  • 2 months later...
New bathroom door confirmed with Josh White.
Mark & Claudia
“Mr. Douglas” 2024 LE ll twin, hull # 1457, Truma AC & WH, Platinum solar, Natures Head
2024 Ford f250 Lariat Ultimate 7.3L gasser / 3.75, FX4
Thank you.
Are they far enough along to announce prices?
I don't see the 2-5/16” Bulldog Coupler or Andersen No-Sway Hitch System as an option on the 2024 build sheet!
**Sold😞**
The extra items like bulldog coupler upgrade are considered a service dept upgrade and on a separate price list.
Ah gotcha, was just curious because those options were on my 2023 build sheet. Thanks!
**Sold😞**
Any idea what this change will be?  If there is one thing I find mildly annoying in VellOllie it’s the bathroom door.  It makes way too much noise when you fully open and close it.
MaryBeth
Boulder, CO
2022 Elite II #953
What kind of noise?  Hinges?  Ours is very quiet.
As is the bathroom door in our 2022 Elite II.
So they haven't gotten rid of the touch lights that have been problems. Two of ours have failed in the first 2 years.
As I currently understand it -
the "new" bathroom door will be similar to the closet door in both look and in the hardware that is used for the latch etc..  Also, as with the current door, the large mirror will still be used on the "outside" of the door - the side facing the interior of the cabin.
p.s.  I think that the "noise" being referred to is caused when opening the door and the magnets don't all release the door at the same time.  This causes to door to "vibrate" which, in turn, causes the noise.  It is either that or the door hits against the frame when opened or closed causing the noise.
Edited by topgun2
spelling
That’s what mine does (2022 Elite 2).
my Oliver has camped here
Our Head Door seems like an afterthought.  It would be a nicer fit/finish with a similar styled door as the closet door, IMO.
  • (SOLD) 2022 TUNDRA
So the new doors are held closed by magnets?  The little latch is gone?  I put in a magnet to hold the door open.  Mike
As described by TopGun — it’s difficult to release the door, which causes the whole thing to shake and make a racket. We had them adjust it once on pick-up, and that lasted about two days, so I’m not really sure their adjustment did much.  It seems to be highly dependent on just how perfectly level we manage to get.
mb
MaryBeth
Boulder, CO
2022 Elite II #953
Yep.  Our Hull #1291 has a full-strip magnet which holds the door closed.  We like it a lot.
I don't know if there is any magnet(s) on the new doors or not.  But, I'm assuming that the other hardware - the latch - will be similar to the latch that is on the closet door.
Yes - mine operates as it should.  However, particularly if the camper is a fair degree out of level, the strip of magnet at one corner or the other may not "release" at the same rate as the rest of the door.  This can cause the door to vibrate as apparently VBistro is mentioning.  The solution(s) to this problem is to either correct the alignment of the door or open the door more slowly or reduce the amount of magnetic attraction that is occurring.  Of course, if you reduce the amount of magnetic attraction then you might be in trouble going down the road if you forget to use the latch or some other means to secure the door.
p.s.  Mike - this only has to do with the bath door being opened and nothing to do with it being held open.
Same here, zero issues. 👍🏻
I wasn’t clear… I was asking if doors on newer Olivers were held shut by magnets.  I think @Rivernerd answered that.  My old door has a latch to keep it closed.  I added a magnet inside the dinette seat to keep it open.  Mike
Same here - works great...
I had previously heard (and it was discussed here on the Forum) that the touch lights were not going to be present on the 2024 models.
However, I've not heard anything additional on this subject.
p.s.  It has also been confirmed that the upper fridge vent on the exterior of the Ollie will not be there anymore - i.e. the outside shell will be smooth.  However, the bottom fridge vent that turned into a collapsible table will continue to be the table.
My original bathroom door (Hull #050) was the same door that was on our previous Hull #026. They were hand crafted at the factory and had a full length magnetic strip along the leading edge to hold it shut. There was also the twist latch.
At some time, they decided to have the doors made outside rather than in house. I would have suspected they were made the same way, with the magnetic strip.
The main reasons for the manual latch were to keep the door from opening when you bump it with your butt while taking a shower and, of course, to keep the bears out.
  • Haha 4
I learned the 2024’s will not have touch lights they will have lights that use an on off switch to operate the light per OTT service.
Patriot🇺🇸
