John and Jodi Posted October 11 Posted October 11 I'm not very handy so I haven't looked a lot under and around the bowels of our trailer, but recently I had an occasion to do so. Looking at my shower drain pipe I saw this: It appears that the 1.5 inch drain line has collapsed. The shower still drains slowly and there's no leaks (yet?), but I'm a bit shocked. While the pipe from the shower pan is vertical, the connection to the gray tank(?) pipe appears to be at a 45 degree angle so that buying a new P Trap doesn't appear to be a good option unless I'm willing to re-plump. Is this normal? I'm open for suggestions. 1 John and Jodi San Antonio, TX 2022 Elite II - Hull #1126 being pulled by a 2022 F-150 Powerboost. Map Legend: Red - Driven Through; Orange - Stopped In; Blue - Explored Parts; Green - Explored Whole
Snackchaser Posted October 11 Posted October 11 (edited) Looks like they installed a flexible tube and left a twist in it. You might try loosening a clamp and twisting the kink out. Unfortunately that kink could be set and it seems like too a tight bend even for a replacement piece. Oliver should address that despite the expired warranty, it was just a poor installation from the start. Good luck, Geoff Edited October 11 by Snackchaser 6
Moderators topgun2 Posted October 11 Moderators Posted October 11 Can we assume that you purchased this Ollie "new"? I've never seen that kind of installation. Bill 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
John and Jodi Posted October 11 Author Posted October 11 1 hour ago, topgun2 said: Can we assume that you purchased this Ollie "new"? Yes. New from the factory in 2022. 2 2 1 John and Jodi San Antonio, TX 2022 Elite II - Hull #1126 being pulled by a 2022 F-150 Powerboost. Map Legend: Red - Driven Through; Orange - Stopped In; Blue - Explored Parts; Green - Explored Whole
DanielBoondock Posted October 11 Posted October 11 Nice design actually for maintenance, should be easy to remove and clean out compared to rigid pipe 3 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 530 mile pack)
Ollie-Haus Posted October 11 Posted October 11 Our 2023 has the same connection without the kink. Actually this is a nice trap design as the trap material is soft enough to prevent cracking if water is left in the trap during winter storage. It's a tough location to work in but should be able to be corrected. If the kink remains after removal try placing in boiling water for a few minutes to restore it to normal shape. Otherwise Oliver should be able to supply a new one. 4 What's today?............. the most frequently asked question as a retiree 🙄 Chris and Stacie Neuhaus and Cohen the fearless Border Terrier, Greenfield, Indiana 2021 Ford F350 7.3L Tremor (Redzilla) LE2 #1373 - Ordered 10/21/22 - Delivered 05/10/23
Boudicca908 Posted October 11 Posted October 11 16 hours ago, John and Jodi said: I haven't looked a lot under and around the bowels of our trailer Can you describe how you accessed that area for the photo? If I can, I will send a photo of my Spring 2022.... to see if it looks different. 2 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
John and Jodi Posted October 11 Author Posted October 11 2 hours ago, Boudicca908 said: Can you describe how you accessed that area for the photo? I removed the access panel on the dinette seat closest to the shower and looked down and right. 5 John and Jodi San Antonio, TX 2022 Elite II - Hull #1126 being pulled by a 2022 F-150 Powerboost. Map Legend: Red - Driven Through; Orange - Stopped In; Blue - Explored Parts; Green - Explored Whole
Boudicca908 Posted October 11 Posted October 11 (edited) @John and Jodi I wasn't able to get quite the same angle, but here are my photos. I have the same material, but it's not twisted like yours. .... why do I struggle with photo uploads? I will try to fix these.... a few minutes. Edited October 11 by Boudicca908 photo upload hassle 3 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
jd1923 Posted October 12 Posted October 12 (edited) 5 hours ago, Boudicca908 said: @John and Jodi I wasn't able to get quite the same angle, but here are my photos. I have the same material, but it's not twisted like yours. Good photos yep, one flexible P-trap is straight, the other is certainly twisted. How do they twist this during installation? Sometimes a job is easier when doing it the right way! Wish I had looked that direction when I had all the waste valves out (was instead looking forward to run DC-DC wiring)! Can a person get an arm in there to loosen the two hose clamps? If so, all can be good. You could put the part in hot water to get it back to original shape which was a great suggestion! But first I would send picture to OTT asking them to replace the part ASAP no charge. Also it's so cool to see the 3" ducting to the bathroom! If it kills me, I've got to install semi-rigid ducting, a homerun from furnace to bath. OEM ducting, Why, why, why? When the bottom hull is open for a few extra dollar full RIGID ducting SHOULD be laid. Ours was full of holes across the bottoms, everywhere. I replaced all I could within reach. Edited October 12 by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
John and Jodi Posted October 12 Author Posted October 12 (edited) On 10/11/2026 at 3:40 PM, Boudicca908 said: I have the same material, but it's not twisted like yours. The biggest difference I see is that your gray tank connection seems more or less parallel to the drain pipe (both pointing down), so you have a true "U" shape in your tube. My gray tank pipe connection points towards the drain pipe at 45 degrees, so I think "they" folded the flexible tube to get it on to both pipes. I think that if I removed my tube and warmed it up, it would return to a "U" shape, but not help me because of the angle of my connections relative to each other. It seems to me that the original "defect" is the angle of the gray tank pipe connection. I'm assuming that I can't just twist that pipe so that it points down. Quote But first I would send picture to OTT asking them to replace the part ASAP no charge. I've contacted OTT. I'm not getting the support that I'd like. I've started to escalate, but the response has been disappointing. Edited October 12 by John and Jodi clarify a point 3 John and Jodi San Antonio, TX 2022 Elite II - Hull #1126 being pulled by a 2022 F-150 Powerboost. Map Legend: Red - Driven Through; Orange - Stopped In; Blue - Explored Parts; Green - Explored Whole
jd1923 Posted October 13 Posted October 13 (edited) 7 hours ago, John and Jodi said: It seems to me that the original "defect" is the angle of the gray tank pipe connection. Good observation, John. I had not noticed it at first, but when comparing the two pictures (Thanks Toni!) it's your ABS Tee-junction that was installed incorrectly, which caused the flexible P-trap to fold due to the hard angle. You are certainly correct, the Tee must be installed straight down. Given the Tee is glued firmly in place, you'd have to saw the ABS pipe before and after the Tee and remove it. If you could source a Tee that is 1" or so longer than the OEM part, the job will be easier. Otherwise, you need length to add a coupling too. Could you get tools in there to rework this plumbing? It might be up to you, or a good plumber willing to work on your trailer. I'll keep it in mind to look at ours when I get a chance. I hope they help you with this! 😂 Edited October 13 by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
CRM Posted October 13 Posted October 13 2 hours ago, jd1923 said: It might be up to you, or a good plumber willing to work on your trailer. The first thing a good plumber is going to tell him is that the whole design is wrong. You can't use a sanitary tee on a horizontal drain line and a p-trap must have a horizontal section after it and it can't connect straight to a drain line from the bottom as it is here. I need to take a look at mine to see if it's done in the same manner. 3 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
HDRider Posted October 13 Posted October 13 On 10/10/2026 at 8:25 PM, Snackchaser said: Oliver should address that despite the expired warranty, it was just a poor installation from the start. Don't get his hopes up. I had pipes in the bathroom that leaked due to installation errors and they still charged me. Not much, but it seems that when the warranty expires it is gone. I had even reported the problem while the warranty was in force, but we were on a long trip and by the time they could work me in it had expired. 1 3 Jeff & Cindy - NE Arkansas - 2023 Legacy Elite II - Twin Bed - Hull #1423 TV - 2015 Silverado 2500 Duramax 4x4
Hokieman Posted October 13 Posted October 13 10 hours ago, CRM said: The first thing a good plumber is going to tell him is that the whole design is wrong. @John and Jodi I’m not a plumber but I understand what @CRM is saying. It will be a major hassle to cut and refit those ABS drain pipes the way that OTT usually does it. The result might be a plumbing mess, and regardless, it’s still a poor design. One possible solution might be removing the P-trap and replace with a Hepvo valve. You could use the existing incorrectly installed sanitary tee, and with some creative plumbing install the Hepvo valve horizontally down low on the basement floor. I do not know how well this would work, but throwing it out there for the more competent plumbers to consider. Anyone ever use these Hepvo valves? See link for installation ideas in RV’s. https://hepvo.com/wp-content/uploads/2021/07/HepvO-US-RV-Plumbing-Applications-June-2021.pdf “Ramble” - 2021 Legacy Elite II #797; 2020 Ford F-250. Former owner of 2019 Oliver Legacy Elite #431. Blairsville, GA
CRM Posted October 13 Posted October 13 1 hour ago, Hokieman said: @John and Jodi I’m not a plumber but I understand what @CRM is saying. It will be a major hassle to cut and refit those ABS drain pipes the way that OTT usually does it. The result might be a plumbing mess, and regardless, it’s still a poor design. One possible solution might be removing the P-trap and replace with a Hepvo valve. You could use the existing incorrectly installed sanitary tee, and with some creative plumbing install the Hepvo valve horizontally down low on the basement floor. I do not know how well this would work, but throwing it out there for the more competent plumbers to consider. Anyone ever use these Hepvo valves? See link for installation ideas in RV’s. https://hepvo.com/wp-content/uploads/2021/07/HepvO-US-RV-Plumbing-Applications-June-2021.pdf I've never seen these before, but they look like they could be a good option- if they're not prone to failure. They *should* also prevent backup into the shower if the shut off valve is happened to be left open. To do it right, you would still have to remove the sanitary tee and replace it with a "Wye" fitting entering from the side instead of entering from the bottom. For the record, I'm not a plumber either, though in the course of 30+ years renovating homes and owning rental properties I've learned a few things about plumbing along the way- especially from all my mistakes! 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
Steph and Dud B Posted October 13 Posted October 13 I understand the flexible connection because the shower pan actually flexes a little when you stand near the drain. But this was sloppy work at the factory. Can't say I'm surprised because we've had several issues with sloppy work in our 2022 as well. It's also disappointing to hear that they denied your warranty claim because you couldn't get it to them within the warranty period, even though you identified the issue within the warranty period. Hope you can resolve it without too much trouble. Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Boudicca908 Posted October 16 Posted October 16 On 10/13/2026 at 10:56 AM, Steph and Dud B said: It's also disappointing I agree with @Steph and Dud B and am surprised. Note that there is a "Tech Support" number that has been more responsive to me this year than the "Service" number; maybe due to having more personnel available to answer the phone, I'm not really sure, but you might try that. Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
Snackchaser Posted October 16 Posted October 16 (edited) On 10/13/2026 at 5:13 AM, HDRider said: I had even reported the problem while the warranty was in force, but we were on a long trip and by the time they could work me in it had expired. The Federal and State Trade Commissions say that companies are legally required to fix defects or honor claims reported during the active warranty period. Unfortunately, many companies are not aware of that. They are not obligated to honor claims identified after the warranty expires, but sometimes it's just the right thing to do. Edited October 16 by Snackchaser 1
Geronimo John Posted October 16 Posted October 16 On 10/10/2026 at 8:25 PM, Snackchaser said: Looks like they installed a flexible tube and left a twist in it. On 10/12/2026 at 8:03 PM, jd1923 said: it's your ABS Tee-junction that was installed incorrectly, which caused the flexible P-trap to fold due to the hard angle. You are certainly correct, the Tee must be installed straight down. Assuming the tank is still secure in it's original position I have to agree. That is clearly a MFG Latent Defect. OTT needs to determine the obvious and fix your issure despite the warranty being out of play. In the past, they certainly would have. Suggest elevation of the above relivant posts to Jason E. GJ 3 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
CRM Posted 4 hours ago Posted 4 hours ago Well, they must have changed things along the way since mine is installed completely different and done correctly with a horizontal section after the P-trap. The sink drain runs above and parallel to the shower drain and they both dump straight down into the grey tank. 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
Jim and Chris Neuman Posted 3 hours ago Posted 3 hours ago (edited) I had the same issue with the fresh water tank overflow hose. The hose on our '21 Legacy 2 was too short to reach from tank to outlet fitting in a smooth, gradual arc. Instead the hose was pulled tight and installed with a kink which soon split dumping overflow into the bilge. This was something that absolutely should not have occurred. Overall the workmanship on our trailer was good but the plumbing was sloppily done ... many loose fittings, etc. Ours was a covid era trailer and it appears many of the QC inspections simply went by the board. Edited 3 hours ago by Jim and Chris Neuman
Steph and Dud B Posted 1 hour ago Posted 1 hour ago 2 hours ago, Jim and Chris Neuman said: fresh water tank overflow hose... was too short to reach from tank to outlet fitting in a smooth, gradual arc. Instead the hose was pulled tight and installed with a kink which soon split dumping overflow into the bilge. I wonder if this is what happened in @Rivernerd's case, where the fresh tank pressurized? 2 hours ago, Jim and Chris Neuman said: Ours was a covid era trailer and it appears many of the QC inspections simply went by the board. Same with our 2022. Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
