A quick search of "awning" on the forum returns about 50 pages of posts. With multiple brands having been installed on our Olivers over the years, there's a wide variety of satisfaction and usage. We are looking to replace our Girard awning. We'd like to be able to connect something more robust to the Oliver so that we have a place to cook outside protected from rain and wind. We understand that "protected from" is a matter of degree.
@Hokieman has suggested a MoonShade XL which is the direction we're thinking of (manual, staked down, wind walls available). Has anyone else added or replaced their awning?
Edited by John and Jodi
John and Jodi
San Antonio, TX
2022 Elite II - Hull #1126 being pulled by a 2022 F-150 Powerboost.
Map Legend: Red - Driven Through; Orange - Stopped In; Blue - Explored Parts; Green - Explored Whole
Never considered it, but for the record we have the Fiama brand and rarely if ever use it. Too much of a PITA to deal with. If you go through with it would love to hear your experiences in changing.
Legacy Elite II #70
Here is a setup that @Mike and Carol posted, the awning is further stabilized with support posts and screen anchored for better securement. Maybe they or others with a similar setup will chime in with their experiences.
This may be an adaptation of the Lippert Solera RV Awning Shade Screen or similar product, provided pic for example only:
Edited by Ronbrink
That’s us.  We use our screen often with the awning (Fiamma).  If it’s windy we also stake down the support poles and the awning stays secure in some pretty high winds.  Mike
@Mike and Carol What brand is your screen and where did you get it?
Also, how does it connect to the Flamma awning?
Thanks
Edited by dewdev
Thanks
We got it at Quartzsite at one of the vendors set up outside of the big tent.  Not sure what the brand is, there are no markings.  It slides into the one of the two Keder Rail slots on the Fiamma awning.  There’s a short piece that slides in and then the larger part of the awning zips into the smaller part at the top.  Mike
@Ronbrink We saw the Solera as we've done our internet research. The issue with the Solera is that the black vertical line in the photo next to the window is a brace for the arm. Since our Ollies are round, the brace wouldn't work (besides being ugly). What we think we'd like is a batwing that folds out like this. It even has side walls and awning extensions. The challenge is that all of the ones we've found seem to be for cars/SUVs, so they are lower to the ground and not as long. Anyway, that's why we're asking.
John and Jodi
San Antonio, TX
I’ve seen these on teardrop trailers, as well; compact and affordable. Good luck with your endeavor!
We've been looking for a batwing awning for our TV, a Sprinter van. Add finding a reasonably priced hard-shell case to the list of challenges.  Also, most of them are from Australian companies, so some are only made for left side mounting. Maybe not a problem for an Oliver since they're only 8' long when stored & 16' deployed; one could be mounted over the door to fold back, or over the window to fold forward.
Steve & Mary Allyn
San Antonio, TX
2022 LE II Hull #969 "Un Œuf", 2021 MB Sprinter 3500 "Polly", 2008 Pleasure-Way Excel TS "Val", 1975 GMC Glenbrook "Whoosh"
  • 1 month later...
We have the standard awning without wings.  I like to move the picnic table half under and half outside of the awning.  then I use three tie downs from the awning to the table itself.  For week plus stays with tables, it beats collecting three each 3 gallon buckets of rocks for dead weights... much faster too.
  • 3 months later...
We have a Girard awning on the starboard side.  We wanted something for the port side when we have the space and want the extra shade.   The MoonShade XL works good for this, and it is sturdy and very well made.   It is really just a lightweight tent awning, not like our heavy duty awning.  The XL version is 9’ x 12’, and the longer side just covers both windows, providing shade in the bunk as well as the dinette.  It’s expensive, but I bought it when it was a Kickstarter campaign for much less.  I would not want to use it as the primary awning.
https://moonfab.com/
17 hours ago, Hokieman said:
MoonShade XL
Which connection anchors did you use..for the side of the trailer mount?
CS
The standard plastic & aluminum mounts  that came with it.   They attach with a 3M VHB disc.  Seem very secure, but not very attractive.   I bought the optional aluminum mounts with 3M VHB, but haven’t used them yet.
Edited by Hokieman
Typo
Unfortunately the awnings you describe are found on large trailers, Class A Motor Coaches and 5th Wheels. Those have large exposed frames and arms and wouldn't work on an Oliver. So with that said the awning for small trailers aren't designed to be out in winds or rain. They are designed for providing shade.
You would be better off getting a stand alone canopy with option for sides, or something like the picture. I think it would be a big mistake to remove your Girard awning. The Girard is a top of the line awning, and resale value would be lost
Thanks @jd1923 for the links. I've been wanting to order one of these privacy screens for a while. I have a Fiamma F45S (the best), so I ordered the 14',3" screen, but the 9 foot version for more space.  We'll see how it goes.  It was on sale and I used my Amazon points, so bam, only $50.
Dulepax RV Awning Sun Shade Screen with Zipper 9'X14'3'' -Second Generation RV Awning Shade Screen Significantly Improves Shadew and Privacy.Universal, Awning Screen for RV Camper with Complete Kits
Chris
o-o  2016 Legacy Elite II (demo) - Hull #110 -"Rock'in 110"
o-o  2024 Ford F-250 Lariat, 7.3L Godzilla gasser
o-o  Augusta, Georgia
