Wandering Sagebrush Posted October 2, 2023 Posted October 2, 2023 I dumped the gray water tank this morning, and got a bit of a surprise. The dump hose had a crack in it, about a foot from the outlet connection. Waste water leaked out on the ground. I am so thankful that we have a composting toilet, and that it wasn’t a black water dump. In several decades of RV camping, I’ve never had this happen, but it serves as a good reminder that things break or wear out, and it might be a good preventive idea to replace them occasionally. 2 2 Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L
Moderators topgun2 Posted October 2, 2023 Moderators Posted October 2, 2023 And your experience is a classic example of why those of us with the "standard" toilet should always release a bit of grey water first prior to dumping the black. This makes sure that the hose connections are solid AND that the hose is not going to leak. Bill 2 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
MAX Burner Posted October 2, 2023 Posted October 2, 2023 2 hours ago, topgun2 said: This makes sure that the hose connections are solid AND that the hose is not going to leak. Absolutely @topgun2! We dumped this AM at the house after returning from Mexico yesterday PM... We've always released a small amount of grey water before dumping the good stuff. It may also assist in moving the black effluent down what would otherwise be a dry hose. With the OTT wastewater holding tank flushing feature, (we didn't have this in our previous RV) we're now in the habit of running a wastewater holding tank full of freshwater to dump through the hose after the gray water's been eliminated. A final step that seems to work for us - on many levels. HA! 5 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
BBL Posted October 2, 2023 Posted October 2, 2023 3 hours ago, Wandering Sagebrush said: The dump hose had a crack in it, It's also why I almost immediately got rid of the gray/yellow hose that came with the Ollie and went back to my normal Rhino Extreme hose. I have never had an issue with Rhino's but I have known several people that have had the gray ones fail. BL 5
Galway Girl Posted October 13, 2023 Posted October 13, 2023 Our original hoses from Oliver cracked after a year , and we bought much better quality thicker walled Rhino flex replacement hoses. Listed them in the Oliver Outfitters Guide on Amazon https://4-ever-hitched.com 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
Tom and Doreen Posted October 13, 2023 Posted October 13, 2023 Same story, the waste hose shredded on a cold day last January returning from Oliver. Luckily the Oliver supplied waste hose came in two section and we could utilize the second section. We then replaced the hose with a Rhino and that's been working fine. We have a composting toilet and are very happy with that decision. 2 Tom & Doreen • 2023 Elite ll • Hull #1321 • 2023 Tundra Platinum Crew Max • Cheshire CT
MAX Burner Posted October 23, 2023 Posted October 23, 2023 On 10/2/2023 at 2:38 PM, Brian and Brandelyne said: got rid of the gray/yellow hose that came with the Ollie and went back to my normal Rhino Extreme hose. Same here. Never had a problem with them... 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Wandering Sagebrush Posted October 23, 2023 Author Posted October 23, 2023 32 minutes ago, MAX Burner said: Same here. Never had a problem with them... That is what I replaced “old leaky” with. 2 Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L
Moderators SeaDawg Posted October 24, 2023 Moderators Posted October 24, 2023 On 10/2/2023 at 1:15 PM, Wandering Sagebrush said: I dumped the gray water tank this morning, and got a bit of a surprise. The dump hose had a crack in it, about a foot from the outlet connection. Waste water leaked out on the ground. I am so thankful that we have a composting toilet, and that it wasn’t a black water dump. In several decades of RV camping, I’ve never had this happen, but it serves as a good reminder that things break or wear out, and it might be a good preventive idea to replace them occasionally. Yes. Those corrugated "reinforced" hoses only last so long. Hill #12,,2008, 3rd (maybe 4th) set of hoses. Highly recommend Rhino. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
SNY SD UP Posted October 24, 2023 Posted October 24, 2023 Ours are 3 yo. My problem is I have accidently stepped on them while dumping. Some slight oval-ing, but no cracks or leaks. I think I will replace before next outing... 1 1 Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed
Coastal Aggie Posted October 24, 2023 Posted October 24, 2023 Since i only have grey water i opted for just an 8ft garden hose its much slower but easier to handle and has worked well for me so far. except when 2 other trailers decided to pull up behind me at the dump station the other day right as i started. Some dirty looks since it was taking so long. 2 2018 F150 FX4 5.0v8 2022 Oliver Elite Hull #1285 2023 Oliver Elite Hull #1434
Ronbrink Posted October 24, 2023 Posted October 24, 2023 I transitioned from Rhino Extreme with twist-on lug fittings to Waste Master with CAM lock fittings. I didn’t like the way the Rhino would ‘snake’ and expand in length when dumping, and carrying two 10’ sections, just in case extra length was needed, was a tight fit in the rear compartment. The WM 20’ hose is more robust and smoother inside for better flow and ease of cleaning, compresses to ~5’, holds the desired extended length when setup; and has a clear view port, 90° discharge with a handle, control valve and rubber doughnut at its’ terminus. 2 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Moderators bugeyedriver Posted October 24, 2023 Moderators Posted October 24, 2023 In addition to using the Rhino Extreme hose, I never lay it across the ground, where a gravel rock or some other sharp object could puncture the stinky slinky. instead, I cradle it in one of those gradually descending support structures, such as the Camco Sidewinder 20-Ft Camper/RV Sewer Hose Support which can also be useful for routing around obstacles. 4 Pete & "Bosker". TV - '18 F150 Super-cab Fx4; RV - "The Wonder Egg"; '08 Elite, Hull Number 014. Travel blog of 1st 10 years' wanderings - http://www.peteandthewonderegg.blogspot.com
Moderators topgun2 Posted October 24, 2023 Moderators Posted October 24, 2023 1 hour ago, Ronbrink said: I transitioned from Rhino Extreme with twist-on lug fittings to Waste Master with CAM lock fittings. I haven't purchased any of these waste hoses in awhile - but - they sure seem to be "proud" of this one. Bill 2 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Wandering Sagebrush Posted October 24, 2023 Author Posted October 24, 2023 10 minutes ago, topgun2 said: I haven't purchased any of these waste hoses in awhile - but - they sure seem to be "proud" of this one. Bill Let’s not hear complaints, after all… it’s Lippert, and it’s on “sale”. 😳 4 Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L
Moderators topgun2 Posted October 24, 2023 Moderators Posted October 24, 2023 4 minutes ago, Wandering Sagebrush said: and it’s on “sale”. Dang! I missed that part. Perhaps I'll have to change today's schedule and run out to get one before they are all gone.😇 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Ronbrink Posted October 24, 2023 Posted October 24, 2023 1 hour ago, topgun2 said: I haven't purchased any of these waste hoses in awhile - but - they sure seem to be "proud" of this one. Bill Yep, in good keeping; Oliver owners ‘spare no expense’! 3 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Moderators SeaDawg Posted October 25, 2023 Moderators Posted October 25, 2023 12 hours ago, topgun2 said: I haven't purchased any of these waste hoses in awhile - but - they sure seem to be "proud" of this one. Bill Everything made of plastic (petroleum) has become more expensive. Little pvc fittings are two or three times the price of a few years ago . It's kind of astounding to shop the plumbing fittings aisle, honestly. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
AlbertNTerri Posted October 25, 2023 Posted October 25, 2023 So what's the consensus? Do we think the Orange/black Rhino Extreme, Thetford Titan (black with green ends), or the big green Waste Master? I'm standing by ready to order on Amazon!! Albert & Terri Sterns Paonia, Colorado Elite II Hull #1125 Standard Floorplan / 2017 Ford F250 gas
AlbertNTerri Posted October 25, 2023 Posted October 25, 2023 BTW, I'm just using it for gray water since we have the Nature's Head 1 1 Albert & Terri Sterns Paonia, Colorado Elite II Hull #1125 Standard Floorplan / 2017 Ford F250 gas
MAX Burner Posted October 25, 2023 Posted October 25, 2023 ...getting a bit "stinky-slinky envy" going on here 🤪 2 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Ronbrink Posted October 25, 2023 Posted October 25, 2023 8 hours ago, AlbertNTerri said: So what's the consensus? My thought in buying the Waste Master was that if it lasts 2X longer than the leading competitor at twice the price then nothing lost, right? My Amazon purchase three years ago was $133, double the cost of the former Rhino Extreme setup. Now get this, I listed the Oliver Camco (still in the box) and the Rhino Extreme (used one year) on Marketplace, and sold for $17 and $80, respectively. I should mention the Rhino also went with an orange garden hose (for black tank/sewer hose rinse) and a Valterra Twist-On waste valve. That said, in actuality my upgrade was not that expensive. No regrets, the upgrade resolved a year’s worth of frustration trying to stuff the ‘uncooperative’ Rhino into its’ cage and other cumbersome antics, and having a single connection with the very secure CAM lock is unsurpassed satisfaction. Another worthy note, there is less anxiety at the dump station that ‘all will go well’ as either dump valve is opened; think sewer hose staying in place and/or hose end jumping out of position at the sewer receptacle, thus resulting in a much dreaded unintentional release, yuk! I can now open the ‘primary’ dump valve at the OTT, then hold in place the sewer hose terminus as the ‘secondary’ valve is opened. WOW, I never imagined this task being fun as opposed to just a chore, but I’ve digressed! NOW. when curious drive-bys slowly pass while dumping, I’m never certain if they’re checking out the Oliver or the Waste Master! 1 4 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Gliddenwoods Posted October 25, 2023 Posted October 25, 2023 The outlet head on the Waste Master looks quite large. Question for those who own a Waste Master. Is it difficult to fit the Waste Master outlet head into the Oliver back bumper storage compartment due to size? Thanks. 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
dewdev Posted October 25, 2023 Posted October 25, 2023 When dumping my gray tank, I discovered a crack in my discharge hose. Luckily all I had to do was turn the crack to the top of the hose and continued to empty the gray tank without any further leak. Obviously I replaced the hose after that. Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 aH Lithonics batteries (390 total) and Xantrex Freedom XC 3000 Pro Inverter in 2025 2027 RAM 1500 Rebel, 4 x 4; 5.7L Gas V8 Hemi; 3.92 rear axle; 4 corner air suspension Maine
Moderators topgun2 Posted October 25, 2023 Moderators Posted October 25, 2023 11 hours ago, AlbertNTerri said: I'm just using it for gray water since we have the Nature's Head Why not use a "garden" hose? Even a 3/4 inch one would be a bunch easier to handle versus ANY slinky I know of. Bill 1 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
