johnwen Posted July 12 Posted July 12 (edited) Has anyone replaced their white plastic pipe with pex? These washboard roads on our Alaska trip are causing the retaining clamps that go around the female connector to come loose. The rubber/plastic clamps holding them to the pvc mounting boards are coming loose as the result of the the intense shaking....the screws are stripping out and allowing the connections to loosen. I'm surprised they didn't loosen enough to create a leak. I just think permanent pex connectors would be a better fix. Any reason to not replace. with pex? I haven't studied the layout to see where all that pipe is used...water heater, pump, etc, so I expect difficulties along the way. Just looking for a little advice now and I won't think about starting this project until stationary for a couple of weeks this winter. Might be a good time then to do my furnace ductwork replacement/reconfiguration project :) Thanks for all help, John Edited July 12 by johnwen spelling 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
Moderator+ ScubaRx Posted July 13 Moderator+ Posted July 13 @johnwen be careful of rigid connections to things that move or vibrate like at the water pump. 1 2 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Galileo Posted July 13 Posted July 13 I don’t think I’ve seen any white plastic (PVC) pipe - only PEX. Where is there PVC? 2 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Boudicca908 Posted July 13 Posted July 13 (edited) 18 hours ago, johnwen said: The rubber/plastic clamps holding them to the pvc mounting boards are coming loose as the result of the the intense shaking....the screws are stripping out and allowing the connections to loosen. I'm surprised they didn't loosen enough to create a leak. Last year I found the same issue with the screws coming out of the pvc mounting boards. Service had no suggestions to offer except to replace the pvc mounting board. I don't think the pvc material is the right thing to use for this mounting board, but that's what they use. My brother and I discussed this issue and came up with a simple solution. On my Oliver (and others might vary) there is enough space below the pvc board to place a narrow strip of thin plywood -- just long and wide enough to use to sit below those locations and to reinstall some longer screws through those clamps. I keep checking the existing clamps, and have tried adding some superglue in with the screws, and that has worked on two of them, for now. I don't want to have to take everything out to fix this issue. I don't have the tools to cut this piece of wood, but that is my plan. 2 hours ago, Galileo said: Where is there PVC? @Galileo on an Elite II Twin Bed model, it's below the curb side bed close to the stove location, where the plumbing equipment is mounted. Edited July 13 by Boudicca908 1 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
Townesw Posted July 13 Posted July 13 (edited) Look at using King StarBoard for a better waterproof mounting board. It can be cut and shaped using regular woodworking tools. I get mine from McMaster Carr but there are less expensive places to get it. A shipment from McMaster Carr usually arrives the next day depending on where you are. I think I have ordered some from TAP Plastics https://www.tapplastics.com/product/plastics/cut_to_size_plastic/king_starboard/526?gad_source=1&gad_campaignid=21137328659&gbraid=0AAAAAD_hg_I8XrL-S3Ima0ZSWbIsffsZk&gclid=CjwKCAjwmdLSBhANEiwAkREMN3hswfK8uVUE38-cgCmjAoCwEzeXRTPZLhht1xFJJ1A8-NIIMHzIkhoC2_gQAvD_BwE I don’t know why that link has to have so much gibberish in it. Bill Edited July 14 by Townesw 1 2 Bill and Martha 2018 LEII Hull 313 Original owners 3/14/2018 2019 Chevrolet 2500HD Duramax
Geronimo John Posted July 14 Posted July 14 7 hours ago, Boudicca908 said: My brother and I discussed this issue and came up with a simple solution. On my Oliver (and others might vary) there is enough space below the pvc board to place a narrow strip of thin plywood -- just long and wide enough to use to sit below those locations and to reinstall some longer screws through those clamps I suggest using Riv-Nuts and bolt them down if you are having such a problem. GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
johnwen Posted July 14 Author Posted July 14 12 hours ago, Galileo said: I don’t think I’ve seen any white plastic (PVC) pipe - only PEX. Where is there PVC? It's plastic, not pvc...by water pump, accumulator and shower. You should have it also since you have a 2022 model :) John 1 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
Galileo Posted July 16 Posted July 16 On 7/13/2026 at 10:32 PM, johnwen said: It's plastic, not pvc...by water pump, accumulator and shower. You should have it also since you have a 2022 model 🙂 John I guess I’ll look closer next time. (I go in that area so seldom because it’s a PITA to wedge up the mattress topper, cushions, access cover just to reconfigure the valves to winterize/boondock/nornal.) I wonder if the “engineers” that put valves, breakers, and fuse holders in places that require moving bedding and cushions might have come up with better ideas if they had taken a prototype out first for a few months - changing configurations and the like. 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
jd1923 Posted July 17 Posted July 17 (edited) On 7/12/2026 at 5:41 PM, ScubaRx said: @johnwen be careful of rigid connections to things that move or vibrate like at the water pump. Yes, soft water lines must be installed in and out of the water pump. OTT used some kind of 'white' suction line from the fresh water tank. I'm not sure of the difference between this and PEX except the tubing is translucent and you can see the water within. You can see examples of both tubing in the picture I took after installing motorized ball valves. Edited July 17 by jd1923 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Galileo Posted July 17 Posted July 17 I forget the name/chemical shorthand - for the stuff that’s common in mobile homes. We used to have people looking for it at the hardware store I worked at. I think it’s the MH (manufactured Housing) industry little joke they play on folks. It’s -just- different enough size-wise that PEX and Shark Bite fittings don’t work on it. I wonder if that’s the “translucent suction like” you mention and show. My water pump is acting kinda lackluster at the moment - so it’s in my list of things to tear into when I’m not occupying the trailer. I’ll attend to the “plastic” piping at the same time. I don’t know if I’m feeling ambitious enough to do the electric valve upgrade like @jd1923 did. I guess having to tear up the king bed to change the valves at the start and end if the season has become a big enough PITA to motivate me. 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
jd1923 Posted July 17 Posted July 17 18 minutes ago, Galileo said: I don’t know if I’m feeling ambitious enough to do the electric valve upgrade like @jd1923 did. I guess having to tear up the king bed to change the valves at the start and end if the season has become a big enough PITA to motivate me. For us it's not a seasonal event. We use the boondocking valve configuration every week or two since we most often boondock in remote areas and pump extra fresh water from the 35-gal water tank in our truck bed. We also have 12" heavy foam mattresses and thankfully have not had to move a bed once while camping since we installed our motorized valves day-one! 😎 Got this idea from Steve @ScubaRx when I was a Forum Newbie and it has been an upgrade worth its weight for sure! At the same time, we did not want to live with the basic OEM water pump and installed a Made-in-USA Remco variable-speed pump which does not require an accumulator. They claim it's quieter, but I'd say it has a different sound as it increases speed to provide better flow. This pump can run dry for hours to and is generally self-priming given water is nearby in the plumbing. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators mossemi Posted July 18 Moderators Posted July 18 On 7/12/2026 at 5:53 PM, johnwen said: The rubber/plastic clamps holding them to the pvc mounting boards are coming loose as the result of the the intense shaking....the screws are stripping out and allowing the connections to loosen. I have had some success with threaded insert nuts in the OTT installed PVC Foam Board. They are very effective on the horizontally mounted foam board, such as the water pump location. Mossey 1 4 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Galileo Posted July 23 Posted July 23 On 7/13/2026 at 10:32 PM, johnwen said: It's plastic, not pvc...by water pump, accumulator and shower. You should have it also since you have a 2022 model 🙂 I haven’t looked at or around the water pump or accumulator yet - but I did notice the white “plastic” pipe that the San-T-Flush is plumbed with has PEX style fitting and clamp rings, and is stamped “SharkBite” - which is big in PEX, so I’m guessing it’s just a white or off-white PEX. I know we had PEX in red, blue, AND white(ish) at the hardware store I worked at. 1 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Hokieman Posted July 25 Posted July 25 (edited) On 7/12/2026 at 5:53 PM, johnwen said: Has anyone replaced their white plastic pipe with pex? These washboard roads on our Alaska trip are causing the retaining clamps that go around the female connector to come loose. The rubber/plastic clamps holding them to the pvc mounting boards are coming loose as the result of the the intense shaking....the screws are stripping out and allowing the connections to loosen. @johnwen I’m wondering if there are some misunderstandings of your original question. I understand your issue is the connectors are shaking loose. Yes, that’s happened to me on my 2021 model as well. My pipes are white, Sharkbite brand PEX-b, with the same plastic connectors. I assume yours are too. The problem isn’t the pipe type, it’s the connectors. I have replaced many of my plastic connectors and used PEX copper crimp rings, because I already had the tool to do home repairs. This solves the loose connection problem, but sometimes the plastic elbows break. I’ve only had one break while camping, and fortunately a Home Depot was within an hours drive. .There are also other types of clamps such as stainless PEX clamps, which require a different tool. Since my crimp ring tool is really big and heavy, and I cannot get it into some small spaces, I leave it at home and carry a half dozen various Sharkbite push-in quick connects and a few spare pieces of PEX-b pipe for campsite repairs. There are threads in this forum where some owners have replaced elbows with brass, some have replaced all with Sharkbite quick connects, available in plastic or brass. There are several ways to fix your loose connection problem, just depends on your preference, but you should not need to replace your pipes.. All of these fittings and pipes are readily available at stores like Ace, Lowes, Home Depot, etc. Sometimes we are camping too far from such conveniences, which is why I carry the spares. I haven’t had any clamps pull loose yet, but that shouldn’t be difficult to repair on the road. It’s got me thinking about better ways to do it though. Edited July 25 by Hokieman Typos 3 “Ramble” - 2021 Legacy Elite II #797; 2020 Ford F-250. Former owner of 2019 Oliver Legacy Elite #431. Blairsville, GA
johnwen Posted July 25 Author Posted July 25 Hokieman, This is good news. I didn't know about the type a pex, now I do. I'll probably do what you did and not worry about them coming loose again. Thanks for the help! 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
