  2. Complete Victron, yeah! šŸ˜Ž
  3. Yesterday
  4. Apparently this is how you’re supposed to set up a sewer hose support Bill 313
      • 1
      • Haha
  5. Chris, I wrote about this in my install thread. You can keep the tray if you remove it first and machine cut the steel back wall off the tray and reinstall. The inside battery would hang an inch off but I believe Steve told me they added a longer base sheet inside the tray. Either way 3 in line will just barely fit inside. Notice the change in direction of the straps to hold three together on the tray. Too bad they didn’t show the actual installation work in the video. I was going this route but after removing my old tray, the sliders were crusty and the tray itself weighs 30 LBS. I prefer it without the tray which allows for 2-3ā€ extra height too. I can check/tighten the bolts and remove the main ground as they sit on 3/4ā€ rubber and foam insulation surround. With the tray, it has to be rolled out for battery post inspection or disconnect.
  6. I see Steve was able to fit three 300ah batteries into his tray. Didn't you have to remove yours to make them fit? Different size trays, or did battery dimensions change?
  7. It’s easy to test for voltage on either side of the awning switch. Your LevelMatePRO has been working, so it should be wired to the right side. Where is the LevelMatePRO grounded? You have an odd set of lights out, others working. I don’t believe they’re wired like Christmas lights! See if a ground came loose common to all dead circuits. A ground that’s open will not blow fuses and your fuses are good. Good luck with it and let us know.
  8. Copy/pasting reply from FB Thanks John. We’re only out for a few days, so I’m going to wait until we get home to try tracking down the fault with my good meter instead of the $10 travel one. I know the fuse is good, because the other lights on the circuit work. Yes, the blue indicator light are what I’m referring to, plus’s the upper cabinet lights. It’s most likely a wire disconnected somewhere. I had the switch panel by the door out, and the access port behind. Tugging on wires didn’t result in anything loose, but it could also be a bad switch. It’s just odd that some indicator lights work and others don’t. And on that the indicators that don’t work, the device they operate do function correctly except the upper cabinets. They all worked two days ago, so something bounced loose or failed while on the road.
  9. Yes, and they just look better in white!
  10. Welcome to the Big Boy club! 🤣 Three (3) Forum members now have 900 Ah Epoch (one with 920). 🤠
  11. Three years ago I wired my LevelMate Pro to the always hot Street Awning switch, and that has worked fine until yesterday. After a drive to our accommodations for the weekend, the LevelMate wouldn’t power up. But the awning did. So apparently, I hooked into the indicator light terminal on the awning switch. Then I realized that several of the switch indicator lights didn’t work, nor did the lights in the upper cabinets. But other indicator lights do work, as do the closet outdoor, and cabinets lights and other interior lights. So, I figured a wire on the indicator light circuit pulled loose, but after pulling out that messy jumble of wires behind the switch panel, I can’t find anything loose. And that wouldn’t explain the cabinet lights not working. The fuse is fine, and is the same fuse as the other cabinet lights. This led me to the possibility that either the indicator lights, the upper cabinet lights, or both, are run in series instead of parallel, like on those impossible to fix Christmas tree lights. The wiring diagrams I have do not go into that detail. Has anyone had upper cabinets light or indicator light problems, and can steer me as to where to look? It isn’t trip critical; just an inconvenience. I’m rewiring the Level Mate to the other leg of the switch. Thanks for any suggestions
  12. Finished the coating, looks great! In the long tradition of 'you learn how to do it when you finish' the bottom half is the best job. The mistakes were all in applying the coating. You have to be really careful applying this, constantly rechecking for any high spots that didn't get rubbed out. Looking from different angles for reflections is the only way. And don't underestimate the flashing off period, its hard to wipe off good coating that hasn't cured but the longer you wait the harder it becomes. The problem is this stage is at the end when you're the most tired. I've got a number of mistakes on the top half. I also was super braindead on the street side bottom and just compounded with Cutmax 06 04 and a microfiber pad, instead of EX 04 06 and a foam pad. The numbers refer to cutting power (e.g. Cutmax 06 XX) and polishing (Cutmax XX 04). Microfiber pads are more aggressive. Anyhow that evening I realized my goof, boy was that upsetting but you know what? You can't tell. They're sending these out now with mirror finishes and the polishing stage doesn't visibly add much of anything to the compounding. I'd still do it as its an easier step, but fortunately with this combo it doesn't matter so fuggit about it! So fixing those coating mistakes on the upper half, today I'll work on that. Gemini recommends using the Sonax EX 04 06 on those, alcohol wipe and reapply. Nobody else will notice or care but I'd like to do the best job I can so will work on that today. And upside is now I'm experienced enough to do my truck. Fiberglass is really forgiving so that was a good platform to learn. I'm saving $10k probably doing it myself for truck/trailer, and I'm doing more than any shop (all the extra bits), so time well spent. Good muscle workout and I enjoy being out with the trailer as it's a lovely storage lot next to State Park.
  13. Steve, quite an impressive install! Mike
  14. Steve, cool vid. So glad to refer you to Easton at Inverter Services and he got you all taken care of. He handled all your upgrades exceptionally well. As previously post, Easton installed the same outstanding and comprehensive Victron system on XPLOR Hull # 634 after we returned from our 54-day trip to Maine last fall. Nothing like a super clean professional upgrade/install. I highly recommend Inverter Services and Mr. Easton sure knows his way around Olivers!
  15. Try THIS THREAD for more info on colored Olivers Bill
  16. If that were the case then Glacier would not be full either. They got a bunch of those furry creatures up there - at least everywhere we went both inside and outside the Park. Bill p.s. enjoy the heck out of that area - it's special
  17. For those that have never had the chance to see the interior of the Outlaw Oliver, be sure to look around during this short video. Steve and Tali have switches for switches and extra "lifts" for the beds that increase storage room a bunch. Bill
  18. Also - do you have solar panels? Do you have a solar panel cut-off switch? do you have an inverter? Is it on or off? do you have a fridge that runs off DC power (i.e. a three way fridge)? If yes then what setting is the fridge on (a/c, d/c, or propane? Bill
  19. Last week
  20. More info please. Type of batteries? What voltage do you see when you press the Battery button on the SeeLevel monitor? Are you plugged into shore power or running off batteries? Do your interior lights work? Do you have a multimeter?
  21. This video will give you a basic outline to some of the upgrades we had done earlier this summer on the Outlaw Oliver.
  22. Glacier National Park, Saint Mary Campground near eastern entrance to the park. The campground amenities vary a bit depending on the loop, but they have hot showers (free) as well as fresh water spigots, waste water dump station (for gray water from dish washing) and an RV dump near the entrance. Full of berries and full of bears; maybe that's why the campground isn't full! The sites cannot be reserved before the day-of-arrival, but it wasn't a problem to find space. I'm so glad I took the opportunity to come here this year, at the suggestion of a friend. The weather has been perfect camping weather; cold enough to want a camp fire, and damp enough to be allowed to have a camp fire.
  23. That's nice work and a good looking toilet!
  24. Today, my unit suddenly indicated through the Xantrex solar unit that the batteries were dead! New batteries as of last year! Circuit breakers checked out fine. Why is the system apparently draining the batteries?
  25. I'm thinking they came to their senses that adding colors would not sell more trailers, would increase production complexity and increase inventory costs. not a winning formula
  26. Thanks Mike - I couldn't remember his Forum name for the life of me. Bill
  27. Somewhere here on the Forum there are pics of the colored Ollies, the stories behind them and the story as to why they are not produced. Bill
