katanapilot Posted May 29 Posted May 29 I was going to ask the same thing. I’m pretty comfortable with a 4 leaf full length spring made with US steel and a 2000 lb rating. 3 2020 Elite II Hull #628, Houghton Heat Pump, Victron MP2, SmartSolar, Orion, Cerbo, Lynx distributor and shunt TV - 2011 Toyota Tundra Crew Max Platinum 4WD, Magnuson Supercharger, OME suspension, Wilwood front and rear brakes
Geronimo John Posted May 29 Posted May 29 18 hours ago, CRM said: Why the focus on the weight of the spring and where does this number come from? I admit that I know nearly nothing about leaf spring tech, but shouldn't the weight rating of the spring and the quality of the steel and construction be all that really matters? More steel means a spring is likely to be able to handle stress longer for a given design. The weight of the spring design can be found in it's specifications. Where made is a different discussion entirely. TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
CRM Posted May 29 Posted May 29 15 minutes ago, Geronimo John said: More steel means a spring is likely to be able to handle stress longer for a given design. The weight of the spring design can be found in it's specifications. Where made is a different discussion entirely. I understand all this, I was just wondering how you came up 17 pounds being the minimum weight. I would hope that if Alcan designs a spring with a 2000# rating that it would perform as expected and exceed what is required for an LE2 no matter the weight of it. I'm running on 16 year old springs at the moment, that thankfully don't show any of the typical Dexter flattening near the eyes, but want to upgrade soon myself and I'm a little worried about installing springs rated for nearly double the weight we usually travel at. 2000# Alcan's seem like a perfect match but now I'm a little nervous and and asking questions due to your opinion on the weight of them... 1 2010 Elite II Hull #45- the first LE2 sold. 2020 Toyota Tundra Limited 4WD 5.7 with tow package.
jd1923 Posted May 29 Posted May 29 5 minutes ago, CRM said: I'm running on 16 year old springs at the moment, that thankfully don't show any of the typical Dexter flattening Ours are 10 years old, look nicely arced. Purchased a backup pair for travel safety, but leaving ours as-is until maybe one day I upgrade to 5200 lb axles and the would get the 5-leaf Alcans which is the co recommendation. Perhaps Dexter used better steel 10-16 years ago. Leave well enough alone in our case. 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jdmmtx Posted May 30 Posted May 30 We had the 4-leaf Alcan springs installed yesterday along with the 5200 axles. Not sure if we’re the first with this spring version but think we may be. We’ve only towed about 125 miles but so far so good. Will update in a week or so after we have traveled a much longer distance. GJ, one of the guys at Alcan said the 5-leaf spring weighs in at around 23 pounds, so, if that is accurate, I’d say the 4-leaf is more than 17. But I certainly don’t know for sure. 1 1 Joe and Mindy ▪️ 2019 Legacy Elite II ▪️ Hull 457
Mountainman198 Posted May 30 Author Posted May 30 7 hours ago, jdmmtx said: We had the 4-leaf Alcan springs installed yesterday along with the 5200 axles. Not sure if we’re the first with this spring version but think we may be. We’ve only towed about 125 miles but so far so good. Will update in a week or so after we have traveled a much longer distance. GJ, one of the guys at Alcan said the 5-leaf spring weighs in at around 23 pounds, so, if that is accurate, I’d say the 4-leaf is more than 17. But I certainly don’t know for sure. Glad you got what you wanted. Lew and his team are Great. the springs you bought are just like the top one in the attached pic, minus the bottom most (short) leaf, correct? Please keep us advised as you put more miles on the new suspension 1 2021 Elite II, Hull# 898 2018 Toyota Tundra, 2003 Dodge Ram 3500 5.9l SRW
Geronimo John Posted May 30 Posted May 30 (edited) On 5/28/2025 at 12:30 PM, CRM said: Why the focus on the weight of the spring and where does this number come from? I admit that I know nearly nothing about leaf spring tech, but shouldn't the weight rating of the spring and the quality of the steel and construction be all that really matters? More steel means a spring is likely to be able to handle stress longer for a given design. The weight of the spring design can be found in it's specifications. Under no circumstances would I replace my springs with a lightweight version. (Edit: under 16 pounds) Where made is a different discussion entirely. Edited May 31 by Geronimo John Clarified what a light weight version is... 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Geronimo John Posted May 30 Posted May 30 (edited) On 30 May 2025 at 9:15 AM I spoke with Tim at ALCON. He responded with shipping weights. So I asked him to actually weigh the naked springs we are using. Here is his verified statement: 4 Leaf 2,000 Pound Rated Spring with 19 1/2 pounds of USA made Steel 5 Leaf 2,700 Pound Rated Spring with 23 pounds of USA made Steel As I stated a couple of times above, the ALCON 4 leaf clearly has the Rating (2,000#), weight (19#+), and compliance (4-Leaf) to make it very well suited for use by most OTT owners. As such, it is my recommendation for likely +/- 85% of the fleet to use as replacements. If price point is of concern, then the Dexter PR4 springs fits the bill as well. Also as indicated in a few places in this mile long thread, if you are heavy and/or do a lot of boondocking with questionable roads/paths or hiking trails with your Ollie, you are part of the +/- 15% of the fleet and should consider the USA made Alcon 5 leaf spring. GJ Edited May 31 by Geronimo John typos 1 3 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Geronimo John Posted May 30 Posted May 30 15 hours ago, jdmmtx said: We had the 4-leaf Alcan springs installed yesterday along with the 5200 axles. Not sure if we’re the first with this spring version but think we may be. Rock Solid. Wish I had the same with disk brakes too! GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
jdmmtx Posted May 31 Posted May 31 16 hours ago, Mountainman198 said: the springs you bought are just like the top one in the attached pic, minus the bottom most (short) leaf, correct? Correct! Joe and Mindy ▪️ 2019 Legacy Elite II ▪️ Hull 457
Galway Girl Posted Monday at 04:45 PM Posted Monday at 04:45 PM On 5/30/2025 at 12:42 PM, Geronimo John said: As I stated a couple of times above, the ALCON 4 leaf clearly has the Rating (2,000#), weight (19#+), and compliance (4-Leaf) to make it very well suited for use by most OTT owners. @Geronimo John I’m planning on doing the 4 leaf pack later this fall. Do you think for new shocks it’s better to use new Bulldog Shocks or stick with the OEM Monroe’s. I’ve changed out my Monroe’s about 2 years ago. I’m thinking of using new Bulldog’s and keeping the 2 best old Monroe’s as spare. Thanks for your advice. craig 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com
Geronimo John Posted Monday at 09:48 PM Posted Monday at 09:48 PM 4 hours ago, Galway Girl said: I’m planning on doing the 4 leaf pack later this fall. Do you think for new shocks it’s better to use new Bulldog Shocks or stick with the OEM Monroe’s. I’ve changed out my Monroe’s about 2 years ago Craig: I got 40K Miles out of our OEM Monroe shocks. All four of them were fine. With tires off they are a snap to change, I would do so when doing the springs. But a lot of others have gotten a lot less miles on their OEM Monroe shocks. I have no experience with the Bulldog's, but from this forum it appears they are doing well. How well vs. cost? How about it fellow "Bull Doggers" Any shocking experiences so far? 🙂 GH 1 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
jd1923 Posted Tuesday at 10:50 PM Posted Tuesday at 10:50 PM (edited) On 6/2/2025 at 9:45 AM, Galway Girl said: I'm planning on doing the 4 leaf pack later this fall. We're traveling this week, 1300 miles in a few days on our original leaf springs (backup set onboard in case of roadside failure). This will be our first trip of real mileage, likely 4500 miles when back home and done. I love auto restoration with HD/HP parts, so I will start collecting parts, budget permitting over the next year or two, as I always have. First, I will purchase two 5200 LB axles to fit the Oliver (68" or 68 1/2")? Then likely a disc brake system, although upgrading from 10" to 12" drum brakes may be enough for a trailer (cost basis). Then we will go with the Alcon recommended leaf springs, proven by our friends and confidants, Lance @Mountainman198 (how are you buddy)? And of course Steve @ScubaRx (call me before I call you), and say hey to Tali, see you soon)!!! When you see Steve's 3500+ Diesel Truck, 1000 LBS of tools onboard (beside the usual campin' stuff), he is cruisin'. 🤣 We're are going to have a b!tch'n setup (when?) and when we're up I will likely mount my Honda CRF in place of the front basket and mount a big-@ss basket in the rear. I totally need a waterproof carrier like a Thule carrier, just to hold my acoustic guitar! And to carry all the extra weight, my 25-year-old Ram-Cummins will need extra leaf springs on each side of the rear axle! 🤣🤣🤣 Edited Tuesday at 11:40 PM by jd1923 2 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Geronimo John Posted Thursday at 07:23 PM Posted Thursday at 07:23 PM On 6/3/2025 at 12:50 PM, jd1923 said: I will likely mount my Honda CRF in place of the front basket Now that is a bad-boy machine I could really enjoy! I would likely go for the endure street legal 350 version. In a younger day, I had a 400 Penton KTM and Husky CR400. Both were way too pippy on the torque band, and more than I could handle even then as a young beast. The new 350 would have plenty of power for what I'm likely to get into. If I wait too long then likely a 250! 😞 And a big box on the rear. I see both of these efforts in the future! Thanks for sharing. GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Geronimo John Posted Thursday at 07:25 PM Posted Thursday at 07:25 PM Mountainman: Sorry for the off topic response. GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Mountainman198 Posted Thursday at 08:12 PM Author Posted Thursday at 08:12 PM 45 minutes ago, Geronimo John said: Mountainman: Sorry for the off topic response. GJ No worries. I have a 1979 Husky 390WR that I would put on my tongue, balanced-out by a hitch-mounted Big Green Egg on the back 1 2021 Elite II, Hull# 898 2018 Toyota Tundra, 2003 Dodge Ram 3500 5.9l SRW
jd1923 Posted Thursday at 11:09 PM Posted Thursday at 11:09 PM (edited) 4 hours ago, Geronimo John said: I would likely go for the endure street legal 350 version. In a younger day... Mine, I call the "old man's bike!" It's an '03 CRF230, much detuned from the Motorcross CRF250s. The seat is also lower, so you can straddle the bike, both feet on the ground. And of course, it has electric start. I rebuilt everything on it 5-6 years ago; new tires, brake fluid and fork oil, HD springs for the 200+ LB rider, new seals, cleaned the carb, etc. It rides great and right in Prescott we have a state OHV recreation site called Alto Pit. It was a granite quarry and they have 30-40 groomed and banked trails. Adam and I have been riding there for 20 years. It's a blast! 🤣 I really want to travel with this bike, my 1970 Yamaha R5! Though it needs everything done. I have all the parts it needs including new seat foam and cover, NOS taillights, carb kits, etc. Somehow I just found this picture online and it is the exact bike I own, same seat tears, America Flag Peace sticker on the side cover, bought in Florida 9 years ago for $900. I'd put some enduro tires on it for trail riding. This is a 350cc 2-stroke that can get up to highway speeds in just a couple of heartbeats! Second pic is an example of restored R5! Edited Thursday at 11:36 PM by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators topgun2 Posted Thursday at 11:53 PM Moderators Posted Thursday at 11:53 PM 4 hours ago, Geronimo John said: And a big box on the rear. You mean - like this? 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
John Dorrer Posted 23 hours ago Posted 23 hours ago Nothing like "A Post Hijack"🤣 1 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
jd1923 Posted 21 hours ago Posted 21 hours ago 1 hour ago, John Dorrer said: Nothing like "A Post Hijack"🤣 After 25 pages of comments, it's been jacked a few times. All anybody needs regarding the Alcan Leaf Spring mod is the read the first couple of pages. 🤣 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
John Dorrer Posted 16 hours ago Posted 16 hours ago 5 hours ago, jd1923 said: After 25 pages of comments, it's been jacked a few times. All anybody needs regarding the Alcan Leaf Spring mod is the read the first couple of pages. 🤣 Yep🙃 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Patriot Posted 16 hours ago Posted 16 hours ago (edited) 7 hours ago, John Dorrer said: Nothing like "A Post Hijack"🤣 It’s a common theme here John. What rules? Seems like anything goes! 🤣 Edited 16 hours ago by Patriot 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina 🇺🇸
John Dorrer Posted 16 hours ago Posted 16 hours ago 14 minutes ago, Patriot said: It’s a common theme here John. What rules? Seems like anything goes! 🤣 🤣 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
