Mattnan Posted February 7, 2022 Posted February 7, 2022 Beacon needs a Bath. Our Ollie was getting dirty and after a trip into White Sands today our Ollie has caked on gypsum sand. It looks like plaster. Same for our truck and wheel wells. In Florida we found a pull through self service bay and that worked ok. I am not finding one of those here in Deming, NM. Most Campgrounds won't let you wash your camper or vehicle. Has anyone used a truck wash. I have no idea how they work and if it is a good solution. Once again looking for advice. Thanks
Moderators topgun2 Posted February 7, 2022 Moderators Posted February 7, 2022 At the end of my 2 month western trip late last summer I tried a Blue Beacon truck wash. Not bad for the price but if I do it ever again I'll only have them wash the Ollie or wash the Ollie and the tow vehicle separately. The reason for this was that the "soap" that they used dried on the tow vehicle before they got a chance to wash/rinse it off and this left a very difficult to remove film. Previously I've used those do it yourself spray washes and even though they take time and some effort I personally prefer them. Particularly if I have my own cleaning pad which I almost always carry. Good luck! Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Steph and Dud B Posted February 8, 2022 Posted February 8, 2022 When our fifth wheel was covered in all the oil from our oil pan (another story) we took it through a Blue Beacon and they did a good job with no damage. 2 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Mattnan Posted February 8, 2022 Author Posted February 8, 2022 Thanks all for the advice. We stopped in Wilcox AZ at a truck wash that had decent ratings. Just wanted to get the caked on stuff off. They did a decent job and the Ollie and the truck look much better. Far from perfect but much better. I opened the basement door and found some of the stuff in the handle for the tank drain valves. Thanks again. 1 3
Moderators topgun2 Posted February 8, 2022 Moderators Posted February 8, 2022 1 hour ago, Mattnan said: I opened the basement door and found some of the stuff in the handle for the tank drain valves. Sounds to me like you could use a bit more weather stripping around that basement door? 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Mattnan Posted February 8, 2022 Author Posted February 8, 2022 Possibly, that stuff even got inside my truck fuel door 1
John and Debbie Posted February 9, 2022 Posted February 9, 2022 2 hours ago, topgun2 said: Sounds to me like you could use a bit more weather stripping around that basement door? Does the Ollie come with weather stripping around the outside doors? John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022
John and Debbie Posted February 9, 2022 Posted February 9, 2022 4 hours ago, Mattnan said: Thanks all for the advice. We stopped in Wilcox AZ at a truck wash that had decent ratings. Just wanted to get the caked on stuff off. They did a decent job and the Ollie and the truck look much better. Far from perfect but much better. I opened the basement door and found some of the stuff in the handle for the tank drain valves. Thanks again. "We stopped in Wilcox AZ at a truck wash that had decent ratings. Just wanted to get the caked on stuff off." What does it cost for a trailer wash at those places? Do they do it or is it like a self serve car wash? Hopefully they're careful around the solar and other attached items. John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022
Stevon Posted February 9, 2022 Posted February 9, 2022 I’ve washed more than once at a normal self service car wash. Most have a taller bay that you can definitely fit in. While on the road I don’t try to get it spotless, but sometimes I just gota get some of that dirt n bugs off. 3 2021 Oliver Legacy Elite II Hull #845
Mattnan Posted February 9, 2022 Author Posted February 9, 2022 It was $50 for my truck and the Ollie. They did a decent job! There was not a good self wash option near us. We are certainly not in show room condition but much better. I would use this type of service again. There were 4 guys doing the washing. They were pretty careful and I did give some initial instructions. 1
Jim_Oker Posted February 9, 2022 Posted February 9, 2022 That gypsum is super fine. When the wind kicks up there it looks like fog hanging in the air above the dunes. In this shot, the wind was ripping - I'd guess 30+ MPH gusts and pretty steady 20 MPH ish between gusts. The glow on the edge of the dunes is a thick layer of suspended gypsum. Above that, running up to and well above the top of the shot is less dense suspended gypsum - the fog bank. And in this next photo, maybe around an hour later, the wind had died down to maybe 5-8 MPH but you can still see a lot of gypsum in the air where it shows up against the mountains in the background (the lighter haze against the bottom of the mountains). I picked my lens for this shoot while i was in the car, and even then was fast and careful about changing that lens on so as to try to avoid it infiltrating the inside of my camera. 2 4 Jim and Yanna, Woodinville WA 2004 Ford E250 camper conversion Oliver Elite II hull #709
Jim_Oker Posted February 9, 2022 Posted February 9, 2022 BTW the dunes are spectacular and clean if you catch them during or soon after a big blow. It was a treat for photography to get this experience on my last evening there, after four prior days shooting sunrise and sunset there in which a big part of the challenge was finding good sense didn't have obvious footprints all over them. And the edges of the ripples and the dune edges were softer/muddier looking than this last evening. Thanks for sharing your experience - it makes sense driving out to the end invites the gypsum into all the nooks and crannies. In my case that was a rental car company's problem. I think they're used to it. 2 4 Jim and Yanna, Woodinville WA 2004 Ford E250 camper conversion Oliver Elite II hull #709
Moderators SeaDawg Posted February 9, 2022 Moderators Posted February 9, 2022 What a delight to see these as the first posts I read this morning. Your photos are absolutely beautiful ! Thank you so much for sharing them. 1 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Moderators Mike and Carol Posted February 9, 2022 Moderators Posted February 9, 2022 10 hours ago, John Welte said: Does the Ollie come with weather stripping around the outside doors? Yes. I have increased the insulation on the basement door and put insulation on the battery door so that they both now make a very tight seal. Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
John E Davies Posted February 9, 2022 Posted February 9, 2022 1 hour ago, Mike and Carol said: Yes. I have increased the insulation on the basement door and put insulation on the battery door so that they both now make a very tight seal. Mike Everyone should be reminded that you can’t block the air vent holes if you have standard lead acid or AGM batteries, doing so is very unsafe. OTH it is good for lithiums in the winter, since they need to be kept warm when it is really chilly outside. https://rvnerds.com/2017/11/01/electrical-myths-part-4-agm-batteries-dont-need-venting/ John Davies Spokane WA 1 2 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
John E Davies Posted February 9, 2022 Posted February 9, 2022 Jim, those dune pictures are gorgeous. How did you deal with gypsum inside the Ollie? I have severe dust/ smoke allergies and that scenario would be horrible for me. I would never willingly get myself into those conditions, unless I knew I could stay upwind. It’s one reason I made HEPA filters for the windows. The gypsum crystals are OK, it is the dust that is bad. …. https://www.lafargeholcim.us/sites/us/files/atoms/files/gypsum_sds_english.pdf John Davies Spokane WA 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Moderators topgun2 Posted February 9, 2022 Moderators Posted February 9, 2022 Just to make absolutely sure that everyone is clear on this subject - John Davies is absolutely correct with his statement above with regards to the battery compartment door! However, additional insulation and weather stripping can be applied to the basement door in order to improve the seal around both the outside shower, the dump valves and the basement compartment itself. I simply used another layer of Reflextix on top of the layer that comes standard and then added window weather stripping around the entire outside shower/dump handle area. Many owners will have to adjust the length of the door lock when doing this. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
John E Davies Posted February 9, 2022 Posted February 9, 2022 20 minutes ago, topgun2 said: I simply used another layer of Reflextix on top of the layer that comes standard That can help a little if it covers up areas that the first layer missed, but the Reflectix manufacturer states that multiple layers do not increase the R value, which is just R1. You must have a physical air gap between the layers to increase that figure. I suspect that when you stack them, so that they touch, the heat transfers through conduction, and a gap prevents that from happening. Imagine holding your hand close to a frigid window, then pressing it hard against it, the difference is pretty intense. That is why the Oliver double hulls work. This is definitely drifting off topic. John Davies Spokane WA 2 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Mountainman198 Posted February 9, 2022 Posted February 9, 2022 There is a tall self serve wash in Deming across from the McDonalds. I have washed my Ollie there twice this Season 1 2021 Elite II, Hull# 898 2018 Toyota Tundra, 2003 Dodge Ram 3500 5.9l SRW
John and Debbie Posted February 9, 2022 Posted February 9, 2022 8 minutes ago, Mountainman198 said: There is a tall self serve wash in Deming across from the McDonalds. I have washed my Ollie there twice this Season Crazy question, but do you get up on top and wash, or does everyone use a ladder and use a long handled brush to get the top. I bet it's slick up on top. John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022
Moderators topgun2 Posted February 9, 2022 Moderators Posted February 9, 2022 38 minutes ago, John Welte said: do you get up on top and wash, or does everyone use a ladder and use a long handled brush to get the top. A couple of times a year I'll do a fairly through job on the top and (mostly) use a ladder to reach all that needs to be reached without actually climbing directly onto the roof. For all other washes I use a ladder and long handled brush/mop. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators Mike and Carol Posted February 9, 2022 Moderators Posted February 9, 2022 4 hours ago, John E Davies said: Everyone should be reminded that you can’t block the air vent holes if you have standard lead acid or AGM batteries, doing so is very unsafe. OTH it is good for lithiums in the winter, since they need to be kept warm when it is really chilly outside. Yes, good point. I replaced my 4 AGMs with 2 Lithiums (and have a third being delivered Saturday -woo hoo!). I also plugged my vent holes that are covered with the nice chrome covers on the battery door. Now, when I wash the trailer everything stays pretty dry (staying on topic 😊). Mike 3 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Mountainman198 Posted February 9, 2022 Posted February 9, 2022 4 hours ago, John Welte said: Crazy question, but do you get up on top and wash, or does everyone use a ladder and use a long handled brush to get the top. I bet it's slick up on top. I am height advantaged so can get the wand and brush up pretty high. 😀 2 1 2021 Elite II, Hull# 898 2018 Toyota Tundra, 2003 Dodge Ram 3500 5.9l SRW
Moderators Mike and Carol Posted February 9, 2022 Moderators Posted February 9, 2022 1 hour ago, Mountainman198 said: I am height advantaged so can get the wand and brush up pretty high. 😀 Yes, you are!! 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Moderator+ ScubaRx Posted February 10, 2022 Moderator+ Posted February 10, 2022 8 hours ago, John Welte said: ...I bet it's slick up on top... You can bet your sweet bippy it is, like unto a water slide. I have some commercial scaffolding that I set up when I need/want to work on the top. 3 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
