Has anyone replaced their white plastic pipe with pex?  These washboard roads on our Alaska trip are causing the retaining clamps that go around the female connector to come loose.  The rubber/plastic clamps holding them to the pvc mounting boards are coming loose as the result of the the intense shaking....the screws are stripping out and allowing the connections to loosen.  I'm surprised they didn't loosen enough to create a leak.  I just think permanent pex connectors would be a better fix.  Any reason to not replace. with pex?  I haven't studied the layout to see where all that pipe is used...water heater, pump, etc, so I expect difficulties along the way.  Just looking for a little advice now and I won't think about starting this project until stationary for a couple of weeks this winter.  Might be a good time then to do my furnace ductwork replacement/reconfiguration project :)
Thanks for all help,
Edited by johnwen
spelling
ALAKAZARCACOFLGAIDILINIAKSKYLAMEMDMAMIMN
  • The title was changed to Replacing white plastic pipe with pex...
@johnwen be careful of rigid connections to things that move or vibrate like at the water pump.
I don’t think I’ve seen any white plastic (PVC) pipe - only PEX.
Where is there PVC?
King Bed Floorplan
electronics package
Truma Aqua-Go
LOUD Dometic Penguin A/C
LevelMate Pro+
(17.9mpg towing, 35mpg clean)
RealTruck hard tonneau cover
Rove R2-4K DashCams
Last year I found the same issue with the screws coming out of the pvc mounting boards. Service had no suggestions to offer except to replace the pvc mounting board. I don't think the pvc material is the right thing to use for this mounting board, but that's what they use. My brother and I discussed this issue and came up with a simple solution. On my Oliver (and others might vary) there is enough space below the pvc board to place a narrow strip of thin plywood -- just long and wide enough to use to sit below those locations and to reinstall some longer screws through those clamps.  I keep checking the existing clamps, and have tried adding some superglue in with the screws, and that has worked on two of them, for now.  I don't want to have to take everything out to fix this issue. I don't have the tools to cut this piece of wood, but that is my plan.
2 hours ago, Galileo said:
Where is there PVC?
@Galileo on an Elite II Twin Bed model, it's below the curb side bed close to the stove location, where the plumbing equipment is mounted.
Edited by Boudicca908
my Oliver has camped here
Look at using King StarBoard for a better waterproof mounting board. It can be cut and shaped using regular woodworking tools. I get mine from McMaster Carr but there are less expensive places to get it. A shipment from McMaster Carr usually arrives the next day depending on where you are.
I think I have ordered some from TAP Plastics
https://www.tapplastics.com/product/plastics/cut_to_size_plastic/king_starboard/526?gad_source=1&gad_campaignid=21137328659&gbraid=0AAAAAD_hg_I8XrL-S3Ima0ZSWbIsffsZk&gclid=CjwKCAjwmdLSBhANEiwAkREMN3hswfK8uVUE38-cgCmjAoCwEzeXRTPZLhht1xFJJ1A8-NIIMHzIkhoC2_gQAvD_BwE
I don’t know why that link has to have so much gibberish in it.
Edited by Townesw
Bill and Martha
2019 Chevrolet 2500HD Duramax
I suggest using Riv-Nuts and bolt them down if you are having such a problem.
Where is there PVC?
It's plastic, not pvc...by water pump, accumulator and shower.  You should have it also since you have a 2022 model :)
On 7/13/2026 at 10:32 PM, johnwen said:
It's plastic, not pvc...by water pump, accumulator and shower.  You should have it also since you have a 2022 model 🙂
I guess I’ll look closer next time.
(I go in that area so seldom because it’s a PITA to wedge up the mattress topper, cushions, access cover just to reconfigure the valves to winterize/boondock/nornal.)
I wonder if the “engineers” that put valves, breakers, and fuse holders in places that require moving bedding and cushions might have come up with better ideas if they had taken a prototype out first for a few months - changing configurations and the like.
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
Yes, soft water lines must be installed in and out of the water pump. OTT used some kind of 'white' suction line from the fresh water tank. I'm not sure of the difference between this and PEX except the tubing is translucent and you can see the water within. You can see examples of both tubing in the picture I took after installing motorized ball valves.
Edited by jd1923
I forget the name/chemical shorthand - for the stuff that’s common in mobile homes. We used to have people looking for it at the hardware store I worked at. I think it’s the MH (manufactured Housing) industry little joke they play on folks. It’s -just- different enough size-wise that PEX and Shark Bite fittings don’t work on it.
I wonder if that’s the “translucent suction like” you mention and show.
My water pump is acting kinda lackluster at the moment - so it’s in my list of things to tear into when I’m not occupying the trailer. I’ll attend to the “plastic” piping at the same time.
I don’t know if I’m feeling ambitious enough to do the electric valve upgrade like @jd1923 did. I guess having to tear up the king bed to change the valves at the start and end if the season has become a big enough PITA to motivate me.
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
For us it's not a seasonal event. We use the boondocking valve configuration every week or two since we most often boondock in remote areas and pump extra fresh water from the 35-gal water tank in our truck bed. We also have 12" heavy foam mattresses and thankfully have not had to move a bed once while camping since we installed our motorized valves day-one! 😎 Got this idea from Steve @ScubaRx when I was a Forum Newbie and it has been an upgrade worth its weight for sure!
At the same time, we did not want to live with the basic OEM water pump and installed a Made-in-USA Remco variable-speed pump which does not require an accumulator. They claim it's quieter, but I'd say it has a different sound as it increases speed to provide better flow. This pump can run dry for hours to and is generally self-priming given water is nearby in the plumbing.
I have had some success with threaded insert nuts in the OTT installed PVC Foam Board.  They are very effective on the horizontally mounted foam board, such as the water pump location.
I haven’t looked at or around the water pump or accumulator yet - but I did notice the white “plastic” pipe that the San-T-Flush is plumbed with has PEX style fitting and clamp rings, and is stamped “SharkBite” - which is big in PEX, so I’m guessing it’s just a white or off-white PEX. I know we had PEX in red, blue, AND white(ish) at the hardware store I worked at.
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
@johnwen   I’m wondering if there are some misunderstandings of your original question.   I understand your issue is the connectors are shaking loose.  Yes, that’s happened to me on my 2021 model as well.    My pipes are white, Sharkbite brand PEX-b, with the same plastic connectors.   I assume yours are too.  The problem isn’t the pipe type, it’s the connectors.   I have replaced many of my plastic connectors and used PEX copper crimp rings, because I already had the tool to do home repairs.   This solves the loose connection problem, but sometimes the plastic elbows break.   I’ve only had one break while camping, and fortunately a Home Depot was within an hours drive.   .There are also other types of clamps such as stainless PEX clamps, which require a different tool.    Since my crimp ring tool is really big and  heavy,  and I cannot get it into some small spaces, I leave it at home and carry a half dozen various Sharkbite push-in quick connects and a few spare pieces of PEX-b pipe for campsite repairs.    There are threads in this forum where some owners have replaced elbows with brass, some have replaced all with Sharkbite quick connects, available in plastic or brass.    There are several ways to fix your loose connection problem, just depends on your preference, but you  should not need to replace your pipes..   All of these fittings and pipes are readily available at stores like Ace, Lowes, Home Depot, etc.    Sometimes we are camping too far from such conveniences, which is why I carry the spares.   I haven’t had any clamps pull loose yet, but that shouldn’t be difficult to repair on the road.   It’s got me thinking about better ways to do it though.
Edited by Hokieman
Typos
  • 5 weeks later...
I second the PITA!  I did figure out on our recent trip I can fold the mattress from front to back (with bedding in place) and the frame on the window blinds will hold it in place while I get into the front compartment.
2022 LE II Hull #1120, 2023 Tundra 4x4
When I installed my accumulator tank in my old #110, I put a new mounting board up for it, I think it was PVC board maybe.  Anyways, my first attempt to glue it to the fiberglass hull near the water pump did not hold long.  I then tried Gorilla Heavy Duty Construction Adhesive (white).  Oh man, was I impressed with that.  That board has not moved since, and may never. I've used it now on other projects.  It seems good to me.
I'm also surprised that the remainder of the adhesive, in the opened tube, has not hardened up yet, nearly two years later.  Then again, I keep it in the air conditioned house.
I need to add a small tube or two of this to my tool packing list for long travels.
Chris
o-o  2016 Legacy Elite II (demo) - Hull #110 -"Rock'in 110"
o-o  2024 Ford F-250 Lariat, 7.3L Godzilla gasser
o-o  Augusta, Georgia
Yeah pain to get to the valves for sure. In the ‘26 layout its well thought out at least. I think they designed it to easily switch between regular use (either city or pump) and boondocking mode (pull water from jugs into the tank). The two modes are reversals of the other, just switch all the valves to the other setting, don’t need the graphic. Winterizing/sanitizing are the oddballs but that doesn’t happen a lot
They could do a Nautilus panel but it would involve a lot of extra plumbing which is more places for problems. I think it’s a fine solution, the bed is light.
Sierra EV AT4 2026 (max range 530 mile pack)
"Well thought out?" Any need to move beds and bedding is not a good design. @ScubaRx was first to install motorized ball valves! I believe Steve has his switches outside somewhere. I installed them right under the bed, so Chris throws the switches after I run the hose (the third switch/valve is used to drain the fresh tank). Our 12" mattresses are quite heavy and Chris is particular about the sheets/bedding. I don't touch the beds when made, only when home for mods when the sheets are in the laundry!
Notice the underbed duct delete too and the addition of a return duct air filter! 😎
@Dennis and Melissa recently blew the fuse for their front jack. Seeing the (extra) fuse at the front jack, he didn't think about three fuses under the streetside bed. Who would? Honestly, only some book-smart engineer in China, that never in his life traveled in an RV, could find a more illogical place for these fuses!
We have yet to have to move our beds while camping. See my mod post below. It's worth the work, at least it has been for us! 😎
Water Tank.jpgSome hand carry water jugs. But we always have an extra 35 gallons in the truck bed and we fill via the "boondocking" valve configuration about every other week when camping.  I thought I was the only one who added this extra FWT, but recently @FloraFauna wrote, "wish I had opted for 40 or 45 gallons." I bring 25' and 10' hoses and together 35 ft will get from the truck bed to the Oliver rear while hitched.
I could not see hand-carrying water (or moving the bed), for something we use so often when boondocking. As soon as one of us hears the water pump gurgle, start to take air, we'll pump in about 20 gallons, saving the remainder for a couple days later. Double your fresh water supply, will allow you to double your stay! 😍
Edited by jd1923
I hear ya, but unfortunately I’m corrupted by spending the last 32 years continually discussing what ‘good design’ is 😅
There’s many different types, ‘design for test, design for mfg, design for repair, design for usability … ‘ What you really mean is it has poor accessibility design. Agreed, or at least it’s not optimal. However it has excellent manufacturing, repair, and simplicity design. Also my post above points out it has excellent usability - once you get in the cabinets its easy to use, don’t need the documentation (diagram) most of the time. And it has the best aesthetic design. The layout is beautiful, and it doesn’t intrude into the cabin with ugly gubbins. So just back of the envelope, it wins in five categories and loses in one (accessibility). Hey, if you can get that kind of hit rate than yes it’s a good design!
Quote
<Dennis> recently blew the fuse for their front jack. Seeing the (extra) fuse at the front jack, he didn't think about three fuses under the streetside bed. Who would? Honestly, only some book-smart engineer in China, that never in his life traveled in an RV, could find a more illogical place for these fuses!
Design for repair, and design for repair documentation. You’re complaining about the latter. Basically nobody worries about that, it’s what repair manuals (or support lines) are for. I mean seriously, those fuses aren’t hard to find, I did it in my first trip when the composting fan went out. That fuse is in the same spot, I was glad it was so accessible. Turned out it just needed reseating.
Anyhow I’ll stick up for Oliver here. One of the things I appreciate about this trailer is how well designed it is. Because they’re not changing the basic design every year! They have one body and frame - that’s been perfected within the form factor, and they just keep refining the interior components and layout. It’s always massive compromise and I love working on this thing, they’ve balanced it all so well after all these years. I absolutely love how neat and tidy it is, with automotive channel wrap on all the wires. Work of art …
Ah sorry, been too long at the farm 😅
I think you forgot the golden rule of design," we gotta make money" which follows all of your design examples.
Yeah that's a boundary condition. If you were a painter that would be the picture frame you're working in, so you don't think of it much (or at least us lab rats don't, the marketing guys do 😅) Like, a 100 ft canvas is off the table, but the market will support a 4' portrait, so figure out how to make a picture within that frame. Which is why govt jobs go off the rails so easily if they're not fixed price contracts 🙃
tl/dr
The Oliver is pretty fascinating from a project standpoint. Never ceases to amaze me how the way you set up a project determines where it ends up. The Oliver brothers put 'The Big Idea' as it's called as "Highest quality". So nothing was spared. I marvel at the complex shape they have for this body. They actually molded in a 'glass skirt to hide the frame! But wait, it does more, it also acts as a water basin if any leaks occur. I've gotten a few big one setting up a filter unit. No shorts, the water just collected and drain, no damage at all. Hold on, what else? Those provide inner body channels to run piping and hoses. Finally it so happens to also provide wire run channel under the trailer, for propane and two exterior cameras I installed! Utterly protected and a snap to install.
That's some genius design in one feature, just because they're not afraid of doing fiberglass and went the extra distance on the body shape. I'm a weirdo, I'll sit outside my trailer and just admire the fiberglass all day 😂🥰
