NCeagle Posted January 25, 2021 Posted January 25, 2021 (edited) 10 hours ago, John E Davies said: A fuse will not blow when the breakaway switch is activated when everything is working correctly, because the normal current flow is less than the fuse rating. The fuse is there to protect the wire if it should short out to ground, such as if a mouse chews through the insulation and the conductor touches the aluminum frame, and the wire suffers a severe current overload. The fuse pops, the wire is saved. If the same thing happens without a fuse, the wire overheats and literally melts somewhere. And your emergency brakes don’t work in either case. You still have to find and fix the problem, you just don’t have other burned stuff also, or, the worst case ever, have your beautiful Ollie burn to the pavement... Most people do not understand, a fuse protects the wire, not the device at the end of it. Your stereo shorts out, the fuse blows, the wire is safe, you replace the stereo and replace the fuse... no worries. Electrical fires are not to be taken lightly, use Google to look at some pics of “automotive electrical fire images”. Like this one: John Davies Spokane WA Wow - what a dramatic image. Interestingly, that's also what the battery could look like after the travel trailer broke free from the TV and crashed and burned - all because the emergency brakes didn't work due to a blown fuse that isn't supposed to be there. I think I'll wait for OTT to issue a safety recall if it's not correct as is. Edited January 25, 2021 by NCeagle 1 2020 Elite II, Hull 688 --- 2021 Silverado 2500HD, 6.6L Duramax Diesel
Frank C Posted January 25, 2021 Posted January 25, 2021 (edited) Looking at similar discussions on other trailer forums like Airstream Airforum and the Escape forum it looks like the breakaway switch is not fused by other trailer manufacturers either. Whether it is a regulatory retirement issue or not isn’t clear but the industry practice seems to be no fuse on the trailer emergency breakaway power circuit. So I wouldn’t say this is an oversight by Oliver or a flaw. It looks like it was a risk assessment decision by the manufacturers, balancing the risk of fuse problems vs. the risk of electrical short in a mission critical emergency system. And based on discussions here and elsewhere, fuse problems (wrong value installed, fuse holder corrosion, etc.) seem far more common than dead shorts in wiring. Edited January 25, 2021 by FrankC 1 2
Jim_Oker Posted January 25, 2021 Posted January 25, 2021 5 hours ago, NCeagle said: I think I'll wait for OTT to issue a safety recall if it's not correct as is. Yup, same here 2 Jim and Yanna, Woodinville WA 2004 Ford E250 camper conversion Oliver Elite II hull #709
John E Davies Posted January 25, 2021 Author Posted January 25, 2021 (edited) Well, this has been very interesting, there are strong feelings on both sides. I am waiting to see if the BAS manufacturer replies with any useful info. If so, I will post their response here. As an ex aircraft tech, my personal view of the Oliver electrical systems is that they make mistakes or weird choices through lack of care in the production line, or from marginal design engineering. Like the inverter recall a couple years ago because they left off the mandated extra chassis ground (they never caught that very serious error until it was pointed out here in the forum and they were notified as a service request). Burying important wire splices in inaccessible places. Not using minimal cable lengths, and instead leaving the many extra feet of it in an unsecured tangle, AKA “rats nest”. Using grossly oversized inverter cables, which are costly and awkward to deal with. I am making those statements based on Hull 218, they have definitely improved, but I won’t blindly accept something like the lack of fuse protection here, unless there is a documented reason for it, one that actually makes sense to me. 😬 John Davies Spokane WA Edited January 25, 2021 by John E Davies 3 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
BackofBeyond Posted January 25, 2021 Posted January 25, 2021 (edited) Perhaps it is a RIVA spec - here is a link: https://www.rvia.org/standards-regulations/laws-and-regulations & State/Cite (rvia.org) Or NHTSA. Perhaps it is a Canadian regulation? Call Oliver - I would believe they know. I don't really care to spend time searching. My 16" tandem 3500 lb axle "farm" utility trailer does not have the break-away - however my former enclosed tandem axle did have the BAS. All my boat trailers did not have BAS. Who knows??? As the BAS is a normally open - closed when activated - you would NOT know of a open fuse until it is to late - in most cases. As has been stated - Oliver must be counted on to understand the requirements, and engineer and build accordingly. I would not recommend altering the circuit - for legal reasons alone. Were one to have an issue - your Oliver takes off on it's own. the brakes do not work as designed, the subsequent wreck causes havoc on something or someone - and a subsequent investigation finds the altered circuit. Hmmm - we have seen this move before. I must say Oliver owners are a cut above - most others just use the RV until they don't - BAS - what BAS. Happy Trails all Keep them little doggies behind you Hooked up, tethered, and BAS working. Edited January 25, 2021 by BackofBeyond correction 3 Cindy, Russell and "Harley dog" . Home is our little farm near Winchester TN 2018 Oliver Legacy Elite II - 2018 GMC 2500 Duramax "Die young - As late as possible"
John E Davies Posted January 26, 2021 Author Posted January 26, 2021 Thanks for all the comments. I did hear back from a Bryson Elliot, customer service rep at Equalizer Hitch, the manufacturer of the Zip BAW switch used on our Ollies. While he VERY expertly danced around the "Why" part of my message, he did say two important things: "There is not once in our company history since we have released the zip cable that we have had a problem with the zip shorting and burning the trailer at all." He did not mention internal (inside the hull) wire failure. "There isn't a need to use a fuse with the zip breakaway cable. However we haven't ever had any issues with people using a fuse with the cable. So you can do whichever you'd prefer." He did not say why their wiring diagram shows no fuse, or even a recommended wire gauge, for that matter.... I did look all over the Web for diagrams, I found ONE that showed a fuse in this circuit. No others. So, take his comments for what they is worth, they are still vague. Do as you feel, understanding the possible (remote, but maybe serious) legal implications of modifying this wire. I will open a Service request to see what Oliver says about this. Thanks for your time and participation. John Davies Spokane WA 5 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
mjrendon Posted January 26, 2021 Posted January 26, 2021 I also looked a the wiring instructions for several other break away switch manufacturers and none of them showed a fuse in their instructions for their switches.
John E Davies Posted January 26, 2021 Author Posted January 26, 2021 1 hour ago, mjrendon said: I also looked a the wiring instructions for several other break away switch manufacturers and none of them showed a fuse in their instructions for their switches. Yep, I agree, but I did find this one with a fuse from an unverified source. But only this one.... John Davies Spokane WA 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
mountainoliver Posted January 26, 2021 Posted January 26, 2021 This would be an ideal use of a panel mounted fuse holder (probably under the rear dinette seat) visible from the trailer cabin. In particular a fuse holder that lights up when the fuse is blown. Periodic testing would be more important with a fuse installed in the emergency brake power wire. 1 2 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
John E Davies Posted January 31, 2021 Author Posted January 31, 2021 I have submitted a Service Ticket and will follow up with any new information. John Davies Spokane WA 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
JRK Posted February 2, 2021 Posted February 2, 2021 California Highway Patrol will inspect large trailers, (big ones) as a class a driver license (same one as an 18-wheeler) is required. The checklist includes many points. One of them is to verify that there is NO fuse in the breakaway wiring. The wiring is also checked. the checklist does not provide a justification, but the assumption is that if needed, a problem causing the blown fuse may exist when the trailer is rolling away from the TV. (Also, the checklist includes for the breakaway cable to be connected directly to the TV, and not the safety chain.) John 1 3 2022 Ford F150 4x4 2021 Elite I #758
John E Davies Posted March 6, 2021 Author Posted March 6, 2021 Update via email, Jason described the factory wiring of this switch, I have NOT completely inspected my trailer to verify this. The circuit is not fused, and he could not tell me why. The wire goes from the rear bus circuit breaker, then it exits through the belly and runs along the outside to the breakaway switch. So some of the wire is out in the open, but several feet of it is NOT, and that remains a fire hazard IMHO. I kept the 20 amp inline fuse that I added, and will not worry about anything more. I will continue to test the switch operation before each trip. If you feel like crawling around under your trailer, look to see if there is a wire coming out above the axles, heading toward the front. Please comment about what you find, or don't find 😉 Thanks. John Davies' Spokane WA 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
ADKCamper Posted March 6, 2021 Posted March 6, 2021 Our Ollie (Elite-I) is in winter storage now, but last fall I scoped out the route of the pink BAS feed to help me understand what's what if I ever got to the point where I could install EOH disc brakes. On my Ollie the pink wire goes from the battery side of the 20A self-resetting breaker on the tow vehicle 12V charge line (street-side,, adjacent to the wheel well) into a bundle of split-loom protected wires. It exits the hull from the bottom of that bundle somewhere very close to there, and comes out right above the street-side end of the axle. From there (also covered by split-loom) it goes to the center of the trailer and then follows the hollowed-out path forward along the bottom of the hull, along-side the soft copper propane line to a point near the front of the fiberglass chassis. From this center-forward position the pink wire then heads street-side where it is butt-spliced to the "hot" pigtail on the breakaway switch. 2 Tom & Holly 2018 Oliver Legacy Elite #409 - 320W rooftop solar, 300Ah Epoch LiFePO4, Victron Smart Solar MPPT 100/30 charge controller, PD4060CVS 60Amp Lithium-capable Converter, Xantrex PROwatt SW 2000 inverter; Tow Vehicle: 2017 Silverado 1500, 5.3L Gas, 4x4 Z71, Dbl Cab, Std Bed.
ADKCamper Posted March 6, 2021 Posted March 6, 2021 Oh - and the pink BAS "feed" wire is 12 AWG gauge... 1 Tom & Holly 2018 Oliver Legacy Elite #409 - 320W rooftop solar, 300Ah Epoch LiFePO4, Victron Smart Solar MPPT 100/30 charge controller, PD4060CVS 60Amp Lithium-capable Converter, Xantrex PROwatt SW 2000 inverter; Tow Vehicle: 2017 Silverado 1500, 5.3L Gas, 4x4 Z71, Dbl Cab, Std Bed.
Patrick1962 Posted September 21, 2024 Posted September 21, 2024 I know this is a dead thread, but the epilogue to this story is that the 2024 Oliver trailer walk-through video shows they have added a thermal-type self-resetting breaker to the trailer breakaway circuit (same type of breaker used by the solar charge controller output to the house battery).
jd1923 Posted September 24, 2024 Posted September 24, 2024 Personally, I'm not worried about the fuse issue. What is the simplest yet valid test to know the Fastway breakaway switch is working? Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators topgun2 Posted September 24, 2024 Moderators Posted September 24, 2024 39 minutes ago, jd1923 said: What is the simplest yet valid test to know the Fastway breakaway switch is working? Pull on that red cord in order to activate the breakaway switch. You should hear the brakes on the Oliver engage and you should not be able to move the Oliver without the tires sliding on whatever surface you are parked on. Of course - after you have conducted your test (this should only take 30 to 60 seconds) push the pin back into the breakaway switch. This should disengage your brakes and now you should be able to, once again, move the Ollie with the tires rotating normally. I test mine at least twice a year in this manner. Bill 2 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Boilermaker Chemist Posted September 25, 2024 Posted September 25, 2024 Several years ago on a trip through CO, we made an overnight stop at a campground near Gunnison. It was dark and since we were in a level site I didn’t unhitch. In the morning, I noticed that the trailer battery was dead. As I looked around I discovered the pin from the BAS had been pulled out. I must have snagged it while getting something out of the truck in the dark. No matter how I tried to reinsert the pin, it wouldn’t go in. Upon reading the installation instructions I found that if the pin is pulled out for an extended period the high current from the battery will weld the contacts together! Needless to say our departure that morning was delayed. So if you pull the pin to test your BAS, be sure you don’t get distracted and end up forgetting about it. 2 2 Mike 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
Patriot Posted September 25, 2024 Posted September 25, 2024 4 hours ago, Boilermaker Chemist said: Several years ago on a trip through CO, we made an overnight stop at a campground near Gunnison. It was dark and since we were in a level site I didn’t unhitch. In the morning, I noticed that the trailer battery was dead. As I looked around I discovered the pin from the BAS had been pulled out. I must have snagged it while getting something out of the truck in the dark. No matter how I tried to reinsert the pin, it wouldn’t go in. Upon reading the installation instructions I found that if the pin is pulled out for an extended period the high current from the battery will weld the contacts together! Needless to say our departure that morning was delayed. So if you pull the pin to test your BAS, be sure you don’t get distracted and end up forgetting about it. Excellent reminder especially for owners who don’t know this about the BAS. 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina 🇺🇸
