Landrover Posted March 27, 2021 Posted March 27, 2021 I’m not sure if things are changing with in the forum. I noticed when I log in, the activity button is not there? It just shows Home, Forums, Service. No more activity. When your not logged in there is a area to the right to click Show all activity? 1 Grant 2022 GMC Denali 2500 HD 2019 Elite 11😎
DavidS Posted March 27, 2021 Posted March 27, 2021 (edited) I have bookmarked this link, https://olivertraveltrailers.com/forums/discover/, which I use to get to the All Activity page. Edited March 27, 2021 by DavidS David Stillman, Salt Lake City, Utah 2016 Oliver Elite II Hull 164 | 2017 Audi Q7 tow vehicle. Travel and Photography Blog: http://davidstravels.net
Overland Posted March 27, 2021 Posted March 27, 2021 There's been no change to my knowledge, and the activity button is still there for me, both Safari and on the iPhone pull down. Is anyone else having the same problem? Could be a browser issue maybe.
Moderators topgun2 Posted March 27, 2021 Moderators Posted March 27, 2021 Yep - still there for me too. I'm using Google Chrome on a home "tower" at the moment. Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Overland Posted March 27, 2021 Posted March 27, 2021 (edited) By the way, the button on the right (with the little newspaper icon) is for your default activity stream, and it's correct that people who aren't logged in will see it labelled as "All Activity". When you log in, that button will default instead to "Unread Content". But, if you select one of the other items under Activity, or create your own Activity Stream, you can then click on the blue Stream Options button to the right, where you can select that view as the default stream. That will change the newspaper button to whatever you select. Edited March 27, 2021 by Overland
bhncb Posted March 27, 2021 Posted March 27, 2021 Same new feature here when logged in. Either Chrome or Safari. Work around: Click on "Unread Content" at upper right then on "Activity" within the "Home > Activity > Unread Content" string at upper left.
Overland Posted March 27, 2021 Posted March 27, 2021 (edited) I wonder if this is one of those Member+ bugs. I've tried logging in with a non-moderator account and everything shows up fine, but it doesn't have Member+ status. Everyone who's posted about it does, though. I've sent a note to the admin to check. Edited March 27, 2021 by Overland
SNY SD UP Posted March 27, 2021 Posted March 27, 2021 (edited) this is what i am seeing. Home Forums Activity Service Edited March 27, 2021 by SNY SD UP forgot something, i never remember everything the first time... Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed
SNY SD UP Posted March 27, 2021 Posted March 27, 2021 (edited) Oops... Edited March 27, 2021 by SNY SD UP Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed
Landrover Posted March 28, 2021 Author Posted March 28, 2021 19 hours ago, Overland said: There's been no change to my knowledge, and the activity button is still there for me, both Safari and on the iPhone pull down. Is anyone else having the same problem? Could be a browser issue maybe. Overland i use an I pad since the start. The Activity area as you show is no longer there? Any suggestions Grant 2022 GMC Denali 2500 HD 2019 Elite 11😎
dewdev Posted March 28, 2021 Posted March 28, 2021 Not there for me! I use Google Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2027 RAM 1500 Rebel, 4 x 4; 5.7L Gas V8 Hemi; 3.92 rear axle; 4 corner air suspension Maine
Landrover Posted March 28, 2021 Author Posted March 28, 2021 This is now what is showing. It has been this way for a couple of weeks. Not concerned just interested why? Grant 2022 GMC Denali 2500 HD 2019 Elite 11😎
BackofBeyond Posted March 28, 2021 Posted March 28, 2021 My views change periodically - could be something other than the Oliver site - as we are living in a simulation - it may be that------ 😄 RB Cindy, Russell and "Harley dog" . Home is our little farm near Winchester TN 2018 Oliver Legacy Elite II - 2018 GMC 2500 Duramax "Die young - As late as possible"
Overland Posted March 28, 2021 Posted March 28, 2021 @Landrover I’m pretty sure that this is going to be a problem with the Member+ group, but we’ll see once Jason checks it. I think when he created that group, all of the settings didn’t get duplicated - there were earlier, more obvious issues when he first set it up, but this one is more subtle. Thanks for bringing it up and hopefully Jason can get it corrected shortly. 2
Administrators JWalmsley Posted March 28, 2021 Administrators Posted March 28, 2021 On 3/27/2021 at 1:48 PM, Overland said: I wonder if this is one of those Member+ bugs. I've tried logging in with a non-moderator account and everything shows up fine, but it doesn't have Member+ status. Everyone who's posted about it does, though. I've sent a note to the admin to check. That's what it was. Hidden setting in the menu. It's fixed now. 4 Full Stack Developer/Marketing @ Oliver Companies Oliver Forums Guidelines & Rules
Landrover Posted March 28, 2021 Author Posted March 28, 2021 38 minutes ago, Overland said: Excellent - thanks! A simple click modern technology love it . It’s back. Thank you 2 Grant 2022 GMC Denali 2500 HD 2019 Elite 11😎
