John E Davies Posted August 26, 2017 Posted August 26, 2017 You know how it is when you are parked just slightly off level toward the street - the door will not stay open, no way, no how.... The eyelet is a thin piece of stainless steel, with a hole in it just large enough to allow two sections of standard nylon paracord to slide through it with a good amount of drag. When installing onto the door, be sure to support the bottom of the door or it might come apart, since that screw holds the frame together at the upper corner. The cord is adjustable for length just by sliding it, and you can remove it entirely by pulling through the eyelet since there is no knot in the left side of it. Set the length so that it will just slip under the knob at the bottom for travel. Works good, if you slip the end under just the outer arm of the coat hook, you can still hang stuff like hats from it. Be sure to sear the cut ends or they will look nasty. And you don't have to use bright green ;) John Davies Spokane WA 2 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Moderators Mike and Carol Posted August 26, 2017 Moderators Posted August 26, 2017 We just got the small door magnets. On Command strips hold one on the bottom of the door and one on the side under the dinette seat. They work well and not very noticeable at all. Mike 4 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
ShallowGal Posted August 26, 2017 Posted August 26, 2017 no way, no how…. Mr. MacGyver, this one cracked me up. I appreciate your ingenuity. To my level-headed-farm-boy husband's dismay, I'm a bit of a nerd myself & was wondering ... [Keep in mind I've only been inside an Ollie II once & that was a couple months ago.] Could you slice one side of a swim noodle & cut it to fit the width of the door jam, then shove the noodle over the edge of the jam to keep the door open? Chris & Duke Chadwell 🐾Maddie & Baxter🐾 Elite II Hull 292 2022 F-250 Lariat 7.3 Godzilla 4x4 Lakeland,FL
John E Davies Posted August 26, 2017 Author Posted August 26, 2017 Could you slice one side of a swim noodle & cut it to fit the width of the door jam, then shove the noodle over the edge of the jam to keep the door open? Sure, a noodle or a piece of slit water pipe insulation would work for off season ventilation, but that will only hold it art way.... This is intended for when you are occupying the trailer for a short time, for example a Rest Stop, and want to keep the door fully open. Sometimes we don't disconnect and/or run down the jacks down for overnight, if I can get the trailer close to level by maneuvering. If the trailer has a slight right cant, the door won't stay open without this string, or the magnets mentioned above, which I was too dim to think of. We keep the dog water bowl in the bathroom, so the door needs to be open most of the time. You can always prop it open with a shoe or some other object, but that doesn't work very well. John Davies Spokane WA 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Moderators topgun2 Posted August 27, 2017 Moderators Posted August 27, 2017 Mike & Carol - Ya got a picture of your door magnets? Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators Mike and Carol Posted August 27, 2017 Moderators Posted August 27, 2017 Mike & Carol – Ya got a picture of your door magnets? Bill I don't right now. We're going to drive over to the storage in a bit to make sure all is OK. Will bring back pics. Mike Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Moderators Popular Post Mike and Carol Posted August 27, 2017 Moderators Popular Post Posted August 27, 2017 https://www.amazon.com/gp/product/B01INZ7RY0/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1 Mike 19 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Moderators topgun2 Posted August 27, 2017 Moderators Posted August 27, 2017 Mike & Carol - that is very nice and CLASSY - just like both of you! Bill 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Free2Roam Posted August 27, 2017 Posted August 27, 2017 Mike & Carol - LOVE this idea!!! -Angela 1 2017 Legacy Elite II Standard 2006 Chevy 2500 HD Diesel 4WD
Nana Posted June 28, 2018 Posted June 28, 2018 HI Mike, I like your magnets to hold the bathroom door open. I ordered the same item. It came with holes to attach with screws but I don’t want to put holes in my Oliver. You mentioned that you attached with 3M tape. Did you use a special kind of 3M tape and is it remaining secure after using for awhile?
Moderators topgun2 Posted June 28, 2018 Moderators Posted June 28, 2018 Nana - I'm sure that Mike & Carol will respond, but, in the meantime - I also used their idea and like you I didn't want to drill to install them. I used Command double sided tape: https://www.amazon.com/Command-General-Decorative-20-Strips-GP023-20NA/dp/B0751VFF2P/ref=sr_1_5?ie=UTF8&qid=1530229593&sr=8-5&keywords=command+strips&dpID=51vrI6-Vl1L&preST=_SY300_QL70_&dpSrc=srch of the appropriate size a year ago and there has been absolutely no movement in either magnet to date. Bill 1 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators Mike and Carol Posted June 28, 2018 Moderators Posted June 28, 2018 We used the Command double sided tape. Beside Amazon, you can find it at Walmart and Home Deport in a variety of sizes. Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
ScottRicki Posted July 10, 2018 Posted July 10, 2018 [attachment file=Bath Door Magnet.pdf] [attachment file=Bath Door Magnet2.JPG] We used the magnet method also. Ours are a little flatter. Used the 3M Adhesive/sealer Oliver used on trailer. Not near trailer right now to take pics but attached is where I ordered. Bath-Door-Magnet.pdf Scott&Ricki 2017 Legacy Elite II Twin, Hull 225, The Bus 2007 Tundra Prev: 2003 Casita, 2009 Weekend Warrior
ScottRicki Posted July 10, 2018 Posted July 10, 2018 OK - I will try the pic again [attachment file=Bath Door Magnet2.JPG] Scott&Ricki 2017 Legacy Elite II Twin, Hull 225, The Bus 2007 Tundra Prev: 2003 Casita, 2009 Weekend Warrior
ScottRicki Posted July 10, 2018 Posted July 10, 2018 Where https://www.thehardwarehut.com/catalog-product.php?p_ref=297731 And what SUG-MC-JMP45 Sugatsune Sealed Counterplate - EACH (White) SUG-MC-JM45WT Sugatsune Sealed Magnetic Catch - EACH (White) Scott&Ricki 2017 Legacy Elite II Twin, Hull 225, The Bus 2007 Tundra Prev: 2003 Casita, 2009 Weekend Warrior
BackofBeyond Posted July 10, 2018 Posted July 10, 2018 Well Well Well , We won't pick up our Ollie until next week, and I ordered two pair from the big "A". Thanks guys, I'm ahead of the game-- for once... Cindy, Russell and "Harley dog" . Home is our little farm near Winchester TN 2018 Oliver Legacy Elite II - 2018 GMC 2500 Duramax "Die young - As late as possible"
mountainoliver Posted July 10, 2018 Posted July 10, 2018 Mike, just received my magnets from Amazon and installed them with Command tape. I have been looking for something just like this to replace the bungee cord that I have been using. This works great and looks much better, thanks! 1 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
Moderators Mike and Carol Posted July 10, 2018 Moderators Posted July 10, 2018 Mike, just received my magnets from Amazon and installed them with Command tape. I have been looking for something just like this to replace the bungee cord that I have been using. This works great and looks much better, thanks! It’s been a year since we stuck our magnets on and they show no signs of coming off! Glad it’s working for you. Mike Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
rideadeuce Posted July 31, 2018 Posted July 31, 2018 I think this has got to be the best $5 mod that you can do! 2 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
Spike Posted January 13, 2019 Posted January 13, 2019 I used Mike's magnet-and-Command-Strip method, but found that I could put one magnet on the door and the other one inside the compartment under the seat. This has two advantages as far as I can tell: It eliminates adding another protuberance. It weakens the magnetic pull, making it easy to pull the door back and not put any strain on the door. (These magnets are pretty powerful.) I think that someone mentioned having to put something over the magnets to weaken the pull. Putting one magnet inside the compartment accomplishes the same thing. 5 2 Onward through the Fog! EarthPicks of Cochise County
Moderators Mike and Carol Posted January 13, 2019 Moderators Posted January 13, 2019 Jeff, brilliant! What a great idea! Why didn’t I think of that? I’m going to do as you did when I have the trailer here later this week. We’re loading up to head to Quartzsite (passing through Cochise County!) then on to California. Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Spike Posted January 14, 2019 Posted January 14, 2019 What a great idea! Why didn’t I think of that? Well, Mike, I wouldn't have thought of it if you hadn't thought of the magnet-Command-strip solution in the first place. If it works out, and you have a stay over in our neck of the woods, perhaps we can connect. It was viewing your Ollie that cinched our decision to get one. 1 Onward through the Fog! EarthPicks of Cochise County
KountryKamper Posted January 14, 2019 Posted January 14, 2019 I have the magnets but did not install them because they were so strong. Great idea. Tom & Cheryl LE II #305 2018 GMC 2500HD SLT Duramax
SNY SD UP Posted June 30, 2021 Posted June 30, 2021 On 1/13/2019 at 11:55 AM, Spike said: I used Mike's magnet-and-Command-Strip method, but found that I could put one magnet on the door and the other one inside the compartment under the seat. This has two advantages as far as I can tell: It eliminates adding another protuberance. It weakens the magnetic pull, making it easy to pull the door back and not put any strain on the door. (These magnets are pretty powerful.) I think that someone mentioned having to put something over the magnets to weaken the pull. Putting one magnet inside the compartment accomplishes the same thing. Spike, did you use the same magnets that Mike & Carol used? if not, which magnets did you buy??? Maggie & Bryan | Arnegard, ND | 2020 LE II "Twins" Hull #665 | 2021 RAM 2500 6.4L HEMI Gasser 4dr 6.5' bed
dewdev Posted June 30, 2021 Posted June 30, 2021 We ordered on Amazon the same magnetics that Mike and Carol have in their picture and they came with screws and double sided tape. We put one magnetic on the bottom corner of the door and (instead of placing the other magnetic on the face of the fiberglass under the dinette seat) the second magnetic was installed inside of the cabinet, out of site, and this installation holds the door open with no problem. 2 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
