Geronimo John Posted yesterday at 12:27 AM Posted yesterday at 12:27 AM (edited) 4 hours ago, Snackchaser said: As Jd suggested, the batteries are older and you could upgrade to lithiums. That would be a big improvement. However, unless there are pages missing from the manual, it looks like your converter is for lead acid batteries only The manual I posted above is for our 2018 OE2 and his is older than ours. Our units do/did not have the lithum switch... unless it was upgraded by someone that bought 12V LA's.... not likely.... So if going Lithium, at a minimum, an updated master board would be needed. If purchasing one, and going lithium I suggest upgrading from the 4045 (45 amp converter) to the 4060 (60 amp converter). That extra 15 amps makes a nice reduction in charging time. Or if budget allows, an upgrade into the Victorn lines if you are into neat gizmology. 1 hour ago, Mike and Carol said: Great news! Overnight, the batteries charged and are now at 12.2 volts. DBL-R: Not necessarily. Without a smart charger, a trick simple test will tell you very clearly. Both tests are founded on Watt's Law: Watts = Volts xAmps?) It says for a given wattage, with in reason you can power up a load with various voltages and amperages so long as their product = the Watts of the load. If your battery is surface charged, it may flow the optimum amps and volts off the surface initially. But then seconds later the voltage drops, the load in watts does not change, so the amps must increase. In your case you are looking at a voltage that can change, a fixed load, and variable amps as a result. As the volts decrease, the amps must increase.... until the buse blows. Two ways to test your battery for load carrying ability and health: If you have an Inverter (Changes 12V DC battery power into 120V AC power): First, unplug from shore power, turn on the inverter and hook up your volt meter to your batteries. Have someone start your microwave while you monitor the voltage. If the microwave tries to run but shuts off quickly, you have a surface charge. Only hope is to try using a smart charger to desulfate as mentioned above. If you don't have an Inverter, just cycle the front jack. If the batteries can raise and lower a full cycle then you may just be the lucky guy of the day. But if it slows down and stops, or blows the 30 amp jack fuse.... Time to desulfate.... Also keep in mind that a fully charged deep-cycle LA battery typically tests at 12.7V to 13.0V (for 12V systems) after resting for several hours. So more charging is also needed. Just be careful not to boil the batteries with too much charging amps or time. GJ GJ Edited yesterday at 12:40 AM by Geronimo John 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
DBL-R Posted yesterday at 12:46 AM Author Posted yesterday at 12:46 AM Thank you, I am using a Deltran battery tender, it’s a smart charger and it has not fully charged the batteries (yet). My panel does not match what was in the manual!
Geronimo John Posted 12 hours ago Posted 12 hours ago (edited) 17 hours ago, DBL-R said: I am using a Deltran battery tender, it’s a smart charger and it has not fully charged the batteries (yet). That is good. I'm sure you already have, but out of an abundance... Since this is taking some time, recommend you periodically monitor battery water and top off as necessary with distilled water. GJ Edited 12 hours ago by Geronimo John TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Steph and Dud B Posted 12 hours ago Posted 12 hours ago 17 hours ago, DBL-R said: My panel does not match what was in the manual! If the previous owner accidentally connected the batteries backwards, even for a second, the reverse polarity fuses will blow and your converter won't charge the batteries. So, first, verify that your batteries are connected properly: positive cable (usually red) connected to the positive battery terminal. Just to be sure. Next: Those 2 green 30 Amp fuses at the bottom of your photo appear to be the reverse polarity fuses that are suspect. Pull them and test them. If you don't know how to test them, just buy 2 new 30 Amp fuses and replace them. See if that solves your problem. Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Geronimo John Posted 12 hours ago Posted 12 hours ago Also the terminals appear that they could use a cleaning as well. 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
dewdev Posted 11 hours ago Posted 11 hours ago (edited) 22 hours ago, dewdev said: @DBL-R Based on my 2018 wiring diagram, I have 3 - 25 (or 30 in your case) amp fuses which are called Reverse Battery Fuses. Strange that your system calls for 30 amp. As indicated in this post, check the batteries for property wiring and then check the Reverse Battery Fuses to make sure they are not blown. Not sure why you do not have 3 fuses in place. It might be a good idea to call OTT to confirm the 3 fuses in your Ollie are required. Good luck @DBL-R I updated my post. Again, suggest that you call OTT to find out if you in fact you should have 3 Reverse Battery Fuses in place. Edited 11 hours ago by dewdev 2018 Oliver Elite II, Twin Bed, Hull #354, new Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
DBL-R Posted 11 hours ago Author Posted 11 hours ago Everything appears to be wired correctly and the fuses are good. I spoke with OTT and other than the batteries loosing voltage, there is no way for me to test it. The suggested taking it to a service center and having them do diagnostics. Since it is in the garage, on a battery tender, and not winterized I will do that this spring. Since it is new to us, it will be worth a piece of mind to have it check out. While we are at is does anyone know the make and model number for the shocks? I want to replace those and all I could find was the Monroe 555001, not sure if that is correct or not. I am waiting on a call back from the parts department. Thank you all for you assistance. Ron
Moderators topgun2 Posted 10 hours ago Moderators Posted 10 hours ago (edited) Ron - there are a bunch of posts on this subject. I found THIS ONE by using the Search function at the top of the page. Bill p.s. since you are fairly new to the Forum - all you have to do is left click on "this one" above and it will take you to a post on the subject. Edited 10 hours ago by topgun2 added detail 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Galway Girl Posted 8 hours ago Posted 8 hours ago 2 hours ago, DBL-R said: While we are at is does anyone know the make and model number for the shocks? These are the ones shipped from the factory with the trailer: Bulldog Shocks are the ones folks tend to 'upgrade' to if replacing the OEM shocks. Bulldog Shock Parts to Replace Monroe 555001 (OEM) Bulldog part number: HD1213-0656 Price about $150.00 for 4 depending upon supplier. Monroe (Yellow on Top in Pix) Bulldog on Bottom. Link to 4 states truck parts: https://www.4statetrucks.com/bulldog-hd-shock-absorber-replaces-555001-19-050000007 Craig 1 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
jd1923 Posted 6 hours ago Posted 6 hours ago 23 hours ago, DBL-R said: Thank you, I am using a Deltran battery tender, it’s a smart charger and it has not fully charged the batteries (yet). My panel does not match what was in the manual! Battery tenders on 4 LA batteries down to 9V will take several days to charge as you are witnessing. interesting how most Olivers are different. Your hull #99 and our #113 both have Blue Sky SCs, but my breaker and shunt were wired on the right side. Never seen a 120VAC panel where breaker #1 isn’t the 30A main and ours has only 6 breakers. They wired the microwave with the 110V outlets on the same breaker. Yours is written “Charger” they wrote “Converter” on ours! Since I replaced the converter with a Victron inverter/charger, I now use the 6th breaker for what was the microwave circuit, now an air-fryer/oven. I still have the original converter installed as a backup just in case, with the hot/black wire disconnected. Every Oliver is unique, yet many similarities. I use many 2017 electrical and plumbing schematics that were not available for 2016 and they’re often close enough to figure things out! I’d say new batteries are in your future and there are many posts on bettering the electrical wiring and other systems. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
2008RN Posted 2 hours ago Posted 2 hours ago 8 hours ago, DBL-R said: While we are at is does anyone know the make and model number for the shocks? I don't mean to overwhelm you. While you are under the Oliver looking at the shocks, Pay close attention the leaf springs. Look to make sure the leafs are not sitting flat on one end or the other and/or over-sprung. If they are it could cause the shocks to wear out prematurely. If they are there is a huge topic on leaf springs ( more like a book). Remember to just take one thing at a time, you have an older trailer, but is built to last. There is a ton of information on this website, and people that care about there Olivers. Happy Travels. Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648
