A couple snuck in
12 hours ago, Mike and Carol said:
I’ve had 4 tow vehicles.  Below is the latest.
If you’re doing model too, my 2500 is a Laramie.
...getting in late on this:  Here you go - thanks!
             TOYOTA    Tundra  SR5    2022   2WD   GAS   3.4L twin-turbo V6   3.31  AirLift Suspension     LEII         226
        Crew MAX/5.5' bed
        10-Speed
        1,400# payload
        8,300# Tow Cap.
  • (SOLD) 2022 TUNDRA
No worries.   I will keep adding folks all along.
I will slice and dice once most folks verify what I have.
So Far...
14 Fords
 4 GMs
3 Rams
2 Toyotas
I will do more slicing later
2021 Toyota Land Cruiser HE,  5.7L Gas, 8-speed, 3.3:1 rear, full-time 4WD, 8100 pound towing weight, 1460 cargo capacity, 750 tongue weight. Added airbags
I know of at least seven other LC owners on here, four of us with the 8-speed, and four with the 6-speed and different rear gearing. All have 100ish# less cargo capacity, as mine came from the factory without the third row jump seats. five have air bags, and all but one of us use the Andersen hitch
Steve - Northern Ohio, USA
Facebook - Instagram
Just got the tundra in december.  Have not pulled the elite yet..  I had a 2020 Ridgeline before..
spacer.png2022 Elite I  # 1179  |  2024 Tundra SR5 4x4 Crewmax. 5.5 ft. Bed. 3.31gears 10 spd.trans
Elite I, Gas engine
Thanks for the TV summary!
Tom & Holly
HDRider, thanks for putting this together!
Towing #75 LE2 2022 Toyota Tundra SR5 2WD Gas 3.5L twin-turbo V6 1400 pound load capacity Tow Capacity 11,400 pounds
Elite 1, 2008 Ram 1500 4x 4, hemi, 5.7.
I sorted by hull to make verification easier.  Let me know
Sorted by make, series & fuel type - Let me know if you want another view of the data - I will keep adding to the data as long as people want to share their info.
HDRider,
The rear differential ratio is 3.31 on on our model SR5 2022 CrewMax Cab 2WD Tundra towing #75 LE2.
When I first purchased the 2022 Tundra most were calling the engine an i-Force 3.5L including my original Toyota window sticker 🙂, but on the 2024 Toyota website today it's called an "i-Force" 3.4L engine.The twin turbo 3.4 V-6 engine replaced the 5.7L V-8 starting in 2022. For those that have a 2022 or later Tundra, some come with a hybrid system (more power/torque) called "i-Force MAX" power train.
Thanks for your work on this project.
Pickup truck sales in the U.S. in the 1st quarter of 2022 and 2023, by model(in units)
image.png.f012ea40a990fea8c1ffbc29743b3628.pngimage.thumb.png.e50f2e28e36630e75f81d07a29037ed2.png
2021 Ford Expedition, 3.5 Ecoboost, gas, 3:73 rear end, Heavy tow package/9200 towing weight, FX4 package.
2022 LE II, Hull 1271.
2022 Elite II, Hull #1271
Picked up 10/12/22
2024 F250 King Ranch FX4, 7.3 gas, 3:73.
2021 FX4 Expedition, Heavy tow package, 3:73, Anderson Hitch.
HD -
I don't really think that there is that much difference but -
there is a 3.5 Ecoboost Ford engine and also a 2.7 Ecoboost Ford engine.
I have the 3.5 job.
21 minutes ago, topgun2 said:
HD -
I have the 3.5 job.
So noted
Hi,
We have hull 1305, E2
Overland truck conversion of 2018 Ram 3500, 8 foot bed with full bed slide out, lockers, and raised air intake, on board air, and AEV bumper with 16.5 warn winch.
hanks,
Kirk
Hay Kirk:
A couple pictures of your 2018 RAM 3500 conversion would be appreciated.
Maine
