dewdev Posted July 27, 2025 Posted July 27, 2025 (edited) For my 2018 Elite II, I would like to find the charge wire inside the Ollie to disconnect it as part of a Lithium battery upgrade, instead of doing it at the 7 pin pigtail that plugs into the truck. Is the wire accessible inside the Ollie? A picture would be helpful. Thanks Edited July 27, 2025 by dewdev Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2027 RAM 1500 Rebel, 4 x 4; 5.7L Gas V8 Hemi; 3.92 rear axle; 4 corner air suspension Maine
Ray Kimsey Posted July 27, 2025 Posted July 27, 2025 (edited) I have a 2020 and here is where it is located. It is the wire on the right (labeled in picture with notebook paper and tape). It is on the driver side. Picture is looking forward through the hatch underneath bed next to cabinet. I disconnected and taped over the end. In the first picture the charge wire is attached in the second, I have disconnected, covered/sealed and stored next to solar shutoff. Edited July 27, 2025 by Ray Kimsey typo 2019 Ram 1500 5.7L V8, 3.92 axle ratio - 2020 LEll - Hull676
jd1923 Posted July 27, 2025 Posted July 27, 2025 25 minutes ago, dewdev said: Is the wire accessible inside the Ollie? A picture would be helpful. Should be. The trick is finding it since every old Oliver seems to be somewhat different. First thing I suggest is to text you test for voltage at your 7-blade connector to see that it is powered and which blade connects to the Black charge wire. Later after disconnecting the wire, you want to see that the same blade is no longer powered. This is the only true means to know you got the correct wire disconnected. Some have reported seeing the cable split under the bathroom vanity, so perhaps you can see where the black wire branches from there. I got lucky to find mine at the +bus under the streetside bed. Notice in the picture, the black wire at the left side of the bus where I have the screw loosened. I removed all the wiring to this bus, shortened the 3 fused + connections to the stabilizer jacks, added a more substantial + bus under the rear dinette seat for easy access. I was able to sort out all the wiring, no extra cables to the batteries, etc. In doing this, I've learned what almost every wire is for in the basement areas of Hull #113! 🤣 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted July 27, 2025 Posted July 27, 2025 (edited) 10 minutes ago, Ray Kimsey said: I have a 2020 and here is were it is located. Yes, the wiring is VERY different from 2016 to 2020 and @dewdev's is a 2018, likely to be closer to our older hull, but who knows! Edited July 27, 2025 by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
dewdev Posted July 27, 2025 Author Posted July 27, 2025 (edited) 1 hour ago, jd1923 said: Should be. The trick is finding it since every old Oliver seems to be somewhat different. First thing I suggest is to text you test for voltage at your 7-blade connector to see that it is powered and which blade connects to the Black charge wire. Later after disconnecting the wire, you want to see that the same blade is no longer powered. This is the only true means to know you got the correct wire disconnected. Some have reported seeing the cable split under the bathroom vanity, so perhaps you can see where the black wire branches from there. I got lucky to find mine at the +bus under the streetside bed. Notice in the picture, the black wire at the left side of the bus where I have the screw loosened. I removed all the wiring to this bus, shortened the 3 fused + connections to the stabilizer jacks, added a more substantial + bus under the rear dinette seat for easy access. I was able to sort out all the wiring, no extra cables to the batteries, etc. In doing this, I've learned what almost every wire is for in the basement areas of Hull #113! 🤣 This is a copy of my buss, which is different than yours. JD, any other ideas would be appreciated. Tomorrow I will check with OTT. Edited July 27, 2025 by dewdev Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2027 RAM 1500 Rebel, 4 x 4; 5.7L Gas V8 Hemi; 3.92 rear axle; 4 corner air suspension Maine
routlaw Posted July 27, 2025 Posted July 27, 2025 Amazing how different each Oliver is from year to year. On my 2015 #70 it doesn't even look remotely like any of these pics. 1 Legacy Elite II #70
jd1923 Posted July 27, 2025 Posted July 27, 2025 3 hours ago, dewdev said: This is a copy of my buss, which is different than yours. JD, any other ideas would be appreciated. Actually they look a lot alike except yours only has the 3 stabilizer jack wires. Did you test for power at the 7-blade adapter? You got to get a yes/no answer to this before doing anything else. You have a fuse all the way to the right in your picture. It looks just like the one @Ray Kimsey pointed to as his Black Charge Wire. It could be yours too. You can see how your system a 2018 is somewhere between mine a 2016 and Ray's 2020. Our Oliver has none of those two-post fuses at all. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted July 27, 2025 Posted July 27, 2025 2 minutes ago, routlaw said: Amazing how different each Oliver is from year to year. On my 2015 #70 it doesn't even look remotely like any of these pics. That's OTT for ya! I would think yours would look closer to mine since our 2016 was actually built fall of 2015 when you check the label dates on all components. But there is also some distance between #70 and #113. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Galway Girl Posted July 27, 2025 Posted July 27, 2025 For our 2019 here's where it connects under the street side bed (hatch nearer the pantry) 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
dewdev Posted July 28, 2025 Author Posted July 28, 2025 (edited) @Galway Girl My 2018 Ollie is slightly different than yours. In the picture below the red wire has a 1 amp fuse in line. Wht is that for? Sorry the picture come in upside down when coping to the foruml Edited July 30, 2025 by dewdev Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2027 RAM 1500 Rebel, 4 x 4; 5.7L Gas V8 Hemi; 3.92 rear axle; 4 corner air suspension Maine
routlaw Posted July 28, 2025 Posted July 28, 2025 @dewdev no idea what the fuse is for but allow me to add the following. On my wiring at the trailer plug the hot charge wire is black and assuming yours is the same (worth checking out) why would they change from black to red? Perhaps this is not your charging wire from TV. Also jd123 makes a good point in an earlier other thread, disconnecting at only one end still leaves the wire potentially a hot wire. IOW's disconnecting at both ends might be a better scenario. Now if I could only find my own charge wire that would be great. I still think the best method is to eliminate the charge at the source, that being the fuses (assuming they are there) pulled on the tow vehicle. Unfortunately for my new truck this part is also a mystery that even Ford mechanics don't seem to be privy to. 1 Legacy Elite II #70
Galway Girl Posted July 29, 2025 Posted July 29, 2025 23 hours ago, dewdev said: red wire has a 1 amp fuse in line. @dewdev that is the 1AMP fuse for the propane/leak detector in our case located under the dinette. 1 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
dewdev Posted July 30, 2025 Author Posted July 30, 2025 I think (based on a old Jason Essary email) that the black line going to the 2 button red auto reset breaker has the 7 pin charge wire. I think that is what @Galway Girl and their picture was referring to. Know I have one more question. Does anyone know what these wires go to in the attached photo? Thanks to all. Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2027 RAM 1500 Rebel, 4 x 4; 5.7L Gas V8 Hemi; 3.92 rear axle; 4 corner air suspension Maine
Moderators mossemi Posted July 31, 2025 Moderators Posted July 31, 2025 (edited) I think that is a picture of an automatic resetting breaker in the B+ path from the solar charge controller. Both the red/black and the solid black should run up the the wall to the Solar CC. The red/black wire eventually goes to the battery positive/B+ and the black wire ends up at the battery negative/B-. They are zip cord wires just like a lamp cord, so you can verify my thoughts by determining if the insulation is in fact joined together as it heads up the wall under the SS bed. I’m pretty sure they will be 8AWG wire. Mossey Edited July 31, 2025 by mossemi 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
dewdev Posted July 31, 2025 Author Posted July 31, 2025 (edited) Thanks @mossemi. I did confirm that they are the solar wires. I did not know that the connector was a automatic resetting breaker. @Galway Girl. I was told by OTT that the red wire with the 1 amp fuse goes to my composting toilet fan. I believe that the propane/leak detector wire (which is likely in the corrugated wire guard) is connected to the red device with the two buttoms. I will be verifying this later today. Thanks Edited July 31, 2025 by dewdev Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2027 RAM 1500 Rebel, 4 x 4; 5.7L Gas V8 Hemi; 3.92 rear axle; 4 corner air suspension Maine
Moderators SeaDawg Posted August 2, 2025 Moderators Posted August 2, 2025 On 7/28/2025 at 10:48 AM, routlaw said: own charge wire that would be great. I still think the best method is to eliminate the charge at the source, that being the fuses (assuming they are there) pulled on the tow vehicle. Unfortunately for my new truck this part is also a mystery that even Ford mechanics don't seem to be privy to. Yup. Years ago, it was easier. My 2005 Silverado has a fuse. Messed us up early on (2008) as I recall. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Galway Girl Posted August 2, 2025 Posted August 2, 2025 On 7/31/2025 at 7:48 AM, dewdev said: red wire with the 1 amp fuse goes to my composting toilet fan. Wow...that's an early composting toilet then...we don't have one. That means even between builds the factory might change which wire is for which purpose. 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
dewdev Posted August 4, 2025 Author Posted August 4, 2025 (edited) @ScubaRx had a great idea. Go to the truck fuse box and disconnect the fuse that provides power to charge the Ollie batteries (I am installing lithium batteries in the Ollie). A great idea to pull the charger wire fuse so there is no power in the line at all to the 7 pin connector. Unfortunately on my 2024 RAM there is no such fuse for power that would charge the Ollie batteries. The 2024 RAM fuses for the trailer are (1) Trailer tow backup; (2) Trailer stop/left turn signal, (3) Trailer stop/right turn signal, (4) Trailer tow park lamp. I guess I would have to remove the wire from the "Aux 12V Power" connector at the 7 pin connector, if I want to stop power from my vehicle alternate to not charge the Ollie batteries or find the wire in the Ollie to disconnect, but then there is still power in that wire. @Galway Girl and others that have converted from AGM batteries to Lithium batteries: Is the "Aux 12V power" on the 7 pin connector the wire to disable ??? Can the vehicle charge wire to the trailer stay in place when installing lithium batteries ??? Will the vehicle alternate be compromised if the wire is not disconnected ??? Thanks All Edited August 5, 2025 by dewdev Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2027 RAM 1500 Rebel, 4 x 4; 5.7L Gas V8 Hemi; 3.92 rear axle; 4 corner air suspension Maine
Moderator+ ScubaRx Posted August 5, 2025 Moderator+ Posted August 5, 2025 15 hours ago, dewdev said: @ScubaRx had a great idea. Go to the truck fuse box and disconnect the fuse that provides power to charge the Ollie batteries (I am installing lithium batteries in the Ollie). I do know the GM trucks have a trailer charging line (as well as the others) that is fused under the hood. 1 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Boilermaker Chemist Posted September 2, 2025 Posted September 2, 2025 On 8/4/2025 at 10:08 AM, dewdev said: Unfortunately on my 2024 RAM there is no such fuse for power that would charge the Ollie batteries. I would think code would require a fuse on that wire. Mike 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
Galway Girl Posted September 2, 2025 Posted September 2, 2025 On 8/4/2025 at 7:08 AM, dewdev said: Is the "Aux 12V power" on the 7 pin connector the wire to disable ??? See section 7 of the article on the upgrade ...in our 2019 EII manual it shows it as a Black Charge wire as shown in the wiring diagram and in the PICTURE below. The reason we disconnected the wire inside the 7 pin cable was to protect the alternator. Lithium Batteries they can "draw" charge current much faster than older AGM or other Lead Acid Batteries...so ultimately they would try to draw way more power than the truck wiring would provide. (To install the DC/DC converter you'll run dedicated lines back to the DC/DC charger.) Full battery upgrade is here...including the section 7 about disabling the charge wire. https://4-ever-hitched.com/blog-articles/f/lithium-battery-upgrade Step 7; Disable the 7 Pin Charge Line: We will be installing a new DC/DC charger into our Oliver EII. But before we do that install we need to disable the current charging wire that runs from the 7 pin cable on the tongue of the Oliver. That 7 pin connector is the one that plugs into the back of the truck for lights, brake lights, emergency brake power. Inside the 7 pin cable there is a BLACK wire that provides 12V (B+ ) from the truck battery/alternator B+ all the way back through the trailer, through a 20A breaker and back to the batteries via the 12V Bus bar in the trailer. We will not be using that (Black) charge line for the trailer an longer. We disabled that line on the 7 pin connector by putting heat shrink coating over the screw terminal on the black B+ wire conductor and also taping up the screw lead the body. We reassembled the conductor and tested that no 12V was present on the wires inside the trailer. Wiring Digram for Oliver EII 7 Pin To disable the Charge Wire (BLACK) from the 7 pin, remove the cover and disconnect the wire from the connector by taping up the wire and putting it back inside the cover. Don't cut the wire in case you need to use it in the future. 3 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
Moderators Mike and Carol Posted September 2, 2025 Moderators Posted September 2, 2025 11 hours ago, Galway Girl said: To disable the Charge Wire (BLACK) from the 7 pin, remove the cover and disconnect the wire from the connector by taping up the wire and putting it back inside the cover. Don't cut the wire in case you need to use it in the future. Exactly what I did when we went with lithiums. 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
