Wolfepack Posted January 13, 2023 Posted January 13, 2023 Hi Everybody! Has anyone successfully installed a 32 in TV in place of the 24in standard? If so, any issues? Thanks for any assistance. Cheers, Pat Patrick and Danielle Wolfe / 2022 LE II Tail #22-1052 / 2023 GMC 2500HD SLT 6.6L Gas
Moderators topgun2 Posted January 13, 2023 Moderators Posted January 13, 2023 I know that at least one owner has increased the size or their TV. Hopefully they will respond here. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
bhncb Posted January 13, 2023 Posted January 13, 2023 I posted about my experience with upgrading to a 28" TV in the thread linked below. Take a look at the pictures and my description of the issues I encountered. Your biggest concern is going to be the overall height dimension of the 32" you're considering. You'll. have to determine if the case will interfere with the overhead cabinet when it's down in the viewing position., and whether there is enough clearance between the window shade when it's folded up. My sense is that any 32" will be too big. There is some adjustment of the mount but it trades one direction for the other. Relocating the mount any appreciable amount would be a major operation. https://olivertraveltrailers.com/forums/topic/4188-television/#comment-41664 3
CRM Posted January 13, 2023 Posted January 13, 2023 6 hours ago, Wolfepack said: Hi Everybody! Has anyone successfully installed a 32 in TV in place of the 24in standard? If so, any issues? Thanks for any assistance. Cheers, Pat I was able to get a 34" installed in mine, but had to also install a track system for the mount to make it work. Thought I responded here, but somehow I clicked on the link in bhncb's response and posted on that thread instead... https://olivertraveltrailers.com/forums/topic/4188-television/?do=findComment&comment=85831&_rid=6801 3 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
Wolfepack Posted January 14, 2023 Author Posted January 14, 2023 19 hours ago, bhncb said: I posted about my experience with upgrading to a 28" TV in the thread linked below. Take a look at the pictures and my description of the issues I encountered. Your biggest concern is going to be the overall height dimension of the 32" you're considering. You'll. have to determine if the case will interfere with the overhead cabinet when it's down in the viewing position., and whether there is enough clearance between the window shade when it's folded up. My sense is that any 32" will be too big. There is some adjustment of the mount but it trades one direction for the other. Relocating the mount any appreciable amount would be a major operation. https://olivertraveltrailers.com/forums/topic/4188-television/#comment-41664 Thanks bhncb and CRM for the replies! I know I had seen your responses, but I am obviously no internet sleuth. Those are some very good mods and definitely worth considering. This will def help in my consideration for this mod. Cheers! 2 Patrick and Danielle Wolfe / 2022 LE II Tail #22-1052 / 2023 GMC 2500HD SLT 6.6L Gas
Jjnps Posted February 9, 2023 Posted February 9, 2023 Hi there, I actually replaced mine the first week of ownership last month. I replaced with a Samsung QN32Q60AAFXZA 32 inch. It just fits, you may need to tinker with the vesa mount screws a bit, I had to trim two screws from my collection of misc screws in my garage to get it to work, the screws from the Visio TV to the mount will not fit right. From there you will need an hdmi extension cable, I found one on Amazon that was 6inches and it did the trick. You will need to adjust the mount bracket slightly lower and then tighten the screw locks on the bar as the last step so that the tv will not hit the shade but clear the upper cabinet. Took about 45 mins to do just to get the right screw fit. 4
Wolfepack Posted February 9, 2023 Author Posted February 9, 2023 Jjnps that looks awesome and I’m impressed you made it fit. Looking at your suggestion and CRMs track method. Thanks for posting! 1 Patrick and Danielle Wolfe / 2022 LE II Tail #22-1052 / 2023 GMC 2500HD SLT 6.6L Gas
Mike W Posted March 21, 2023 Posted March 21, 2023 Hi everyone! I upgraded to a 32 inch. I installed a Sylvox 32" (made in china, but cant find one made in the US.) Its a smart TV with all the bells and whistles. its also a 1080 dpi, so its sharper then the original Vizio. It is also a 12 volt/DC so I don't need to run the inverter to watch tv. I needed a new adapter plate I purchased from Mount-it! (an MI-782), the same people that made the original mount. (an MI-4211). Just bolted the mounting plate to the old stand and then attached the TV to that. It swings up out of the way just fine, and is much nicer to watch then the old 24". I have a 2021 Elite II with the standard floor plan. Got any questions, Id be happy to help out. 5 2021 Elite II, #703. Lithium solar package, composting, standard floor plan. 2017 F-150 extended cab, 4X4, V-8, Snug Top shell.
Steve Morris Posted March 21, 2023 Posted March 21, 2023 12 Volt! That's great. Where did you find it. I was already contemplating eventually replacing the original TV with a 12V, so bigger is even better. Thanks! Nevermind, I found it: https://www.amazon.com/SYLVOX-Powered-Television-Integrated-Speaker/dp/B0BN2WV3TZ?th=1 1 1 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
CnC Posted March 21, 2023 Posted March 21, 2023 I installed a 32 LG Smart TV and I wrapped the cords in a WHITE cover - like Oliver should have done 😉 Charlie. 3 Arizona | 2020 Oliver Elite II Twin bed Hull #617 | 2021 Ram 1500 e-Hemi 4x4
MAX Burner Posted March 22, 2023 Posted March 22, 2023 I'm in the process of replacing the corner "pole" mount with the newer "flip-up" mount and moving it to a centered position. We didn't like the "always down" positioning - it seemed to be in the way of whoever is using the starboard (street) side rack. But we really like the flip-up feature of the newer mount since we don't watch much "tube" these days and can stow it away in the "UP" position. I replaced the original TV unit because the integrated DVD was INOP. The new tube is a smart TV with all the bells and whistles, but still a 24" diagonal viewing area. I'm liking Charlie's (CnC's) idea of using a WHITE cord cover - I'll do the same. I can send pix in a subsequent post - if anyone's interested. Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Moderators mossemi Posted March 22, 2023 Moderators Posted March 22, 2023 5 minutes ago, MAX Burner said: I'm in the process of replacing the corner "pole" mount with the newer "flip-up" mount and moving it to a centered position. I bought 25 white 2" hole plugs in 2019 when I relocated my TV. And I have 23 left, so if you can use 1 or 10 let me know. Mossey 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
John E Davies Posted March 22, 2023 Posted March 22, 2023 43 minutes ago, mossemi said: I bought 25 white 2" hole plugs in 2019 when I relocated my TV. And I have 23 left, so if you can use 1 or 10 let me know. Mossey LOL, those darn white 2” ones are really hard to find, I probably bought from that same Amazon vendor. I needed just one. So I have 24 left… they are grossly undersized for a 2” hole, I had to glue it in. In case anyone wants the link 2” hole plugs white, way too many but the only source John Davies Spokane WA SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
MAX Burner Posted March 22, 2023 Posted March 22, 2023 Hey, Mossey: I'll split the cost with you for the 2" hole plugs! I'll only need one, at least, for now... Thanks, brother! Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
MAX Burner Posted March 22, 2023 Posted March 22, 2023 OBTW: Just curious - what are y'all using to plug the drill holes for the mount screws besides white latex caulk? Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
CnC Posted March 22, 2023 Posted March 22, 2023 We use "Snap Caps." 1 1 Arizona | 2020 Oliver Elite II Twin bed Hull #617 | 2021 Ram 1500 e-Hemi 4x4
John E Davies Posted March 22, 2023 Posted March 22, 2023 I prefer this brand of snap cap. John Davies Spokane WA 3 3 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Moderators mossemi Posted March 22, 2023 Moderators Posted March 22, 2023 5 hours ago, MAX Burner said: OBTW: Just curious - what are y'all using to plug the drill holes for the mount screws besides white latex caulk? I don’t remember what size the mounting holes were, but I used some small round pads that I found at my local Ace Hardware store. They aren’t plugs, more like the pads you find on the feet of a table top radio or a clock. They aren’t rubber, maybe some space age material with a glue backing, but they are pretty thin and have stayed up almost 4 years. Amazon has a large selection of plastic or nylon hole plugs if you can find the right size. Mossey 3 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
CnC Posted March 22, 2023 Posted March 22, 2023 2 hours ago, John E Davies said: I prefer this brand of snap cap. They don't kill rattlesnakes in Arizona! Charlie 1 Arizona | 2020 Oliver Elite II Twin bed Hull #617 | 2021 Ram 1500 e-Hemi 4x4
MAX Burner Posted March 23, 2023 Posted March 23, 2023 16 hours ago, John E Davies said: I prefer this brand of snap cap. John Davies Spokane WA Concur 100% - these are the only "Snap Caps" I'm familiar with. Got 'em all the popular sizes - very handy for keeping those perishable skills honed, ha! 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
MAX Burner Posted March 31, 2023 Posted March 31, 2023 On 3/22/2023 at 4:09 PM, MAX Burner said: whoever is using the starboard (street) side rack. Correction - meant to say, "whoever is using the starboard (CURB) side rack." My bad. Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
MAX Burner Posted April 5, 2023 Posted April 5, 2023 The "center mount" TV hardware arrived from Oliver (thanks to Ryder!) last week. So, we removed the curbside/aft corner vertical TV mount on our rig a couple days ago. We mounted the new hardware just aft of the LED light over the nightstand. I've still got the power & HDMI cables routed through the original hole, but thanks to mossimi, I'll cut a new hole aft of the TV mount (less conspicuous) and use moss' 2" plug that he sent me to cover the original cable hole. I was amazed how random the wiring was behind the bulkhead in the aft storage compartment. Cleaned a lot of that up. Also, the wiring set up had 2 massive (L, R, Video) cables from the TV through the original hole - one of which ran back to the Furrion controller - we removed them both, not needed. Quite a mess back there. We ordered a new 27" viewing size "Smart TV" to replace the original Furrion model (which the DVD player was INOP). Tucked up nice and neatly. I've got some white wire/cable loom ordered to replace the black mesh that Oliver uses. I think the white loom will look more appealing than the black stuff... IMHO. We've also ordered a 12VDC Furrion subwoofer which can connect to the Furrion AV/Radio Controller which should liven up the tunes a bit whilst sipping on a nice chilled margarita... 3 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Galileo Posted January 2 Posted January 2 I realize this is an older thread, but still a viable topic. I hate, Hate, HATE the original Vizio television that came in our 2022 LE2 (hull 1059). It has a mind of its own and we DON’T agree. It is basically a computer with a display, and when it’s doing its background housekeeping tasks - or seeming to be lost in thought - it doesn’t give a damn what -I- would like it to do. Worst of all, it picks the least opportune times to outright ignore the remote. Usually at 2 or 3 am when we’ve fallen asleep watching a movie and I wake up to shut it off. Nope. Remote unresponsive even with new batteries. I have to pop open the cabinet and unplug it to shut it off. Anyway, seems the 24” Vizio is an oddball size for a “television” - probably more like a low-end computer monitor. I -think- I can make an inexpensive (Walmart) 32” ONN/Roku set fit with some work on the mount. It -should- fit, clearing the window shade frame and the cabinet. Looks like I’ll have to find some bits and pieces to cobble together a mounting though. Any more activity on this topic? 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
jd1923 Posted January 2 Posted January 2 53 minutes ago, Galileo said: I hate, Hate, HATE the original Vizio television that came in our 2022 LE2 (hull 1059). I understand, feel your pain! First thing I did was to replace the corner mounted 24" TV. Prior owner had replaced the OEM with an Amazon Fire TV, but still bad and ugly. I also do not like the folding center mounts that OTT uses since they fold forward and the TV is hanging out in front of the nightstand vs. back against the rear window for better viewing while in bed. Another goal was also to install a WHITE framed 32" smart TV! Samsung is my favorite brand (better OS than Android, Roku and other). Added a Samsung soundbar too that connects automatically via choice of Wi-Fi or Bluetooth. The very thin hi-rez screen is beyond the quality most and the sound sure beats the 4 cheap OEM corner speakers. It's been 18 months now and I would not change a thing! 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Galileo Posted January 2 Posted January 2 Our 2022 LE2 has a center-mounted, flip up/down mount under the rear cabinet - so not familiar with the side/post mounts a few owners have mentioned. My concerns about the work (probably) have to do with to attach the new, 32” Tv to the exiting mount is that I no longer have access to a workshop or a lot of my tools. So I’ll be back to the bad old shade tree mechanic days using curbs, parking stones, and sewer covers instead of workbench’s and vises…. 1 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
