Zodd Posted November 9, 2021 Share Posted November 9, 2021 4 hours ago, VBistro said: You might want to check your numbers here...most computers use less than 1Ah, not 80. @VBistro I agree, that is why I am confused. My 80 number comes from Jason in the video when he states the invert amp rate is about 10x. So if your device draws 8amps it is drawing 80amps from the battery through the inverter. Maybe I miss understanding the video (take a listen at the link, the link starts right where he says it). Todd & Kat 2023 LE ll twin, hull # 1305, Truma AC & WH, Platinum solar, Natures Head 2024 Ford F250 Lariat 7.3L gasser / 3.75, FX4 Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted November 10, 2021 Moderators Share Posted November 10, 2021 @ZoddThe inverter is taking dc 12v to 120 for the typical user (microwave, keurig, ac.) Hence, 10x , for those 110 /120 appliances. In your case, the laptop is plugged into 110 or 120, but converts to a few amps dc, with its own charging brick. It will never use more than it needs, and not likely ever ! 80 amps. More like 1 to 5, max, dc. You will have some power loss, going dc battery to ac inverter back to dc plug/brick on your pc charger, but nowhere near 80 amps . Maybe 5 , imo. When we used a pc, 1000 watt inverter, and 110 to dc charger, on agm batteries, we barely noticed the loss. We did charge during the sunny part of the day, on solar. Take a look at your brick on the charger, and look at volts and amps. If I've done the mental math incorrectly, I'm sure someone will jump in and correct me. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
Zodd Posted November 10, 2021 Share Posted November 10, 2021 Thanks @SeaDawg I think your statement helps. Maybe I was just misunderstanding the directional part of his statement. BTW this is not about how much a given device does or does not draw (not trying to prove how much a laptop does or does not draw). It was just about his 10x statement of it draw 10x more regardless of device, hence my random example. But if the statement was more about directionally needing to go from 12 to 120 that makes sense. It was not how I hear it but at least makes sense in that framing. For anyone reading this you will not understand the statement if you respond without listening to the clip 🙂 2 Todd & Kat 2023 LE ll twin, hull # 1305, Truma AC & WH, Platinum solar, Natures Head 2024 Ford F250 Lariat 7.3L gasser / 3.75, FX4 Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted November 10, 2021 Moderators Share Posted November 10, 2021 @Zodd, I get it. Translation back and forth from 12v dc to 110 ac can be mind-boggling. Fwiw, when we switched from a laptop to tablets, we removed the inverter entirely. No need, and less to worry about. Everything we use on a daily basis is 12v. If we need 110, we'll, we'll go to a hookup. Or fire up the generator. Makes the math so much easier for my little brain. 😁 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
ChrisMI Posted November 13, 2021 Share Posted November 13, 2021 One option for those with an excessively loud charging fan might be to add another smaller charger to the system. A 15-20 amp silent unit could be utilized most of the time with the option to use the high power unit when needed. This might actually increase the battery life with the slower charge rate and likelihood to reduce the depth of discharge. 2 Link to comment Share on other sites More sharing options...
Fritz Posted December 3, 2021 Author Share Posted December 3, 2021 I received the following private message, and am posting it here in case anyone else has the same question (or to give others a chance to correct my response): "Are there switches/breakers inside the trailer that I need to switch off before I remove my batteries? I would assume so - like a "main" switch similar to on a house panel that would just power everything off." I have not yet removed the batteries for the season (I'm still trying to get an inverter issue resolved). That said, I think the only thing that is necessary is to stop all major loads (e.g., unplug from shore power, turn off major uses (e.g., microwave), and perhaps turn off the solar controller (the red dial-switch located in the upper cabinet above the streetside bed). Record the SOC and voltage for warranty purposes (I take screenshots of these readings for each battery). Take a photo of the wiring array before you begin disconnecting terminals to help with reconnection in the spring. Then turn off each of the Lithionics batteries (the light-blue lit button in the far right corner of each battery). Disconnect the batteries beginning with the primary negative terminal (this is the right-front terminal with multiple, heavy-gauge wires), then disconnect all of the other wires being careful not to accidentally bridge terminals with a wrench. As a heads-up for reconnecting in the spring, I think I recall seeing a torque specification in the manual for tightening nuts on the terminals (to avoid damaging the batteries by over tightening terminal nuts). 1 1 2021 Oliver LE2 Ram 2500 diesel Link to comment Share on other sites More sharing options...
Fritz Posted December 18, 2021 Author Share Posted December 18, 2021 On 11/4/2021 at 10:39 AM, Fritz said: Charging to 14.4 volts requires shore power Charging to 14.4 volts can’t be done with the currently-installed Zamp controller; it must be done with shore power (or perhaps a generator). This is a limitation of the Zamp pulse-width modulation (PWM) controller; a maximum power point tracking (MPPT) solar charge controller could charge the batteries to 14.4 volts, but this is not what Oliver installs. Similarly, at least some of the DC-to-DC chargers that have been described in other threads allow the tow vehicle to top off batteries to 14.4 volts, but such a charger requires aftermarket installation. For an example installation, search for John Davies’ Redarc DC-to-DC charger installation description. My comment about the Zamp controller in the original post in this thread is incorrect. The Zamp controller does charge the batteries up 14.4 volts. Moderators: I tried to modify the original November 4 post, but could not find the "edit" option. Could one of you please show me how to correct the error in the original post? 2 2021 Oliver LE2 Ram 2500 diesel Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted December 18, 2021 Moderators Share Posted December 18, 2021 13 minutes ago, Fritz said: Moderators: I tried to modify the original November 4 post, but could not find the "edit" option. Could one of you please show me how to correct the error in the original post? Until members have made a certain number of posts, editing time is limited to something like 24 hours. Then, the edit button disappears. If you would send me a pm with a revised paragraph from your original post, I'll be happy to edit it for you. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
DaveAndBecky_NorthernMI Posted March 30, 2022 Share Posted March 30, 2022 I am home and learning the ins and outs of Lithionics batteries. I have 2022 Elite II with Pro Solar package (390 Amp/hrs or batteries). Trailer is currently winterized and I am trying to build confidence in the Lithionics App Status of Charge (SOC) that Fritz and others have discussed here. My batteries read ~13.2 volts with no load but have SOC of 98%, My understanding is 13.2 is closer to 50% and 100% would be 13.6. I am trying to draw down batteries and then recharge to allow the algorithm for SOC to recalibrate (thanks Fritz). What reading should I rely on to decide when to plug in to shore power - Lithionics volts? First image is Xantrex with inverter on and small heater plugged in (no shore power). Second is Lithionics readings with heater plugged in. Seems ok. Third image is Lithionics reading with no load (inverter off). Thanks in advance! 2022 Oliver Elite II Hull#1047 "Saunter" 2014 VW Touareg TDI Link to comment Share on other sites More sharing options...
Jps190 Posted March 30, 2022 Share Posted March 30, 2022 1 hour ago, DaveAndBecky_NorthernMI said: I am home and learning the ins and outs of Lithionics batteries. I have 2022 Elite II with Pro Solar package (390 Amp/hrs or batteries). Trailer is currently winterized and I am trying to build confidence in the Lithionics App Status of Charge (SOC) that Fritz and others have discussed here. My batteries read ~13.2 volts with no load but have SOC of 98%, My understanding is 13.2 is closer to 50% and 100% would be 13.6. I am trying to draw down batteries and then recharge to allow the algorithm for SOC to recalibrate (thanks Fritz). What reading should I rely on to decide when to plug in to shore power - Lithionics volts? First image is Xantrex with inverter on and small heater plugged in (no shore power). Second is Lithionics readings with heater plugged in. Seems ok. Third image is Lithionics reading with no load (inverter off). Thanks in advance! I would start by charging the batteries until they go into float. While charging you will see voltage go up to around 14.5 then start to drop back down to round 13.5. Once you are in float mode I would give the cells a chance to balance. You will see a status code on the Lithionics app if the battery cells are balancing. Then apply a load to the system like a small space heater. Allow this to run while periodic checking the SOC for each battery. They should be relatively close. You can allow the batteries to drop down to their Low voltage cutoff which is controlled by the BMS. You might have to check the inverter settings before doing this since the inverter also has a setting that will stop discharging the batteries at a preset voltage. If I remember correctly mine was set higher than the BMS setting. Also be aware that the batteries will not all shut off at once so you have to make sure the load you are using doesn’t stress the system when you get down to one battery. John 1 1 John and Kim 2021 GMC Sierra 2500 AT4 6.6L Duramax 11350 GVWR 3048lb Payload 2021 Oliver Elite II. Hull #887 Link to comment Share on other sites More sharing options...
MnG KY Posted August 1, 2022 Share Posted August 1, 2022 I don't want to know ANY of this technical stuff. I just want the darn thing to work. If I have to learn all this, I want my money back. 1 George and Melinda Pierce 2022 EII hull 1171, 2021 Ford 150 Hybrid with Pro Power Onboard Link to comment Share on other sites More sharing options...
Moderators Mike and Carol Posted August 1, 2022 Moderators Share Posted August 1, 2022 10 hours ago, MnG KY said: I don't want to know ANY of this technical stuff. I just want the darn thing to work. If I have to learn all this, I want my money back. I understand the frustration. You don’t need to be a technical expert, I’m certainly not. But, a basic understanding of all the systems in your trailer and how they work is important. You need to know where the fuse box is and what all is in it, where the big circuit breakers are under the seat and bed (where mine are) and how to know if they are tripped and how to reset. What the readouts on your solar controller mean. Where the microwave is plugged in, where your black tank and gray tank valves are located, where the water pump is and how it is wired, how to manually raise/lower your jacks, etc. I say all these things because I have had to address them in my own trailer over the years. Knowledge will come over time, you pick up nuggets of info slowly just by asking questions and getting help from other owners and from Oliver Service. Mike 7 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Link to comment Share on other sites More sharing options...
MnG KY Posted August 1, 2022 Share Posted August 1, 2022 Mike, thanks for that reply. We are learning a lot fast. I did not realize I was going to have to monitor all the systems as much as we are. I thought managing the black tank would be my biggest hurdle, but that so far has been the easiest. 1 George and Melinda Pierce 2022 EII hull 1171, 2021 Ford 150 Hybrid with Pro Power Onboard Link to comment Share on other sites More sharing options...
Moderators Mike and Carol Posted August 1, 2022 Moderators Share Posted August 1, 2022 1 hour ago, MnG KY said: Mike, thanks for that reply. We are learning a lot fast. I did not realize I was going to have to monitor all the systems as much as we are. I thought managing the black tank would be my biggest hurdle, but that so far has been the easiest. These things seem to happen one-by-one. You won’t forget to check to see if your batteries are on again and you’ll know that if there is no 12V to check the batteries and the breakers. If your water pump quits working, don’t panic. There are two red wires that connect to the underside of the pump, they like to come disconnected if you travel some rough roads. Easy to fix. If the microwave quits, check to see if it is still plugged in to 110V. Etc, etc. There’s help here on the forum, lots of smart, technical folks and some not so technical (me) who have dealt with seemingly big issues that turn out to be no big deal. Pretty soon you’ll be giving advice! Enjoy your camping! Mike 4 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Link to comment Share on other sites More sharing options...
MnG KY Posted August 1, 2022 Share Posted August 1, 2022 29 minutes ago, Mike and Carol said: These things seem to happen one-by-one. You won’t forget to check to see if your batteries are on again and you’ll know that if there is no 12V to check the batteries and the breakers. If your water pump quits working, don’t panic. There are two red wires that connect to the underside of the pump, they like to come disconnected if you travel some rough roads. Easy to fix. If the microwave quits, check to see if it is still plugged in to 110V. Etc, etc. There’s help here on the forum, lots of smart, technical folks and some not so technical (me) who have dealt with seemingly big issues that turn out to be no big deal. Pretty soon you’ll be giving advice! Enjoy your camping! Mike Thanks for the encouragement. ! 2 George and Melinda Pierce 2022 EII hull 1171, 2021 Ford 150 Hybrid with Pro Power Onboard Link to comment Share on other sites More sharing options...
Geronimo John Posted March 23 Share Posted March 23 On 11/6/2021 at 6:00 AM, mountainoliver said: three or four Battle Born batteries, I have three and would be hard pressed to figure out how you got four of them in there unless yours are the ones mounted sideways with buss bars utilizing great care and extremely brilliant craftsman skills. For the normal DYI owner, three 100 amp BB's seems the limit. GJ 3 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR). Link to comment Share on other sites More sharing options...
Moderators Mike and Carol Posted March 23 Moderators Share Posted March 23 7 hours ago, Geronimo John said: I have three and would be hard pressed to figure out how you got four of them in there unless yours are the ones mounted sideways with buss bars utilizing great care and extremely brilliant craftsman skills. For the normal DYI owner, three 100 amp BB's seems the limit. GJ Ken and I both have 3 BB’s. There’s no room for 4 and three gives plenty of capability. Mike 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Link to comment Share on other sites More sharing options...
jd1923 Posted March 24 Share Posted March 24 22 hours ago, Geronimo John said: I have three and would be hard pressed to figure out how you got four of them in there unless yours are the ones mounted sideways with buss bars utilizing great care and extremely brilliant craftsman skills. For the normal DYI owner, three 100 amp BB's seems the limit. GJ GJ, Mike and many others, have better batteries than we! 450 AH of lead acid here. I read here that two 300AH Epoch batteries fit, which is totally amazing! By the time we upgrade, 2025, 2026, I'm hoping some manufacturer can stuff 800AH into the bay size holding four 6V golf cart batteries! 4 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins! Link to comment Share on other sites More sharing options...
Moderators Mike and Carol Posted March 24 Moderators Share Posted March 24 8 hours ago, jd1923 said: GJ, Mike and many others, have better batteries than we! 450 AH of lead acid here. I read here that two 300AH Epoch batteries fit, which is totally amazing! By the time we upgrade, 2025, 2026, I'm hoping some manufacturer can stuff 800AH into the bay size holding four 6V golf cart batteries! Lithiums are a nice upgrade, but we camped for years with four AGM batteries in our Oliver and they did a fine job in all kinds of conditions. Mike 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Link to comment Share on other sites More sharing options...
MAX Burner Posted March 25 Share Posted March 25 On 3/24/2024 at 6:11 AM, Mike and Carol said: Lithiums are a nice upgrade, but we camped for years with four AGM batteries in our Oliver and they did a fine job in all kinds of conditions. Mike Same here for us, Mike. AGMs served us just fine with our previous TT - however, for us at least, the Lithiums have been a game changer. For example, we just returned from a short 3-nighter to Columbus, NM. We started each afternoon with 100% SOC on the BBs (200w portable solar module tucked away in the TV). Standard boon-docking afternoon/evening drill for us is fridge operating in gas mode, inverter OFF, dinner off the gas grill, cocktail lamp - "LIT", furnace OFF, Starlink up and an after-dinner "Shoot 'em Up" movie (neither one of us makes it to the end before crashing-out)... The three nights averaged an 11% drop in SOC by morning. The OTT 340watt solar module roof mount (during MAR sun angles near the US/Mexico border) brought the SOC back up to 100% by 3pm-ish. FYI: DAY-2 was overcast, but we still had 100%SOC before we lit the cocktail lamp - we're love'n this system! Cheers, ALL! 4 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
Geronimo John Posted March 25 Share Posted March 25 On 3/23/2024 at 5:35 PM, jd1923 said: GJ, Mike and many others, have better batteries than we! 450 AH of lead acid here. I read here that two 300AH Epoch batteries fit, which is totally amazing! By the time we upgrade, 2025, 2026, I'm hoping some manufacturer can stuff 800AH into the bay size holding four 6V golf cart batteries! Certainly there at least two other brands that have similar safety characteristics as the BB's and can also fit into an OE2 battery tray and provide more than 300 AH. But the brand that MountainOlivers is stating is specifically the Battleborn's. At some point, my experience with them will be out of date. But as of today, I have not yet heard of anybody getting more than 300 AH's from Battleborns in an OE2 battery box. Hence my reaction to the statement of "three or four Battle Born batteries". Have they come out with a new product that will let us get four of their batteries into an OE2 and get more than 300 AH? If so, I'm all ears! GJ 1 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR). Link to comment Share on other sites More sharing options...
MAX Burner Posted March 25 Share Posted March 25 4 minutes ago, Geronimo John said: Certainly there at least two other brands that have similar safety characteristics as the BB's and can also fit into an OE2 battery tray and provide more than 300 AH. As discussed in many threads on these forums, individual camping style/needs dictate what direction (ie: Rabbit Hole) one's (or a couple's) modifications take them. Gotta tell y'all, for us and our "style", a 300AH storage capacity totally meets our needs. We do sub-freezing days on end - but not necessarily in the minus zero range for sure. However, there are many owners out there that take advantage of the sub-0 winter months for their boon-docking camping style. Understood, 100%. If we went for a sub-zero, multiple overcast day adventure like that, I could see how 300AH might not be enough. That's when we'd probably need to break out the EU2000 on DAY-3 or 4 when our SOC is floating around 30%. Still doable, I suppose - but that 600AH option in that scenario sounds really nice! HA! Just say'n... perspective. Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
mountainoliver Posted March 25 Share Posted March 25 Four 100 amp Battle Born batteries will in fact fit into the 2017 version battery tray. I say 2017 version because Oliver has used a couple of different makes that I am aware of. Oliver history buffs maybe can clarify this. Since the Battle Born brand batteries can be mounted in any orientation, four of the standard form factor batteries can be mounted on end. Battle Born also has a vertical form factor battery. Four of these vertical batteries also will fit in the tray. For both types of batteries mounted vertically, the cable connections get a little challenging. There is a forum post that covers a lithium battery installation and I think that it covers the four battery choices. Of course in recent history, there are several manufacturers who have large amp batteries that don’t require trying to shoehorn multiple batteries into the tray. 2 1 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax Link to comment Share on other sites More sharing options...
Moderators Mike and Carol Posted March 26 Moderators Share Posted March 26 4 hours ago, MAX Burner said: For example, we just returned from a short 3-nighter to Columbus, NM. We started each afternoon with 100% SOC on the BBs (200w portable solar module tucked away in the TV). Standard boon-docking afternoon/evening drill for us is fridge operating in gas mode, inverter OFF, dinner off the gas grill, cocktail lamp - "LIT", furnace OFF, Starlink up and an after-dinner "Shoot 'em Up" movie (neither one of us makes it to the end before crashing-out)... The three nights averaged an 11% drop in SOC by morning. The OTT 340watt solar module roof mount (during MAR sun angles near the US/Mexico border) brought the SOC back up to 100% by 3pm-ish. FYI: DAY-2 was overcast, but we still had 100%SOC before we lit the cocktail lamp - we're love'n this system! That mirrors what we’ve experienced with our three BB’s. 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Link to comment Share on other sites More sharing options...
jd1923 Posted March 26 Share Posted March 26 4 hours ago, Geronimo John said: ... I'm all ears! GJ Me too, isn't that why we login each day? Thank you GJ, this made my day! @Mike and Carol reinforced my thought that my 450AH of LA might be good enough for many camping styles. And we have a near new battery bank the prior owner purchased in 2021. @MAX Burner also reinforced the idea, stating 300 AH works for them (although Art has a KILLER DC-to-DC installation). I'm going to keep reading, learning and likely will put off an LI upgrade for a couple of years. Just ask @SeaDawg, as she has been babying her AGMs for years. At the same time, would love to have 600AH of Epoch LI batteries ready for your next trip. All in time... 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins! Link to comment Share on other sites More sharing options...
