John and Jodi Posted yesterday at 12:34 AM Posted yesterday at 12:34 AM I'm not very handy so I haven't looked a lot under and around the bowels of our trailer, but recently I had an occasion to do so. Looking at my shower drain pipe I saw this: It appears that the 1.5 inch drain line has collapsed. The shower still drains slowly and there's no leaks (yet?), but I'm a bit shocked. While the pipe from the shower pan is vertical, the connection to the gray tank(?) pipe appears to be at a 45 degree angle so that buying a new P Trap doesn't appear to be a good option unless I'm willing to re-plump. Is this normal? I'm open for suggestions. John and Jodi San Antonio, TX 2022 Elite II - Hull #1126 being pulled by a 2022 F-150 Powerboost. Map Legend: Red - Driven Through; Orange - Stopped In; Blue - Explored Parts; Green - Explored Whole
Snackchaser Posted yesterday at 01:25 AM Posted yesterday at 01:25 AM (edited) Looks like they installed a flexible tube and left a twist in it. You might try loosening a clamp and twisting the kink out. Unfortunately that kink could be set and it seems like too a tight bend even for a replacement piece. Oliver should address that despite the expired warranty, it was just a poor installation from the start. Good luck, Geoff Edited yesterday at 01:27 AM by Snackchaser 4
Moderators topgun2 Posted 13 hours ago Moderators Posted 13 hours ago Can we assume that you purchased this Ollie "new"? I've never seen that kind of installation. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
John and Jodi Posted 12 hours ago Author Posted 12 hours ago 1 hour ago, topgun2 said: Can we assume that you purchased this Ollie "new"? Yes. New from the factory in 2022. 1 2 John and Jodi San Antonio, TX 2022 Elite II - Hull #1126 being pulled by a 2022 F-150 Powerboost. Map Legend: Red - Driven Through; Orange - Stopped In; Blue - Explored Parts; Green - Explored Whole
DanielBoondock Posted 11 hours ago Posted 11 hours ago Nice design actually for maintenance, should be easy to remove and clean out compared to rigid pipe 2 Oliver Elite II Twin 2026 (all the upgrades) Sierra EV AT4 2026 (max range 530 mile pack)
Ollie-Haus Posted 10 hours ago Posted 10 hours ago Our 2023 has the same connection without the kink. Actually this is a nice trap design as the trap material is soft enough to prevent cracking if water is left in the trap during winter storage. It's a tough location to work in but should be able to be corrected. If the kink remains after removal try placing in boiling water for a few minutes to restore it to normal shape. Otherwise Oliver should be able to supply a new one. 2 What's today?............. the most frequently asked question as a retiree 🙄 Chris and Stacie Neuhaus and Cohen the fearless Border Terrier, Greenfield, Indiana 2021 Ford F350 7.3L Tremor (Redzilla) LE2 #1373 - Ordered 10/21/22 - Delivered 05/10/23
Boudicca908 Posted 9 hours ago Posted 9 hours ago 16 hours ago, John and Jodi said: I haven't looked a lot under and around the bowels of our trailer Can you describe how you accessed that area for the photo? If I can, I will send a photo of my Spring 2022.... to see if it looks different. 1 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
John and Jodi Posted 6 hours ago Author Posted 6 hours ago 2 hours ago, Boudicca908 said: Can you describe how you accessed that area for the photo? I removed the access panel on the dinette seat closest to the shower and looked down and right. 3 John and Jodi San Antonio, TX 2022 Elite II - Hull #1126 being pulled by a 2022 F-150 Powerboost. Map Legend: Red - Driven Through; Orange - Stopped In; Blue - Explored Parts; Green - Explored Whole
Boudicca908 Posted 5 hours ago Posted 5 hours ago (edited) @John and Jodi I wasn't able to get quite the same angle, but here are my photos. I have the same material, but it's not twisted like yours. .... why do I struggle with photo uploads? I will try to fix these.... a few minutes. Edited 5 hours ago by Boudicca908 photo upload hassle 2 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
jd1923 Posted 45 minutes ago Posted 45 minutes ago (edited) 5 hours ago, Boudicca908 said: @John and Jodi I wasn't able to get quite the same angle, but here are my photos. I have the same material, but it's not twisted like yours. Good photos yep, one flexible P-trap is straight, the other is certainly twisted. How do they twist this during installation? Sometimes a job is easier when doing it the right way! Wish I had looked that direction when I had all the waste valves out (was instead looking forward to run DC-DC wiring)! Can a person get an arm in there to loosen the two hose clamps? If so, all can be good. You could put the part in hot water to get it back to original shape which was a great suggestion! But first I would send picture to OTT asking them to replace the part ASAP no charge. Also it's so cool to see the 3" ducting to the bathroom! If it kills me, I've got to install semi-rigid ducting, a homerun from furnace to bath. OEM ducting, Why, why, why? When the bottom hull is open for a few extra dollar full RIGID ducting SHOULD be laid. Ours was full of holes across the bottoms, everywhere. I replaced all I could within reach. Edited 19 minutes ago by jd1923 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
