Patriot Posted May 10, 2025 Posted May 10, 2025 (edited) A big thanks to @Ollie-Haus for passing along this RV water hose upgrade while at the rally. It’s hard to imagine not having to wrestle with our fresh water white Camco hoses any more when storing them in the milk crate in our Oliver basement. So based on Chris’s recommendation, I scooped up (3) of these Gorilla collapsible 25’ hoses while at Home Depot this morning. https://www.homedepot.com/p/Gorilla-1-2-in-x-25-ft-Marine-and-RV-Hose-GMAR0025/325990305 “Two is one and one is none”.🇺🇸🫡😊 Edited May 11, 2025 by Patriot 1 5 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Rolind Posted May 11, 2025 Posted May 11, 2025 This is a great hose. I roll up ours into a milk crate and still plenty of room for the 30 amp power cord and a ridgid charger and drill. Recommend it with no reservations. I got mine at Home Depot or maybe Lowe’s. 1 Robert and Cheryl, Louisville, KY, Legacy Elite II Hull #1390 Oliphino, TV F250 Tremor
Patriot Posted May 11, 2025 Author Posted May 11, 2025 4 hours ago, Rolind said: This is a great hose. I roll up ours into a milk crate and still plenty of room for the 30 amp power cord and a ridgid charger and drill. Recommend it with no reservations. I got mine at Home Depot or maybe Lowe’s. Glad to hear your positive review. It will be a space saver and much easier to manage. Thanks! 3 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
John Dorrer Posted May 11, 2025 Posted May 11, 2025 10 hours ago, Patriot said: Glad to hear your positive review. It will be a space saver and much easier to manage. Thanks! When we get home. Carry 3 water hoses cooler in the bed. This looks like a winner. 3 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Geronimo John Posted May 11, 2025 Posted May 11, 2025 Do these hoses "shrink up" a bunch when not under pressure or just go flat? When storing do you need to twist them when coiling around your arm or placement into a bucket/box? Tried to find a video of them was was not successful. GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Patriot Posted May 11, 2025 Author Posted May 11, 2025 1 hour ago, Geronimo John said: Do these hoses "shrink up" a bunch when not under pressure or just go flat? When storing do you need to twist them when coiling around your arm or placement into a bucket/box? Tried to find a video of them was was not successful. GJ GJ, I have not used the hose yet, but it’s my understanding that they flatten back out to the shape you see it in the packaging. @Ollie-Haus or @Rolind can give more feedback on field use and storage. 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Patriot Posted May 11, 2025 Author Posted May 11, 2025 (edited) 2 hours ago, John Dorrer said: When we get home. Carry 3 water hoses cooler in the bed. This looks like a winner. Agree John, this has to be better than trying to put that a hard white plastic mind of its own magical “Camco Geine hose” back in the bottle. 😂 Edited May 11, 2025 by Patriot 2 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderators Mike and Carol Posted May 11, 2025 Moderators Posted May 11, 2025 3 hours ago, Patriot said: GJ, I have not used the hose yet, but it’s my understanding that they flatten back out to the shape you see it in the packaging. @Ollie-Haus or @Rolind can give more feedback on field use and storage. They are like fire hoses, they don’t shrink up just flatten out. Very easy to handle and use. We’ve been using these type hoses for years. I don’t have much patience for traditional hoses, especially in cold weather. 7 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
John Dorrer Posted May 11, 2025 Posted May 11, 2025 30 minutes ago, Mike and Carol said: They are like fire hoses, they don’t shrink up just flatten out. Very easy to handle and use. We’ve been using these type hoses for years. I don’t have much patience for traditional hoses, especially in cold weather. Oh Ya!, that dreaded cold weather memory 3 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
jd1923 Posted May 12, 2025 Posted May 12, 2025 (edited) Anybody know of this style hose in 5/8” or 3/4” ID? On second thought, I don’t think we could use a flat hose. We have a 10’ hose and water filtration system with a 4’ hose attached. When at a campsite with water, this 15’ length is all we need. Then we have a 25’ hose when a longer reach is required. I need the 25’ plus 10’ hoses to reach from our truck 35-gal water supply to the Boondocking port. This is where a flat hose will not work since you cannot pull water through a flat hose. We fill this way more often than we connect to campground water. I've found if I wind the hose in large 3’ dia loops, squeeze it oval shaped to get it into the Oliver trunk, it unwinds nicely. If you coil tight, it’s hard to get the hose to lay flat. Edited May 12, 2025 by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Ollie-Haus Posted May 12, 2025 Posted May 12, 2025 (edited) 6 hours ago, Geronimo John said: Do these hoses "shrink up" a bunch when not under pressure or just go flat? When storing do you need to twist them when coiling around your arm or placement into a bucket/box? Tried to find a video of them was was not successful. GJ The hose is soft and pliable even in cold temps. It rebounds to its original flat shape, self draining in the process. I roll mine up in a flat coil for storage. It’s specifically for potable water. When pressurized, if it gets a kink, just give the hose a flip and the kink pops out. We’re a year into this hose and won’t be going back to a “ regular” hose ever again. It comes with a very good warranty on top of all that. Home Depot is the source. Edited May 12, 2025 by Ollie-Haus Typo 1 4 1 What's today?............. the most frequently asked question as a retiree 🙄 Chris and Stacie Neuhaus Greenfield, Indiana 2021 Ford F350 7.3L Tremor (Redzilla) LE2 #1373 - Ordered 10/21/22 - Delivered 05/10/23
Patriot Posted May 12, 2025 Author Posted May 12, 2025 (edited) 5 minutes ago, Ollie-Haus said: The hose is soft and pliable even in cold temps. It rebounds to its original flat shape, self draining in the process. I roll mine up in a flat coil for storage. It’s specifically for potable water. When pressurized, if it gets a kink, just give the hose a flip and the kink pops out. We’re a year into this hose and won’t be going back to a “ regular” ever again. It comes with a very good warranty on top of all that. Home Depot is the source. Thanks Chris! Nothing like tried and true field experience. Keeping it simple on the hose front! Edited May 12, 2025 by Patriot 3 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Jason Foster Posted May 12, 2025 Posted May 12, 2025 Storage is a premium in an Oliver. I like this idea and will be upgrading in the near future. 4 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Moderators topgun2 Posted May 12, 2025 Moderators Posted May 12, 2025 14 hours ago, Ollie-Haus said: The hose is soft and pliable even in cold temps. For a number of years I've had a similar hose - but - it is not any more pliable than a regular round hose and it gets a bit stiffer just like a regular round hose. Therefore, if you are in the market for one of these "flat" hoses I'd suggest sticking with this recommended brand. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted May 12, 2025 Author Posted May 12, 2025 (edited) 5 minutes ago, topgun2 said: For a number of years I've had a similar hose - but - it is not any more pliable than a regular round hose and it gets a bit stiffer just like a regular round hose. Therefore, if you are in the market for one of these "flat" hoses I'd suggest sticking with this recommended brand. Bill Sounds like a perfect time to switch to the Gorilla hose Bill! 🤔 Edited May 12, 2025 by Patriot 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderators topgun2 Posted May 12, 2025 Moderators Posted May 12, 2025 54 minutes ago, Patriot said: Sounds like a perfect time to switch to the Gorilla hose Bill! 🤔 For the amount that I use any of the four potable water hoses I presently have I'm too "cheap" to simply throw any of them out. I did buy one of those Zero G hoses a couple of years ago to be used when needed for length and/or as a backup in the event something happened to the other one I carry. However, when it comes time I'll certainly look at this Gorilla. 2 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
MAX Burner Posted May 13, 2025 Posted May 13, 2025 @Ollie-Haus: Many thanks for showing this hose to me, @Geronimo John, and @Patriot at the rally! Definitely a no-brainer "must have" item - especially for space saving feature. I'm tired of wrestling with that stiff white Camco hose when rolling it up. Headed to Home Dumbo today for 2 of these.... We'll do an OPS-check this weekend down south. 2 is 1 and 1 is none! 5 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Jason Foster Posted May 14, 2025 Posted May 14, 2025 10 hours ago, MAX Burner said: Home Dumbo 2 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Ronbrink Posted May 14, 2025 Posted May 14, 2025 On 5/12/2025 at 10:52 AM, topgun2 said: I did buy one of those Zero G hoses a couple of years ago to be used when needed for length and/or as a backup in the event something happened to the other one I carry. I’m a zero-G guy, carry three for dedicated purposes; freshwater fill, black tank rinse and general wash hoses. I find them easy to roll up and stow; they are very flexible and durable. Each are setup with quick connects and accessories for their respective applications. 3 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Patriot Posted May 14, 2025 Author Posted May 14, 2025 (edited) 1 hour ago, Ronbrink said: I’m a zero-G guy, carry three for dedicated purposes; freshwater fill, black tank rinse and general wash hoses. I find them easy to roll up and stow; they are very flexible and durable. Each are setup with quick connects and accessories for their respective applications. Nice! 👍🏻Options are always good! Strong reviews too. -https://www.amazon.com/Lightweight-Leakproof-OrangeBlack-10-FT/dp/B0DNM146J5/ref=sr_ Edited May 14, 2025 by Patriot 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderators mossemi Posted May 14, 2025 Moderators Posted May 14, 2025 I will be the first to admit that I lean toward the lazy side of the street! This is my method for storing the Gorilla Marine and RV hose. Mossey 5 1 2 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Patriot Posted May 14, 2025 Author Posted May 14, 2025 2 hours ago, mossemi said: I will be the first to admit that I lean toward the lazy side of the street! This is my method for storing the Gorilla Marine and RV hose. Mossey Looks a whole lot neater than my soon to be no longer used Camco water hose. 👍🏻 1 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Jason Foster Posted May 15, 2025 Posted May 15, 2025 5 hours ago, Patriot said: Looks a whole lot neater than my soon to be no longer used Camco water hose. 👍🏻 Used Camco water hose, free delivery within 10 miles. 1 2 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Jason Foster Posted May 15, 2025 Posted May 15, 2025 8 hours ago, mossemi said: I will be the first to admit that I lean toward the lazy side of the street! This is my method for storing the Gorilla Marine and RV hose. Mossey I prefer the word efficient to lazy. Less time to set up/break down means more time for the important things. Like beer. 2 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
jd1923 Posted May 15, 2025 Posted May 15, 2025 1 hour ago, Jason Foster said: Used Camco water hose, free delivery within 10 miles. Keep one if you ever need to use the boondocking port. 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
