Can anyone elaborate on the extendable tongue feature of the Elite II? Is that still standard and how much adjustment can it give me?
I don't yet have one of these, but I am considering whether or not it would be practical to tow an Ollie with a "regular width" (50 inches) Polaris RzR in the back of my Ram 3500 short bed. I would like to be able to park the trailer and go exploring in the mountains with my wife and two dogs, so a pair of small motorcycles (my preference) or e-bikes are out. The dogs would ride in a cage type carrier mounted behind the passenger seats. I would probably back it in to get more of the weight toward the front of the bed.
Found on the Internet:
The truck has a massive payload so I am unconcerned about the weight, but the lowered tailgate will be a serious issue in terms of towing clearance (especially when backing). Though I could remove it if necessary. I would rather keep it in place.
I do not want to use a hitch extension at the receiver, for many reasons. Who is using the extended tongue on their Oliver, and can you please educate me about it? I have one on my little utility trailer and I think it is cool as heck.
Thanks.
John,
I believe all current trailers coming off the line are being created with a tongue that is not adjustable.  Folks were simply not in the habit of changing their tongue length, for the most part, and the new units' tongue is now a massive hunk of extruded aluminum to provide incresed structural strength.  (They are always tweaking the design for improvements). The length of new tongues is set at about the middle extension of the older, adjustable ones.  This will allow folks who desire an accessory basket on the front to have one.
Perhaps a new Elite II owner could measure the distance from the center of where the Bulldog hitch would sit on the ball to the electric jack, which would be the first obstacle.  Then you could compare it the the measurement from your hitch ball to the end of the down tailgate.
Shoutout to any of you "big guys".  How 'bout a little help!
Pete
We are out camping so I just grabbed my tape measure and took a couple of pics.  It is not adjustable.  Looks likes about 38" from the center of the hitch to the jack.
I have a 2014 model Elite II and it measures 30 inches from jack to ball.
Stan
Stan and Carol
Blacksburg, VA
2014 Dodge Durango 5.7 Hemi
Since the alimunim frame is made at the Oliver factory, perhaps they would be amenable to making its length to your specifications.  Won't hurt to ask.  They might just say "Yes, how long do you need it to be?"
Both our Oliver's had the receiver for the extendable tongue lengthened by 24 inches at our request so it's not out of the question.
  • 5 years later...
Reviving an ancient thread…. Can anybody post a few good closeup pictures of the original setup? All I could come up with is this blurry screen capture of an old factory tour. This was on an LE2.
They were using a smaller square (?) beam for the tongue main member and it appears that the extension is also an aluminum beam. The new frames are much beefier, 5” x 3” x 0.625” wall. The tricky part would be eliminating play and I believe that there was a bolt failure, that could be interesting, depending where the safety cables were located😳
Is there a beam extrusion  available with correct dimensions that would slide snugly into or over the existing big one on my later hull? Would Oliver consider modding my trailer to give an extra 12”, enough for me to install a sideways single bike tray in front of the jack? Any idea of cost? I can submit a ticket, but first I wanted to see exactly how they did it in the Olde Days.
What would be cool is if they would sell the necessary parts as an extension kit for an owner to have installed by a (very) qualified local welder. Otherwise it would be a long round trip for me to go back to TN. It is really hard to source small lengths of reeeeealy big aluminum beams. Buying a ten foot length to obtain a foot or two is not economically viable.
Welding on a fixed extension is probably going to be far simpler, but being able to remove it for storage and theft deterrence would be neat…
Thanks.
THE GUY you want to talk to at length about this is ScubaRx (Steve).  I'm sure that he can tell you the good, the bad and the very ugly on this topic.
I'd bet that there is no way at all for you to convince Oliver to do this mod for you and/or have virtually any part in doing it.  But, what do I know?
Good luck!
 There are a couple pictures in the post.
 3rd page bottom
Thanks Mike. I have to say that it looks a more than a little weak compared to the newer frames, especially with 100+ pounds of rack and wiggly bikes levering away at it at freeway speeds.... Here is one of those pics, cropped a little:
IMG-3053.jpg.4dfbb5c65b2a8c97ee1486721e9487be.thumb.jpg.db2e314db942743a026f3bf9d9cb8780.jpg
One reason I would like a fixed low mount is that it doesn't stress parts. neither the bike nor the trailer. Another is so I can drive the bike onto it using a ramp and the walk mode button.
3 hours ago, rideandfly said:
Took these photos a few years ago after installing an electronic sway device:
Bill:  I am very interested in your hitch extension.  Don't feel a need for the electronic sway device, but would love info on that extension!
Thanks,
OH COME ON JD...    Surely you would find additional projects/mods to utilize the remaining 8'...
My guess is I was probably not the only one with this thought when we read your comments.
Respectfully,
Bryan
My Visited North America Map
Thanks.
JD
would an extension off the back of your TV hitch be just as applicable ? They make different lengths.  Tongue and cargo weight may come into play. Eventually you have to say to yourself how much is too much. 🥴
1 hour ago, Landrover said:
JD
My Land Cruiser 200 has a short 112" wheelbase and a long rear overhang. I already have a +3" Andersen stinger and can't practically go longer. I wish I could..... thanks for the comment.
Thanks,
John,
Took a few additional photos and measurements this morning of Oliver's extendable hitch. I do not know what kind of aluminum they used, but I'm sure it has a pedigree. Steve (ScubaRX) probably knows.
There are 3 different sizes of square aluminum tube used, outer sizes shown. Everything is 1/4" wall, the very short sleeve welded on close to the hitch is 4" square outer measurement, slipped on and welded in place over the 3 1/2" outer tube with the 3" inner telescoping square tube.  The bolt through the short 4" tube is 3/4" Grade 8. The 3 1/2" tube welds to a cross member in the main aluminum frame, about 4' behind the LP tanks.
Looks like a major conversion if someone tried to attempt this modification. I can gather additional information, if needed.
Already see the next thing I need to do to Ollie, belly wash!
Wow. That is awesome craftsmanship.
I agree with your thoughts on the Pedigree of the AL, and it's availability.  I can only imagine what the counter guy would say by my asking for several pieces of large aluminum tubing all about a foot or less long.  I suspect I would be wearing his boot as I flew through the doors.
Unlike JD and his Land Cruiser, I think I'll look closer at welding an extension on the 2" receiver to pull back the Anderson.  Suspect it would only require about 3".  On my F-150 SuperCrew that probably would work pretty well.
I very much appreciate your taking the time and effort to showcase the solution you have on your trailer.
Mahalo,
Geronimo John
