Hi,
Can someone please explain the proper operation and use of this option? Should the valve be kept OPEN or CLOSED? I just got my trailer out of winter storage after bringing it home from Hohenwald in November. I was going over all of the systems to insure that everything works. I also looked at the owners manual and found parts diagrams, but no instructions for its use. Any help would be appreciated. Thanks.
John Z., Hull#405, '18 F150 EB
John & Eileen
2018 F150 EB Super Crew FX4
2018 Oliver Elite II Hull #405
John,
It is my understanding it should be closed during travel so the contents of the grey tank does not slosh up into the shower pan through the floor drain and open when in use.
Andrew
Andrew
Andrew is correct.  Closed when traveling/storing.  Open when using.  If it is closed when water is going down the drain to the gray tank it will start to back up through the shower floor drain.  You can guess how I know....   Mike
Thank you Mike (and Andrew), that is exactly what I experienced, however I was fortunate enough to be just using fresh water. That's how we learn. John
John & Eileen
Now that you know about "open" and "close" all you have to remember is to actually "open" and "close" it.  Don't ask me how I know this!
Now that you know about “open” and “close” all you have to remember is to actually “open” and “close” it. Don’t ask me how I know this!
I won’t ask because I know how you know!  I think about everyone has forgotten once or twice to open while setting up camp.  It gets  back to checklists/routines/flags/double checking/etc.  Mike
"Certainly I can remember something as simple as THAT!"
Which is the reason I now carry 2 rugs for the bath floor so I can still have one to use while the other one is drying.
  • Haha 2
  • 2 years later...
How does this system work WITHOUT the auto drain option? Is the option simply an electric switch vs a manual valve? I'm trying to understand what the $300 gets me and how things work without one.
John and Jodi
San Antonio, TX
2022 Elite II - Hull #1126 being pulled by a 2022 F-150 Powerboost.
Map Legend: Red - Driven Through; Orange - Stopped In; Blue - Explored Parts; Green - Explored Whole
Without the Auto feature, there is a regular pull handle in the bathroom wall down low, You push it IN for travel (closed), OUT for camping (open). It operates a waste valve just like the other two ones in back. It actually opens and closes the grey tank vent, to allow it to work correctly. Is it worth $300 to not do it by hand? Only you can answer that. I would rather buy something actually useful with the money. Like a TPMS system
14 minutes ago, John E Davies said:
Like a TPMS system
TPMS?
John and Jodi
San Antonio, TX
3 minutes ago, John and Jodi said:
TPMS?
Tire Pressure Monitoring System.
I use the TST TPMS.  There are other good ones, Tireminder is one.  I have a sensor on each trailer wheel.  Tells me the pressure and temperature of each tire.  If there is a sudden reduction in pressure I get an alarm.  Mike
We will definitely get a TPMS.   Is that something that you get in Hohenwald or will OTT put that in?   It's not an option so I assume it's on us to install.   If we put it in,  I figure it's probably one more thing that I need to buy to bring to Tennessee when we pick up in November.
Auto drain valve? One more thing to break, IMO. I like the KISS principle here. TPMS? We also have the TST system. If you plan to bring it to your delivery, take some time at home to program it for the correct tire pressures before you go down. One less thing to do in Hohenwald.
We have the manual drain valve and like many others have forgotten to open it once or twice!!  It is on our check list now.  The manual is easy to use.  Automatic won't solve the problem of forgetting to open or close the valve.  I have to agree manual in this instance makes sense.  One less thing to fail for whatever reason, and reallocating those funds for tpms is a terrific idea.
Yes.
You need to have your TPMS when you get to Hohenwald.  There’s not much to installation…. With the TST you just screw the sensors onto the tires, do some programming (button pushing) on the small monitor and you’re done.  Mike
That's one of my wife's jobs to control that valve, I personally don't know which way is open, or closed.
trainman
You'll know to place the valve in the "other" position when your feet get wet.😁
trainman
In is closed.  When you push it in, it moves the valve down to closed position.  Just like the black and gray tanks.
My wife and I took delivery of LEII Hull 990 on 2/17/22.  Among the options we chose was the Auto Drain, for $300.  There is nothing "auto" about this drain switch,  I had incorrectly assumed this switch closed the valve preventing back flow of grey water into the shower using some motion sensor to determine when the trailer was in motion.  Not at all.  The switch (mounted just inside the closet on the left side) flashes a red light continually when open, and no light when closed.  To change state from open/close a rocker switch at the top must be held until the valve fully opens or closes.  I find flashing red lights annoying, usually indicating some malfunction.  I recommend avoiding this option.
  • Sad 2
Mike,  I watched the video on how to set it up.   Looks easy.   Thanks for confirming that.
Make note of the support phone number just in case you have any questions.  They are excellent!
Are you referring to TechnoRV?   That was the video I watched.
No!  The TST support team is who I was referring to.  Sorry about the confusion.
TechnoRV has also been very helpful.
