Everything posted by BigTexas
Seeking New Air Conditioner for Hull # 145
BigTexas replied to ScottyGS's topic in Ollie Modifications
Another Chill Cube customer here however I've not installed it yet. I waited until the heat pump version came out to make my purchase. I didn't see the no drain system as a problem. I have a small window unit at my vacation home that uses the same method of throwing condensate on the condensing coil for additional evaporative cooling. It sounds like a waterfall when it starts but has never dripped. Now, I realize I'm making a big leap of faith the Cube will work the same but I'm not too worried if a little condensate flows off the trailer. We're still rocking lead acid batteries and don't have an inverter. My goal wasn't energy conservation as we're usually plugged in or occasionally on a small generator at lunch stops. My goal was quiet and humidity control in the trailer. My hope is when the Cube ramps down to a constant run state, it will achieve both. Fingers crossed -
Automatic Leveling for the Oliver Trailer β DIY style!
BigTexas replied to Snackchaser's topic in Ollie Modifications
This is brilliant! Oliver already makes it pretty easy to level the trailer. But if I wanted to make my camping friends (even more) jealous, I would build this and watch them grimace with envy. -
I downloaded the pdf for when I get around to doing my upgrade. Thanks for all the detail and thought you put into putting this together.
With all the cautions mentioned above, I do what others have mentioned. Get the trailer close to level using lifts or blocks under the wheels, if needed, and then use the jacks the last few inches to make the trailer level. The jacks are pretty robust and seem to lift and support the trailer without problem. Having said that, I also highly recommend the use of blocks under the lifts to reduce the amount they have to extend. I read this forum weekly if not daily and find it a valuable resource of information for owning, using and enjoying your Oliver.
OK, I'll confess. I've used the screw in plugs...but only because they are so easy to pack and very quick to use. To my surprise they seal pretty well but I consider them very temporary. Just something to get you off the side of the road. If I'm going to plug a tire, I also like the tried and true "string plugs" mentioned above. The concern I have with the screws, is since it's held in mechanically, the flexing of the tire may cause it to dislodge. Now, I've never had one come out so this is pure paranoia on my part. One consideration, is they are a good first attempt because you can back them out as easily as they go in. So if the screw plug doesn't work move on to the string plug or alternative method. I also have the mushroom plug kit. I've never been able to make them work but may be bad technique on my part.
My main concern regarding damaging the system would be if somehow the Ceilo inadvertently bypassed the compressor delay (not allowing high side pressures to normalize before restarting). But it's only providing commands via IR signals. It doesn't have the ability to cut power to the system like opening a circuit breaker and then turning it back on, which could defeat the compressor delay. I think an analogy may be similar to a computer. Power off the computer and it starts a shut down process protecting your data and the system. Pull the plug and you may loose everything. The Ceilo is just giving commands via IR to the motherboard. But the motherboard retains all the manufacturers protection protocols. But I'm no expert. I just watch a lot of YouTube air conditioning videos.
We loved our Casita but I could never go back to the rat fur on the walls. Looking at the layout of the Casita 24 made me wonder if I would trade the closet in the Oliver for the dry bath layout in the new Casita. For me it's an easy no. But I often hear the wet bath in the Oliver is a non starter for some folks.
Ok, this is brilliant. Don't know why I didn't think of this. I've already had to replace the sprayer head once due to freezing. (Where's the head slapping icon?)
As others have noted, these trailers do very well in cold weather. So I think you'll be fine as long as you have heat. We traveled to Moab for a January wedding. There were several days on the road where the temp never got above freezing and the trailer was covered in ice when we arrived at our overnight stop. We relied mainly on the internal water tank as the supply hose would freeze. One lesson we learned was to be gentle with the trailer when you arrive. Without heat, some of the plumbing may have frozen while traveling. Give it some time with the heat on to thaw out. I broke the toilet petal once by being impatient, not knowing the flush valve in the back had frozen. I carry extra flush valves but the pedal is not available as a separate replacement part. Not my finest hour.
Hardwire your LevelMate Pro for under a buck!
I just got around to doing this mod. Super easy since Geoff did all the design work and sourced the components. Thanks! I previously had the Level Mate attached just inside the door to make turning it on easy when we arrived at the camp site. However I was unwilling to drill into the beautiful fiberglass finish for mounting so I used Command strips. Just me touching the Level Mate to turn the switch on was enough to throw it out of calibration so it became useless. I wired it up, mounted it in the same location mentioned above and hopefully will never have to touch it again. Now I too have 9 remaining converters. If anyone is considering doing this mod, drop me a line and I'll happily drop one into an envelope for you. Thanks again for posting this mod. -
I'm also following this topic closely as I too am anxious to get away from the noise of my Dometic A/C. And thanks for being the sounding board for all the interest in the Ceilo Max. I get that Wi-Fi is needed for initial set up via the phone app. However in a camping spot, with no Wi-Fi, is Comfy mode still accessible? From reading the website it's only on the phone app and my concern is once Wi-Fi is lost so is Comfy mode.
Big Texas - We didn't give it much thought. We saw this printed on the collar of my daughter's corgi. Realized the dog and the trailer had the same shape. Then asked my daughter to design the logo. In conversation we just refer to it as "the Oliver".
BigTexas replied to John and Jodi's topic in General Discussion
Thanks for sharing your story. I think you are correct in that we think we're prepared but in reality, we're prepared for the most basic incident. I think a contributing factor was the Oliver tows so well, you were unaware of the disintegrating tire behind you. In the past, I've relied on the Oliver's jacks to raise the tire high enough for removal and replacement. My thought is to use the scissor jack, that came with the truck, as a back-up jack. I've never had much luck with Fix-a-flat. Instead I carry a tire plug kit and compressor (12v or 120v if you have an inverter). Tire plugs can be controversial. Some feel once you plug a tire, you should replace it as soon as possible. Most tire stores refuse to repair a previously plugged tire. Others plug a tire and just run it. The plug kit allows you to deal with as many flats as you have plugs until you get to a position where you can purchase a new quality tire. In addition to learning from your experience, I've made a note to bring along my impact driver. Thanks again for sharing. -
Late-Model RAM Owners - how do you like your βtechβ?
BigTexas replied to Galileo's topic in Towing an Oliver
I have a 2024 Ram 2500 that I'm still learning all the features that come with the infotainment system. My truck came with the 12" screen which at first seemed excessive but I've learned to split the screen into several functions (Map on top, radio and engine parameters on bottom) If that's not enough info for you, the map and additional vehicle information parameters can be also be displayed on the drivers dash screen. I love all the cameras, although this has become pretty standard these days but they greatly assist when parking. At first, I did not like the digital rear view mirror and turned it off because my old eyes didn't like the change in focal length. But it has not become my favorite feature. A rear view mirror is mostly useless when towing a trailer the size of an Oliver but the wide field of view lets you see down both sides of the trailer even before checking the side mirrors. I still use the wireless rear camera that came with our trailer. There is a convenient 12V plug up on the dash so no power wires dangling everywhere. The adaptive cruise control is handy in stop and go traffic (unless you come to a complete stop; then it kicks out) As mentioned Apple Car Play is wireless and works smoothly. Apps like IExit and MyRadar are very useful on the big screen. Things I don't like or I'm not sure of. The truck nav system is based on Tom Tom. It works well but is an interface I'm not used to. The jury is still out on the Trailer Steering option when backing up. Once it learns your trailer it's good at backing up straight but a slight turn of the knob will send your steering wheel spinning. Maybe I'm a DIY back up guy. Also, lots of reliance on voice actuation. The truck has it's VO system plus Siri is available. I don't know, I'm just not much for talking to my truck. All in all, I'm pleased with the systems. I came from a 2015 so a big jump in available technology. Finally, I'd say it strikes a good balance between being too intrusive and just letting you drive the vehicle. My wife has a new Lexus. It's always beeping at her and warning her of potential hazards. Some of it is just annoying. -
We use quick connects. I also use a Y adaptor with individual gate valves at the park spigot to depressurize the line before disconnecting. Seems obvious but if you ever forget things get exciting quickly, especially if you use one of the expandable hoses. Also, the search function on this site sometimes is not very helpful. Others have posted a web format to use to make Google search the site more effectively.
As a former ad guy, I approve!! π
- 1 reply
- 4
Weigh Safe 180 Aluminum hitch with 3β shank, 10β drop
BigTexas replied to Patriot's topic in Towing an Oliver
I purchased the same hitch when I switched to a 2500. In addition to looking good it also allows you to reverse the balls under the truck when not in use to save your shins. -
Check your leveling jack feet!
BigTexas replied to mountainoliver's topic in Mechanical & Technical Tips
Thanks for posting. It would have never occurred to me to check this. Looks like lock tight is in order. -
Thanks for posting Mike. I'm a firm believer in having spare capacitors on hand as cheap insurance because you never know when they're going to stop working and their easy to switch out. I'm using your pictures to order the spares. I'm guessing the black capacitor is an added on hard start capacitor? Do you have the Oliver factory installed Micro-Air Easy Start option on your A/C unit? I know the Micro-Air unit also contains a capacitor but I've not taken the time to look it up. I'm thinking an A/C unit wouldn't have both a hard start cap and the Micro-Air. I need to do some preventive maintenance on mine. They're easy to forget about until they don't work.
The high viewership of the Escape video could be all the Escape owners clicking to see how bad it is (Oliver owners too). The bear delivered the best lines in the spot.
Dometic Toilet -broken flush mechanism
BigTexas replied to Galway Girl's topic in General Discussion
This also happened to me when I flushed the toilet not realizing the pipes were still frozen. Non replicable part. I first tried to glue it with a special "epoxy plastic glue". Worked for about three days. Did the same as others and ordered a new toilet, scavenged the useful parts I needed and discarded the rest of the toilet (what a waste for such a small part) After discussing the problem with a friend, he suggested searching the web for a 3D printing file of the part. He mentioned a lot of small parts like this get scanned and the files are posted to the web. Then one can have it printed locally (or he offered to do it for me) I know nothing of 3D printing how it works or what it takes to create a file for a small part but if someone had the knowledge and resources to create such a file, they would be making an immense contribution to mankind; or at least to those of us who had to learn the art of hand flushing the toilet. -
Very low water flowing from faucets when on city water
BigTexas replied to MnG KY's topic in General Discussion
+1 to Max Burner's description. Had the same problem. One day is fine the next day all the faucets and toilet have barely a trickle. Had to clean out all the screens. Found a white calcified substance in all of them. After that all was well. Note: there is often a screen located at the connection to the flexible hose that feeds the shower head and kitchen faucet head. I never found any in the actual valve assembly. I assumed all this calcification came from the water heater but the mystery to me was how it got into all the cold water lines. -
KE5PRE - I'm not very active. Mostly I mount my rig on a motorcycle to support charity bicycle events around the state. The MS Society has an annual ride this weekend. I'm working the route going from to Austin to College Station with an overnight in LaGrange. The other routes are coming from the Houston area so we use a statewide linked net. I usually take an HT camping with us with some local repeaters stored when we hike. Just incase we have an emergency with no cell service.
Traveling between campgrounds when itβs freezing
BigTexas replied to RustyMD's topic in General Discussion
Also, when you arrive at your campground, after traveling in very cold conditions, give the trailer time to thaw out before using any of the plumbing; especially the toilet. We were caught by a quick moving cold front which resulted in traveling in temps in the teens. When we arrived at camp, I made the mistake of using the toilet before the trailer had properly warmed up. The flush valve was frozen and the give point was the plastic pedal when I stepped on it to flush. By the way, Dometic does not sell the pedal as an individual part. Instead I had to purchase one of their cheaper all plastic models to cannibalize the foot pedal. An expensive lesson. "Run your furnace while traveling" - brilliant! Best piece of advice. I would have never thought of that. (insert sound of hand slapping forehead)
