Traveling Angels Posted April 26, 2024 Posted April 26, 2024 Any ideas for easy install of a 12V access to exterior of Elite 2? We want to run an external freezer without running inverter! I have a few ideas, but has anyone already installed this? 1
Steve Morris Posted April 26, 2024 Posted April 26, 2024 Not yet, but I plan to add an external Anderson plug on the lower portion of the propane housing. I’ll wire it into the front jack power connection. I’ve already purchased this plug. https://a.co/d/dZGlkHd My refrigerator in the tow vehicle has an Anderson plug, so this will be a more secure setup than a typical cigarette lighter outlet. And the 640 A/hr batteries in the trailer won’t even notice the extra 2-3A load of the fridge. 4 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
Galway Girl Posted April 26, 2024 Posted April 26, 2024 (edited) I use the solar accessory plug which is near my 2019 battery compartment for several 12v accessories. It has a SAE connection that is wired through a fuse to the trailer batteries. While its SAE connector it set for zamp panels it works for anything you wish. Just pay attention to polarity as the zamp connecters are reversed from normal SAE. Adapters can be made from that SAE plug to your fridge. Zamp Solar Port On Oliver EII - Note : Top Pin is ( + ) Terminal Bottom is ( - ) Edited April 26, 2024 by Galway Girl Add pix 1 4 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine Aug 2024 on way to Nova Scotia.
Traveling Angels Posted April 26, 2024 Author Posted April 26, 2024 (edited) Great! I’ll check this plug out! I was thinking of that exact location for a plug but hadn’t heard of the Anderson plug! Both are good ideas, I’ll decide today, which will work best for me! I appreciate it! Edited April 26, 2024 by Traveling Angels
Moderators topgun2 Posted April 26, 2024 Moderators Posted April 26, 2024 If you don't have that "Solar Plug" and still want exterior 12 volt, there are several owners that have installed a plug port similar to the ones on the interior of the Oliver. Usually the location is near the external 120 volt outlet on the curb side rear. Just on the interior from this location there are several 12 volt lines that can be tapped into fairly easily. Or, of course, a new line could be run around the basement back to the fuse box if a dedicated circuit was required. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Ronbrink Posted April 26, 2024 Posted April 26, 2024 (edited) 2 hours ago, Traveling Angels said: Great! I’ll check this plug out! I was thinking of that exact location for a plug but hadn’t heard of the Anderson plug! I purchased the Powerwerx plug @Steve Morris highlighted, but returned it because there is no weatherproof way to seal it when in use. Even if mounted inside the propane tank housing there is a chance of moisture intrusion. I keep my Dometic dual-zone in the TV under cap and primarily operate it on a solar portable power station. I’ve never considered taking it out of the TV when at camp; it’s very heavy when loaded, and like keeping it out of the elements and secure from theft. However, as backup I can run it from a bumper-mounted Anderson. Although this particular plug can be fitted with an environmental boot as shown, it is not flush-mount and better suited for a forward rather than a side Oliver mount. I also use this Anderson to run the Viair. Edited April 26, 2024 by Ronbrink 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Ronbrink Posted April 26, 2024 Posted April 26, 2024 32 minutes ago, topgun2 said: If you don't have that "Solar Plug" and still want exterior 12 volt, there are several owners that have installed a plug port similar to the ones on the interior of the Oliver. Usually the location is near the external 120 volt outlet on the curb side rear. Just on the interior from this location there are several 12 volt lines that can be tapped into fairly easily. Or, of course, a new line could be run around the basement back to the fuse box if a dedicated circuit was required. Bill This reminded me of a Furrion Solar Port inlet I believe installed by @John E Davies if memory serves me. I copied this pic for future reference; multi-use for solar and fridge. Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
MAX Burner Posted April 26, 2024 Posted April 26, 2024 4 hours ago, Ronbrink said: I also use this Anderson to run the Viair. Same here. We use the same Anderson to connect the 12v-12v Charger between the TV and OTT. The fitment is such that they clean off oxidization enough for a good contact every time they're plugged/unplugged. Not cheap, but bomb proof... Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Geronimo John Posted April 26, 2024 Posted April 26, 2024 15 hours ago, Traveling Angels said: Any ideas for easy install of a 12V access to exterior of Elite 2? Our solar power port is similar to the Z-Amp one. I chose to mount it on the battery compartment door itself. Ran wires to the litho's and shunt with a fuse in line. Rationale is keeping the run as short as possible and not drilling another hole in the fiberglass wall of Ollie. GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ronbrink Posted April 26, 2024 Posted April 26, 2024 (edited) 1 hour ago, MAX Burner said: Same here. We use the same Anderson to connect the 12v-12v Charger between the TV and OTT. The fitment is such that they clean off oxidization enough for a good contact every time they're plugged/unplugged. Not cheap, but bomb proof... The DC/DC connection is the primary purpose of my bumper-mount install, but great for a convenient 12v power source. 💥KAPOW!!💥 Edited April 26, 2024 by Ronbrink 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
rich.dev Posted April 26, 2024 Posted April 26, 2024 I don’t want to hijack the OPs thread, but to all of you that’s also using the external Solar suitcase port as a power source, I assume that’s only possible if the charge controller is part of the solar suitcase and not inside the the trailer? **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Moderators mossemi Posted April 26, 2024 Moderators Posted April 26, 2024 2 hours ago, rich.dev said: I don’t want to hijack the OPs thread, but to all of you that’s also using the external Solar suitcase port as a power source, I assume that’s only possible if the charge controller is part of the solar suitcase and not inside the the trailer? I have a folding 100 watt solar panel with an on board CC. I have always thought that a CC mounted in the Ollie would be a better solution if I needed to place the solar panels further away from the batteries due to line loss. This would provide a higher voltage at the CC in the RV. Which led me to think a 3 position battery switch would be needed if I did mount the CC in the Ollie and wanted to supply 12V's to power an electric cooler. I can plug into my solar port now because it is wired straight to the batteries. Mossey 3 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
rich.dev Posted April 27, 2024 Posted April 27, 2024 2 hours ago, mossemi said: Which led me to think a 3 position battery switch would be needed if I did mount the CC in the Ollie and wanted to supply 12V's to power an electric cooler. Good idea!😉 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
MAX Burner Posted April 27, 2024 Posted April 27, 2024 9 hours ago, Ronbrink said: 💥KAPOW!!💥 Exactly, right on! HA! 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Geronimo John Posted April 27, 2024 Posted April 27, 2024 6 hours ago, mossemi said: This would provide a higher voltage at the CC in the RV. Which led me to think a 3 position battery switch would be needed if I did mount the CC in the Ollie and wanted to supply 12V's to power an electric cooler. I can plug into my solar port now because it is wired straight to the batteries. From a risk management perspective, the three way eventually will cause issues with an OOPS plug in. Why not just use one Zamp port labeled solar input, and a second one next to it labeled Power Port? No confusion that the switch may cause AND you could for the same cost have a solar input and load attached at the same time. Also "Wired straight to the batteries" is something to ponder upon. Suggest having an inline fuse on all inputs/outputs. Just for safety grins. GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
MAX Burner Posted April 27, 2024 Posted April 27, 2024 6 hours ago, mossemi said: I can plug into my solar port now because it is wired straight to the batteries. That's exactly our thought process too, Mike. We, like many owners have done, mounted our external 12vDC receptacle on the battery compartment hatch and wired it to the Victron SmartShunt (NEG) and batteries (POS) directly with an inline fuse. Serves both as a solar input from the Renogy 200W module "suitcase" kit and an accessory 12vDC output plug. On cloudy days when the BBs need a bit of a bump in solar, it's a snap to connect the suitcase array to the questionably "weatherproof" receptacle on the battery hatch. 1 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Geronimo John Posted April 27, 2024 Posted April 27, 2024 15 hours ago, Ronbrink said: bumper-mounted Anderson I sure like your weather proof Anderson port way better than my plastic one. Can you share a cut sheet or purchase info for it? Is it weather proof on the back side as well? Thanks GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ronbrink Posted April 27, 2024 Posted April 27, 2024 (edited) 8 hours ago, Geronimo John said: I sure like your weather proof Anderson port way better than my plastic one. Can you share a cut sheet or purchase info for it? Is it weather proof on the back side as well? For product details, go to powerwerx.com and search ‘environmental boot’. These boots are completely sealed when installed, front and back. Here is a pic of the ‘source side’ and ‘load side’ boots joined to power the DC-DC in the Oliver, the caps also mate up. Here is a pic of a plug extension wire (‘load side’ boot) I assembled to enable use of the bumper-mounted Anderson to operate my Dometic dual-zone staged under cap in the TV bed, as necessary. Edited April 27, 2024 by Ronbrink 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Moderators mossemi Posted April 27, 2024 Moderators Posted April 27, 2024 8 hours ago, Geronimo John said: Also "Wired straight to the batteries" is something to ponder upon. Suggest having an inline fuse on all inputs/outputs. Just for safety grins. That goes without saying! Mossey 3 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Moderator+ ScubaRx Posted April 28, 2024 Moderator+ Posted April 28, 2024 20 hours ago, Geronimo John said: Also "Wired straight to the batteries" is something to ponder upon. The negative side should run through the shunt rather than to the batteries. 3 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Moderator+ ScubaRx Posted April 28, 2024 Moderator+ Posted April 28, 2024 (edited) On 4/25/2024 at 9:38 PM, Traveling Angels said: Any ideas for easy install of a 12V access to exterior of Elite 2? We want to run an external freezer without running inverter! I have a few ideas, but has anyone already installed this? I would pick a location where you want the freezer to sit and install one of these near it. You would probably want to run a new power line from the distribution center under the dinette to power only this receptacle. You can pick up the negative side from the buss bar under the aft dinette seat. You'll need a 1-1/8" hole saw to cut the mounting hole. Edited April 28, 2024 by ScubaRx 4 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
MAX Burner Posted April 28, 2024 Posted April 28, 2024 4 hours ago, ScubaRx said: I would pick a location where you want the freezer to sit and install one of these near it. We use Blue Sea Systems components whenever possible - we've had good experience with every BSS product installed on Casablanca, FYI. High quality components, IMO. 2 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Wandering Sagebrush Posted April 28, 2024 Posted April 28, 2024 7 hours ago, MAX Burner said: We use Blue Sea Systems components whenever possible - we've had good experience with every BSS product installed on Casablanca, FYI. High quality components, IMO. I agree ! You can’t go wrong with Blue Sea! 1 Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L
John Dorrer Posted April 28, 2024 Posted April 28, 2024 Is it possible to convert one of the two 110 exterior plugs to 12v? 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Moderator+ ScubaRx Posted April 28, 2024 Moderator+ Posted April 28, 2024 36 minutes ago, John Dorrer said: Is it possible to convert one of the two 110 exterior plugs to 12v? It could be done. You would want make sure to use a polarized plug so that the positive and negative can’t be reversed. It might not even matter, depending on what you plan to use it for. 2 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
