It does sound like the generator cannot supply enough power to satisfy the amount of current needed to charge the batteries.  The breaker setting is a good place to start as mentioned above.  There is also another setting, #24 (charger current)  that allows you to adjust the amount of current allowed to charge your batteries.  For lithium batteries I believe the setting is 150 amps.  You can try changing that value to something lower ( as a test ) to see if that helps, you can try something really low like 10 amps as a test.
Okay we turned off the EMS and it is charging with the generator. Okay so what does that mean? How do I fix this for the future. I trust the generator is okay. Is there a reset for the surge protector?
Explore, Dream, Discover
Christi, Matt & Lucy
2022 Legacy Elite II, TB
Hull # 1261
2019 F150 Limited
I don't even have an app for the inverter. Is this something I  need to get?
Hull # 1261
2019 F150 Limited
I have an Iphone but it should be the same for an Android. Search "FXC Control" in apple store or google play,
ANDROID USERS
APPLE USERS
Download the Xantrex FXC App at: https://apps.apple.com/us/app/fxc-control/id1484424847
download the app then follow this video to connect it to your Xantrex remote display.
Edited by rich.dev
added links to download FXC App
**Sold😞**
Will this app correct my issue and allow me to turn the EMS back on?
Hull # 1261
2019 F150 Limited
I do not have the type of Xantrex inverter/charger you have so I am not an expert.
But what I have read on this Forum for quite awhile now is that it looks to me like you need to change the charger current setting.  Tom and Doreen and rich.dev in the posts above explains what setting to change.
if you have cell phone service where you are, I would download the app now and try changing the charger current setting as they suggest. Then try the generator again with the EMS turned on. Hopefully that will work. Do NOT forget to put the setting back to here it was when you are hooked up to shore power. Write down the existing setting before changing it so you do not forget the initial setting.
If all else false, contat Xantrex (or Oliver) on Monday.
Good luck and let us know how you make out.
If you turned the EMS off and you're now charging correctly you may want to investigate why your EMS is preventing your generator from supplying power.  Possibly a problem with the EMS itself or there could be truly something wrong with your generator output.  By turning your EMS off you will no longer be protected from AC line problems.  Is it possible that you could borrow a external power watchdog to test the output of your generator? powerwatchdog.jpg.00897a005d91a6dfa6380f97767ad99e.jpg
Good reading info!   One item to make sure is that all other loads, such as water heater, A/C, microwave are OFF.  This will allow you to adjust the charge setting to a level consistent with a max RUNNING (Not surge) amps of your generator.
It would do that if your grounding plug (Technically a grounded neutral plug) is defective.  If there are other RV's in the area, ask to momently borrow their Grounded neutral plug for a quick test.
Geronimo John
PS:  The fancy one displayed above is nothing but a regular 120V plug with a jumper wire inside it from the ground wire terminal to the neutral terminal.  Most of us buy a $5 plug and make our own.
Edited by Geronimo John
Added PS
If you hear clicking like the batteries are trying to charge and then it shuts off and resets everything, then you will have two issues.  One is grounding.  Looks like someone already mentioned the required grounding plug.  The other is the charge controller is pulling too much power.  It has to be reset.
3 hours ago, chiwald said:
I don't think that's it because our inverter works and the breaker was not tripped. I think it has something to do with the transfer relay. When the generator is plugged in the The transfer relay keeps trying to switch back and forth and no charging is happening
You definitely want to submit a service ticket to Oliver, and provide everything you have shared.
support@olivertraveltrailers.com
You will get an immediate response back with a ticket. Oliver will follow up pretty quickly on Monday.
Glad you got it working and a big THANKS to all that got on board trying to help a fellow owner - that is what "family" is all about.
Again, sorry I had to run earlier but you were in good hands with all that came to your aid.
Yes, this is a GREAT BIG WONDERFUL FAMILY!!  Thank you everyone for all of your input and advice. And for responding so quickly. Our batteries are at 80% and will be fine until we get home tomorrow. I will contact Oliver on Tuesday.
Hull # 1261
2019 F150 Limited
Excellent! Glad you are able to finish your trip. My gut feeling is you have a bad EMS unit. OTT should get you straightened out.
Yup or a bad bonding plug, cheap fix!😊
**Sold😞**
IMG_5762.jpeg.8a4203e8b5f4e6d7cf9eeca46c1a77e6.jpegAs a safety check as you contact Oliver.
There have been a few of those under the dinette  transfer switches that failed due to loose wiring connections inside and had thus melted internal wiring.
Transfer relay wires can wiggle loose and cause the switch  to toggle back and forth when power is applied.
To check,  you would need to disconnect from shore power and generator, then open the transfer switch box to check if its connections are tight and no smoked wiring.
I picked up one of these relatively inexpensive generator test kits a while back.  It lets you verify both generator voltage and also how many watts and amps the generator is actually generating at site conditions (altitude and temperature) with the clamp meter.  This can help you rule out generator issues.  It comes with a test pigtail to make measurement easy. (see pictures below).  You can find it at Microair .net
image.thumb.png.9f3084e8169cec4d22a05541b5207318.pngimage.png.0e52f9f81b5cc21ad59bb78907f69c70.png
Steve and Lornie
Oregon
UPDATE: I was indeed the grounding plug! Got a new one and it charges like a champ now!! So glad it was a simple fix!! Thank ya'll again for all your help!
Hull # 1261
2019 F150 Limited
We carry cheap lightes from harbor freight,  for the tiny duty group 27 batteries, which wr jave
