4 hours ago, SeaDawg said:
Our labor (however long it takes) is free, since we're retired.
Even "semi-retired", we convert our time into "money saved" and "projects completed!"  Love'n it!
  • 2022 TUNDRA
I bought a used 2016 LE2 2 years ago and have upgraded it in phases. First 2 270AH Battleborn GC2’s, wiring and all Victron components including 3000 watt inverter. We were forced to install a new Aquago due to the failure of the old. Recently installed the Houghton and Cruise 130 compressor refrigerator. I have been surprised with how much I use the heat pump on the Houghton when hooked up. I put the remote above my head in bed and fire it up before getting up.
Financially we are about $25K better off than buying a new one, though a new one would be nice. All the major work was done by service techs as it is over my head. But the prices for service haven’t been that bad. I paid $1800 to install the refer and A/C in So. Calif.
We have taken the trailer to Alaska and back. And numerous other trips, and so far no problems. However, I am aware that I have an older machine and think about the axles and other issues you could avoid by going new.
2016 Oliver Legacy Elite II.  2021 Ford F250 Diesel
Just curious... what axle issues are you concerned with?
  • 2022 TUNDRA
We’ve got a 2016 and have close to 100K miles.  No axle issues.  I’m not aware of any other older trailers with axle issues either.  I will be replacing our brakes in the spring.  As soon as I decide on which quiet AC to get I’ll replace our jet-engine Dometic, although is still cools fine.  I’ve replaced the inverter, batteries, 7pin connector, power inlet on the side of the trailer and a few other small items that simply wore out.  Are there other areas you are concerned with?  I feel like I’ve got ours broken in pretty well as we start our 8th year.   Mike
Anyone who buys a used trailer has to think about aged gear, and, gee, what did the previous owner do, or not do, for maintenence and care.
And, did they do mods with safety in mind, and a background to do them?
I'd offer mine (2008) up as an example. We've done most of our own mods. Dc fridge, pulled and reinstalled windows, 400 watts solar on an elite. Installed our own replacement Houghton ac, and maxxair dome plus bath fan. Among others...
We have the skills, and my retired husband was licensed.  But, hey, we have probably 150k miles on our little Elite.
No odometer. You'd have to trust us on that "meticulously " maintained thing (which it is, but who knows, except looking at our service log.) And, of course, our history of comments here.
Most Ollie owners take good care of their trailers. A few here have purchased used trailers with less than stellar maintenance,  and have had to do a lot of work. Most seem happy.
As far as axles, most things can be vetted via visual inspection. And/or replaced.
Mine will likely never go up for sale. Btw. But, when we're gone, if my daughter doesn't want to camp anymore,  maybe. We've (daughter and I)  already had this conversation.
Worst thing for any vehicle, or trailer, imo , is to sit, unused.
If you can't use it, sell it, imo.
To answer Max Burner, it is not a specific concern, more a general one re all the running gear under the trailer. I don’t know the actual mileage, or the lifespan of those components. So far I’ve replaced the brakes and I lube the zerks and all is well. But it isn’t new.
Since your springs have the heavy duty hardware, they should last indefinitely with regular servicing, a warning sign that you need to relube is creaks or pops when making tight turns. They should be dead silent otherwise. Keep an eye on the rubber cushions in the equalizers and the shocks, they can deteriorate from sun exposure. (Clean the grease residue off so you can see what’s underneath.) Check all the hardware for correct torque, look for sagging or unusual tire wear. Check for blown shocks, they occur when running too much air in the tires, the LT tires should be set to 50 psi max. Shocks are not expensive and have a lifetime warranty, you should consider just installing new ones, the trailer will ride better.
A good degreasing followed by a pressure wash will make them look much better, obviously you must lube them afterwards.
While you are underneath with your tools, check the mount bolts for all three jacks, you will definitely find them loose.
I have Hull 218, almost as old as yours, here is the belly and suspension after a very intense detail session,on my back, which wore me out 😉 prepping it for sale. Old doesn’t mean bad, on a trailer. The owner is a different story entirely…
FYI the equalizer shackles are flipped, that happens after taking off the wheels, they should flip back right away when towing.
What hull number? Please add that to your signature. And pictures are always welcome here.
John:
Thanks for the information.  I will do the checks you indicate the next time the Oliver comes out of storage. Hull 141.
Jeff.
We decided against solar when we purchased our 2022 Elite II. The technology is moving so fast we were concerned newer and better stuff would be evolving rapidly and decided to save the $$$.   I have 2 great generators (Honda) that serve us well.
Yup that was also our plan, I was going to install lithium and solar panels until I found out they stopped prewiring for solar panels in 2021. Didn’t want to go through the hassle of snaking wires through the inside of the hulls so we went with the lithium package.
I didn't know Oliver stopped prewiring for solar in 2021. Thanks for the update.
I didn't know this either  - are you sure?
It seems strange to me that Oliver would take that portion of the electrical harness out of the loop when evidence would suggest that Oliver has taken great pains to "standardize" as much as they can on the production line.
Yup that’s what I was told from my my rep (Josh) at Oliver last year September…..his words “we stopped prewiring for solar panels around a year or so ago”!
In the immortal words of Artie Johnson - "Very interesting".
p.s.  PM sent asking for clarification from Oliver on changes to the wiring harness.
In the usual Oliver fashion - we have a very quick response to the question:
"Oliver has stopped prewiring ALL travel trailers for solar panels" (note my emphasis on the word "ALL")
The Oliver response to this statement is:
"For trailers without solar, they are not being pre-wired. Just a cost saving for production. The only trailers that do not have solar are ones with the base wet cell batteries. All AGM and Lithium battery power packages include solar and inverters. We rarely sell any with just the wet cell batteries anymore."
Hope this helps clarify the subject.
  • Thanks 5
I can’t imagine solar not being ordered on a new Oliver especially now that they are no longer prewired. Just me.
Patriot🇺🇸
North Carolina 🇺🇸
Patriot🇺🇸
For resale value alone. At this price point, add-ons are not overly significant in the price increase and makes it easier to sell.
Agreed, that’s why we went with lithium/solar, it was either you get the solar package or no prewiring!
Had they offered Lithium/solar in 2020 we would have been all in. It’s a nice option!
North Carolina 🇺🇸
Yes and I think reasonably priced.
Well, that makes us the odd duck.
Agm and lots of solar. (400+ watts bifacial  fixed, 200 watts portable.
My husband and I have discussed a lithium upgrade for a few years now. If we go that way when the current agms die, it will likely be a single battleborn.  Maybe two.
We'll see.
Times have definitely changed, but so has technology.
The heavy gauge wire and labor is a significant $$$ number, but I'm still a bit disappointed at no announcement.  Our 2008 was not "pre-wired", but it's a heck of a lot easier to work with a 2008. No foam insulation, no cabinet liners.
I wonder if they would agree to prewire for an additional charge if you didn't want the solar package?
I was wondering that, as well.
Pre-wiring was undoubtedly super expensive,,with heavy gauge wires.
It would be nice to know the hull # when the practice was abandoned.
I agree but those few trailers that have been ordered since the start of 2021 that were ordered without solar and with wet cell batteries should be the only ones affected.  I'd guess that we could count those on one hand.
I was told the factory or service department will not prewire the trailer, due to having to drill holes in the external fiberglass and then having to possibly repair the fiberglass. The only option I was offered, was that they could add a solar port on the side of the trailer for a suitcase solar panel if I was not getting any other solar package.
