Hi Everybody!
Has anyone successfully installed a 32 in TV in place of the 24in standard?  If so, any issues?
Thanks for any assistance.
Cheers,
Pat
Patrick and Danielle Wolfe / 2022 LE II Tail #22-1052 / 2023 GMC 2500HD SLT 6.6L Gas
I know that at least one owner has increased the size or their TV.  Hopefully they will respond here.
I posted about my experience with upgrading to a 28" TV in the thread linked below. Take a look at the pictures and my description of the issues I encountered.
Your biggest concern is going to be the overall height dimension of the 32" you're considering. You'll. have to determine if the case will interfere  with the overhead cabinet when it's down in the viewing position., and whether there is enough clearance  between the window shade when it's folded up. My sense is that any 32" will be too big.  There is some adjustment of the mount but it trades one direction for the other. Relocating the mount any appreciable amount would be a major operation.
https://olivertraveltrailers.com/forums/topic/4188-television/#comment-41664
6 hours ago, Wolfepack said:
Hi Everybody!
Cheers,
Pat
I was able to get a 34" installed in mine, but had to also install a track system for the mount to make it work.  Thought I responded here, but somehow I clicked on the link in bhncb's response and posted on that thread instead...
https://olivertraveltrailers.com/forums/topic/4188-television/?do=findComment&comment=85831&_rid=6801
Thanks bhncb and CRM for the replies!  I know I had seen your responses, but I am obviously no internet sleuth.  Those are some very good mods and definitely worth considering.  This will def help in my consideration for this mod.  Cheers!
  • 4 weeks later...
Hi there,
I actually replaced mine the first week of ownership last month. I replaced with a Samsung QN32Q60AAFXZA 32 inch.  It just fits, you may need to tinker with the vesa mount screws a bit, I had to trim two screws from my collection of misc screws in my garage to get it to work, the screws from the Visio TV to the mount will not fit right. From there you will need an hdmi extension cable, I found one on Amazon that was 6inches and it did the trick. You will need to adjust the mount bracket slightly lower and then tighten the screw locks on the bar as the last step so that the tv will not hit the shade but clear the upper cabinet. Took about 45 mins to do just to get the right screw fit.
Jjnps that looks awesome and I’m impressed you made it fit.   Looking at your suggestion and CRMs track method. Thanks for posting!
  • 1 month later...
Hi everyone!
I upgraded to a 32 inch. I installed a Sylvox 32" (made in china, but cant find one made in the US.) Its a smart TV with all the bells and whistles. its also a 1080 dpi, so its sharper then the original Vizio. It is also a 12 volt/DC so I don't need to run the inverter to watch tv. I needed a new adapter plate I purchased from Mount-it! (an MI-782), the same people that made the original mount. (an MI-4211). Just bolted the mounting plate to the old stand and then attached the TV to that. It swings up out of the way just fine, and is much nicer to watch then the old 24". I have a 2021 Elite II with the standard floor plan. Got any questions, Id be happy to help out.
2021 Elite II, #703. Lithium solar package, composting, standard floor plan.
2017 F-150 extended cab, 4X4, V-8, Snug Top shell.
12 Volt! That's great. Where did you find it. I was already contemplating eventually replacing the original TV with a 12V, so bigger is even better. Thanks!
Nevermind, I found it: https://www.amazon.com/SYLVOX-Powered-Television-Integrated-Speaker/dp/B0BN2WV3TZ?th=1
Steve - Northern Ohio, USA
Facebook - Instagram
I installed a 32 LG Smart TV and I wrapped the cords in a WHITE cover - like Oliver should have done 😉
Charlie.
I'm in the process of replacing the corner "pole" mount with the newer "flip-up" mount and moving it to a centered position.  We didn't like the "always down" positioning - it seemed to be in the way of whoever is using the starboard (street) side rack.  But we really like the flip-up feature of the newer mount since we don't watch much "tube" these days and can stow it away in the "UP" position.  I replaced the original TV unit because the integrated DVD was INOP.  The new tube is a smart TV with all the bells and whistles, but still a 24" diagonal viewing area.  I'm liking Charlie's (CnC's) idea of using a WHITE cord cover - I'll do the same.  I can send pix in a subsequent post - if anyone's interested.
  • 2022 TUNDRA
I bought 25 white 2" hole plugs in 2019 when I relocated my TV.  And I have 23 left, so if you can use 1 or 10 let me know.
LOL, those darn white 2” ones are really hard to find, I probably bought from that same Amazon vendor. I needed just one. So I have 24 left… they are grossly undersized for a 2” hole, I had to glue it in.
In case anyone wants the link
2” hole plugs white, way too many but the only source
Hey, Mossey:  I'll split the cost with you for the 2" hole plugs!  I'll only need one, at least, for now...  Thanks, brother!
  • 2022 TUNDRA
OBTW:  Just curious - what are y'all using to plug the drill holes for the mount screws besides white latex caulk?
  • 2022 TUNDRA
We use "Snap Caps."
I prefer this brand of snap cap.
  • Haha 3
I don’t remember what size the mounting holes were, but I used some small round pads that I found at my local Ace Hardware store.  They aren’t plugs, more like the pads you find on the feet of a table top radio or a clock.  They aren’t rubber, maybe some space age material with a glue backing, but they are pretty thin and have stayed up almost 4 years.   Amazon has a large selection of plastic or nylon hole plugs if you can find the right size.
They don't kill rattlesnakes in Arizona!
Charlie
Concur 100% - these are the only "Snap Caps" I'm familiar with.  Got 'em all the popular sizes - very handy for keeping those perishable skills honed, ha!
  • 2022 TUNDRA
Correction - meant to say, "whoever is using the starboard (CURB) side rack."  My bad.
  • 2022 TUNDRA
The "center mount" TV hardware arrived from Oliver (thanks to Ryder!) last week.  So, we removed the curbside/aft corner vertical TV mount on our rig a couple days ago.  We mounted the new hardware just aft of the LED light over the nightstand.  I've still got the power & HDMI cables routed through the original hole, but thanks to mossimi, I'll cut a new hole aft of the TV mount (less conspicuous) and use moss' 2" plug that he sent me to cover the original cable hole.  I was amazed how random the wiring was behind the bulkhead in the aft storage compartment.  Cleaned a lot of that up.  Also, the wiring set up had 2 massive (L, R, Video) cables from the TV through the original hole - one of which ran back to the Furrion controller - we removed them both, not needed.image.thumb.jpeg.8eaf014557c71b5b272638b1913a947b.jpeg
Quite a mess back there.
We ordered a new 27" viewing size "Smart TV" to replace the original Furrion model (which the DVD player was INOP).
Tucked up nice and neatly.  I've got some white wire/cable loom ordered to replace the black mesh that Oliver uses.  I think the white loom will look more appealing than the black stuff... IMHO.  We've also ordered a 12VDC Furrion subwoofer which can connect to the Furrion AV/Radio Controller which should liven up the tunes a bit whilst sipping on a nice chilled margarita...
  • 2022 TUNDRA
  • 1 year later...
I realize this is an older thread, but still a viable topic.
I hate, Hate, HATE the original Vizio television that came in our 2022 LE2 (hull 1059). It has a mind of its own and we DON’T agree. It is basically a computer with a display, and when it’s doing its background housekeeping tasks - or seeming to be lost in thought - it doesn’t give a damn what -I- would like it to do. Worst of all, it picks the least opportune times to outright ignore the remote. Usually at 2 or 3 am when we’ve fallen asleep watching a movie and I wake up to shut it off. Nope. Remote unresponsive even with new batteries. I have to pop open the cabinet and unplug it to shut it off.
Anyway, seems the 24” Vizio is an oddball size for a “television” - probably more like a low-end computer monitor.
I -think- I can make an inexpensive (Walmart) 32” ONN/Roku set fit with some work on the mount. It -should- fit, clearing the window shade frame and the cabinet. Looks like I’ll have to find some bits and pieces to cobble together a mounting though.
Any more activity on this topic?
King Bed Floorplan
electronics package
Truma Aqua-Go
LOUD Dometic Penguin A/C
LevelMate Pro+
RealTruck hard tonneau cover
Rove R2-4K DashCams
I understand, feel your pain! First thing I did was to replace the corner mounted 24" TV. Prior owner had replaced the OEM with an Amazon Fire TV, but still bad and ugly. I also do not like the folding center mounts that OTT uses since they fold forward and the TV is hanging out in front of the nightstand  vs. back against the rear window for better viewing while in bed. Another goal was also to install a WHITE framed 32" smart TV! Samsung is my favorite brand (better OS than Android, Roku and other). Added a Samsung soundbar too that connects automatically via choice of Wi-Fi or Bluetooth. The very thin hi-rez screen is beyond the quality most and the sound sure beats the 4 cheap OEM corner speakers. It's been 18 months now and I would not change a thing!
Our 2022 LE2 has a center-mounted, flip up/down mount under the rear cabinet - so not familiar with the side/post mounts a few owners have mentioned.
My concerns about the work (probably) have to do with to attach the new, 32” Tv to the exiting mount is that I no longer have access to a workshop or a lot of my tools. So I’ll be back to the bad old shade tree mechanic days using curbs, parking stones, and sewer covers instead of workbench’s and vises….
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
