That unit sure does look a lot like the EZ Tire TPMS but the GUTA is a bunch cheaper.
Edited by topgun2
TST system, one color monitor, 2 sensors and a repeater. I got mine from Alice at Accent my ride in Duluth, Ga. The price was 239.00. She can get other items too. Nice lady, she met me half way in the Target parking lot. I know the price was right...alot less than the TST company she gets them from. I did not need the repeater on my 17ft Casita but kept it in case I need one on the Oliver. They work great and I was so relaxed knowing with a glance at the monitor that all was good. It monitors the tire pressure and the temperature.  As you drive the tires and axles warm up and you can see the increase in both and then they stay constant. Safety First!
accentmyride@outlook.com
Edited by Fran
Not sure about all brands but my 2021 GMC came with 4 tire sensors to install in your trailer tires.  The sticker showed it as a $50 option.  These sensors send info to the OEM screen when you have the trailer connected.   Not sure when this feature became available but would be worth checking to see if you have a similar option on your vehicles.
John and Kim
2021 Oliver Elite II.   Hull #887
I think that this has been mentioned before - but - if you are ordering a TPMS then strongly consider getting six (6) sensors, or, if your tow vehicle does not already have a TPMS you should get ten (10) sensors.
Rarely (if ever) does the tow vehicle spare tire have a pressure sensor on it and they are usually difficult to get to.  Then, of course, you will need four (4) more for the Ollie II and the last of the six would be used for the spare tire on the Ollie.
Edited by topgun2
added detail
Does anyone run TPMS on the TV?
Asking for SELF...
My Visited North America Map
SNY -
Most newer TV's come standard with a TPMS.  Both my current and former truck had it and our Subaru Outback has it along with the two previous Volvo's.
Many vehicles do not have a true TPMS, the only thing it looks for is low pressure in any tire, then the idiot light flashes. My Land Cruiser shows all four pressures (to the nearest 1 psi) plus the spare tire. It would be nice if the TV system showed everything, including temperature. Having not owned a Big 3 truck later than model year 2006, I can’t comment on the newest ones. Do they show pressure for each tire? Is the alarm setting adjustable, for example if you changed tire types, or aired them down to 20 psi for off-road?
TG Bill,  Thank You.  do not let my sense of humor in any way dismiss your sincere response.
We have a 2010 GMC 1500, and Wifey will have to be pretty comatose to agree that I need a new TV, just so i now have On-Board TPMS.
I have been looking at upgrading to a (new or recent) 3/4 ton, and came close to committing to a used one on the forum a couple of months ago; However the planets were not quite aligned, for it to happen.
I will go with the 8 (4+4) remotes & Monitor and continue to look to that elusive truck.  And it gives me one more screen to monitor... Not really, Co-Pilot does  all that.
Our "newest" tow vehicle is a 2008 dodge ram 1500, 4x4, hemi. It has the idiot lights that show low pressure, but not tire pressure numbers. Still valuable. No way to monitor trailer tires.
I am in the camp of --if you own a reliable vehicle, with proper ratings, run it til you really, really find something else you want. Or, in our case, we hope to run ours til it dies.
I'm excited, and also concerned, about all the new tech in trucks. As in, if the truck always "backs in for you", how do you learn when it "doesn't ", because some board component fails? (More for new people than us, obviously. )
Conversely, I will have to say, that I  love the new safety features of newer vehicles, that we obviously do not have, like  blind side monitor, always on rear camera, pexestrian awareness, etc.
And, hopefully,  someday when I'm less confident about driving, the autopilot programs will be perfected. I know it's been really, really difficult for my mom since she gave up her driver's license.
My two cents. Probably worth the same.
Both of the trucks (2011 and 2017 F-150) and the 2020 Subaru only show tire pressure - no temp and no alarm setting except for the "alarm" of the idiot light telling you that they are low.  I'm not sure what happens with either if there is a "blow out" other than that same idiot light coming on.  As far as "airing them down" they do automatically adjust for this event once the vehicle is driven either a certain speed and/or distance.
The TPMS sensors will eventually cause the valve stems to have a slow leak. It took about 4 years for this to happen. Had them all changed out today.
TMPS.HEIC
Edited by geO
We changed our valve stems to metal when we added the tpms.
The owner of this tire shop told me even the steel ones fail because I asked him about that. SeaDawg, how long have you been running them?
We also changed our stems to metal and had the tires rebalanced with the TST TPMS sensors installed about 4 years ago.
Probably because he didn't have any to install.
I have yet to find a shop that does have the metal ones in my neck of the woods.
Eleven years.
Edited by SeaDawg
58 minutes ago, SeaDawg said:
Eleven years. We have transferred metal stems to new tires, actually.
WOW... looks like I need those steel stems. Guess I'll search the internet for them. Thanks SeaDawg, I wonder if living in the desert has any impact. I do know rubber gets messed up quick in my environment.
I purchased Tuson TPMS and had them installed in my Oliver Tires before we headed out last February.  It works very nice.  The display shows Tire pressure and temperature.  The TPMS are installed in the tire and replaces the existing stem.  The TPMS is only activated after the trailer starts moving and there is a delay before shutting down.  Batteries are integrated into the TPMS, so the entire unit will need to be replaced after about 5 years.
David
Hull 509 "The Swallow"
David
Keep an eye on the temps as it can help avert a huge problem.
Boy!  I wish I had one of dem thar things!  Really looks nice.
On the topic of TPMS - I too have metal stems for my TPMS.  But, metal stems are not necessarily the greatest thing on earth.  While I believe that metal stems generally do a better job when these external TPMS sensors are used since they "flex" less than the rubber stems.  But, in the event you are going down a rough road (off road for the most part) and hit a rock, tree root, deep rut in the road, etc. the metal stem could get broken or cracked where it is possible that the rubber stem would simply bend a bit and keep on trucking.  Also, generally speaking, a rubber stem would be a bit easier to repair in an emergency situation versus the metal stems.
Thanks for the input Bill. I don't have a 4x4 and so don't go down crazy roads until I do. Google maps has taken me down some roads I've regretted with zero turn arounds...lol I bet most know what I mean...lol
If you have a NAPA auto parts store near you, they stock the metal valve steams.
Edited by Maverick
Horace & Dianne
Chesapeake, Virginia
57 minutes ago, geO said:
Just got this protection for my Ollie against the desert sun
That's realky nice!
Low angle sun and heat may still affect your tires. Looks like 5 to 6 ft. high open wall?
I'd still cover the tires , imo.
