Steph and Dud B Posted January 2, 2022 Posted January 2, 2022 Looking at how far forward the cargo/generator basket is mounted. Has anyone had a problem with the basket interfering with tight turns? It does stick out a bit from the A-frame. Or is it far enough back from the coupler to be a non-issue? Also, while on the topic, does anyone have a problem with their pickup tailgate clearing the basket? Thanks. 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
John E Davies Posted January 2, 2022 Posted January 2, 2022 The basket can contact the truck when reversing at too tight an angle, for sure (jack knifing). During normal full-lock turns while driving forward it is fine. The open tailgate may hit it if the trailer is at a severe angle, you should try to park with it aligned. Many have noticed that the tailgate can hit the Bulldog coupler, this depends on the tow vehicle, and where the receiver is located in relation to the gate. There have been a number of threads discussing tailgate clearance. With your HD truck it is less likely to be a problem. My 2006 Ram 3500 had tons of room, my 2013 Land Cruiser would hit, until I installed a longer Andersen ball mount. I moved my basket from the tongue back to the rear bumper and I much prefer it there, for a number of reasons, including a greatly reduced tongue weight. It certainly is easier to climb over the tongue without it in the way. Until you get used to it, have a helper stand out there watching while you reverse, to make sure you don’t over do it. When backing sharply, go really slow once the angle gets past 45 degrees. Does your GMC have a backup camera? John Davies Spokane WA 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Steph and Dud B Posted January 2, 2022 Author Posted January 2, 2022 9 hours ago, John E Davies said: Does your GMC have a backup camera? Yes, it does, so that will help with turns. Our dually does sit a couple of inches lower than single axle 3500s. I think the tailgate will clear the coupler, but I suspect it won't clear the storage box. 2 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
dewdev Posted January 2, 2022 Posted January 2, 2022 The previous owner of my Ollie, did dent in his truck bumper when he did a sharp turn (jack knife) when backing and mentioned to be careful. His truck was low to the ground. I have not had a problem when backing even turning sharply but I am careful. My truck is higher off the ground than the previous owner's truck. The tail-gate of my truck does not hit the storage box when connected to the trailer. That could be a problem for trucks that are closer to the ground. 1 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension Maine
Moderator+ ScubaRx Posted January 2, 2022 Moderator+ Posted January 2, 2022 5 hours ago, Steph and Dud B said: ...Our dually does sit a couple of inches lower than single axle 3500s. I think the tailgate will clear the coupler, but I suspect it won't clear the storage box. Our 2022 Single Rear Wheel Silverado 3500's tailgate does not hit anything, 1 2 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
CnC Posted January 3, 2022 Posted January 3, 2022 The lowered tailgate on our 2021 Ram 1500 Laramie came within an inch of the top of our receiver 😑. Too close to suit me, so I flipped the receiver and cut off the bottom couple of inches to keep it from bottoming out when boondocking in desert ridges. That worked for me. 1 Arizona | 2020 Oliver Elite II Twin bed Hull #617 | 2021 Ram 1500 e-Hemi 4x4
Moderators SeaDawg Posted January 3, 2022 Moderators Posted January 3, 2022 @CnC, are you still able to tow level? 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
IL_Travelers Posted January 7, 2022 Posted January 7, 2022 On our return home from delivery, I had to jackknife the trailer sharply to make it into our driveway. The next morning I noticed the $600 dent in the bumper of our brand-new 2021 GMC Denali HD's bumper. It has been repaired, and the basket is now sitting in storage; we do not miss it. 2 4 2021 Legacy Elite II Twin Beds "R-Villa" ~ Hull #803 2021 GMC Denali HD, 6.6 L Duramax Turbo-Diesel, 10-speed Allison
Moderators Mike and Carol Posted January 7, 2022 Moderators Posted January 7, 2022 On 1/1/2022 at 8:42 PM, Steph and Dud B said: Also, while on the topic, does anyone have a problem with their pickup tailgate clearing the basket? Thanks. On both of my Ram 1500’s the lowered tailgate hit the top of the Andersen hitch. On my Ram 2500, with no Andersen, the tailgate doesn’t even come close to hitting the hitch. Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
John E Davies Posted January 7, 2022 Posted January 7, 2022 FYI, If the basket collides with your truck hard enough to damage the truck, you should also inspect the basket itself for damage, it possibly could have cracks on the support brackets or mounting holes. It is only held down in the middle by two rather undersized u-bolts. Here is a pic of the early style tray, showing the angle brackets that "straddle" the tongue, and the two sets of holes for the u-bolts. (The rubber strips have been removed in this pic.). This design is adequate for a heavy load like a generator IF it is centered over the tongue, but if you load it unevenly, it may not be OK. For example a full Jerry can on just one side might be a problem Since relocating mine to the back, I no longer worry about damaging the truck, but I now have to worry about ramming it into my house (; John Davies Spokane WA 1 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Rivernerd Posted January 7, 2022 Posted January 7, 2022 2 hours ago, IL_Travelers said: On our return home from delivery, I had to jackknife the trailer sharply to make it into our driveway. The next morning I noticed the $600 dent in the bumper of our brand-new 2021 GMC Denali HD's bumper. It has been repaired, and the basket is now sitting in storage; we do not miss it. That is the reason we are not ordering a front storage basket on our Elite II. I have been required to jack knife my raft trailer many times when backing into tight spaces. I welded a 3' straight steel extension onto the front of that A-frame trailer many years ago after denting a bumper during a jack knife maneuver. Problem solved. So, I want as much leeway between the Oliver trailer frame and the TV bumper as possible. If I could get one of the extendable tongues that was available on very early Olivers, I would get that upgrade for the same reason: maximum clearance if you must jack knife the trailer when backing. 3 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
Boudicca908 Posted January 7, 2022 Posted January 7, 2022 5 hours ago, IL_Travelers said: and the basket is now sitting in storage; we do not miss it. Is it hard to remove the basket? My order is in, I'm not sure I could change it at this point (though they aren't scheduled to build until next month)... Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel
John E Davies Posted January 8, 2022 Posted January 8, 2022 40 minutes ago, Boudicca908 said: Is it hard to remove the basket? My order is in, I'm not sure I could change it at this point (though they aren't scheduled to build until next month)... Remove four nuts under the tongue, remove two “square” u bolts, lift off the tray. That is how my 2017 one works, the current one may differ slightly. If you really don’t want it, ask them to delete it from your build sheet, there is no reason they would not, at this very early stage. It is probably one of the last things they do after all the other stuff is completed. If you do remove it, there will be two holes left in the fiberglass, which might bother you. It would be better to stop it from being installed in the first place. How much is that option now? It was about $700 for mine…. That will buy a lot of gas. John Davies Spokane WA . 3 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
John E Davies Posted January 8, 2022 Posted January 8, 2022 I thought this pic might be useful, from my Stone Stomper thread, it shows the trailer as close as it ever gets while driving forward (full steering lock). Obviously when reversing it would get close enough to hit. If other members have similar pics, please post them! John Davies Spokane WA 2 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Moderators SeaDawg Posted January 8, 2022 Moderators Posted January 8, 2022 We've never wanted a basket, for tongue weight, and also this . You can jack knife, without the basket, and still dimple a bumper, imo. Far easier with a basket . That's why someone is backing, and someone is watching. I'm ok without the extra hassle. We carry what we need in the truck bed. 3 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Geronimo John Posted January 8, 2022 Posted January 8, 2022 On the other hand, the tongue basket is very handy for all those goodies that are not suitable for inside Ollie. Some of the things I carry in mine are: Ground plates for three jacks 2" X 6" wood shims to reduce wear of jacks, but more importantly to give me a slip point so that if I drive off with a jack down there is a chance that I'll hear the thump before I brake the jack. I've seen this with my own eyes by other owners making that mistake. One was at OTT in the service yard! Spray Lithium Grease for my Anderson Ball Long range wasp spray and Cutter/Deep Woods bug repellant 2 gallon jerry can of gas for the generator Anderson chain and whale bone, pins and trailer lights when parked Old rag to wipe of my hands after puttzing with all of the above That said, I admit that I have a damaged left rear bumper as a result of this issue. It would be nice if Bulldog made a longer coupler. This would also eliminate the interference of the Anderson upgraded ball mount that sits just a bit higher than the ole one. Drop my F-150 tail gate and the tailgate camera and the Bulldog release lever end up saying bad words to each other. But alas Bulldog does not seem to have one. They do make a lever less release (Slide Coupler) that will resolve the tailgate/Bulldog issue, but would not fix the bumper/box issue. Any metal experts out there know if an extension could be welded onto the bulldog to fetch about 4 inches? That likely would be a lot less expensive than replacing the Oliver Aluminum behind the bulldog. Your thoughts? GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Geronimo John Posted January 8, 2022 Posted January 8, 2022 46 minutes ago, SeaDawg said: You can jack knife, without the basket, and still dimple a bumper, imo. Far easier with a basket . That's why someone is backing, and someone is watching. I'm often alone when parking the trailer. So finding somebody that I can trust can be a challenge. My solution is to back up a bit, then stop and put my truck into reverse so that it's back-up camera shows how close I am to a Box and Bumper MMA match. Doing so also slows me down a bit so that I can also look up at my Ollie tail mounted camera that I have powered up from the parking light circuit in the attic. So if you are following me, and I turn on my trailer lights, I've got an eyeball on you! 🙂 3 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Landrover Posted January 8, 2022 Posted January 8, 2022 I have never had to jackknife any trailer to that extreme. Could someone please explain how the trailer moves back when the Tv is at a 90dg angle to the trailer. It doesn’t work that way. The only thing that will be accomplished is to bend things as some have found. Being on that much of an angle you need to stop pull forward and reposition the trailer. If someone can back a trailer into a spot with the Tv at a 90dg angle please video it id like to see it.😳😰 5 Grant 2022 GMC Denali 2500 HD 2019 Elite 11😎
John and Debbie Posted January 8, 2022 Posted January 8, 2022 2 hours ago, Landrover said: I have never had to jackknife any trailer to that extreme. Could someone please explain how the trailer moves back when the Tv is at a 90dg angle to the trailer. It doesn’t work that way. The only thing that will be accomplished is to bend things as some have found. Being on that much of an angle you need to stop pull forward and reposition the trailer. If someone can back a trailer into a spot with the Tv at a 90dg angle please video it id like to see it.😳😰 "I have never had to jackknife any trailer to that extreme." Good point. I never have that much of an angle while backing up. John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022
Moderators Mike and Carol Posted January 8, 2022 Moderators Posted January 8, 2022 12 hours ago, Landrover said: I have never had to jackknife any trailer to that extreme.😳😰 I’ve never jackknifed either. We’ve had a couple of tight spots but maneuvered without any extreme trailer positioning. 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Geronimo John Posted January 10, 2022 Posted January 10, 2022 You must not park your trailers where I on rare occasions out of necessity I have to. Idea is to back up the trailer only as tight as you have to. If you don't have a tight spot with poor or no turning radius that's great. But sometimes stuff gets in the way and bringing the box close to the bumper is the only way to get it into the space. Going slow and watching the angle on the back-up camera can be very helpful... and several times made the difference in getting my Ollie into a tight situation. In my re-read, I failed to mention that getting out of the truck and taking a look is part and parcel with the process... when alone, or with a spotter. My bottom line is that I feel that nothing beats a "YOUR eyes on" approach first, and periodically when baking. My comment about the rear view cameras was more of a joke as I don't find them real useful (Like using my eyeballs at the hitch or rear of Ollie. The cameras are nice, but not effective enough for me to risk crunching Ollie or the TV. But for the TV and Basket issue, my F-150 tail gate camera is very effective in giving me an idea if I need to pull forward and re-adjust the angle. On 1/7/2022 at 7:46 PM, John Welte said: If someone can back a trailer into a spot with the Tv at a 90dg angle please video it id like to see it.😳😰 If the tongue is at 90 degrees to the bumper, most likely you have already damaged either your box or your bumper. TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
