John Dorrer Posted August 2 Posted August 2 1 hour ago, Gliddenwoods said: Alcan confirmed with Dexter... Sorry, Never Adjust is the brakes. John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
jd1923 Posted August 2 Posted August 2 5 hours ago, John Dorrer said: JD, He has a 100,000 mile warranty on the hubs/bearings. He shouldn't have to do anything with the bearings according to the 2022 manual. I also believe the hubs are sealed. When I read @Gliddenwoods post and read the term Nev-R Adjust I mistook it for the previous generation bearing type called EZ-Lube. John Dorrer knows the spec for 2022-25 Olivers and even though you were told you do not have Nev-R Lube bearings, perhaps you actually do (ask again). Please strike my comment made last night re upgrading to Timken. https://www.dextergroup.com/nev-r-adjust-brakes https://www.dextergroup.com/user_area/content_media/raw/nev-r-lube-lit-215-00.pdf A few of us are considering carrying replacement Nev-R Lube bearings to have as spares in our toolbox. The 5-year 100,000 mile warranty is a good claim but will not help if a bearing fails on the road in some remote location. Alcan quoted me the same price as eTrailer has it listed. It would be good to have one or more of these with you. Read page 29 of this thread for more information re these bearing kits. https://www.etrailer.com/Trailer-Bearings-Races-Seals-Caps/Dexter/31-73-3.html And as John wrote above, grease your leaf spring welt bolts but Nev-R Lube bearings do not require service as suggested in the name! 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
CRM Posted August 2 Posted August 2 15 minutes ago, jd1923 said: A few of us are considering carrying replacement Nev-R Lube bearings to have as spares in our toolbox. The 5-year 100,000 mile warranty is a good claim but will not help if a bearing fails on the road in some remote location. Alcan quoted me the same price as eTrailer has it listed. It would be good to have one or more of these with you. Read page 29 of this thread for more information re these bearing kits. https://www.etrailer.com/Trailer-Bearings-Races-Seals-Caps/Dexter/31-73-3.html If you zoom in on the bearing included in this kit you'll see that they are NTN brand made in Japan. If that's what comes in the axles from the factory I'd probably leave them in and run with them instead of swapping them out ASAP with Timken's like I was originally thinking. I'd still carry a new set(s) and the tools to change them though... 2 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
jd1923 Posted August 2 Posted August 2 (edited) 21 minutes ago, CRM said: If you zoom in on the bearing included in this kit you'll see that they are NTN brand made in Japan. If that's what comes in the axles from the factory I'd probably leave them in and run with them instead of swapping them out ASAP with Timken's like I was originally thinking. I'd still carry a new set(s) and the tools to change them though... My new axles should ship next week. I want to remove a hub to see what's what inside, bearing make and model#, etc. Issue is the spindle nut is one-use only, must be replaced if removed. Alcan wrote they can get spindle nuts from Dexter at $42 each! 🤣 We're hoping to figure out the spec for the axle nut to source at a reasonable cost from some industrial supplier vs. this flagrant pricing from Dexter. If you read the Dexter spec sheet for Nev-R Lube linked above, it states the bearings are Made-in-USA. The 42mm bearing on RockAuto shows Timken, Made-in-USA. Good eye to see this NTN brand made in Japan. I too would be good with either, Japan or USA, just no-way on Chinese knock-offs! Hoping the USA made Timken $36 at RockAuto is correct and then all we need is correct spindle nuts. The other parts should be re-usable for at least the replacement of a second bearing. We'll know more soon... Edited August 2 by jd1923 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Geronimo John Posted August 3 Posted August 3 On 3/5/2024 at 4:21 PM, mountainoliver said: Thank you for the information. You are at least the fourth Oliver owner to have broken springs. The number is way north of double that. GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Geronimo John Posted August 3 Posted August 3 8 hours ago, jd1923 said: And as John wrote above, grease your leaf spring welt bolts but Nev-R Lube bearings do not require service as suggested in the name! Some would also say that the brakes will need inspection occasionally as well. GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Gliddenwoods Posted August 3 Posted August 3 8 hours ago, jd1923 said: When I read @Gliddenwoods post and read the term Nev-R Adjust I mistook it for the previous generation bearing type called EZ-Lube. John Dorrer knows the spec for 2022-25 Olivers and even though you were told you do not have Nev-R Lube bearings, perhaps you actually do (ask again). Please strike my comment made last night re upgrading to Timken. https://www.dextergroup.com/nev-r-adjust-brakes https://www.dextergroup.com/user_area/content_media/raw/nev-r-lube-lit-215-00.pdf A few of us are considering carrying replacement Nev-R Lube bearings to have as spares in our toolbox. The 5-year 100,000 mile warranty is a good claim but will not help if a bearing fails on the road in some remote location. Alcan quoted me the same price as eTrailer has it listed. It would be good to have one or more of these with you. Read page 29 of this thread for more information re these bearing kits. https://www.etrailer.com/Trailer-Bearings-Races-Seals-Caps/Dexter/31-73-3.html And as John wrote above, grease your leaf spring welt bolts but Nev-R Lube bearings do not require service as suggested in the name! Thanks for the explanation! If I understand correctly it is very possibe (likely) I have "nev-r-lube" axles AND "nev-r-adjust" brakes. Yes? 2 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
jd1923 Posted August 3 Posted August 3 20 minutes ago, Geronimo John said: Some would also say that the brakes will need inspection occasionally as well. GJ Yes John, a good reminder! You can tell a lot lifting the tires off the ground, have a helper press the TV brake pedal gently then abruptly. Tighten the self-adjusters to the point where you just hear and feel the shoes rub, because we know they don’t always self-adjust as they should and the rears will be usually be looser than the fronts. Get them as so and you can be relatively confident all inside the drum is working as designed. I worked this service recently and found out brake controller was not working right. Replaced the controller and brake response was night and day. To do a full interior inspection with the Nev-R Lube bearings you’ll need a new set of 4 spindle nuts but on the positive side you won’t have to remove and repack the outer bearings (or both) as we have for decades with the old-style wheel bearings. 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted August 3 Posted August 3 14 minutes ago, Gliddenwoods said: Thanks for the explanation! If I understand correctly it is very possibe (likely) I have "nev-r-lube" axles AND "nev-r-adjust" brakes. Yes? Correct! Who knows why Dexter makes a marketing slogan out of “Nev-R Adjust!” Drum brakes have had self-adjusters almost since the automobile industry invented drum brakes! 🤣 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted Wednesday at 08:03 PM Posted Wednesday at 08:03 PM On 7/27/2025 at 2:45 PM, srthomsen said: A 2023 LE1 owns us also. Number 1403 and it too has a 5033# rated D52 axle with 12" brakes and Never Lube bearings. You and @Golfnut with LEI have this. Just got my new axles yesterday and they are rated the full 5200#. Must be an LEI thing likely limited to 5033# due to the springs. Good news, my axles are here! Bad news, Dexter packed them so poorly, they came badly damaged and going back. Alcan was the reseller on the axles. I special ordered the 50.00" axles from them. They got right on the phone with Dexter this morning, forward the many pictures I took showing the damage. Dexter will Rush Order my axles but rush means another 2 weeks plus shipping. Notice dinged Nev-R Lube cap and dented backing plate. So bashed in that the drum on the left will not turn. What a waste! 3 4 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
2008RN Posted Thursday at 05:04 AM Posted Thursday at 05:04 AM So sorry to hear about this. It is really frustrating. 1 1 Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648
Ronbrink Posted Thursday at 11:50 AM Posted Thursday at 11:50 AM 15 hours ago, jd1923 said: Bad news, Dexter packed them so poorly, they came badly damaged and going back. If not damaged beyond repair, ask for a significant price reduction/refund and make do. Just say’n! 3 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Patriot Posted Thursday at 01:53 PM Posted Thursday at 01:53 PM 17 hours ago, jd1923 said: Dexter will Rush Order my axles but rush means another 2 weeks plus shipping. That’s terrible. Hopefully they will take extra care with the next shipment. Free shipping for your troubles? Can’t hurt to ask. 3 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina
mountainoliver Posted Thursday at 04:33 PM Posted Thursday at 04:33 PM The one axle that has the bent brake backing plate must have really been hit hard! The backing plate on mine is at least 1/8 inch thick steel. With the strengthening ribs and flange it would take a lot to bend it which means the drum must have taken a heavy hit as well. The drum being cast iron could be cracked I wouldn’t use it and if the brake backing plate is tweaked at its mounting flange the shoes will never contact the drum squarely and you’ll always have braking issues with that assembly. You’re doing the right thing to send the entire mess back and get all new assemblies. 5 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
