GPnBIRDIE Posted May 31, 2023 Posted May 31, 2023 Last week, I began an evening with full charge (Lithium Pro 390 AH). Running only two small ac Fans along with roof vent at 60% capacity (frig on propane), the batteries went down below 10% over night. This does not seem appropriate and welcome any feedback.
LeBill Posted May 31, 2023 Posted May 31, 2023 Running two small ac fans...implies that you had the invertor turned on. Is it possible there were other appliances (water heater, refrigerator, ?) that were on AC that you hadn't intended? Based on my limited experience, your stated capacity / draw you should expect a week or so. Do you have other previous instances of running on strictly battery? Bill G LeBill Elite I Hull 1352 2021 Jeep Gladiator Northwestern NC (retired)
Rivernerd Posted May 31, 2023 Posted May 31, 2023 1 hour ago, GPnBIRDIE said: Running only two small ac Fans along with roof vent at 60% capacity By "ac fans" do you mean your air conditioner? If so, that could explain the substantial draw down on your batteries. Our Truma AC pulls about 1100 watts when the compressor is running. Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
DaveAndBecky_NorthernMI Posted May 31, 2023 Posted May 31, 2023 If you have the Lithionics app on your phone you can see how much current you are drawing. 1 2022 Oliver Elite II Hull#1047 "Saunter" 2022 Ram 1500 5.7L Hemi
Moderators SeaDawg Posted June 2, 2023 Moderators Posted June 2, 2023 If you mean you ran the inverter, and just ran two small 110 fans, i think you may have an issue. Please complete your signature. Many lithium require full charge within a period of time to properly register "full charge" status. Even our Bluesky, with agm batteries, requires hitting 100 per cent charge to show proper readings after a disconnect. Kind of a "reset" situation. You may also have a wiring issue. 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Moderator+ ScubaRx Posted September 4, 2023 Moderator+ Posted September 4, 2023 On 5/31/2023 at 1:40 PM, DaveAndBecky_NorthernMI said: If you have the Lithionics app on your phone you can see how much current you are drawing. Being a 2022 model, a quick glance at their Victron monitor would give them a ton of real time information. I’m not a fan of Bluetooth Apps to get info about my system’s status. Too much trouble to find your phone, find the app, get it up and running…… Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
MobileJoy Posted September 4, 2023 Posted September 4, 2023 2 hours ago, ScubaRx said: Too much trouble to find your phone, find the app, I can't help with finding the phone as it is a problem I often have myself. Finding the app is simplified for me because I organize all my apps in folders and then organize the folders alphabetically. This folder is named "Oliver" and it contains Lithionics, Xantrex, LevelMate, and WBA Check. In the folder I organize based on frequency of usage, although with only four apps in this one that's hardly important. 4 2021 Elite II Twin #850 "Mojo", 2020 F250 Lariat 7.3L FX4 3.55
Moderator+ ScubaRx Posted September 5, 2023 Moderator+ Posted September 5, 2023 20 hours ago, MobileJoy said: I can't help with finding the phone as it is a problem I often have myself. Finding the app is simplified for me because I organize all my apps in folders and then organize the folders alphabetically. This folder is named "Oliver" and it contains Lithionics, Xantrex, LevelMate, and WBA Check. In the folder I organize based on frequency of usage, although with only four apps in this one that's hardly important. Oh, I do all that the same way you're describing; apps in groups, groups placed where they are easily found. It's still easier for me to glance at a dedicated read-out mounted in the trailer than to jump through all those hoops. 3 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
