John and Jodi Posted October 20, 2025 Posted October 20, 2025 (edited) A quick search of "awning" on the forum returns about 50 pages of posts. With multiple brands having been installed on our Olivers over the years, there's a wide variety of satisfaction and usage. We are looking to replace our Girard awning. We'd like to be able to connect something more robust to the Oliver so that we have a place to cook outside protected from rain and wind. We understand that "protected from" is a matter of degree. @Hokieman has suggested a MoonShade XL which is the direction we're thinking of (manual, staked down, wind walls available). Has anyone else added or replaced their awning? Edited October 20, 2025 by John and Jodi John and Jodi San Antonio, TX 2022 Elite II - Hull #1126 being pulled by a 2022 F-150 Powerboost. Map Legend: Red - Driven Through; Orange - Stopped In; Blue - Explored Parts; Green - Explored Whole
routlaw Posted October 21, 2025 Posted October 21, 2025 Never considered it, but for the record we have the Fiama brand and rarely if ever use it. Too much of a PITA to deal with. If you go through with it would love to hear your experiences in changing. 3 Legacy Elite II #70
Ronbrink Posted October 21, 2025 Posted October 21, 2025 (edited) Here is a setup that @Mike and Carol posted, the awning is further stabilized with support posts and screen anchored for better securement. Maybe they or others with a similar setup will chime in with their experiences. This may be an adaptation of the Lippert Solera RV Awning Shade Screen or similar product, provided pic for example only: Edited October 21, 2025 by Ronbrink 3 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Moderators Mike and Carol Posted October 21, 2025 Moderators Posted October 21, 2025 8 hours ago, Ronbrink said: Here is a setup that @Mike and Carol posted, the awning is further stabilized with support posts and screen anchored for better securement. Maybe they or others with a similar setup will chime in with their experiences. This may be an adaptation of the Lippert Solera RV Awning Shade Screen or similar product, provided pic for example only: That’s us. We use our screen often with the awning (Fiamma). If it’s windy we also stake down the support poles and the awning stays secure in some pretty high winds. Mike 1 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
dewdev Posted October 22, 2025 Posted October 22, 2025 (edited) @Mike and Carol What brand is your screen and where did you get it? Also, how does it connect to the Flamma awning? Thanks Edited October 22, 2025 by dewdev 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
Moderators Mike and Carol Posted October 22, 2025 Moderators Posted October 22, 2025 2 hours ago, dewdev said: @Mike and Carol What brand is your screen and where did you get it? Also, how does it connect to the Flamma awning? Thanks We got it at Quartzsite at one of the vendors set up outside of the big tent. Not sure what the brand is, there are no markings. It slides into the one of the two Keder Rail slots on the Fiamma awning. There’s a short piece that slides in and then the larger part of the awning zips into the smaller part at the top. Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
jd1923 Posted October 22, 2025 Posted October 22, 2025 (edited) Looks like this, several on Amazon, side shades too. https://a.co/d/95YrFh4 https://a.co/d/25pOwgP Edited October 22, 2025 by jd1923 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
John and Jodi Posted October 23, 2025 Author Posted October 23, 2025 @Ronbrink We saw the Solera as we've done our internet research. The issue with the Solera is that the black vertical line in the photo next to the window is a brace for the arm. Since our Ollies are round, the brace wouldn't work (besides being ugly). What we think we'd like is a batwing that folds out like this. It even has side walls and awning extensions. The challenge is that all of the ones we've found seem to be for cars/SUVs, so they are lower to the ground and not as long. Anyway, that's why we're asking. John and Jodi San Antonio, TX 2022 Elite II - Hull #1126 being pulled by a 2022 F-150 Powerboost. Map Legend: Red - Driven Through; Orange - Stopped In; Blue - Explored Parts; Green - Explored Whole
Ronbrink Posted October 23, 2025 Posted October 23, 2025 20 minutes ago, John and Jodi said: What we think we'd like is a batwing that folds out like this. It even has side walls and awning extensions. I’ve seen these on teardrop trailers, as well; compact and affordable. Good luck with your endeavor! Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Steve and MA Posted October 23, 2025 Posted October 23, 2025 1 hour ago, John and Jodi said: The challenge is that all of the ones we've found seem to be for cars/SUVs, so they are lower to the ground and not as long. We've been looking for a batwing awning for our TV, a Sprinter van. Add finding a reasonably priced hard-shell case to the list of challenges. Also, most of them are from Australian companies, so some are only made for left side mounting. Maybe not a problem for an Oliver since they're only 8' long when stored & 16' deployed; one could be mounted over the door to fold back, or over the window to fold forward. Steve & Mary Allyn San Antonio, TX 2022 LE II Hull #969 "Un Œuf", 2021 MB Sprinter 3500 "Polly", 2008 Pleasure-Way Excel TS "Val", 1975 GMC Glenbrook "Whoosh"
Geronimo John Posted November 28, 2025 Posted November 28, 2025 On 10/21/2025 at 4:26 AM, Ronbrink said: Maybe they or others with a similar setup will chime in with their experiences. We have the standard awning without wings. I like to move the picnic table half under and half outside of the awning. then I use three tie downs from the awning to the table itself. For week plus stays with tables, it beats collecting three each 3 gallon buckets of rocks for dead weights... much faster too. GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
