Moderator question
Landrover
I’m not sure if things are changing with in the forum. I noticed when I log in, the activity button is not there? It just shows Home, Forums, Service.  No more activity. When your not logged in there is a area to the right  to click  Show all activity?
I have bookmarked this link, https://olivertraveltrailers.com/forums/discover/, which I use to get to the All Activity page.
Edited by DavidS
Yep - still there for me too.  I'm using Google Chrome on a home "tower" at the moment.
By the way, the button on the right (with the little newspaper icon) is for your default activity stream, and it's correct that people who aren't logged in will see it labelled as "All Activity".  When you log in, that button will default instead to "Unread Content".  But, if you select one of the other items under Activity, or create your own Activity Stream, you can then click on the blue Stream Options button to the right, where you can select that view as the default stream.  That will change the newspaper button to whatever you select.
Edited by Overland
I wonder if this is one of those Member+ bugs.  I've tried logging in with a non-moderator account and everything shows up fine, but it doesn't have Member+ status.  Everyone who's posted about it does, though.  I've sent a note to the admin to check.
Edited by Overland
this is what i am seeing.
Home  Forums  Activity  Service
Edited by SNY SD UP
forgot something, i never remember everything the first time...
ABBCMBNBNTNSONPEQCSKYTALARCTDEFLGAILINIAKSKYLAMEMDMAMIMNMSMONENHNJNYNCNDOHOKPARISCSDTNTXVTVAWVWIxlg.jpg.d41b39fcf844ad1935d35acdc8a6c203.jpg
19 hours ago, Overland said:
There's been no change to my knowledge, and the activity button is still there for me, both Safari and on the iPhone pull down.  Is anyone else having the same problem?  Could be a browser issue maybe.
1186668869_ScreenShot2021-03-27at12_07_28PM.thumb.png.27ff8bec48ddf4d67457949fe28e7299.png
Overland  i use an I pad since the start. The Activity area  as you show is no longer there? Any suggestions
My views change periodically - could be something other than the Oliver site - as we are living in a simulation - it may be that------ 😄
RB
@Landrover I’m pretty sure that this is going to be a problem with the Member+ group, but we’ll see once Jason checks it.  I think when he created that group, all of the settings didn’t get duplicated - there were earlier, more obvious issues when he first set it up, but this one is more subtle.  Thanks for bringing it up and hopefully Jason can get it corrected shortly.
  • Administrators
That's what it was. Hidden setting in the menu. It's fixed now.
  • Thanks 4
