nrvale0 Posted March 22, 2020 Posted March 22, 2020 (edited) Perhaps someone else has seen this. It has me flummoxed. A handful of times in the last year I've gone outside at night and noticed that the brake lights on the trailer are on -- faint but on -- even though the trailer is chocked + x-chocked and disconnected from the tow vehicle. The last time it happened I had a theory it was that the brake safety wire had fallen off the tongue and the weight of the carabiner was pulling the mechanism to engage the emergency brake. After placing the biner back on the tongue and putting a little slack in the wire the lights did turn off by the next evening, however, I sit here now with the passenger-side light (and only that light!) faintly lit for like 2 days now. Thoughts? I don't see anything in the manual(s) on this topic. Edited March 22, 2020 by nrvale0
Moderators topgun2 Posted March 22, 2020 Moderators Posted March 22, 2020 (edited) nrvale0 - More than likely you will be able to trace your problem to water/dirt in the Olivers "pigtail". The pigtail is the cord that you plug into your tow vehicle. Try taking a "Q-tip" and cleaning the contacts and then (if you have some) place a small amount of dielectric grease on each of those contacts in order to keep them less prone to this problem. Bill Edited March 22, 2020 by topgun2 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
WhatDa Posted March 22, 2020 Posted March 22, 2020 Water causing a short on the 7-pin trailer connector Between Olivers…
Overland Posted March 22, 2020 Posted March 22, 2020 This is more common than you'd think. What happens is that moisture gets into the plug of the wiring harness and creates a path from the trailer's batteries to the lights. I've had it happen once, and just shaking the water out of the plug was good enough to get the lights off. The best way to prevent it is to keep the plug under cover.
Overland Posted March 22, 2020 Posted March 22, 2020 3 answers at once - this must be a pretty helpful forum. 😁 2
Moderators Mike and Carol Posted March 22, 2020 Moderators Posted March 22, 2020 If you don’t have a cover just drape the cord over the tongue so that the plug is pointing down. I used a cover for a few months, lost it and have been doing the “downward drape” for almost four years with no phantom lights. 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Overland Posted March 22, 2020 Posted March 22, 2020 Mike, I used to do that on mine, but then I started getting water seeping in at the joint between the cable and plug. Some silicone sealant probably would have fixed it, but I got this cover instead and it's worked great. 1 2
Mainiac Posted March 22, 2020 Posted March 22, 2020 I have always 'draped ' the umbilical cord over the tounge, plug down, to eliminate water intrusion. To my surprise one evening I found the taillights on. Shook the plug and the lights went out. That is when I noticed my plug is not moulded on. So we took some clear exterior silicone adhesive and with our finger smeared it on and into where the cord and plug come together. Smoothed it out and let it cure. As of yet , no more "ghost" lights... 1
Moderators Mike and Carol Posted March 22, 2020 Moderators Posted March 22, 2020 2 hours ago, Overland said: Mike, I used to do that on mine, but then I started getting water seeping in at the joint between the cable and plug. Some silicone sealant probably would have fixed it, but I got this cover instead and it's worked great. I put one in my Amazon cart. Thanks! Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
bhncb Posted March 22, 2020 Posted March 22, 2020 4 hours ago, nrvale0 said: Perhaps someone else has seen this. It has me flummoxed. A handful of times in the last year I've gone outside at night and noticed that the brake lights on the trailer are on -- faint but on -- even though the trailer is chocked + x-chocked and disconnected from the tow vehicle. The last time it happened I had a theory it was that the brake safety wire had fallen off the tongue and the weight of the carabiner was pulling the mechanism to engage the emergency brake. After placing the biner back on the tongue and putting a little slack in the wire the lights did turn off by the next evening, however, I sit here now with the passenger-side light (and only that light!) faintly lit for like 2 days now. Thoughts? I don't see anything in the manual(s) on this topic. My thoughts: For future reference, activating the breakaway switch will not turn on the brake lights. Also, it's good practice to routinely pull and re-insert the switch pin to verify operation. The first time you do this will give you an idea of the actual force required. In the seven-way plug, the right turn/stop and tail/marker light contacts are adjacent to the 12V aux. This explains the two anomalies you experienced. My solution for keeping water out, 1
Galway Girl Posted March 22, 2020 Posted March 22, 2020 7 Pin Waterproof Holder Mod - Did this for our unit as we had that exact problem...water in the 7 pin after heavy rains. Now we are good... 2 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
nrvale0 Posted March 23, 2020 Author Posted March 23, 2020 (edited) Wow, that was fast and enthusiastic response! I guess, like me, everyone is locked up and bored! 😉 I do always make sure the pigtail is facing downward and I have made a pretty regular habit of cleaning it and shooting with di-electric grease but I will give that another try. Will also make sure there's no ability for water to run down the wire and through the housing. My last trip to current location was definitely wet and dirty so it seems like a distinct possibility that something might be knocking around in there. Given all the stores being on lockdown, I'll likely just seal it off with a ziplock and rubber band until I can figure out if I can get something a bit less janky. Thx, everyone! I will let you know if it continues to be a problem. Edited March 23, 2020 by nrvale0
nrvale0 Posted March 29, 2020 Author Posted March 29, 2020 Just looping back on this to confirm a fix until I can get a cap...popping the plug of the pigtail against my hand a half dozen times was enough to dislodge/dry the contacts in the plug and turn the lights out. It looks to me like the housing on the plug is fine but I went ahead and sealed it with silicon anyway. Thx for the advice folks. I probably should have known this one from working on wet, muddy, old dirt bikes. 😕 2
thompsonkd Posted October 22, 2020 Posted October 22, 2020 We are having a bit of trouble with our seven pin pigtail connector; usual issue with moisture in the housing. I want to take it apart and clean it out with air and a brush. We were advised to disconnect the negative terminal on the battery when we did this though though; we have the 4 AGM battery set up with solar. Do I need to disconnect each negative terminal on each battery or just one? Thanks in advance. Kim and David Thompson Nomads' Nest 2018 LE2 #366 2018 Toyota Tundra, 4x4, 5.7L
Moderators topgun2 Posted October 22, 2020 Moderators Posted October 22, 2020 Just the one that goes back into the Ollie would be the safest. Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators SeaDawg Posted October 22, 2020 Moderators Posted October 22, 2020 Topgun, assuming he's already disconnected from the ollie. Getting leakage from olllie battery. 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Moderators topgun2 Posted October 22, 2020 Moderators Posted October 22, 2020 (edited) Sorry - I guess I needed to be a bit more specific. The negative cable from your battery that goes back into the Oliver from the battery compartment is the one I'm talking about. Bill Edited October 22, 2020 by topgun2 spelling 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
bhncb Posted October 22, 2020 Posted October 22, 2020 16 minutes ago, topgun2 said: The negative cable from your battery that goes back into the Oliver from the battery compartment The stiffer black one, which might actually be yellow, that's attached to the post adapter on the inside front battery. 1
thompsonkd Posted October 22, 2020 Posted October 22, 2020 Do you mean the stiff cable that connects the 2 front batteries? Kim and David Thompson Nomads' Nest 2018 LE2 #366 2018 Toyota Tundra, 4x4, 5.7L
bhncb Posted October 23, 2020 Posted October 23, 2020 (edited) 2 hours ago, thompsonkd said: Do you mean the stiff cable that connects the 2 front batteries? No. It is one of the cables that comes in though the front of the battery box. Here's a picture of my 2018 I found. Third one up from the bottom on the left. Stiff refers to insulation not cable size. Edited October 23, 2020 by bhncb 1
thompsonkd Posted October 23, 2020 Posted October 23, 2020 Thanks for the responses re negative terminal on battery-the picture was helpful as well. David Kim and David Thompson Nomads' Nest 2018 LE2 #366 2018 Toyota Tundra, 4x4, 5.7L
Ray and Susan Huff Posted October 23, 2020 Posted October 23, 2020 15 hours ago, bhncb said: No. It is one of the cables that comes in though the front of the battery box. Here's a picture of my 2018 I found. Third one up from the bottom on the left. Stiff refers to insulation not cable size. I'd wager you will not find another battery compartment as well finished as Oliver's 👍 1 Ray and Susan Huff Elite II Twin "Pearl" - Hull#699; delivered December 7, 2020 2013 F350 6.7l diesel Super Duty 4x4 long bed crew cab 1UP-USA Heavy-duty bike rack 2017 Leisure Travel Van Unity Twin Bed (sold)
theOrca Posted November 22, 2020 Posted November 22, 2020 I just posted a similar story... Disassemble your trailer 7 pin connector. The moisture and corrosion is on the back side of the plug, not the front side. You are going to find a mess. Clean it up. Add a bunch of dielectric grease and put it together again. LED lamps have a very low "light off" voltage. Leakage which you would have never seen with old style lights will show up early with LEDs;. 1 theOrca, 2020 Legacy Elite II, Twin, Hull 615 Tow Vehicle - 2016 Ram 1500, Hemi, 8 Speed with 1500# rear springs and Goodyear bags.
theOrca Posted November 22, 2020 Posted November 22, 2020 Note: I'll bet that only the outside lamps of all four assemblies are the ones lighting up.... The running lights are the wire right next to the 7 pin "hot" wire that goes to the batteries. theOrca, 2020 Legacy Elite II, Twin, Hull 615 Tow Vehicle - 2016 Ram 1500, Hemi, 8 Speed with 1500# rear springs and Goodyear bags.
