jgilliam1955 Posted 23 hours ago Posted 23 hours ago We have a Casita and are looking to purchase a used Oliver II. I noticed it is 7000 pounds gross. I am towing with a Chevy Colorado Equipped with a Tow package, which has a 7,500-pound capacity. Should I get a bogger truck? Thanks
Tony and Rhonda Posted 20 hours ago Posted 20 hours ago I'm hesitant to reply to this since we're new Oliver members/owners but the rule of thumb I've been told is trailer should be no more than 80% of your TV's rated tow capacity. For your Colorado that's 6000#. I think towing right at your rated capacity is also going to cause more wear and tear on the TV. Another consideration is your towing experience. If you're crawling up hills at 45mph in a 70-80mph speed zone it's not going to be pleasant. Lot's of questions on this forum on towing so try the search function, or better yet search with Google. Tony 2 New to us 2017 Legacy Elite II Hull #251 (with updates) TV: 2023 Tundra Double Cab 4x4 TRD Sport (still with original engine) Formerly 2004 Tundra with 2015 Four Wheel Camper Fleet
Roger Posted 20 hours ago Posted 20 hours ago (edited) I second everything Tony says. I had an F150 with a 10,000 lb. towing capacity. I never had any issues with it. Early this year, I upgraded to an F350 and I must say pulling my Oliver is a much better experience with the F350, especially when going downhill. Edited 20 hours ago by Roger spelling 2 2021 Elite II Twin Bed Hull #1023 - Kimba | 2025 Ford F-350 6.7 Diesel
Moderators topgun2 Posted 20 hours ago Moderators Posted 20 hours ago 46 minutes ago, Tony and Rhonda said: I'm hesitant to reply to this since we're new Oliver members/owners but T & R - Absolutely no reason to be hesitant replying to any question. Specifically, your response to the question asked is right on the mark. Indeed, there have been many discussions here on the Forum concerning this exact subject (and with other similar tow vehicles to the Colorado). The tow rating is not the only limiting factor on these "mid-sized trucks". Heck - even 1/2 ton trucks tend to run up against limitations due to payload capacity. Thanks for your reply. Bill 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderator+ ScubaRx Posted 19 hours ago Moderator+ Posted 19 hours ago 3 hours ago, jgilliam1955 said: Should I get a bogger truck? Thanks I would suggest a bigger bogger truck. 😊😊😊 Seriously, we have a GMC Canyon with a diesel engine. But we tow with our Silverado 3500HD diesel. Move up to a 2500 or 3500 and you’ll be set. 4 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Rivernerd Posted 17 hours ago Posted 17 hours ago 3 hours ago, jgilliam1955 said: Should I get a bigger truck? We tow our Elite II with a 2019 SR5 Double Cab Toyota Tundra, which is technically a 1/2 ton truck, but has many features common to 3/4 ton pickups, like oversize disc brakes. We opted to try to make the Tundra work, as we already owned it when we bought our Elite II. With an Andersen weight distribution hitch, the Tundra is an adequate tow vehicle for two of us, with gear, towing an Elite II. I don' feel like "the tail is wagging the dog" when towing--with the Andersen hitch. As noted by Topgun 2, a more important limiting factor is payload capacity, not listed "Towing Capacity." Towing capacity is calculated with nothing but an average-sized driver in the tow vehicle. If you plan to drive alone, with minimal gear, you might barely squeak by with a Colorado towing an Elite II. Another important factor is the curb weight of the tow vehicle vs. the trailer. If trailer weight exceeds tow vehicle weight, the "tail" may "wag the dog" in some conditions--not good. The curb weight of our 2019 Tundra SR5 Double Cab is roughly 5600 lbs. An Elite II weighs just over 5K lbs. empty. We put more of the gear and people weight in the Tundra than in the trailer, to increase our tow vehicle-to-trailer weight ratio. As noted above, this is just adequate, in my experience. The curb weight of a new Chevy Colorado is listed at between 4164 and 4827 lbs. Had I already owned a Colorado when we bought our Oliver Elite II, I would not have been comfortable "getting by" with one. I would have chosen to "bite the bullet" and trade up to a 3/4 ton. So, I recommend at least a 3/4 ton tow vehicle. You will be much safer, and I expect, enjoy the towing experience much more. 2 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
Moderators bugeyedriver Posted 17 hours ago Moderators Posted 17 hours ago 5 hours ago, jgilliam1955 said: Should I get a bogger truck? Short answer - YES Pete & "Bosker". TV - '18 F150 Super-cab Fx4; RV - "The Wonder Egg"; '08 Elite, Hull Number 014. Travel blog of 1st 10 years' wanderings - http://www.peteandthewonderegg.blogspot.com
rideandfly Posted 17 hours ago Posted 17 hours ago We just moved up to a F-350 and really enjoy towing Ollie with it. On our previous 1/2 ton tow vehicles I added rear suspension systems to reduce rear end sag, these modifications are not needed with the F-350 when towing Ollie. Really like the increased payload with the F-350, a couple of our past TV had to monitor the TV weight with Ollie connected to be sure we did not exceed the TV axles & gross weight. 1 Bill 2015 LE2 #75 2024 F350 6.8L
Moderators topgun2 Posted 16 hours ago Moderators Posted 16 hours ago 51 minutes ago, rideandfly said: We just moved up to a F-350 Congrats! 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
rideandfly Posted 15 hours ago Posted 15 hours ago 50 minutes ago, topgun2 said: Congrats! Bill, Thanks! It has the 6.8 Mini-Zilla gas engine, a de-stroked 7.3 Godzilla, with 10R100 transmission. It's an old school gas V-8. Really like how it tows Ollie, too. 1 Bill 2015 LE2 #75 2024 F350 6.8L
Moderators topgun2 Posted 15 hours ago Moderators Posted 15 hours ago Can I be the "flag guy" for that drag race between you and Patriot? - Please! 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
rideandfly Posted 14 hours ago Posted 14 hours ago (edited) 3 hours ago, topgun2 said: Can I be the "flag guy" for that drag race between you and Patriot? - Please! I think that race has happened on Youtube, Diesel Wins! Retired from the railroad, never met an unhappy Diesel Locomotive Engineer! 😁 Edited 11 hours ago by rideandfly Bill 2015 LE2 #75 2024 F350 6.8L
