Badger Posted September 30, 2023 Share Posted September 30, 2023 My outlets aren’t working under battery power or shire power? The GFI has no indication light. I checked the fuses, breakers, even took the cover off the inverter and confirmed the red LED light inside is on?? What next? Link to comment Share on other sites More sharing options...
MobileJoy Posted September 30, 2023 Share Posted September 30, 2023 Please post your trailer information, year and model. Also add your electrical systems info (inverter model, batteries, etc.). When on shore power, does your refrigerator work when AC power is selected? The fridge circuit is direct to a breaker (no GFCI), so if it does maybe your GFCI has failed. 5 2021 Elite II Twin #850 "Mojo", 2020 F250 Lariat 7.3L FX4 3.55 Link to comment Share on other sites More sharing options...
MobileJoy Posted September 30, 2023 Share Posted September 30, 2023 Sorry, I just noticed that you don't own an Oliver. Thus my previous advice may not be applicable as I have no idea of how your trailer is wired. 2021 Elite II Twin #850 "Mojo", 2020 F250 Lariat 7.3L FX4 3.55 Link to comment Share on other sites More sharing options...
Badger Posted September 30, 2023 Author Share Posted September 30, 2023 I DO! Hull # 590. Link to comment Share on other sites More sharing options...
Moderators Mike and Carol Posted September 30, 2023 Moderators Share Posted September 30, 2023 Does your microwave or refrigerator work on 110? Did you check to see if there are any lose connections? Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted October 1, 2023 Moderators Share Posted October 1, 2023 Congratulations on your new to you Ollie. We'll work out how to reset your profile later. Hull number 590 probably means 2019, or so. ELITE 1 or 2? What batteries? Does the gfci reset, or no? Have you tried? Are you on shore power? Have you checked the shore power connection? Does anything work on 110? Fridge, ac, etc. Give us a bit more info, and folks will be happy to help. If you have the transfer switch (extra power connection), try unplugging from the pedestal, and wait a minute. Plug in again. Our transfer switch doesn't always kick in, right away. When it does, we hear a click inside, and when we had a microwave, the microwave beeped. Sorry for your troubles. A little more info will help us help you. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
Steph and Dud B Posted October 1, 2023 Share Posted October 1, 2023 52 minutes ago, SeaDawg said: If you have the transfer switch (extra power connection), try unplugging from the pedestal, and wait a minute. Plug in again. Our transfer switch doesn't always kick in, right away. When it does, we hear a click inside, and when we had a microwave, the microwave beeped. If you're on shore power, have the 2 power connectors outside (left side body and right side by the propane tanks), and the transfer switch doesn't click/microwave doesn't beep when you plug in, can your cord reach the other power connector? 1 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999: Link to comment Share on other sites More sharing options...
Badger Posted October 3, 2023 Author Share Posted October 3, 2023 On 9/30/2023 at 10:20 PM, SeaDawg said: Congratulations on your new to you Ollie. We'll work out how to reset your profile later. Hull number 590 probably means 2019, or so. ELITE 1 or 2? What batteries? Does the gfci reset, or no? Have you tried? Are you on shore power? Have you checked the shore power connection? Does anything work on 110? Fridge, ac, etc. Give us a bit more info, and folks will be happy to help. If you have the transfer switch (extra power connection), try unplugging from the pedestal, and wait a minute. Plug in again. Our transfer switch doesn't always kick in, right away. When it does, we hear a click inside, and when we had a microwave, the microwave beeped. Sorry for your troubles. A little more info will help us help you. More dumb questions! I'm a novice. So I have the legacy II, 2020. I put 4 new interstates in it. Now that I am back in my barn and plugged in to shore power. everything is working! A/C, batteries got restored, outlets working gfi ,yes! So I think my portable Generator 30 amp plug was not working? battery drained after 2 days . here is my questions. Do the outlets in the RV work on battery power only? I thought so, and That may have been my first misdirection... Do I have an Invertor? What is the Black box mounted on the inside compartment under the table? Looks like an invertor. Link to comment Share on other sites More sharing options...
PAndrews Posted October 3, 2023 Share Posted October 3, 2023 Hi Badger, When using a generator with the Oliver, it is important to have a bonding plug otherwise known as a neutral ground plug on the generator. The Oliver comes standard with a built in surge protector and if you do not have this plug, the surge protector will not allow the 120v power to work as it is not grounded. Here is an example of a ground plug that you can buy on Amazon for $19. https://www.amazon.com/Southwire-Company-LLC-44400-Generator/dp/B07F4R7BDL/ref=sr_1_5?keywords=generator+bonding+plug&qid=1696360581&sr=8-5 - Phil Andrews, Oliver Travel Trailers 2 2 Phillip Andrews Oliver Travel Trailers Sales and Delivery Specialist Link to comment Share on other sites More sharing options...
Badger Posted October 3, 2023 Author Share Posted October 3, 2023 Thank you Phil! Ordered.... 1 Link to comment Share on other sites More sharing options...
Steph and Dud B Posted October 3, 2023 Share Posted October 3, 2023 Yes, you need a bonding plug to get power from most generators into your trailer. That should solve your initial problem. I don't know if Hull 590 has an inverter. Most Olivers do. Do you have a black control panel labeled Xantrex in your trailer? Something like this: https://www.amazon.com/Schneider-Electric-Solar-Inv-808-0817-01/dp/B0756BJQCN/ref=asc_df_B0756BJQCN/?tag=hyprod-20&linkCode=df0&hvadid=312094677816&hvpos=&hvnetw=g&hvrand=10946446638069115879&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9003252&hvtargid=pla-519123927354&psc=1 If so, you have an inverter. Instructions on its use are in Oliver University, linked from the main Oliver website. Basically, if you have no shore power, pushing the round silver button in activates the inverter and creates 120v power for your outlets, microwave, etc. from your batteries. The green LED next to the battery icon will indicate it's working. Note that this can consume a lot of battery power, especially running the microwave, so use it sparingly. The inverter does consume some power whenever it's on, even if there's nothing plugged into the outlets, so turn it off when not needed. 2 3 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999: Link to comment Share on other sites More sharing options...
dewdev Posted October 3, 2023 Share Posted October 3, 2023 1 hour ago, Badger said: Thank you Phil! Ordered.... Badger: It would be helpful for others on the forum to learn that have similiar problems that you explained to indicate what was the resolution to you not have 110 v power to the outlets. 2 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio Maine Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted October 4, 2023 Moderators Share Posted October 4, 2023 @Doug S, all good questions. And, understandable quandries. When you wrote the original post asking for help, were you on generator without the ground plug? If you were on campground shore power, let us know. Different scenario. The more info you can provide, the more the collective minds can help. So glad everything is working now, at home . When did you install the new batteries? And, welcome aboard. Glad to have you here. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
Moderator+ ScubaRx Posted November 13, 2023 Moderator+ Share Posted November 13, 2023 On 10/3/2023 at 4:11 PM, dewdev said: Badger: It would be helpful for others on the forum to learn that have similiar problems that you explained to indicate what was the resolution to you not have 110 v power to the outlets. Richard, I know this is a little late in the game but I believe Badger's solution was to purchase the bonding plug that Phil mentioned. 2 Steve, Tali and our dog Rocky plus our beloved Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4 Link to comment Share on other sites More sharing options...
Boudicca908 Posted May 28 Share Posted May 28 On 11/12/2023 at 10:50 PM, ScubaRx said: I know this is a little late in the game but I believe Badger's solution was to purchase the bonding plug that Phil mentioned. Much later … I have been reading various posts about this “neutral grounding plug” “neutral bonding plug” and have tried without success to access the Amazon products linked in several posts. The product links are outdated (I guess) and one leads to a Xantrex Remote Control. Can someone please give me a more specific description of the plug, and where it’s supposed to be inserted? I was expecting to find mention in an OTT video or OTT knowledge base article, but so far I’ve failed to find it or specific information on changes (if necessary) to my Xantrex settings, so I can recharge my lithium batteries with a Pulsar Inverter Generator 2000i (a gift to me, so it’s all new territory). Thanks for any assistance here. Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel "Estrella" Link to comment Share on other sites More sharing options...
Shawna and Scott Posted May 28 Share Posted May 28 9 minutes ago, Boudicca908 said: Much later … I have been reading various posts about this “neutral grounding plug” “neutral bonding plug” and have tried without success to access the Amazon products linked in several posts. The product links are outdated (I guess) and one leads to a Xantrex Remote Control. Can someone please give me a more specific description of the plug, and where it’s supposed to be inserted? I was expecting to find mention in an OTT video or OTT knowledge base article, but so far I’ve failed to find it or specific information on changes (if necessary) to my Xantrex settings, so I can recharge my lithium batteries with a Pulsar Inverter Generator 2000i (a gift to me, so it’s all new territory). Thanks for any assistance here. Here is a link you can try - https://www.amazon.com/Southwire-Company-LLC-44400-Generator/dp/B07F4R7BDL/ref=sr_1_3_pp?dib=eyJ2IjoiMSJ9.ze77urC3E0cv-Sgy2WBsnrvWHUzSct3XLNL2KRQJF5jRV26fObiFrn-fdZ9V6ncjRqGkCLXsrfyTmnKguORXLUfA_JKxet2ICSQxoPvuTc3hCJLLcKRzlYEC5-VZyzT798M5op3pqiInJ11dYfB8Euf6jd4m4F6Blflkk94yVnDsw4Qj1WLAR65hHtvwqhgli8Bs8EMxQE2wC4D8U5kgLaHkVl3BIzxZmMjQLqiyb4A.h0dBUVDPH0kSJAixrF7N_6HAJVNoU0KaEwuMFPX1d_Q&dib_tag=se&keywords=generator+bonding+plug&qid=1716918903&sr=8-3 This seemed to be one a few folks used when I did research on it back in 2022. 1 Vincent, Ohio | 2022 Elite ll, Hull #1182, 2014 Ford F150 3.5L EcoBoost, Max Towing PKG Link to comment Share on other sites More sharing options...
Boudicca908 Posted May 28 Share Posted May 28 (edited) 1 hour ago, Shawna and Scott said: This seemed to be one a few folks used when I did research on it back in 2022. Thank you — I ordered it, and I am guessing it won’t come with instructions. This looks like a standard plug. I thought it would be a plug that would accept my Oliver’s 30amp plug. I guess I am going to have to trust YouTube videos to try to understand what this does to change the behavior of my OTT — if and when I trust the information and try to use this generator to boost my lithium batteries. I did find this article useful: https://support.olivertraveltrailers.com/portal/en/kb/articles/power-management I still need more information though, to understand what it requires. Edited May 28 by Boudicca908 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel "Estrella" Link to comment Share on other sites More sharing options...
Shawna and Scott Posted May 28 Share Posted May 28 (edited) 28 minutes ago, Boudicca908 said: Thank you — I ordered it, and I am guessing it won’t come with instructions. This looks like a standard plug. I thought it would be a plug that would accept my Oliver’s 30amp plug. I guess I am going to have to trust YouTube videos to try to understand what this does to change the behavior of my OTT — if and when I trust the information and try to use this generator to boost my lithium batteries. I am by no means an expert in this area but I understand that the bonded neutral plug is needed. I have one but have not used my generator yet to charge the batteries or run anything in the oliver. I copied this from a thread on this topic: https://www.rvtravel.com/rv-electricity-generator-neutral-bonding-basics/ Also found this in another thread: "Without a neutral/ground plug in an outlet on the generator, no electricity will pass through the EMS" Scott Edited May 28 by Shawna and Scott 1 Vincent, Ohio | 2022 Elite ll, Hull #1182, 2014 Ford F150 3.5L EcoBoost, Max Towing PKG Link to comment Share on other sites More sharing options...
Steph and Dud B Posted May 28 Share Posted May 28 The neutral bonding plug goes in one of the 15A standard "household" outlets on your generator and connects the ground lead (the round third prong on the plug) to the neutral lead (one of the flat prongs). Without going into details, this is the setup the EMS expects to see, but most portable generators are not set up that way. Hence the plug. 1 2 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999: Link to comment Share on other sites More sharing options...
Boudicca908 Posted May 28 Share Posted May 28 1 hour ago, Steph and Dud B said: this is the setup the EMS expects to see, but most portable generators are not set up that way. Hence the plug Thank you! I was worried, because I found online other “grounding plugs” that were the 30 amp style/size. Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel "Estrella" Link to comment Share on other sites More sharing options...
SNY SD UP Posted May 29 Share Posted May 29 The issue i have with the “neutral grounding plug” “neutral bonding plug” concept is it ties up one of the two (Champion 2500) Generator 110v Outlets. I just created a 10ft. 10ga. wire with a couple of large Alligator clips on each end, one to the grounding nut on my Gen., and one to a one penny spike i drive into the ground. That way i have an open 110v plug, when the gen is doing its business with the the other outlet. i.e. Run a coffee pot while charging the Batts. I just do not leave the coffee outlet drawing power longer than the brew cycle. You can hear the Gen draw down a bit. A bit Neanderthal, but it works for me. 2 Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed Link to comment Share on other sites More sharing options...
Ronbrink Posted May 29 Share Posted May 29 7 hours ago, SNY SD UP said: That way i have an open 110v plug, when the gen is doing its business with the the other outlet. i.e. Run a coffee pot while charging the Batts. As an alternative, even though the ‘neutral bonding plug’ encumbers one of the duplex outlets on the generator one can always utilize the OTT’s external outlet, as needed. 2 2020 OLEll, Twin, 579 2012 Silverado 1500 4x4 No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, Hughes Autoformer, dual Lagun tables Link to comment Share on other sites More sharing options...
Ronbrink Posted May 30 Share Posted May 30 On 5/28/2024 at 12:45 PM, Boudicca908 said: I was expecting to find mention in an OTT video or OTT knowledge base article, but so far I’ve failed to find it or specific information on changes (if necessary) to my Xantrex settings, so I can recharge my lithium batteries with a Pulsar Inverter Generator 2000i This was sent me by Oliver upon request when I converted to LFPs last summer. In particular, Setting 20 (Battery Type) was switched to LFP and Setting 24 (Charger Current) on my Xantrex was checked and left at the factory 90 value for my older Freedom 2000 unit. 1 2 2020 OLEll, Twin, 579 2012 Silverado 1500 4x4 No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, Hughes Autoformer, dual Lagun tables Link to comment Share on other sites More sharing options...
Ronbrink Posted May 30 Share Posted May 30 On 5/28/2024 at 1:38 PM, Boudicca908 said: I thought it would be a plug that would accept my Oliver’s 30amp plug. Most small generators only have a single duplex receptacle with two outlets. One outlet will be used for the neutral grounding plug, the other will require a 30 Amp to 15 Amp 110 Volt RV adapter. This is the one I bought from etrailer.com, but many similar are available on Amazon. I also make use of this plug at my storage facility for shore power. 1 2020 OLEll, Twin, 579 2012 Silverado 1500 4x4 No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, Hughes Autoformer, dual Lagun tables Link to comment Share on other sites More sharing options...
Boudicca908 Posted May 30 Share Posted May 30 5 hours ago, Ronbrink said: Most small generators only have a single duplex receptacle with two outlets Thanks for this — I have a similar adapter, bought before I picked up my Oliver. As I look, this (new to me) generator is similar to your description. The friend who gave it to me also gave me a small adapter (I will attach photos if possible). That friend had to depart, sadly, for medical care. So far, I haven’t run down my lithium batteries to the point where I need to use the generator (after doing so once, and then waiting a couple of days for them to rejuice with the sun). But I am not using much, hardly using the microwave and never using the AC… as it gets hotter, my frugality might be confronted by my desire for some comfort. Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel "Estrella" Link to comment Share on other sites More sharing options...
