Steph and Dud B Posted August 27, 2023 Share Posted August 27, 2023 We also have the Platinum package with the built in battery heaters. Because I only had one shared 15A outlet outside I throttled the Xantrex back to only 5A (setting 28) and it did just fine sitting outside here in CT all winter. The heaters don't draw much. 2 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999: Link to comment Share on other sites More sharing options...
MAX Burner Posted August 27, 2023 Share Posted August 27, 2023 12 hours ago, Steph and Dud B said: @MAX Burner, is that a 10x12' bay door? That's exactly right, an insulated 10'x12' bay door... The width of the OTT makes it very easy to slide right in (unlike the AS, which usually took a couple passes). 2 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
Rivernerd Posted August 27, 2023 Share Posted August 27, 2023 16 hours ago, Half Fast Hugo said: Question for the collective minds though, they only have 15 amp receptacles on the wall and, will that allow it to keep the batteries full and warmed by the battery heaters? The facility is not heated so I'm concerned whether or not I should remove the batteries for the winter as we quite often get below 0F in January and February. 2021 LE2 with the platinum solar package. 15A AC power, with a 15A to 30A adapter of course, is more than adequate to keep even 630Ah of Lithionics LiFePO4 batteries warmed by the internal battery heaters, even down to 0 F. Our 390Ah Lithionics pro package fully recharges from reserve cutoff levels with a 15A connection in a few hours. The battery warmers don't draw even close to enough DC power to offset that AC infusion, even at only 15A. 16 hours ago, Half Fast Hugo said: I will have 24/7 access if need be and will still have to winterize the plumbing systems. Every 3 months you leave your Elite II plugged in to shore power full time, Lihionics recommends running a full discharge/recharge cycle down to the reserve power level, then restoring shore power. For our winter in the Idaho mountains last year, with our Elite II stored in our 30' x 30' shed with 30A receptacle beginning in mid-November, I did one full discharge/recharge cycle in February. By April, we were using the Oliver again, so only one discharge/recharge cycle was necessary. I presume you are planning to install a 30A receptacle in your new 30' x 36' garage? 2 1 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package Link to comment Share on other sites More sharing options...
Half Fast Hugo Posted August 27, 2023 Share Posted August 27, 2023 1 hour ago, Rivernerd said: I presume you are planning to install a 30A receptacle in your new 30' x 36' garage? Good info and thank you! Yes, one 30A on the outside for guests and one on the inside as well since I'll have a big enough service line to do so. 3 2021 LE II - Hull 922 - "Ollie Be Back" 2013 Silverado 2500HD Duramax Hugo & Penny Bob & Cash (the pups) Link to comment Share on other sites More sharing options...
Moderator+ ScubaRx Posted September 25, 2023 Moderator+ Share Posted September 25, 2023 On 8/5/2023 at 8:45 PM, SeaDawg said: Our 2008 came with the original single step, and we used a stool as a second step for several years. My short legs, and one flip of that sturdy stool, for me, at a crazy hilly campsite in Tennessee, prompted us to upgrade to the double step when it came available. It's a bolt on. A great "upgrade" for us, standard for all the new folks. Best double step in the marketplace. Superbly constructed. Way overbuilt, but that's the Oliver way. The step brackets on the older frames are attached in a different place and mounting a current set of steps may involve some creativity. @CRM, I have an extra set of double steps that came off a trailer just a few hull numbers from yours that might bolt right up. We’d need to measure to make sure. 2 3 Steve, Tali and our dog Rocky plus our beloved Storm, Maggie, Lucy and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4 Link to comment Share on other sites More sharing options...
CRM Posted September 25, 2023 Share Posted September 25, 2023 2 hours ago, ScubaRx said: The step brackets on the older frames are attached in a different place and mounting a current set of steps may involve some creativity. @CRM, I have an extra set of double steps that came off a trailer just a few hull numbers from yours that might bolt right up. We’d need to measure to make sure. That would be awesome if they would fit! Let me know what measurements you need and I'll get them to you ASAP. 2010 Elite II, Hull #45. 2014 Toyota Sequoia Platinum 4WD 5.7 with tow package. Link to comment Share on other sites More sharing options...
rideandfly Posted September 26, 2023 Share Posted September 26, 2023 We keep Ollie in a 36'X36' hangar with three sides. It does not have power, occasionally take the solar panels or gen-set to the hangar to charge the battery in the winter. It has an asphalt floor. We have had mud daubers to get into Ollie's window drains stopping them up. Now we put tape on the drains to keep the daubers out. 3 1 Bill & Debbie / 2015 LE2 #75 / 2024 F-150 5.0L / North Carolina Link to comment Share on other sites More sharing options...
Sak Posted September 26, 2023 Share Posted September 26, 2023 21 hours ago, rideandfly said: We have had mud daubers to get into Ollie's window drains stopping them up. Now we put tape on the drains to keep the daubers out. Are they also getting in your A/C? I have to plug all the holes in the A/C shroud. Can't use A/C cover because we are located in a very windy area of eastern Washington state. 1 3 2021 Oliver Legacy Elite II - Hull #854 2021 Ford Expedition Platinum Link to comment Share on other sites More sharing options...
rideandfly Posted September 26, 2023 Share Posted September 26, 2023 55 minutes ago, Sak said: Are they also getting in your A/C? I have to plug all the holes in the A/C shroud. Can't use A/C cover because we are located in a very windy area of eastern Washington state. When we purchased Ollie used, there were mud daubers in the AC that made a lot of noise from time to time. It was hard to find them with the cover off, but finally found them & got rid of them, happy to report no issues since. 5 Bill & Debbie / 2015 LE2 #75 / 2024 F-150 5.0L / North Carolina Link to comment Share on other sites More sharing options...
rideandfly Posted September 26, 2023 Share Posted September 26, 2023 There are AC covers available, that could help keep daubers out. https://www.amazon.com/s?k=rv+ac+cover&crid=WMFIA4XGFUNA&sprefix=rv+ac+cover%2Caps%2C121&ref=nb_sb_noss_2 5 Bill & Debbie / 2015 LE2 #75 / 2024 F-150 5.0L / North Carolina Link to comment Share on other sites More sharing options...
Patriot Posted September 26, 2023 Share Posted September 26, 2023 @Sak I had a cover on our former “Demonic Penguin” AC and it never blew off in high wind. It can be cinched down pretty tight. We never had issues with birds or bugs at all. Patriot🇺🇸 5 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor North Carolina 🇺🇸 Link to comment Share on other sites More sharing options...
Sak Posted September 27, 2023 Share Posted September 27, 2023 1 hour ago, Patriot said: I had a cover on our former “Demonic Penguin” AC and it never blew off in high wind. It can be cinched down pretty tight. We never had issues with birds or bugs at all. That's a good news. I will have to try that. Thanks! 1 2021 Oliver Legacy Elite II - Hull #854 2021 Ford Expedition Platinum Link to comment Share on other sites More sharing options...
MAX Burner Posted September 27, 2023 Share Posted September 27, 2023 On 9/25/2023 at 6:38 PM, rideandfly said: We keep Ollie in a 36'X36' hangar with three sides. No... that's not a hangar, that's totally a MAN CAVE! HA! 1 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
rideandfly Posted September 28, 2023 Share Posted September 28, 2023 2 hours ago, MAX Burner said: No... that's not a hangar, that's totally a MAN CAVE! HA! Straight & level make me queasy! 🙃 3 Bill & Debbie / 2015 LE2 #75 / 2024 F-150 5.0L / North Carolina Link to comment Share on other sites More sharing options...
Steph and Dud B Posted November 16, 2023 Share Posted November 16, 2023 Our garage is almost done. Just need electrical run and installed before Eggcelsior can move in. Hoping to have it indoors before the first real snowfall. 4 3 2 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999: Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted November 16, 2023 Moderators Share Posted November 16, 2023 39 minutes ago, Steph and Dud B said: Our garage is almost done. Just need electrical run and installed before Eggcelsior can move in. Hoping to have it indoors before the first real snowfall. I'm soooooo jealous! Congrats. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC Link to comment Share on other sites More sharing options...
