Jps190
Everything posted by Jps190
I haven't been on the forum for awhile but it's funny that this thread was revived recently. I took my Hull #887 down to Tallahassee this past February (2025) to have MAC put on their permanent coating. After 6-8 months the coating began to fail on all of the roof and the front of the trailer. When I got on their website to contact them I noticed the change in their offerings for different surfaces. I had a little difficulty getting someone to contact me regarding my issue but I finally received a call from one of the owners. I explained the situation and said that the only acceptable solution for me would be a refund. He agreed and I received my money back a week later. While I am disappointed that the permanent coating didn't work out for me I have to say that their integrity is top notch. He even offered to let me bring the trailer back and have them polish it and remove the coating so I could wax it normally. Ceramic is great when if you store your vehicles under cover but if you store outside the sun will win in the end. John
Starlink Mini Installation- 2022 LEII- Alternate Approach
Jps190 replied to dhaig's topic in Ollie Modifications
Yeah, it’s pretty simple. I’m 6 feet tall so I just stand on the Oliver ‘bumper” to attach it. I put it together on the ground and once it is attached I fire it up and let it sort itself out. Once it has figured its position I just reach up and align it. -
I also did the POE injector method for powering the Mini. As far as mounting I initially had it on top of my flagpole but the ended up being a problem with the cable and the flags getting bunched up. This is my current method for mounting on the Oliver. It has been working great so far. Links below. NEEWER Aluminum Mount Accessories Kit Compatible with Starklink Mini, Adjustable Roof Rack Super Clamp Mount, RV Ladder Pole Clamp Kit for Yacht Camper, Not for The Lastest Pipe Adapter, ST83+NA02 https://a.co/d/5qcuwb6 ZUOS 8" Glass Suction Cup Lifter, 560lbs Load Capacity, Green, Metal Handle & ABS Pump, Vacuum Glass Lifter https://a.co/d/ippF5gt -
Million Dollar Highway in a half ton truck with LE2?
Jps190 replied to routlaw's topic in Towing an Oliver
We were in Ouray last fall and were heading to Great sand dunes after that so we had the same decision to make. We had driven down to Silverton without the trailer and that was exciting enough. Woke up the day of departure and it was raining so 550 was a no go for us. Headed north back up through Montrose then 50 towards Gunnison. If there is even the slightest chance of rain I would avoid it. -
I just setup standby mode and I am sitting here watching youtube with zero buffering. 🤷♂️
Fast forward and now we have 5 million songs on demand in our pockets!
For anyone with the harbor freight flagpole and the Starlink mini, a 1 1/4 inch PVC union works perfectly with the mount that comes with the starlink. You just need to drill new holes for the clear support ring a little lower down to make room for the PVC.
Epoc Lithium "Keep-It-Simple" Upgrade Advice
Jps190 replied to tallmandan's topic in Ollie Modifications
Consider redundancy also. With 2 batteries you aren’t dead in the water if one fails. With one 460 you would be SOL. Not that these batteries fail that often but it can happen as with all electronics. John -
It really depends on how particular you are about how your ollie looks and also how you store it. I have ceramic on both my truck and my wife's car. Her car lives in the garage and still looks and washes like the day the ceramic was applied. My truck lives outdoors and the ceramic started to fail after the 2.5 year mark. If I stored my trailer indoors then the ceramic would be a no brainer but since my Oliver lives outside at a storage facility I just wash it occasionally and but and wax every 6 months. Does it look perfect, no, but the great part about gelcoat is that it can always (within reason) be brought back to life with a little effort. John
The houghton is designed to have the fan run when the compressor is off. Turing the fan to low makes it less noise and still allows the air to circulate. The issue with the Houghton is that the thermistor is up inside the unit which is why the fan was designed to run constantly according to the manufacturer. I would return the unit to its original design (no relay) and see if that solves your problem. John
We just finished up a 4 week trip and during the last few days we have a horrible gray tank smell in the trailer after a travel day. The first time I noticed it I verified the valve was closed and before the next travel day I made sure there was water in all the traps (both sinks and shower). Happened again today on or last leg home. Tank was empty, valve was closed (verified under the front seat). Anyone have this issue or ideas before I start tearing into things? John
I just looked at my hinge pins and they appear to be installed opposite of those directions also. john
Just my .02 but if I were you, I would seriously consider the switch to Lithium. If you are boondocking 9 days at a time then lithium will give you much better performance in all aspects. They are lighter, last longer, charge faster and you can pack more power into a fixed amount of space. The Elite 2 battery tray can fit 2 of the Epoch 300ah batteries which would give you plenty of power for long boondocking adventures. John
I have done some rather extensive mods to the electrical in my trailer. I have 2 SCCs that are both run through a Victron Lynx distributor. One SCC is for the roof solar (600 watts) and the second is fed from the zamp solar port on the side. The advantage of having the SCC in the trailer as opposed to on the solar panel is that you can run small gauge wires since the amperage is relatively low coming out of the panel. When panels are run in series the Amps aren’t ramped up until after the SCC. Using smaller gauge wire makes it easy to locate your portable panels away from the trailer which may be in the shade. I just use cheap landscape wire which is easy to roll up an store away.
It’s been awhile but here is how the final install turned out. The fridge fit perfectly into the old surround that I scavenged from the norcold. I planed down a piece of walnut to cover the hole, install the digital display and add a vent. Overall turned out great.
Please help me with 2021 rooftop solar specifications
Jps190 replied to GlacierGirl's topic in Mechanical & Technical Tips
I second the Epoch batteries. Great build quality. Those Dakotas are WAY overpriced. John
There is no way to remove the screws from the front without pulling the fridge out. You may be able to get to the screws through the upper vent on the outside of the trailer. There are only 2 of them if I recall correctly. John
Looks Like Jim is the lucky winner. I’ll be in touch. John
