HDRider Posted July 2, 2025 Posted July 2, 2025 Can someone talk to me about the maintenance provided by the mothership at Hohenwald? What all do they do? Has anyone documented a detailed list of their service? I could not find anything on their website. Thanks 1 Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
Steph and Dud B Posted July 2, 2025 Posted July 2, 2025 I've never had them do the routine maintenance. Have had mixed luck with their repair services. One time, under warranty, they did very shabby work, failing to complete tasks they claimed they had completed. This included leaving a loose nut rattling around inside a brake drum. More recently (this spring), they handled a minor fiberglass repair quickly and efficiently. So, a gamble. Unless you live very close to the Oliver plant I would recommend doing your own routine maintenance if you can, or find a local RV shop you trust. Most Oliver components are fairly standard RV gear. 2 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Dennis and Melissa Posted July 2, 2025 Posted July 2, 2025 On our first anniversary of ownership we did the "yearly maintenance" package. It wasn't cheap, and I think the overall quality of their work was "meh" at best. But I am still in learning mode, and we had some minor warranty work done at the same time. So, I think it was reasonable. But I don't intend to make it an annual event. 2024 OLEII - Hull MDIV, born 3/13/24 Ram 1500 5.7L 8 cyl hemi, 4wd, max tow, air shocks, 6’4” box, crew cab
John Dorrer Posted July 2, 2025 Posted July 2, 2025 4 hours ago, HDRider said: Can someone talk to me about the maintenance provided by the mothership at Hohenwald? What all do they do? Has anyone documented a detailed list of their service? I could not find anything on their website. Thanks All you have to do is call Oliver and they will send a list of the services they provide for "Annual Service". I'm sure you can also do a search or on Facebook and get it. 2 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
HDRider Posted July 3, 2025 Author Posted July 3, 2025 15 hours ago, John Dorrer said: All you have to do is call Oliver and they will send a list of the services they provide for "Annual Service". I'm sure you can also do a search or on Facebook and get it. I had used their "Contact Us" page. I have not got a response. They rarely answer the phone. Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
HDRider Posted July 3, 2025 Author Posted July 3, 2025 I plan to take my Ollie to Hohenwald to get the leak fixed, along with a couple of other warranty issues. I do my own maintenance, but I thought while I had her there I'd let the experts go through it. This thing cost a lot of money, and I want my grandkids to use it some day. 1 Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
Tony and Rhonda Posted July 3, 2025 Posted July 3, 2025 A previous owner had the "Yearly Maintenance Premium Package" completed in 2023. As best I can tell from the service sheet I have, there where 23 maintenance items in the package: 1. Inspect & Clean A/C 2. Inspect/Clean/Test Furnace 3. Inspect & Service Fridge 4. Pressurize & Test Plumbing System 5. Inspect & Service Water Heater 6. Decalcify Plumbing Lines & Fixtures 7. Lubricate Blade Valves 8. Lubricate Jack Pivot Points 9. Check Brakes, Repack, if req'd, Grease EZ Flex 10. Prep & Caulk Exterior 11. Perform LP Drop & Operating Pressure Test 12. Test GCFI function 13. Inspect & Test 7-pin 14. Inspect & Lubricate Coupler 15. Inspect Axle & Suspension 16. Check Tire Pressure & tread Depth 17. Inspect & Clean window Tracks 18. Charge & Load Test Batteries, if app. 19. Sanitize Fresh Water & Flush System 20. Wash Exterior 21. Clean Interior 22. Complete Torque Check 23.Complete Visual & Operational Test of Appliances The service sheet says a 4-5 day appointment is required. Price, as best I can tell was about $1600 but not everything on the list was done because the previous owner replaced the A/C with a Truma and replaced the 3500# axles with 5200# Never lubes. I don't know how, or if, these replacements changed the service cost. 1 New to us 2017 Legacy Elite II Hull #251 (with updates) TV: 2023 Tundra Double Cab 4x4 TRD Sport (still with original engine) Formerly 2004 Tundra with 2015 Four Wheel Camper Fleet
HDRider Posted July 3, 2025 Author Posted July 3, 2025 2 hours ago, Tony and Rhonda said: A previous owner had the "Yearly Maintenance Premium Package" completed in 2023. As best I can tell from the service sheet I have, there where 23 maintenance items in the package: 1. Inspect & Clean A/C 2. Inspect/Clean/Test Furnace 3. Inspect & Service Fridge 4. Pressurize & Test Plumbing System 5. Inspect & Service Water Heater 6. Decalcify Plumbing Lines & Fixtures 7. Lubricate Blade Valves 8. Lubricate Jack Pivot Points 9. Check Brakes, Repack, if req'd, Grease EZ Flex 10. Prep & Caulk Exterior 11. Perform LP Drop & Operating Pressure Test 12. Test GCFI function 13. Inspect & Test 7-pin 14. Inspect & Lubricate Coupler 15. Inspect Axle & Suspension 16. Check Tire Pressure & tread Depth 17. Inspect & Clean window Tracks 18. Charge & Load Test Batteries, if app. 19. Sanitize Fresh Water & Flush System 20. Wash Exterior 21. Clean Interior 22. Complete Torque Check 23.Complete Visual & Operational Test of Appliances The service sheet says a 4-5 day appointment is required. Price, as best I can tell was about $1600 but not everything on the list was done because the previous owner replaced the A/C with a Truma and replaced the 3500# axles with 5200# Never lubes. I don't know how, or if, these replacements changed the service cost. Thanks. I contacted Oliver via e-mail and got this. The price has went up and the services has went down. Maintenance Performed Inspect & Clean A/C Includes cleaning coil & filters, removing debris, test operation, & check drain system Pressurize Plumbing & Inspect Includes leak testing Fresh & City water inlets, water lines, connections & fixtures. Inspect & Test Water Heater Includes visual inspection of fixture connections & operation Inspect Anode, if equipped Inspect LP Line Decalcify Plumbing & Water Heater Decalcify plumbing lines & Fixtures to remove calcium buildup Decalcify or flush Water Heater Inspect & Lube Blade Valves Test operation & lubricate valves Inspect & Lubricate Jacks Test operation, lubricate pivot joint, & inspect gears Repack Bearings, Inspect Brakes & Grease EZ Flex Inspect Brake components Inspect Bearings & Repack Grease EZ Flex zerks Recaulk Exterior Clean perimeter & recaulk joints Apply lap sealant on roof for additional seal for penetration points Perform LP Pressure Test Test LP Regulator for proper pressure & lockup pressure Perform LP Timed Pressure Drop Test Test LP lines for leaks Test GFCI Receptacles Ensure GFCI operation to all receptacles Perform 7-Pin Test Inspect & Test 7-Pin function, Clean Exterior & Grease Inspect Coupler Operation Test & Lubricate Coupler Inspect Axle & Suspension Visual inspection of axle & leaf springs Check Tire Pressure & Tread Depth Inspect & Clean Window Tracks Clean window tracks for proper drainage Charge & Load Test Batteries Clean/Sanitize Fresh Tank 1 Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
Steph and Dud B Posted July 3, 2025 Posted July 3, 2025 The only thing on that list that I'd be willing to pay someone to do is recaulk any roof fittings that need it, and that's only because I find getting all the way up on top of the roof awkward and I'm terrible at caulking neatly. 2 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Moderators mossemi Posted July 4, 2025 Moderators Posted July 4, 2025 4 hours ago, Steph and Dud B said: I'm terrible at caulking neatly. From where I’m standing, your caulking looks great! Mossey 1 5 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Moderators SeaDawg Posted July 4, 2025 Moderators Posted July 4, 2025 4 hours ago, Steph and Dud B said: The only thing on that list that I'd be willing to pay someone to do is recaulk any roof fittings that need it, and that's only because I find getting all the way up on top of the roof awkward and I'm terrible at caulking neatly. Among my many friends and acquaintances, I can count zero who actually enjoy caulking. My husband does a better job than i do, so he usually gets the job if we had to flip for it, I'd be seeking a coin with both sides head, and call tails. Yet another reason I like butyl, where applicable. We caulk around the edges to shield, but butyl does the job. 7 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
jd1923 Posted July 5, 2025 Posted July 5, 2025 Caulk only if/when the original caulk has failed. If so, remove the majority of the old caulk before applying a new bead. Caulk on old caulk, you’re not helping yourself. 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Jamie Peghiny Posted December 3, 2025 Posted December 3, 2025 This seems like a lotta money for things that I can mostly do myself, not to mention the 1350 mile one-way trip. Personally, I wouldn’t want to repack my bearings, how much would it cost to have a mechanic do this? $50/wheel? That seems reasonable. I’d grease the zerks though. The folks on this forum seem pretty well informed and capable. Jamie 1 Jamie and Sandi New Harbor, Pemaquid Point, Maine 2021 LEII Hull #802
Moderators Mike and Carol Posted December 3, 2025 Moderators Posted December 3, 2025 8 minutes ago, Jamie Peghiny said: This seems like a lotta money for things that I can mostly do myself, not to mention the 1350 mile one-way trip. Personally, I wouldn’t want to repack my bearings, how much would it cost to have a mechanic do this? $50/wheel? That seems reasonable. I’d grease the zerks though. The folks on this forum seem pretty well informed and capable. Jamie I’ve had most work done (bearings, brakes, etc) locally. Most maintenance is generic and can be done by any experienced RV maintenance person or by the owner. Mike 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Moderators topgun2 Posted December 3, 2025 Moderators Posted December 3, 2025 2 hours ago, Jamie Peghiny said: $50/wheel? With shop rates getting to the point of about $150.00 per hour, you are probably a touch low on the $50. But around $75 per wheel would probably get it done. Bill p.s. while just about any boat or regular trailer can do this job - I'd ask around a bit to get some recommendations. Bearing service is NOT difficult. But, if it is not done properly it can cause you some real headaches down that lonesome road. 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Geronimo John Posted December 4, 2025 Posted December 4, 2025 21 hours ago, topgun2 said: With shop rates getting to the point of about $150.00 per hour, you are probably a touch low on the $50. But around $75 per wheel would probably get it done. Bill Those guys are a lot faster than I am! But if I could do two axles at their pace, it would be $300 a year cost. Ten years that I hope to be around say $3,000. The Dexter NeverLubes I understand should go ten years. So, mathamatically speaking, I am financially well ahead in getting the 5200 never lubes with their better brakes. RIght? GJ 4 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
CRM Posted December 5, 2025 Posted December 5, 2025 16 hours ago, Geronimo John said: But if I could do two axles at their pace, it would be $300 a year cost. Ten years that I hope to be around say $3,000. The Dexter NeverLubes I understand should go ten years. So, mathamatically speaking, I am financially well ahead in getting the 5200 never lubes with their better brakes. RIght? I love your math and will be using it as my sales pitch for new Nev-R-Lube axles to my wife. She'll then return the favor by letting me know what she'll be spending that saved money on! 2 1 4 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
