Gliddenwoods Posted October 2, 2023 Posted October 2, 2023 One of my wheel hubs has fallen off due to broken back clips. Has anyone ordered replacements and can give order advice? Thanks. 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
Gliddenwoods Posted October 2, 2023 Author Posted October 2, 2023 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
John E Davies Posted October 2, 2023 Posted October 2, 2023 Those are hub center CAPS. I sure hope your axle hubs don’t come off. File a Service Request and Oliver can send you a new one, or a new set. There is no other source for them, I am sure. John Davies Spokane WA 1 2 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Gliddenwoods Posted October 2, 2023 Author Posted October 2, 2023 Thanks for the reply and mechanical word correction. Woodworker and geologist here; so when we talk rocks and/ or wood sometime maybe I can do better for you. 2 1 1 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
Moderators Mike and Carol Posted October 2, 2023 Moderators Posted October 2, 2023 Check with Oliver service. These are unique to Oliver. I lost one and Oliver service sent me a replacement. Mike 1 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Townesw Posted October 3, 2023 Posted October 3, 2023 You might consider removing the decorative hub caps altogether. This will allow you to check wheel hub temp using a non contact IR thermometer or by hand. You can also watch for a loose bearing cap. You can also adjust wheel bearing play without having to remove the tire and wheel assembly. I don’t use the x-chocks anymore either. 2 Bill and Martha 2018 LEII Hull 313 Original owners 3/14/2018 2019 Chevrolet 2500HD Duramax
Tom and Doreen Posted October 3, 2023 Posted October 3, 2023 1 hour ago, Townesw said: I don’t use the x-chocks anymore either. Did you find that the x-chocks were causing problems? Tom & Doreen • 2023 Elite ll • Hull #1321 • 2023 Tundra Platinum Crew Max • Cheshire CT
Gliddenwoods Posted October 3, 2023 Author Posted October 3, 2023 1 hour ago, Townesw said: You might consider removing the decorative hub caps altogether Interesting suggestion. Doesn't look bad without and would eliminate another ongoing maintenance (however small it is) task. Thanks. 1 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
Townesw Posted October 3, 2023 Posted October 3, 2023 21 minutes ago, Tom and Doreen said: Did you find that the x-chocks were causing problems? I think they are more of a gimmick than actually a device to chock the trailer. Nothing chocks better than a big chunk of wood or rubber. I don’t think they do much to stabilize the trailer, they are just another step in setting up and taking down, and they are just something else in the way. The simpler you make the process the better. 4 Bill and Martha 2018 LEII Hull 313 Original owners 3/14/2018 2019 Chevrolet 2500HD Duramax
jd1923 Posted October 6, 2023 Posted October 6, 2023 On 10/2/2023 at 4:01 PM, Mike and Carol said: Check with Oliver service. These are unique to Oliver. I lost one and Oliver service sent me a replacement. Mike For sure their logo is unique. If you want the covers, some are against them, and do not care re the logo, you can go with any number of caps. The domes are standard, and the cap size standard, with so many choices of logos or art patterns. These solve the issue at $15 for set of 4. Hundreds of other choices too. The size (47mm OD of inner stays) listed in this ad is what you need: Amazon.com: Modengzhe 4 Pcs Plastic Snap-in Type Wheel Center Hub Cap 54mm Outer Diameter and 47mm Inner Diameter for Cars, Chrome ABS Base Lattice Top : Automotive 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderator+ ScubaRx Posted October 6, 2023 Moderator+ Posted October 6, 2023 Just glue it back on and forget about it. 2 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
SNY SD UP Posted October 7, 2023 Posted October 7, 2023 (edited) For what it is worth, I removed my "Hubs", then purchased & replaced them with the following. https://www.amazon.com/gp/product/B00AEBBBGC/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1 They do make it easier to read hub temps with an IR gun and as mentioned above, the removable rubber cap allows access to the axle nut if it needs adjustment. One other tool that I previously had, similar to this makes it easier to remove and re-insert your axel dust caps. https://www.amazon.com/Sturdy-Built-1-98-Trailer-Installation/dp/B0B6QBJRQH B~Out, PS here are some pics, they show what the rubber caps look like. Ours are a bit dusty, from last ND road trip. Edited October 11, 2023 by SNY SD UP added addtl info & pic Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed
Geronimo John Posted November 27, 2023 Posted November 27, 2023 On 10/3/2023 at 3:51 AM, Gliddenwoods said: Doesn't look bad without and would eliminate another ongoing maintenance If I recall, it was John Davies that first posted the idea. A primary purpose was to facilitate the use of an IR temperature sensor at rest stops to periodically check the hub temperature directly. This I do as well. 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ronbrink Posted November 28, 2023 Posted November 28, 2023 4 hours ago, Geronimo John said: If I recall, it was John Davies that first posted the idea. A primary purpose was to facilitate the use of an IR temperature sensor at rest stops to periodically check the hub temperature directly. This I do as well. But they’re so sexy when wet! Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone Refrigerator and Freezer; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator.
katanapilot Posted November 28, 2023 Posted November 28, 2023 Question - has anyone determined if the TPMS temperature measurement will track (albeit delayed) bearing heating due to bearing wear and impending failure? I like the hub caps and use bearing buddies along with periodic bearing repacking to minimize the chance of bearing failure. And yes, the bearings were replaced with genuine Timken's before our Alaska adventure. 2020 Elite II Hull #628, Houghton Heat Pump, Victron MP2, SmartSolar, Orion, Cerbo, Lynx distributor and shunt TV - 2011 Toyota Tundra Crew Max Platinum 4WD, Magnuson Supercharger, OME suspension, Wilwood front and rear brakes
Moderators topgun2 Posted November 28, 2023 Moderators Posted November 28, 2023 1 hour ago, katanapilot said: has anyone determined if the TPMS temperature measurement will track (albeit delayed) bearing heating due to bearing wear and impending failure? Yes - Its all relative. By this I mean if you check both the hubs (covered or uncovered) and the rims near the hubs on a regular basis with a TPMS or a hand held temperature sensor, you will soon "learn" what your "normal" readings are for your rig. Deviations from these "normal" readings should send you on a mission to find the cause of the difference in temperature. The answer may be simple - the sun is shining on that side of the camper or your tire pressure is too low or the road you're traveling is severely "crowned" in the center or you've been "riding" your brakes in traffic or going down a long hill. Or, it could be the first signs of bearing failure or a "dragging/sticking" brake. I've never had an unexplained "problem" with my Ollie (yet), but, on a couple of RV's previous to the Ollie both the TPMS and checking at each stop really saved my bacon. Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
