I just put a deposit for the Elite II with the Lithium Platinum Package and I have some questions that I am sure folks on this forum can help.  The package comes with Lithium batteries, charge controller and inverter.  My question is, if I need to charge the batteries from my generator using the external 30 amp connection, how does Oliver connect the wiring such that the batteries will be charged but the input does not feedback to other circuitry that might cause damage?  Do I need to add more hardware in order to charge my batteries using a generator?  Thanks
@RV Newbie
The 12v and 120v circuits are isolated in the trailer. Your xantrax inverter/charger will use your generator/shore power to charge the batteries and provide 120 to the rest of your trailer. You can set the incoming current limit so it does not overload your generator. It’s your responsibility to limit 120 usage (microwave, AC, etc) during this charge cycle so the generator can provide continuous clean power.
On 1/2/2022 at 8:06 PM, Mike and Carol said:
Even when we had an electrical hookup I rarely turned our charger on, just relied on the sun.
Now that more campgrounds are charging for electrical use by the amp/hour on top the the regular site fee, this is interesting, You can turn the charger off while connected to shore power? The campground would be really surprised to see no amp/hours used!
I can turn the charger on/off independently of the other electrical things.  I just flip the breaker for the charger in the fuse panel under the dinette.  All the other 110 stuff stays on.  Mike
Do the newer Ollie’s equipped with the Xantrex Freedom XC inverter/chargers have a separate breaker for the battery charging circuit like the Ollie’s equipped with the Xantrex PROWatt inverters and the Progressive Dynamic's converter/charger?  Or is the charging circuit controlled by software?
  • 3 weeks later...
On 11/25/2021 at 1:12 PM, CnC said:
We can't imagine AGM batteries after having lithium.  There are so many advantages to lithium batteries.  While everyone knows they last longer, few think about the advantages of the built-in battery monitoring systems.  No longer do you worry about over-charging, having to have a trickle charger, depleting them to zero, etc., etc.
I guess it depends on what you expect and actually do when camping. We have the 4 6v AGMs and over 3 years they have served us well. We can dry camp for 3 nights (we have no solar) and just plug the trailer in when storing. Camping on the East - and mostly mid south to southeast  means a lot of trees for us and so the advantages of solar would be minimal. When the AGMs bite the dust I would considers lithium, but honestly I’d rather spend the extra money on a quieter air conditioner.
Garry and Kristi
Apex, NC
2018 Oliver Elite II Hull 372
I absolutely agree with "I guess it depends on what you expect and actually do when camping"
Charlie.
  • 11 months later...
We had originally ordered the smaller Lithium package.
They called us during construction and told us that package was unavailable then.
Would we mind if they "bumped us up" to the larger package for an extra 1,000.00 ?
Duh...no brainer !
It's a lot of power, but you can never have too much !
We feel more confident the farther we get from the "insanity"...
Duh...no brainer !
Wow!  I would have jumped on that deal too!
Congratulations!
Same thing happened to us. I'll bet our trailers are littermates. What's your hull number?
Why would you get anything less than the maximum available battery power...?
You can never have too much power but you can definitely have too little...?
In the scope of the whole project...get the best!
22 minutes ago, Lee Cappelletti said:
...get the best!
I agree, I'm too poor to buy anything else.
Charlie.
  • 2 years later...
On 11/25/2021 at 4:54 PM, Geronimo John said:
For those of us that cover a lot of miles and worry about running the 3-Way on 12V there is another solution:  Per John D's info, the 3-Way needs 15 amps.  A Victron Orion 12 |12 -30 DC to DC charger (for example) run with 4 AWG cables from the TV to Ollie's Lithiums will provide just short of 30 amps.  So all of folks with solar suit cases don't need to duct tape them to the truck any more.   🙂
And we have about 50% of the Orion still available to charge our Lithium's too.
The next logical question is what does it cost to power up the 3-Way by the TV or by propane?
Oh, any ideas on how to remove the duct tape residue from taping the solar panels to the roof?    %^)
Gary and Anita Teaney and Ranger
2017 Oliver Elite II Hull 292
2018 Nissan Armada
Tampa, FL
Goo Gone or Goof Off. Then make sure you use soap and water to thoroughly clean the area.
Edited by John Dorrer
Updated Comment
Crazy Horse said use gasoline.  But I think rocket fuel would be more effective.
You should have no issues. You will want the soft start on the AC. I have used our Honda 2200i to charge our Lithonics batteries with no issues. We have a 2022 LE2.
