with the exception of the dealer in Canada, all of them are now gone. All sales have officially moved back to Hohenwald. I think this will come as welcome news to many potential new owners. Many were opting to actually come to Tennessee for their pickup and delivery anyway. It has been reported that many dealers were taking payment, handing over the keys and sending people on their way without any kind of walk through. That's just not acceptable. Other dealers were selling the trailer, allowing the new owners to pick up their unit in Tennessee and still charging them $1.2-1.5K for "cleanup and delivery". That's just wrong. I believe this is a wise and good move for Oliver. They gave it a good run. Sometimes things just don't work out as well as predicted. Good job, Guys...
  19. For those considering installing the Beech Lane fan, the instructions advise to mount it on the upper vent, blowing outwards. There is a small diagram on the side showing fan rotation and airflow direction.
  20. Congrats on your trailer. We mostly boondock with our trips running from 3 weeks to 7 week at a time. We purchased our Oliver used and it came with two awnings. In the eight years of owning the trailer, we have NEVER USED THE DRIVER SIDE AWNING. The drive side awning did come in handy for broken parts one occasion. Based on our experience, a driver side awning is dead weight. Best of luck, Olivers are great trailers.
  21. Yep and Yep. At least for our older trailers, annual cleaning (or more often in some locations) and gutters are the only fixes that worked in our case. GJ
  22. BRIEF UPDATE July 14, 2026: I accepted the generous offer by John @jd1923 and Chris to come farther west to Prescott and tackle this 'Check Trailer Wiring' issue. While my Oliver was jacked up, I was able to take care of some other regular maintenance work, and John helped out with that as well, but I will focus here on the trailer wiring. The main job was to replace the brake wires beginning at the left side (below the battery box) where the wiring exits the hull, and connecting new wires to each of the four brakes. John suggested pulling the new wires through the axle by taping them to the end of the old wires, for various reasons, but once the taped joint reached the opposite side and I needed to pull it out through that small hole in the axle, the tape broke apart. I tried pulling the new wire through that hole with some needle-nose pliers but the wire was so soft that small pieces were breaking off. So we reverted to my initial plan (based on several others here on the forum), and ran the new wires along the rear side of the axles, using split loom and zip ties to anchor it. We found that the butt connectors I ordered from Amazon did not hold; John tested one and the wires pulled right out without any effort. He had some older style butt connectors that we used, with much thicker metal inside, and then we added tape on the connections. I will probably come back to those taped joints with some liquid tape to try to weatherproof them better. (I saw that someone had used a clear sealant -- if anyone knows what that is called, I would like to find it. The liquid tape I have is black like tar.) The finished job looks really good. Note that I haven't tested by towing yet. After the rewiring, I measured the amperage at each wheel, after disconnecting the 7-pin connector from the truck and pulling the Emergency Brake pin. Each one measured about 3.0, with the left front measuring slightly higher. This was a good result in so far as the power was flowing from the Emergency Brake battery (I believe on the Oliver, this is the trailer battery; SOB trailers have a separate little battery for this power). After the tires were back on and everything was back in place, I tested again using the power from the truck through the 7pin connector, with John's son Adam helping me by being at the controls in the truck. Measuring the two main wires exiting the hull (below the battery box) the amperage was 1.85 and 1.71 on the left front and rear wires. This measurement is obviously without being in motion, and my understanding is that the truck will not provide the full power to the brakes in this case; I'm not sure what amount should be expected here, but power is flowing to both wires from the truck. Quoting from @Geronimo John in an older forum post, "... modern brake controllers sense when a vehicle is stopped and back off the power flow to the magnetic coils when stopped..." Yesterday, John and I performed another set of tests on the 7pin Cable wires where they enter the hull and exit the cable, inside a double sized junction box behind the small panel below the vanity sink (see earlier photos in this thread.) We tested amperage for each of the wires, and the 7pin cable seems to be working fine -- even jiggling the wire at the connector and below the Oliver -- so we elected not to replace it. Of course, once again, this is not in motion driving down the highway. None of this is definitive until I actually tow the Oliver, tomorrow morning. I will report again in a few days, and try to add some photos here for clarity. I don't think this is resolved yet, but making progress on eliminating things is good. Many heartfelt thanks to John, Chris and Adam -- they have all been extremely gracious hosts and very helpful, and have cheered me up as well. Many thanks as well to all the other forum members who have been helping out with ideas and links and questions. Now we are heading out for some fun!
  23. And there are Oliver owners who boondock almost exclusively. Hopefully more will pipe in here for you. I live waaaaay down in southwest Florida; I 'boondock' at Cracker Barrel when I'm just trying to get closer to my destination, which is almost always in the Rockies -- about 3,000 miles away from home. Once I reach the west where BLM, USFS and other public lands are abundant, I typically boondock for weeks at a time without plugging in anywhere, but I am mostly at higher elevations so I am reaching for a light blanket rather than the AC. This year has been an exception for me on this; I got away from Florida a lot later in the season. I have the Lithium Pro package (mine is (3) 130 Lithiums) but I am frugal using power. I hardly ever use my microwave. You should also consider where and what time of year you want to camp -- seasons will impact how you use power. Does your Oliver have propane heat? Does it have a propane refrigerator? Mine is 3-way so I can use DC, propane or AC -- but I don't think the new units are like that. I agree with John here. I only have the single awning on the right (curbside) and often enough it's not where I would need it for optimal sun protection. It all depends on the access, even when you are boondocking, and how you decide to position your door, etc. I used my awning a lot my first year but rarely use it any more. Some people create shade with different methods, like hanging shade cloth. I've wished for shade on my left side, but apparently not enough to do anything about it. :) I would opt out of the solar awning. There are other forum members who will give you more concrete data on power use and other options. Have fun as you think about your options.
  24. To each his own, but from what I’ve seen from trailer sway videos, I’d rather have more protection than less, so I’m willing to forgo a little wear on the ball in the unlikely event that I would have to take evasive action at highway speed. So I’m stayin’ on the “Don’t lube your balls team” for now. 🤣
  25. I'm installing a 2-5/16" Bulldog on Thursday. My B & W Stow and Go has both a 2" and 2-5/16" ball. Plan is to inspect the 2" Bulldog, and if it looks good, I will paint it gray and keep it as a back-up.
  26. .
  27. Welcome to the family. As you wait our Blog has lots of info on various gear, upgrades, solar, and campgrounds visited . The link is at the bottom of our signature below. https://4-ever-hitched.com/trips-overview
  28. Did you keep the original 2” ball size or upgrade that, as well?
