GraniteStaters Posted February 26 Posted February 26 Not trying to add fuel to the Truma fire, but we had problems with our Truma last spring after 4 1/2 years and the symptom, delayed ignition and the smell outside adjacent to the Truma. I was directed by Oliver to reach out to Truma, as I recollect and that wasn't unexpected. When I open the case with Truma support, an Elkhart based engineer reached out to me and said they didn't want me to use the Truma anymore. They made me promise as they felt it was a health and safety risk. I naturally agreed, particularly when they said they would have a certified technician of my choice replace the unit for free and document the installation of the Truma with pictures. We went with out hot water in the Oliver for a week at the Maine Rally. I reached out to Tim's RV in Erving, MA and explained to Tim and Brandon that Truma would be shipping a unit to them and compensating them for doing the pictures and installation. We arranged for a late June for the 1/2 day installation. Truma requires certified and trained technicians and extended a courtesy approval after discussing Brandon's experience and in light of our needs. Truma sent the brand new unit to Tim's. We were notified when they received it. Brandon confirmed the delivery too before I made the trip from Concord, NH to Erving. Tim and Brandon were very gracious and Brandon did an outstanding job on the install. 2 8 David Caswell and Paula Saltmarsh Hull 509 "The Swallow"
CRM Posted February 26 Posted February 26 3 hours ago, katanapilot said: Yes, it is an instant on-demand hot water heater (similar to what you might have at home). Thanks. I've never even seen one of the Truma units before. Since it's on-demand it makes sense that it doesn't have an electric option. 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 4.30 axle and tow package.
DaveAndBecky_NorthernMI Posted February 26 Posted February 26 On 2/13/2025 at 3:10 PM, John Dorrer said: There was a small allotment received from Truma, and they were assigned to people with scheduled maintenance. Can confirm. Spoke with Jason today regarding service on March 11-12. He has a burner set aside for me. 1 2022 Oliver Elite II Hull#1047 "Saunter" Solar Pro 390 aH Lithionics 2022 Ram 1500 5.7L Hemi
Moderator+ ScubaRx Posted February 26 Moderator+ Posted February 26 5 hours ago, katanapilot said: Assuming this is true - all the more reason for us as owners to try to come up with practical, near term solutions. Otherwise, it will be years before Oliver gets enough burner assemblies to remedy the recall of 800 units. I can't argue that under these circumstances, it would take a long time to get to everyone. But don't misunderstand what I wrote. These statements are just possibilities that I'm saying COULD be true, I have no evidence that they are, but if I was running Truma and a company pissed me off bad enough, that's exactly what I would do. I don't own a Truma, but if I did and now knowing the exact nature of the issue, you can bet your sweet bippy I would pull that burner out, repair it, put it back in, torque it to the proper specs, hook up and go camping. 7 2 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
katanapilot Posted February 27 Posted February 27 2 hours ago, ScubaRx said: you can bet your sweet bippy I would pull that burner out, repair it, put it back in, torque it to the proper specs, hook up and go camping. Exactly what I plan to attempt. 2 2020 Elite II Hull #628, Houghton Heat Pump, Victron MP2, SmartSolar, Orion, Cerbo, Lynx distributor and shunt TV - 2011 Toyota Tundra Crew Max Platinum 4WD, Magnuson Supercharger, OME suspension, Wilwood front and rear brakes
Rivernerd Posted February 27 Posted February 27 22 hours ago, ScubaRx said: It is my belief that this “shortage of parts” is an issue manufactured by Truma to punish Oliver and (by default) this community of owners for making this problem public knowledge. If you are correct, it is a remarkably poor business decision by Truma. The sooner the product failure is resolved, the sooner it fades from the public consciousness, and Truma's quality reputation can be rebuilt. 4 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
Galileo Posted February 27 Author Posted February 27 (edited) 15 hours ago, katanapilot said: Exactly what I plan to attempt. It’s really quite simple and well within the skill set of anybody who can change their engine oil or a set of spark plugs. You WILL need a couple of Torx wrenches. I forget the size, but both/all were included in a small Elkind folding set, I’d guess a T-10 is one of them. Two open end wrenches to remove the gas fitting. (I don’t think there’s room to use flare nut or “line” wrenches.) About 5/8 or 11/16” I think. Also the big wrench for the nut holding the gas line to the manifold. Other than having to ease it out and caress it back in is to pull out the black control box at the top right of the heater enclosure when you open the access door. Easier than removing the ignition and flame sensor leads and less likely to break them. DO take the picture as Galway Girl suggested to put the disconnected leads back in the right place. Turn off the LP first of course. Once you overcome any trepidation about working on an unfamiliar piece of equipment, it’s a pretty simple job. As others have pointed out - if you fiddle with it, you likely void your warranty. Edited February 27 by Galileo Fat fingers and autocorrect 2 2 2 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
katanapilot Posted February 27 Posted February 27 5 hours ago, Galileo said: It’s really quite simple and well within the skill set of anybody who can change their engine oil or a set of spark plugs. You WILL need a couple of Torx wrenches. I forget the size, but both/all were included in a small Elkind folding set, I’d guess a T-10 is one of them. Two open end wrenches to remove the gas fitting. (I don’t think there’s room to use flare nut or “line” wrenches.) About 5/8 or 11/16” I think. Also the big wrench for the nut holding the gas line to the manifold. Other than having to ease it out and caress it back in is to pull out the black control box at the top right of the heater enclosure when you open the access door. Easier than removing the ignition and flame sensor leads and less likely to break them. DO take the picture as Galway Girl suggested to put the disconnected leads back in the right place. Turn off the LP first of course. Once you overcome any trepidation about working on an unfamiliar piece of equipment, it’s a pretty simple job. As others have pointed out - if you fiddle with it, you likely void your warranty. Appreciate the advice. I built the two airplanes in my profile picture, so I am hopeful I have the skills and tools to do this job. 😉Would prefer to have a service manual but it sounds like those are top secret need to know only and reserved for the few Truma service centers. I think the warranty is long expired. My plan B is to have Truma replace this one with a remanufactured unit. They stated they won’t replace the burner only even at my expense. Not the most customer friendly company I have dealt with. 3 2020 Elite II Hull #628, Houghton Heat Pump, Victron MP2, SmartSolar, Orion, Cerbo, Lynx distributor and shunt TV - 2011 Toyota Tundra Crew Max Platinum 4WD, Magnuson Supercharger, OME suspension, Wilwood front and rear brakes
Galileo Posted February 28 Author Posted February 28 16 hours ago, katanapilot said: My plan B is to have Truma replace this one with a remanufactured unit. They stated they won’t replace the burner only even at my expense. Not the most customer friendly company I have dealt with. Wow. Truma doesn’t seem to be winning many hearts and minds here. I’ve read seemingly very different impressions of Truma’s customer service. Some say they’re great, others - not so much. My only attempt at contacting them didn’t even get the courtesy of a reply. 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Moderators mossemi Posted February 28 Moderators Posted February 28 On 2/24/2025 at 1:16 AM, John and Debbie said: I plan to just turn off the Truma aquago every night and turn it back on in the morning. John Our standard practice has always been to turn the Truma on at the inside control panel when we needed hot water and then turn it off when not needed. This is not a solution to the problem, it just reduces the likelihood of a fire 🔥 when we are not around. We will also add a step to our departure and setup checklist , to turn the outside switch off or on as needed before travel! It’s the best we can do until a repair has been completed. Mossey 1 3 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
srthomsen Posted February 28 Posted February 28 As far as I can tell, the systems are all maufactured in Germany and / or Italy. I cold not find any information pertaining to a Truma manufacturing facility in the USA. This, if true, certainly could account for some of the lack of availability of components with which to repair the defective heaters. Developed in Germany, produced in Italy: Our Products come from a single mold One of our most important success factors: Within the Truma Group, development and production come from a single source. This means we can optimally coordinate manufacturing and production. The development headquarter is part of our German parent company, located in Putzbrunn, Bavaria. Together, we set new standards with coordinated, continuous improvements in development and manufacturing. This enables us to manufacture high-performance, high-precision products that delight our customers and add the greatest possible value. 2023 Elite #1403--2019 Ford F150--2.7 Ecoboost V6--10 speed auto--without Max Tow
Galileo Posted February 28 Author Posted February 28 3 hours ago, mossemi said: Our standard practice has always been to turn the Truma on at the inside control panel when we needed hot water and then turn it off when not needed. This is not a solution to the problem, it just reduces the likelihood of a fire 🔥 when we are not around. We will also add a step to our departure and setup checklist , to turn the outside switch off or on as needed before travel! It’s the best we can do until a repair has been completed. Mossey We do the same with the inside switch. More to conserve propane though. I probably only use hot water once a day - usually less. We generally take our showers at the campground facilities, or at a health club depending upon how long we stay in a given place. I haven’t been turning off the switch on the outside. I guess I never thought about it. Nobody addressed it during our delivery process. I guess I’ll have to read the manual! 2 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
katanapilot Posted March 17 Posted March 17 On 2/26/2025 at 6:37 PM, ScubaRx said: I can't argue that under these circumstances, it would take a long time to get to everyone. But don't misunderstand what I wrote. These statements are just possibilities that I'm saying COULD be true, I have no evidence that they are, but if I was running Truma and a company pissed me off bad enough, that's exactly what I would do. I don't own a Truma, but if I did and now knowing the exact nature of the issue, you can bet your sweet bippy I would pull that burner out, repair it, put it back in, torque it to the proper specs, hook up and go camping. I’m beginning to believe that your suspicions regarding Truma’s response to Oliver’s recall are true. Weeks ago I contacted Truma service to try to set up an AquaGo replacement (at my expense) - during the time that I was already planning to be in Lakeland near their service center. They promised to have the person responsible for setting up the appointments reach back out to me. Since then, crickets. So I will be attempting my own repair until such time as OTT gets enough replacement burners and gets to me in the long line of affected owners. 1 2 2020 Elite II Hull #628, Houghton Heat Pump, Victron MP2, SmartSolar, Orion, Cerbo, Lynx distributor and shunt TV - 2011 Toyota Tundra Crew Max Platinum 4WD, Magnuson Supercharger, OME suspension, Wilwood front and rear brakes
Tom and Doreen Posted March 17 Posted March 17 4 hours ago, katanapilot said: I’m beginning to believe that your suspicions regarding Truma’s response to Oliver’s recall are true. Weeks ago I contacted Truma service to try to set up an AquaGo replacement (at my expense) - during the time that I was already planning to be in Lakeland near their service center. They promised to have the person responsible for setting up the appointments reach back out to me. Since then, crickets. So I will be attempting my own repair until such time as OTT gets enough replacement burners and gets to me in the long line of affected owners. It turns out that there is ONE person in the country that handles appointments for the service centers, and if she's at a show or other event you won't hear from her for weeks. That was the case for us as we were traveling to FL over the winter and had a problem with our water heater. She finally called back two weeks later and I was told that the service center couldn't see us for another three weeks. We ended up going with a " Truma certified mobile tech" and that experience was less than ideal. Our Truma service support was horrible but that's a long story for another time. 1 Tom & Doreen • 2023 Elite ll • Hull #1321 • 2023 Tundra Platinum Crew Max • Cheshire CT
katanapilot Posted March 17 Posted March 17 42 minutes ago, Tom and Doreen said: It turns out that there is ONE person in the country that handles appointments for the service centers, and if she's at a show or other event you won't hear from her for weeks. That was the case for us as we were traveling to FL over the winter and had a problem with our water heater. She finally called back two weeks later and I was told that the service center couldn't see us for another three weeks. We ended up going with a " Truma certified mobile tech" and that experience was less than ideal. Our Truma service support was horrible but that's a long story for another time. Thanks for the information. Maybe I was a bit premature in jumping to the conclusion that Truma is ghosting Oliver owners. I'll be in Lakeland in two weeks, so it looks like I'll be pulling the burner out to check on the crimped ends. Doesn't look too difficult. 1 2020 Elite II Hull #628, Houghton Heat Pump, Victron MP2, SmartSolar, Orion, Cerbo, Lynx distributor and shunt TV - 2011 Toyota Tundra Crew Max Platinum 4WD, Magnuson Supercharger, OME suspension, Wilwood front and rear brakes
katanapilot Posted March 25 Posted March 25 Found a brand new burner assembly from a "cosmetically damaged" AquaGo on eBay and bought it for $200. One goal was to see what is involved in removing said assembly, since we do not have access to a service manual. I also wanted to see what was required to crimp the ends of the intermediate burners. Having done that now, I will also put a small TIG weld bead at the ends to make sure there is never any movement. Still have not heard back from Truma to schedule a replacement unit, but now that I've seen what is involved in replacing the burner, I'm not going to bother. I'll wait for Oliver to get to me in their recall queue, but I'll have a burner that I am comfortable with already installed. 2 1 2020 Elite II Hull #628, Houghton Heat Pump, Victron MP2, SmartSolar, Orion, Cerbo, Lynx distributor and shunt TV - 2011 Toyota Tundra Crew Max Platinum 4WD, Magnuson Supercharger, OME suspension, Wilwood front and rear brakes
Galway Girl Posted March 25 Posted March 25 (edited) @katanapilot Curious, in the 2 pix, the top one has only the end tubes crimped, in the bottom all tubes are crimped. Is the bottom unit from the item you bought one bay? Or did you simply crimp the tubes yourself? Our replacement shipped to the repair facility a couple days back. (On Friday Mar 21,2025) Craig Edited March 25 by Galway Girl 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com
katanapilot Posted March 26 Posted March 26 1 hour ago, Galway Girl said: @katanapilot Curious, in the 2 pix, the top one has only the end tubes crimped, in the bottom all tubes are crimped. Is the bottom unit from the item you bought one bay? Or did you simply crimp the tubes yourself? Our replacement shipped to the repair facility a couple days back. (On Friday Mar 21,2025) Craig I crimped the ends. First picture was as delivered, second was after crimping the burner ends. Took 5 minutes. I'll add another picture when I TIG spot weld them. 2 2020 Elite II Hull #628, Houghton Heat Pump, Victron MP2, SmartSolar, Orion, Cerbo, Lynx distributor and shunt TV - 2011 Toyota Tundra Crew Max Platinum 4WD, Magnuson Supercharger, OME suspension, Wilwood front and rear brakes
Rivernerd Posted March 26 Posted March 26 14 hours ago, katanapilot said: I'll add another picture when I TIG spot weld them. Your burner assembly will then be "better than new." We submitted our replacement request to Oliver promptly after receiving the recall notice, but still we wait for a properly crimped burner assembly... 1 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
Wandering Sagebrush Posted March 26 Posted March 26 When I spoke to the Truma Service Center, the tech I spoke to was very helpful regarding my warm versus hot water issue, but when I mentioned the “Truma” recall, the tech said this is an “Oliver” recall, not a Truma recall. That leads me to believe there may be some assembly or pre install effort on the Truma unit by Oliver. Does anyone know if that is true? Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L
Moderators SeaDawg Posted March 27 Moderators Posted March 27 9 hours ago, Wandering Sagebrush said: When I spoke to the Truma Service Center, the tech I spoke to was very helpful regarding my warm versus hot water issue, but when I mentioned the “Truma” recall, the tech said this is an “Oliver” recall, not a Truma recall. That leads me to believe there may be some assembly or pre install effort on the Truma unit by Oliver. Does anyone know if that is true? Maybe because Oliver eas an early adopter? That would be my guess 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
John and Debbie Posted March 27 Posted March 27 10 hours ago, Rivernerd said: Your burner assembly will then be "better than new." We submitted our replacement request to Oliver promptly after receiving the recall notice, but still we wait for a properly crimped burner assembly... We did the same thing. I wouldn't want to modify the burner assembly on my own even if I knew how to do the welding. You're a former attorney. I would think that if a person did that and if there was a fire, you would not have a legal leg to stand on. Correct me if I am wrong. John 1 John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Alcan 5 leaf springs and Bulldog shocks done May 20, 2025 in Grand Junction, Colorado
Rivernerd Posted March 27 Posted March 27 12 hours ago, John and Debbie said: Correct me if I am wrong. You are right. But, the odds of such a fire spreading to your neighbor's trailer, and therefore creating liability exposure, are slim. Doing your own modifications would more likely just limit your ability to make a claim against Oliver or Truma for the loss of your trailer. 1 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
katanapilot Posted March 27 Posted March 27 I am not an attorney so this is an uneducated opinion only - I believe that anyone who has received notice of the recall and continues to use their AquaGo is probably accepting all liability for damage or loss due to a fire caused by the defective burner. No doubt turning the AquaGo on only when needed mitigates the risk, but the risk still exists regardless. 2020 Elite II Hull #628, Houghton Heat Pump, Victron MP2, SmartSolar, Orion, Cerbo, Lynx distributor and shunt TV - 2011 Toyota Tundra Crew Max Platinum 4WD, Magnuson Supercharger, OME suspension, Wilwood front and rear brakes
katanapilot Posted March 27 Posted March 27 (edited) 16 hours ago, John and Debbie said: We did the same thing. I wouldn't want to modify the burner assembly on my own even if I knew how to do the welding. You're a former attorney. I would think that if a person did that and if there was a fire, you would not have a legal leg to stand on. Correct me if I am wrong. John Do you think you would have any recourse with Oliver or Truma today? You have been notified that your AquaGo may have a defective burner. If you choose to use it anyway and it burns down your trailer, whose fault would that be? Edited March 27 by katanapilot Added clarifying text 2020 Elite II Hull #628, Houghton Heat Pump, Victron MP2, SmartSolar, Orion, Cerbo, Lynx distributor and shunt TV - 2011 Toyota Tundra Crew Max Platinum 4WD, Magnuson Supercharger, OME suspension, Wilwood front and rear brakes
