I’ve seen notifications on LinkedIn and X this morning for a new Oliver model, the X23.  It’s described as an off-road trailer with blacked out trim and a 48V power system.  Nothing on the Oliver home page.  Anyone else seen anything?  Mike
It’s on Facebook, too.  Apex X23.
Yes on FB, but no interior pics or specs.  I guess we need someone who lives in the Austin area to go to the show and check it out and report back what they saw, lol.
2022 Elite II, Hull #1271
Picked up 10/12/22
2024 F250 King Ranch FX4, 7.3 gas, 3:73.
2021 FX4 Expedition, Heavy tow package, 3:73, Anderson Hitch.
From one pic I saw, it looks like it might be running a 48V Houghton AC/Heat pump.
Here you go…..touch pic and scroll left.🤔
https://www.instagram.com/p/DX1y0pnkuH2/?igsh=MXRicTlrancwZXloOA==
Edited by Patriot
It is.
Everybody note...
The new Oliver ApeX-23 is designed and advertised to be an off-GRID trailer NOT an off-ROAD trailer.
  • Thanks 6
Those tires have quite an aggressive tread, they look like something you’d find on an overland rock crawler! I like them.
Edited by Tom and Doreen
We’re just an hour and half from Austin, had I known I would have made plans to see it.  Grandkids today and a busy Sunday tomorrow…..
Looks cool
is it the original hull ? Or a new hull ?
Robert E
2022 LE II , LIthium Pro, 2018 F150 XLT 4WD 2.7 EcoBoost , 355 gears, tow package,36 gallon fuel, factory brake controller, transmission cooler
From what I can see, it's a dolled up LE2 hull aiming to attract the overlander crowd. The 48V electrical system is interesting but would make finding accessories, etc. more difficult and more expensive. Will there be a DC to DC converter and 12V circuits for things like lights, USB ports, and 12V outlets?
Love the new windows and hope they're available as upgrades some time in the future, though I'm not a real fan of the blackout treatment. Very interested in learning more about the electrical system, battery capacity as well as what looks to be a beefed up suspension.
Running gear looks the same , just a wheel & tire change and some black accents.  At least they are trying something different.
If they changed up the suspension for better off road that would make a difference.
14 hours ago, ScubaRx said:
Everybody note...
Looking at their new Instagram posts, it certainly looks like they're marketing it as an off road trailer.
"Most trailers stop where the road does. Not this one- Built for the Road That Ends."
From what I've been reading about 48V systems they are most effective delivering power to high amperage devices like the A/C, fridge, and induction cooktops. With the heat pump, compressor fridge, and an induction cooktop, would there be any need for propane at all in this new trailer? They do make 48v water heaters with 1000-2000W heating elements.
Low amperage devices like lights, USB, etc. are often on 12v circuits powered by a DC to DC voltage converter in a 48v system, so there's no real gain there. (It is possible to get things like 48v lights, but they are more expensive.)
I wonder what the boondocking sustainability difference would be between our LE2, which has the 640Ah 12v lithium system, 30# propane tanks, and LP fueled furnace, fridge, water heater and stove vs. this new 48v model set up as all-electric? As it is, we've never gotten below 50% SOC while camping in good sun and our propane lasts for weeks.
Fresh water and holding tanks would still be limiting factors with this new trailer. I suppose if you had the composting toilet and were camped in a sunny place that allowed emptying gray water on the ground you could stay virtually as long as your fresh water supply allowed, but that's kind of an edge case for a lot of us. On balance, I see the main advantage of the 48v system over our 12v/propane system being increased A/C run time.
The soundtrack suggests trouble ahead, and the footage does seem to suggest off-road more than off-grid. That said -- my Ollie hasn't disappointed me at all, and I've had next-to-no troubles * in  terms of being able to spend weeks at a time off-grid. Of course that requires preparation and contingency plans. Having walked through creeks and stepped into holes several feet deep, I don't think I would want to ford a creek with my Oliver, unless it was an improved surface with known qualities. Still, there are lots of folks who have a bigger yearning for adventure.  I think this will appeal to those who want to go whole-hog off grid and off road. Can this model go longer than my LE2's 3-4 weeks off grid?
* The one exception to my 'no troubles' was a few years ago when I had a propane leak that a local North Dakota TT repair facility failed to correctly identify and fix; in that case, I was left without propane powered refrigerator, hot water, or heater for several months, out west on the road into October.
my Oliver has camped here
Some things I was able to pull from a blurry pic of the brochure- Alcan springs are standard, the 48v battery is 100ah, and it seems only the AC is 48v with everything else being 12v. One really interesting option is a 960 watt solar awning. Would love to have that!
I see you can get the solar awning with the Platinum Pro package, too. It looks pretty cool, but I have to wonder if it will fail eventually from being repeatedly rolled/unrolled.
That is my initial question, as well -- but materials science is rapidly changing. As an example,
"Organic solar cells are made from very thin layers of carbon-based (organic) materials, usually only about 100 nanometres thick. Originally designed as an inexpensive alternative to silicon-based solar panels, they are flexible, lightweight, and more sustainable than other options.   Unlike the OPV film-based version, organic photovoltaic textiles can be stitched onto fabric, giving them greater application potential, such as the tensile fabric architecture of canopies and sails." -- https://perfectsenseenergy.com/solar-fabric/
They dropped a video this morning, mainly just advertising splash
FWIW my opinion so far
Color scheme:
Not my taste. The black trim will take more sun damage and takes away from the elegance of the design language. It's a hard black and white which is way to constrasty, if they could have gone with a softer black it would work but I think the windows set it to a hard black. Also black shows up scratches and dirt like nobody's business. That black AC will absorb heat and age faster
Fully opening window:
From a 2026 owner; a step backwards. I can't tell you how easy and convenient it is to crack the bedside window at night. The sliders would be more challenging I think, and this one, you'd have to get your hand around the window shade and push it somehow, assuming the levers are open. I really don't understand why people want a fully opening window, it doesn't offer anything new
48V system
Been in a lot of discussions of this because the Cybertruck went 48V. My engineering opinion; it doesn't offer you anything. The only technical improvements are thinner battery cables and better power/torque delivery for motors. But they will still have to supply 12V as not every device will support 24V, and for the 12V cig ports. So it'll be a stacked/split system, mostly likely they'll just also have a series 24v connection to the battery, and split 12V rails for those.
I could see the power jacks benefiting, assuming a 48V system. Oh maybe the inverter too - that would be more efficient. Who knows, maybe 48V lets them get to a 4k inverter which honestly would be nice (Xantrex doesn't have one AFAIK though)
Offgrid tires
Look cool, but probably lower efficiency, harder to replace (?), and since they don't provide motor traction of limited use.
Cost:
Probably $$$, I kind of doubt they'll have all those parts in black from the supplier
May be an image of snowplow and text
Sierra EV AT4 2026 (max range 530 mile pack)
Ah just noticed the spec sheet link above
  • Why in the heck is this CHEAPER than the Platinum Pro I got? Probably because the base battery is 400Ah and it doesn't include extra goodies. Fully specced it'll be up there
  • Power is now the EcoFlow. I like the control box. Not super fond of fancy displays
  • They listened to the peanut gallery "Bulldog HD Shocks & Alcan Leaf Springs" 😊
    • Four or five leaf springs?
  • 48V Houghton AC
  • Flex solar is cool. Problem is getting to use it, I'm usually either in shade or there's too much wind
  • How in the heck does the Pro have a 1,360W solar? It must come standard with the solar Girard
On the 2027 they made a bunch of changes
  • I like the stainless sink - kind of wish mine had that instead of molded in. I might do that mod
  • https://cdn2.olivertraveltrailers.com/wp-content/uploads/2026/05/02105828/8K5A6786-1024x683.jpg
  • Why is the bluetooth speaker back by the stove? On my recommendation they moved to the TV - you don't want a speaker in the heat. This was probably in proto before that mod, or maybe they did that just for me?
  • This goes back to the framed in window shades. I love my roller shades fwiw, the trim color valances add a lot of nice design. Looks like a 2026 model only, too bad I think its an improvement
  • I think @jd1923 made this mod? Unfortunately the dinette isn't really that comfortable any way you cut it
    https://cdn2.olivertraveltrailers.com/wp-content/uploads/2026/05/02110222/8K5A6566-1024x683.jpg
Well anyhow glad to see them adding models. Fortunately I don't have buyers remorse, I'm upgrading to Alcan/Bulldog myself, and in theory I could upgrade to Girard solar too. But with 220 kWh on the truck with 10kW available to the trailer I don't need any extra solar. Before somebody asks - no a 1.3 kW panel won't charge the truck worth beans.
