John and Jodi Posted 5 hours ago Posted 5 hours ago I'm not very handy so I haven't looked a lot under and around the bowels of our trailer, but recently I had an occasion to do so. Looking at my shower drain pipe I saw this: It appears that the 1.5 inch drain line has collapsed. The shower still drains slowly and there's no leaks (yet?), but I'm a bit shocked. While the pipe from the shower pan is vertical, the connection to the gray tank(?) pipe appears to be at a 45 degree angle so that buying a new P Trap doesn't appear to be a good option unless I'm willing to re-plump. Is this normal? I'm open for suggestions. John and Jodi San Antonio, TX 2022 Elite II - Hull #1126 being pulled by a 2022 F-150 Powerboost. Map Legend: Red - Driven Through; Orange - Stopped In; Blue - Explored Parts; Green - Explored Whole
Snackchaser Posted 5 hours ago Posted 5 hours ago (edited) Looks like they installed a flexible tube and left a twist in it. You might try loosening a clamp and twisting the kink out. Unfortunately that kink could be set and it seems like too a tight bend even for a replacement piece. Oliver should address that despite the expired warranty, it was just a poor installation from the start. Good luck, Geoff Edited 5 hours ago by Snackchaser 1
