Can someone talk to me about the maintenance provided by the mothership at Hohenwald?
What all do they do?
Has anyone documented a detailed list of their service?
I could not find anything on their website.
Thanks
I've never had them do the routine maintenance. Have had mixed luck with their repair services. One time, under warranty, they did very shabby work, failing to complete tasks they claimed they had completed. This included leaving a loose nut rattling around inside a brake drum. More recently (this spring), they handled a minor fiberglass repair quickly and efficiently. So, a gamble.
Unless you live very close to the Oliver plant I would recommend doing your own routine maintenance if you can, or find a local RV shop you trust. Most Oliver components are fairly standard RV gear.
On our first anniversary of ownership we did the "yearly maintenance" package.  It wasn't cheap, and I think the overall quality of their work was "meh" at best.  But I am still in learning mode, and we had some minor warranty work done at the same time.  So, I think it was reasonable.  But I don't intend to make it an annual event.
Thanks
All you have to do is call Oliver and they will send a list of the services they provide for "Annual Service". I'm sure you can also do a search or on Facebook and get it.
I had used their "Contact Us" page.  I have not got a response.
They rarely answer the phone.
I plan to take my Ollie to Hohenwald to get the leak fixed, along with a couple of other warranty issues.
I do my own maintenance, but I thought while I had her there I'd let the experts go through it.
This thing cost a lot of money, and I want my grandkids to use it some day.
A previous owner had the "Yearly Maintenance Premium Package"  completed in 2023. As best I can tell from the service sheet I have, there where 23 maintenance items in the package:
1. Inspect & Clean A/C
2. Inspect/Clean/Test Furnace
3. Inspect & Service Fridge
4. Pressurize & Test Plumbing System
5. Inspect & Service Water Heater
6. Decalcify Plumbing Lines & Fixtures
7. Lubricate Blade Valves
8. Lubricate Jack Pivot Points
9. Check Brakes, Repack, if req'd, Grease EZ Flex
10. Prep & Caulk Exterior
11. Perform LP Drop & Operating Pressure Test
12. Test GCFI function
13. Inspect & Test 7-pin
14. Inspect & Lubricate Coupler
15. Inspect Axle & Suspension
16. Check Tire Pressure & tread Depth
17. Inspect & Clean window Tracks
18. Charge & Load Test Batteries, if app.
19. Sanitize Fresh Water & Flush System
20. Wash Exterior
21. Clean Interior
22. Complete Torque Check
23.Complete Visual & Operational Test of Appliances
The service sheet says a 4-5 day appointment is required.
Price, as best I can tell was about $1600 but not everything on the list was done because the previous owner replaced the A/C with a Truma and replaced the 3500# axles with 5200# Never lubes. I don't know how, or if, these replacements changed the service cost.
New to us 2017 Legacy Elite II Hull #251 (with updates)
TV:  2023 Tundra Double Cab 4x4 TRD Sport
20. Wash Exterior
21. Clean Interior
Thanks.
I contacted Oliver via e-mail and got this.  The price has went up and the services has went down.
Maintenance Performed
    1. Includes cleaning coil & filters, removing debris, test operation, & check drain system
  2. Pressurize Plumbing & Inspect
    1. Includes leak testing Fresh & City water inlets, water lines, connections & fixtures.
  3. Inspect & Test Water Heater
    1. Includes visual inspection of fixture connections & operation
    2. Inspect Anode, if equipped
    3. Inspect LP Line
  4. Decalcify Plumbing & Water Heater
    1. Decalcify plumbing lines & Fixtures to remove calcium buildup
    2. Decalcify or flush Water Heater
  5. Inspect & Lube Blade Valves
    1. Test operation & lubricate valves
  6. Inspect & Lubricate Jacks
    1. Test operation, lubricate pivot joint, & inspect gears
  7. Repack Bearings, Inspect Brakes & Grease EZ Flex
    1. Inspect Brake components
    2. Inspect Bearings & Repack
    3. Grease EZ Flex zerks
  8. Recaulk Exterior
    1. Clean perimeter & recaulk joints
    2. Apply lap sealant on roof for additional seal for penetration points
  9. Perform LP Pressure Test
    1. Test LP Regulator for proper pressure & lockup pressure
  10. Perform LP Timed Pressure Drop Test
    1. Test LP lines for leaks
  11. Test GFCI Receptacles
    1. Ensure GFCI operation to all receptacles
  12. Perform 7-Pin Test
    1. Inspect & Test 7-Pin function, Clean Exterior & Grease
  13. Inspect Coupler Operation
    1. Test & Lubricate Coupler
  14. Inspect Axle & Suspension
    1. Visual inspection of axle & leaf springs
  15. Check Tire Pressure & Tread Depth
  16. Inspect & Clean Window Tracks
    1. Clean window tracks for proper drainage
  17. Charge & Load Test Batteries
  18. Clean/Sanitize Fresh Tank
The only thing on that list that I'd be willing to pay someone to do is recaulk any roof fittings that need it, and that's only because I find getting all the way up on top of the roof awkward and I'm terrible at caulking neatly.
From where I’m standing, your caulking looks great!
  • Haha 5
Among my many friends and acquaintances, I can count zero who actually enjoy caulking.  My husband does a better job than i do, so he usually gets the job
 if we had to flip for it, I'd be seeking a coin with both sides head, and call tails.
Yet another reason I like butyl, where applicable. We caulk around the edges to shield, but butyl does the job.
  • Like 7
Caulk only if/when the original caulk has failed. If so, remove the majority of the old caulk before applying a new bead. Caulk on old caulk, you’re not helping yourself.
  • 4 months later...
This seems like a lotta money for things that I can mostly do myself, not to mention the 1350 mile one-way trip.
Personally, I wouldn’t want to repack my bearings, how much would it cost to have a mechanic do this?  $50/wheel? That seems reasonable. I’d grease the zerks though.
The folks on this forum seem pretty well informed and capable.
Jamie
Jamie and Sandi
New Harbor, Pemaquid Point,  Maine
2021 LEII Hull #802
Jamie
I’ve had most work done (bearings, brakes, etc) locally.  Most maintenance is generic and can be done by any experienced RV maintenance person or by the owner.  Mike
2 hours ago, Jamie Peghiny said:
$50/wheel?
With shop rates getting to the point of about $150.00 per hour, you are probably a touch low on the $50.  But around $75 per wheel would probably get it done.
p.s.  while just about any boat or regular trailer can do this job - I'd ask around a bit to get some recommendations.  Bearing service is NOT difficult.  But, if it is not done properly it can cause you some real headaches down that lonesome road.
Those guys are a lot faster than I am!
But if I could do two axles at their pace, it would be $300 a year cost. Ten years that I hope to be around say $3,000.     The Dexter NeverLubes I understand should go ten years.
So, mathamatically speaking, I am financially well ahead in getting the 5200 never lubes with their better brakes.  RIght?
I love your math and will be using it as my sales pitch for new Nev-R-Lube axles to my wife.
She'll then return the favor by letting me know what she'll be spending that saved money on!
  • Haha 4
