Our 2016, about the same thing. I reinstalled a replacement cable, but to do it properly I would have to reroute the waste drain plumbing. More here =>
Lesson learned. So after a little deeper dive into cause and effect of how my water filter failed, I learned the following. Last fall when we winterized, I turned off the water supply to the Truma. I went out and pulled the yellow lever down, pulled the filter out and drained all of the water out of the Truma tank. With the system and the tank drained, I reinserted (error on my part) the Truma filter and it must have had a tiny amount of residual water near the internal plastic sacrificial disk inside the filter which resulted in it freezing and then cracking. If I had completely removed the filter and stored it inside the Oliver as I have done for the past 5 yrs, I likely would not be needing a replacement filter. Important to note, the Truma tank system was completely void of water with exception of what residual was in the filter housing which was apparently just enough to cause the sacrificial disk to do what it is suppose to do…fail. To complete my inspection of the Truma hot water tank, I temporarily used my winterization filter and the system worked as designed. We had the system set at 120d within about 8-10 seconds we had unlimited hot water in the galley and shower. Here is what I learned -open source- If your Truma AquaGo filter (or Easy Drain Lever) blew out, gushing water from the housing, the internal plastic disc or O-rings likely failed. This is almost always caused by residual water freezing and expanding inside the housing, or the O-rings being misaligned. [1, 2, 3, 4] The Fix You cannot repair a broken filter assembly with glue or tape due to the system's high water pressure. You will need to replace the entire filter/drain assembly. [1, 2, 3] Depressurize the system: Turn off your RV water pump or city water supply, and open a hot water faucet to relieve the pressure. Remove the old filter: Lift the thumb latch on the easy drain lever to drop the assembly down. Inspect the housing: Look inside the chamber for any leftover pieces of broken black plastic. Install the replacement: Pop the new filter cartridge into place and snap the lever back up to lock it. [1, 3] How to Prevent It Truma designed the filter to fail (break) first to prevent the internal mixing vessel from freezing and causing a $2,000+ tank replacement. During winterization, always make sure you pull the yellow lever, remove the filter cartridge, and drain the water entirely. Do not reinstall the filter until you are ready to use the RV in the spring.
Too funny! I was standing up when I looked under the cover plate and my relief valve lever was turned upwards where I couldn’t see it. Kind of like me looking for the ketchup in the fridge I guess. 😉 Looks like they have the typical water heater relief setup after all. Nevertheless when you look into the open end of the filter, you can see it’s designed with a much thinner wall around the back of the plastic housing, very similar to a rupture disc. Again I don’t know first hand if that’s actually Truma’s design intention, but with an overpressure situation this would be a weak point that would likely fail. And it would fail through the drain port of the water heater as you would expect if that was their intention. Anyway, take it for what it’s worth.
Truma Aqua Go filter failed
DanielBoondock replied to Patriot's topic in Mechanical & Technical Tips
Great comments thanks. This part is interesting because it does have a standard over pressure valve just above the filter housing. Do older Trumas not have this? Otherwise great tip about the antifreeze unit, I had it in there full time -
DanielBoondock replied to Lamar's topic in Mechanical & Technical Tips
Not sure of the exact situation from the information given, but here’s some commentary Using the induction on battery The induction will only pull full 1.8kW when both burners are on full power. The smaller one is limited to 8/10 vs 10/10 of the bigger to meet this spec. With my 3k inverter and the max lithium I can only use both at full power by themselves, no microwave or other high power devices typically at the same time because tripping the 3k is easily possible. But you have a 2k, the reason you can’t get full use out of the 2k is twofold I believe. One is code (for buildings) limits you to I think 80% of full spec for wiring. It depends on various factors like if it’s in conduit or whatnot. But the idea is there’s a difference between continuous high draw and momentary. EV’s for example, if say drawing 32A Level II charging at home overnight, will actually draw close to 32A for hours. Household wiring and sockets aren’t meant for that and will usually overheat, so they have different specifications. But maybe the wiring is rated for full use, as I do get full power on both while on shore. Two, inverters never seem to give the full rated spec, I think they leave margin for spikes. Again 80% is typical from my experience. Seems like if I get close to 3k it’ll freak. Finally there’s the phantom steady state draw from the rest of the camper, so the inverter needs margin for that. All told, an induction cooktop is much like an EV in that when it wants 1.8kW it will draw a full 1.8k until changed. That’s a high load/high stress situation for a camper. So it’s not surprising that a 2k inverter may not support both burners on full. I rarely to never use both mine on full with my 3k, it’s too easy to trip! I use the main burner on full, and if I need to simultaneously use the second one for say boiling some water, I just do it at a lower setting and it takes a little longer. But who cares? Induction is way faster than gas any day of the week so it takes about as long as gas. Breaker The LEII has a 15A dedicated breaker for the stove as you’d expect Stove top not doing anything If there’s zero response from the stovetop - pressing on (which uses no power) doesn’t turn it on than this is a problem. Most likely issue is a tripped breaker. Induction is definitely 120V not 12V feed. Anyhow the induction is a game changer IMO. No toxic gas danger, no condensation from the propane burning, no fire risk, faster, cleaner and better. But you have to know how to work with it as it’s a very high power device. I don’t think it’s a deficiency that the 2k won’t support full power on both burners, that’s ‘by design’. it’s the same reason you can’t run AC, wave and stove at the same time. You pay for the inverter size you wanted. So I wouldn’t worry about that, even at a reduced setting it’s still going to boil water faster than propane. -
Wanted to chime in on the black tank valve cable installed from the factory (2022). Mine was being hard to open and close all the way so I pulled the valve, did a thorough cleaning and reinstalled it. It didn't improve, so I pulled the cable out of the sheath and found a small kink in the cable about midway between the valve and the pull handle. I'm not sure if it was from impact during construction or from being pushed in too hard. I ordered a new cable and looked at the instructions and found out the cable must be straight at both ends for at least 6". It is also required to be secured every 2' O.C. for the entire run. The cable from the factory doesn't meet either criteria. My guess is if the cable was properly installed at the factory it would operate the way it should. Has anyone "properly" installed a replacement cable? Results? Black Tank Blade Valve Cable Installation Instructions.pdf
Here's just a little insight into what likely happened in David's situation and how to reduce the chances of others experiencing the same situation in the future. After examining this filter plug more closely, I have determined that the part that broke out of David's filter is designed as an over pressure protection for the water heater. By code all water heaters are required to have a high pressure relief. For the Truma, instead of a standard pressure relief valve, they have chosen to use a sacrificial relief that's designed to let an over-pressure situation release and drain to the outside. With David's description of the event, I'm convinced that when the water supply valve at the water heater was opened to run through the water heater, a high pressure surge hit the water heater causing the "safety device" to rupture. This was very likely a high water pressure situation, possibly caused by and air pocket in the water line just before the valve that caused a water hammer effect in the heater when the valve was opened. Now I can't prove this is what actually happened, but in liquid and steam systems I have worked with over the years, coils such as that in the Truma water heater are usually protected by what is called a rupture disc, designed to fail before damage can occur to the more valuable parts of the system. Whenever opening a valve to pressurize a system, it's imperative to open the valve very slowly so as not to cause a hydraulic hammering of the system when doing so. Also it's very important to run a system clear of any air pockets before opening a valve to other components in the system. For air and gas systems this is not an issue. But with hydraulic systems it's critical. A very good precautionary step to reduce the chances of water hammer when opening a valve is to very slowly open the valve to prevent a surge. One additional precautionary step to take before repressurizing the water heater is to open one of the faucets to hot water to allow flow through that side of the system when the valve to the is being opened to the water heater. Again this allows flow through the water heater, allowing air pockets to escape without cause a water hammer condition. These steps should prevent this from occurring to anyone in the future. Hope this helps anyone with concerns about their Truma water heater. PS - Obviously a high water pressure from the utility source connected to the trailer could also cause this situation to happen. This is the obvious reason why we must always use a pressure regulator and never setting it above 40 psi. PPS - If you purchased the Truma anti-freeze plug when you bought your Oliver, it can be used in place of the regular filter plug should you need a short term backup. It works exactly the same as the standard filter plug, just has a heat coil built into it. You don't need to plug the coil in for this use purpose.
Maxxfan Dome installation (previously orientation)
Geronimo John replied to Townesw's topic in Ollie Modifications
AMEN! Best suggestion of the week! ++++++++++++++++++++++++++++++++++++++++++++++++ Bill: Best installation approach I have seen. Very creative way to intall the fan on a curved roof. Thanks for your time and effort to create a bathroom fan replacement "Best Procedure" yet. GJ -
Geronimo John replied to jd1923's topic in Ollie Modifications
JD: Great post. Seriously like, and am considering at least the front light install. I would prefer not to have unplug when removing the cover. I have a"glam cam" thru the hull for my DC to DC cables, and the under sink portal hatch. Combined they appear to provide an access pathway. For reference, the belly band is well below the sink cabinet top. What do you think about using the light switch circuit of the jack to provide power to the front light location. Tap the load side of the jack light switch, add fuse and run power under the doghouse area to a cable glam, then inside up into the under sink, and thru the hull to mount just above the belly band? Would it worth the extra effort and possible to do? Thanks GJ -
Geronimo John replied to Snackchaser's topic in Ollie Modifications
I have a couple of speakers that have given up. Will check power and resistance, but suspect they are blown and need to be reuplaced. Are these the ones you used? Thanks, GJ -
That creek that is basically on your right as you take the drive up to Saint Elmo is full of hungry trout. Bill
That’s great news! I hope your issues are resolved soon!
@DunnYet Open source - No, you should not leave the Truma winterization (bypass) filter or standard stainless steel filter installed all season long. [1] If you are actively using your RV during the camping season, you should be using the standard stainless steel filter (or the Truma Electric Antifreeze Kit if actively in use). The official winterization plug/filter is strictly designed to replace the standard filter for winter storage and is not meant to be run full-time. Keep these quick winterization rules in mind: For Winter Storage: Drain your Truma system and remove the filter cartridge entirely. Store the filter in a dry place inside your RV and leave the yellow Easy Drain Lever closed. Leaving any filter inside during freezing weather can trap water, expand, and permanently damage the unit. [1, 2, 3] For Active Winter Camping: If you plan to travel in freezing temperatures, you can use the Truma Electric Antifreeze Kit. This specific kit can be installed in place of your standard filter to keep the water heater from freezing without draining your propane. [1, 2] For Normal Summer Use: Remove the winterization plug and reinstall your standard stainless steel mesh filter before de-winterizing and turning your water system on for regular use.
Made in USA leaf springs
No worries, thanks yeah I did get clued into that trick. Worked great, the suspension quieted right down. Still a little creaky, suspecting the leaves are rubbing or maybe there’s a bit of grease missing somewhere. I noticed on the Alcan page they smartly put poly rub pads on the end of the leaves to avoid this. Well we’ll be in the neighborhood this summertime (roughly) so I set up an appointment to get fitted at Alcan. Full hog five leaf, who am I to argue with them? And I was thinking about when camping we’re going over weight anyhow with all the tanks and people in it. Plus I generally agree with having some extra margin and IIRC Alcan believes 20% is the right amount so OK. -
Thanks for sharing David, I just purchased a backup on Ebay for $25. If anyone needs a replacement or spare and can’t find one on the cheap, they are available on Amazon as well. https://a.co/d/00C38npm
Oliver's response has been outstanding. We are working together to address the issue. More to follow when I have a chance to provide a detailed update. Bob
jd1923 replied to Gliddenwoods's topic in Mechanical & Technical Tips
Just replaced the Blum slide on our nightstand drawer. This item is the OEM part replacement. Maybe I should have bought the 6-pack, LOL! The nightstand drawer and 5 kitchen drawers all use the 18" length, the short drawer uses the 12" Blum slide. https://www.amazon.com/dp/B0G7LQ3PQ4/?th=1 Lately, the drawer would open during travel so I suspected something was wrong. After removing the drawer (squeeze two orange levers underneath), I found the old slide was truly worn out. When fully extended the end would drop a couple inches. Not good! The new slide is in and now again it works great. But per the subject of this thread, OTT installed these slides with only three screws per slide! 😒 The slides are rated to carry 100 LBS, but three short #6 screws are certainly NOT! A couple year backs, working on a kitchen sink leak, I doubled all the screws on the kitchen drawers and went up one size. At the time, I forgot to do the nightstand drawer. The slides all wobbled a bit when unloaded with only 3 screws and I now contend it was the lazy installation that allowed this drawer to shake and eventually wear out the slides. These slides are substantial but need to be installed properly! BTW, Blum supplies 20 wood screws in these kits! 20 screws for 2 slides and 2 brackets not used for our application. I installed 8 screws on each slide! Why not? Blum certainly intends more than 3 should be used! I put 3 in the same holes to hold each slide in place and then drilled small pilot holes and screwed in 5 more (see pic)! Now this should last my lifetime. 😎 I suggest removing all your Oliver drawers, having at least 6 mounting screws per slide, 12 per drawer minimum. - Yesterday
Teaney Hull 292 started following Door window shutter
San Isabel National Forest , Cascade Campground near Buena Vista Colorado Gonna hit the nearby hiking trails, Ghost Town of Saint Elmo, Hot Springs Got the hang of the Ford 10 speed on mountain passes tow haul mode only , select M , 2nd gear off the top
Thanks a million for invite ! That is so kind of you ! we plan to stay in the Colorado High Country for most of the summer one of Therese days we will visit you in Prescott
Thanks very much @Patriot for this. It makes me wonder - I generally leave the “heater” filter in all the time regardless of season. Should I pull it for the “off season” and only put it in during the cold camping months? I only switch to the standard filter when running the decalcification cycle. Am I doing this wrong?
Thanks I will keep an eye on mine!
rideandfly replied to Snackchaser's topic in Ollie Modifications
Wired and tested the iRV62 today. Very easy to wire to Oliver wiring with AM/FM, DVD, and CD player working great with original Jensen TV and Jensen speakers! Great choice! -
Geronimo John replied to Gliddenwoods's topic in Mechanical & Technical Tips
Roger, thanks for the flowers... OH with small washers too! GJ -
Try unloading the fitting and likely you will get it to take grease. Sorry for speed reading this 36 page thread if you already tried this. GJ -
Part number of OEM Filter is AquaGo Replacement Filter # 77000-00251
