ADKCamper Posted September 29, 2025 Posted September 29, 2025 (edited) My deep socket gets stuck as well… with both the closest sae and metric sizes. I suspect poor quality control on the chrome-covered lug nuts’ outer dimensions. I carry a fairly long (and inexpensive) Harbor Freight 1/2” breaker bar for removing stuck or over-torqued lug nuts, and a shorter folding tire cross for putting lug nuts back on. I’m still trying to find a good spot to carry a 1/2” torque wrench. I also carry a 3.5 ton Humvee scissor jack with a combo rectangular & curved adapter on top of its pin. It is fairly short when collapsed and comes with a ratcheting box wrench with a long-ish handle which lifts one side of the Elite easily. It can sit on leveling blocks or 4x4s if required. Edited September 29, 2025 by ADKCamper 1 Tom & Holly 2018 Oliver Legacy Elite #409 - 320W rooftop solar, 300Ah Epoch LiFePO4, Victron BMV-712 & Smart Solar MPPT 100/30, Progressive Dynamics PD4060CVS 60Amp Lithium-capable Converter, Xantrex PROwatt SW 2000 inverter, Bulldog HD1213-0656 Shocks, Falken Wildpeak H/T02 235/65R16C 121/119R; Tow Vehicle: 2026 Silverado 2500, 6.6L Gas, 4x4, Dbl Cab, Std Bed.
jd1923 Posted September 29, 2025 Posted September 29, 2025 6 hours ago, Boudicca908 said: The socket gets stuck — no problem getting it ON, no problem turning the wrench (it’s long handled). And I had help obtaining the correct socket size. Use a 12-point socket vs. the 6-point which is generally recommended for automotive work. The 12-point will remove easier. It is about the stainless-wrapped lugs. I’ll replace ours with solid chromed steel lugs someday. 1 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
ADKCamper Posted September 29, 2025 Posted September 29, 2025 I looked once for solid SS lug nuts, but could not find any in an appropriate configuration. Maybe I’ll give up on that and find some solid chromed steel ones… 1 Tom & Holly 2018 Oliver Legacy Elite #409 - 320W rooftop solar, 300Ah Epoch LiFePO4, Victron BMV-712 & Smart Solar MPPT 100/30, Progressive Dynamics PD4060CVS 60Amp Lithium-capable Converter, Xantrex PROwatt SW 2000 inverter, Bulldog HD1213-0656 Shocks, Falken Wildpeak H/T02 235/65R16C 121/119R; Tow Vehicle: 2026 Silverado 2500, 6.6L Gas, 4x4, Dbl Cab, Std Bed.
Boudicca908 Posted September 29, 2025 Posted September 29, 2025 3 hours ago, ADKCamper said: a good spot to carry a 1/2” torque wrench. I have my crew cab rear seats folded up, and I carry my torque wrench in the folded seat on rolled up towels. 3 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
Gliddenwoods Posted September 29, 2025 Posted September 29, 2025 Oh I know this story too well. My yesterday morning in Salida, Co in the attached photos. I used both a jack and the stabilizing jacks. When using the stabilizer does one use both? Also, why not just remove the hub cap for socket access and then put back on? 1 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
Gliddenwoods Posted September 29, 2025 Posted September 29, 2025 Just now, Gliddenwoods said: Oh I know this story too well. My yesterday morning in Salida, Co in the attached photos. I used both a jack and the stabilizing jacks. When using the stabilizer does one use both? Also, why not just remove the hub cap for socket access and then put back on? Oh yes, having a bike rack on with two bikes is a real pain in the project... 1 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
Moderators topgun2 Posted September 29, 2025 Moderators Posted September 29, 2025 (edited) 4 hours ago, Gliddenwoods said: When using the stabilizer does one use both? Also, why not just remove the hub cap for socket access and then put back on? While not the safest - I've just used the stabilizer alone for changing a tire. Again - this is not the safest procedure by any means. The "hub caps" remove from the back. Therefore, if one is simply checking the torque of the lug nuts , the removal of the hub cap is a bunch of extra work. Bill Edited September 29, 2025 by topgun2 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators topgun2 Posted September 29, 2025 Moderators Posted September 29, 2025 1 hour ago, Gliddenwoods said: My yesterday morning in Salida, Co in the attached photos. I don't see an air compressor in the photos above. But, if you did have an air compressor (or some means to re-inflate the tire), you could have simply "pluggged" that tire without removing it. Note: Plugging a tire is not necessarily the easiest thing to do either. I takes some practice to do it properly. But, in certain situations it is the easiest, cheapest way to get back on the road quickly. Many local tire shops will give you an old tire to practice on. Tire plug kits like THESE can be found at WalMart and almost any automotive parts store. Bill 4 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Tony and Rhonda Posted September 29, 2025 Posted September 29, 2025 15 hours ago, Boudicca908 said: None of us were heavy enough to get the lugs off (I was able to loosen just 2 of them by standing and lightly bouncing my weight on the lug wrench.) I went out and bought 3 sections of galvanized pipe, one for each of us. I've had good luck with a 4-way lug wrench. This allows me to use both arms and body weight to break the lug nuts free. Also makes it quick and easy to spin them off and back on. I finish them off with the torque wrench with 4" extension. No need for deep well sockets on our older model wheels. I keep the 4-way on the floor under the TV's driver's seat. When you have a tire shop work on your wheels/tires, it's a good idea to check the lug nut torque after you get the trailer back. Some shops over torque the lug nuts with their impact wrenches making it very difficult to remove the lug nut manually. I store the torque wrench in the storage area under the rear seat of my TV, it even has cutouts to keep the wrench (or whatever) from rolling around. Tony 3 New to us 2017 Legacy Elite II Hull #251 (with updates) TV: 2023 Tundra Double Cab 4x4 TRD Sport Formerly 2004 Tundra with 2015 Four Wheel Camper Fleet
Tony and Rhonda Posted September 29, 2025 Posted September 29, 2025 sorry for the double post. How did that happen? Can someone delete it? New to us 2017 Legacy Elite II Hull #251 (with updates) TV: 2023 Tundra Double Cab 4x4 TRD Sport Formerly 2004 Tundra with 2015 Four Wheel Camper Fleet
Moderators Mike and Carol Posted September 29, 2025 Moderators Posted September 29, 2025 2 hours ago, Tony and Rhonda said: sorry for the double post. How did that happen? Can someone delete it? Yes, deleted. It happens from time to time… 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
jd1923 Posted September 29, 2025 Posted September 29, 2025 10 hours ago, ADKCamper said: I looked once for solid SS lug nuts, but could not find any in an appropriate configuration. Maybe I’ll give up on that and find some solid chromed steel ones… Stainless Steel (SS) lug nuts are limited. I've never seen them used for custom wheels. I'm not sure whether our wheels require 'acorn' or 'acorn bulge' shaped lugs. Thinking they are 1/2" x 20 and I would also measure the length of the stud extending beyond the wheel before ordering. Does anybody have these specs? Given verification of measurements, something like this may work. They're expensive by the time you buy 6 sets (24 pcs). McGard is a good brand I've used before. These are labeled "Made in USA" so don't buy a cheap bulk set that are made in China instead! https://www.amazon.com/McGard-64010-Chrome-Bulge-Style/dp/B000COMX9K/?th=1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Ronbrink Posted September 29, 2025 Posted September 29, 2025 On 9/25/2025 at 5:18 PM, topgun2 said: Don't forget to get two "extra" sensors - one for the Ollie spare tire and on for you tow vehicles spare tire (all the TPMS systems that I know of that are included on vehicles do not monitor the spare tire on the tow vehicle). Bill Great advice! I will add, if a spare tire is needed one should swap the sensors so the tire on the ground continues to be monitored as positioned on the TPMS display. To your point, the TST brand monitors spares, as well. 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Moderators topgun2 Posted September 29, 2025 Moderators Posted September 29, 2025 11 minutes ago, jd1923 said: I'm not sure whether our wheels require 'acorn' or 'acorn bulge' shaped lugs. Those of us with "older" Ollies - the ones with the wheels that have circles/holes in them versus the more recent that have more like "spokes" - require acorn bulge lug nuts. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators topgun2 Posted September 29, 2025 Moderators Posted September 29, 2025 3 minutes ago, Ronbrink said: To your point, the TST brand monitors spares, as well. As do most all of the TPMS brands that I know of to include my EZE Tire. My comment was referring to those TPMS systems that are included with most (if not all) newer vehicles. My F-150 does monitor the four tires on the truck but it doesn't monitor the truck's spare tire nor does it have the ability to monitor anything on the Ollie. Someone recently made a post that said their new truck did allow the monitoring of TPMS sensors on a trailer in addition to those on the truck. Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Ronbrink Posted September 29, 2025 Posted September 29, 2025 On 9/25/2025 at 5:18 PM, topgun2 said: Don't forget to get two "extra" sensors - one for the Ollie spare tire and on for you tow vehicles spare tire (all the TPMS systems that I know of that are included on vehicles do not monitor the spare tire on the tow vehicle). Bill Great advice! I will add, if a spare tire is needed one should swap the sensors so the tire on the ground continues to be monitored as positioned on the TPMS display. To your point, the TST brand monitors spares, as well. On 9/24/2025 at 7:10 PM, John and Jodi said: I'm interested to hear from you what's in your tire changing tool kit. This plus a battery charger and torque wrench. I find the torque limiting extension bars more convenient and accurate enough for wheel lugs, but the standard ‘click’ torque wrench offers better piece of mind in some instances, like axle suspension components. Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Gliddenwoods Posted September 29, 2025 Posted September 29, 2025 5 hours ago, topgun2 said: While not the safest - I've just used the stabilizer alone for changing a tire. Again - this is not the safest procedure by any means. The "hub caps" remove from the back. Therefore, if one is simply checking the torque of the lug nuts , the removal of the hub cap is a bunch of extra work. Bill I was at Oliver two weeks ago and service manager Mike took off one of my hubs (to confirm axle type) and he took the hub off (and replaced) without taking the wheel off so quick I missed his method...but he did it. 1 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
Ronbrink Posted September 29, 2025 Posted September 29, 2025 2 hours ago, Ronbrink said: Great advice! I will add, if a spare tire is needed one should swap the sensors so the tire on the ground continues to be monitored as positioned on the TPMS display. To your point, the TST brand monitors spares, as well. This somehow got posted twice. Perhaps admin can delete one. Thanks Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Moderators topgun2 Posted September 29, 2025 Moderators Posted September 29, 2025 32 minutes ago, Ronbrink said: This somehow got posted twice. Perhaps admin can delete one. Thanks Done - you're welcome. 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Roger Posted September 29, 2025 Posted September 29, 2025 When I bought my F350 I got the trailer TPMS monitoring system. So far, I have been very happy with it. Unfortunately, the Ford TPMS cannot monitor the spares. The nice thing about the Ford TPMS is there is no sensor to have to fool with when I manually check tire pressures and I don't have another device cluttering my cab. My practice with spare tires is to keep them inflated to the maximum allowed for the tire and then lower the pressure to the correct pressure when I use the spare. I also carry an inflator so in the worst case I can add air to the spare. I think I will add checking the spare tire pressure to my travel checklist, although it is a hassle to check the pressure on the Oliver spare. When I got my new truck, I lowered the spare and flipped it around (Ford has the spare with the valve up from the factory) so that I could check the pressure with it mounted under the bed. 2 2021 Elite II Twin Bed Hull #1023 - Kimba | 2025 Ford F-350 6.7 Diesel
Patriot Posted September 30, 2025 Posted September 30, 2025 7 hours ago, jd1923 said: Stainless Steel (SS) lug nuts are limited. I've never seen them used for custom wheels. @ScubaRx referenced an eBay link to purchase S/S lug nuts a few years ago. I ordered the same set he suggested and have been running them for a few years now, zero issues and no rust. Maybe he still has the link handy? 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Wandering Sagebrush Posted September 30, 2025 Posted September 30, 2025 One more recommendation for a SafeJack kit, compressor (I have a Viair 400p), plug kit, and torque wrench. Your experience was a wake-up call for me to get solid lug nuts. 2 Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L
Boudicca908 Posted September 30, 2025 Posted September 30, 2025 On 9/29/2025 at 3:19 PM, Roger said: I think I will add checking the spare tire pressure to my travel checklist I usually ask service to check my TV spare condition and pressure when I go in for tire rotation — and most recently, I requested it when I replaced my TV tires. HOWEVER, when the tires were replaced, and they checked my TV spare, something happened, and it triggered issues: Warning Messages on the dashboard alternating between “check trailer wiring” and “trailer brakes connected”. I will start a new thread for this, when I get it resolved — but just wanted to make a note that there’s a control module (computer) located somewhere near the TV spare — so be aware of that. **I don’t want this comment to distract from the main thread.** 1 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
Steve Morris Posted October 28, 2025 Posted October 28, 2025 I've not acted on advice to switch to steel valve stems while using our TST tire pressure monitor. Yesterday, that procrastination bit me in the ass on my way home from the Hungry Mother Fiberglass Rally in Virginia. Rapid Pressure Loss" or similar wording was what the monitor said with a constant loud beeping. A quick look in my mirror showed the front left trailer tire was indeed low. Stopped to check, and with 28 PSI showing, I elected to slowly drive to the next exit, and found a flat spot in a gas station lot. The rubber valve stem was partially separated from the rubber base, and if flexed, dumped out pressurized air. No fixing that on the spot! Time to change tires. I have all the tools needed, and it was a cool sunny day, so that was a bit of luck. It had been raining a few hours earlier. I didn't have my impact driver with me, but I do have an 18" breaker bar, so I could loosen the lug nuts. Before jacking up and removing the tire, though, it was time to get the spare. Two heavy e-bikes made this a chore, but fortunately, that's when a large fellow stopped and offered to help. (Oddly enough, the local deputy sheriff who was using the facilities at the station never even checked to see if we needed anything on his way out of the parking lot.) With his help, we slid the rack and mount out far enough to get to the spare. His impact driver made for a faster swap than my breaker bar, and his torque wrench was easier to get to than mine buried in the trailer's basement. All in all, about an hour and a bit delay, and the kind gentleman who stopped to help refused any remuneration. - I usually only carry the impact driver with me on long trips. And while this was about an eight hour drive, I'd elected not to bring it with me. It will now be included in every trip. - I'll be removing the bike rack mount and cleaning those surfaces and applying a dry lube to make it easier to slide the rack in and out. After we were done, I was really re-thinking John Davies choice to not use the fiberglass tire cover while toting bicycles! - I will be changing to all steel valve stems before we leave on our next trip! 1 3 1 ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
Moderators topgun2 Posted October 28, 2025 Moderators Posted October 28, 2025 2 hours ago, Steve Morris said: I will be changing to all steel valve stems before we leave on our next trip! Sorry for the tire issue but at least you had a level spot and help when you needed it. I have steel valves and have never had a problem with them. However, for anyone considering a change to these valves it should be done with the knowledge that the steel valves are simply not as "forgiving" as the rubber valves are when they are bent or hit with something hard. I certainly had to consider this fact when I changed to the steel because I travel over a bunch of dirt and/or two track roads every summer. Even a sage brush could possibly be enough to bend or break one of these valves let alone a rock. Of course, that same brush or rock could possibly damage a rubber valve but .... Bill 2 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
